New Linux user, 15 days, coming from Windows 7 and after some distribution tasting, I felt at home with Manjaro (KDE version).
My problem is with KDE ‘disks and devices’ applet. When I insert a usb disk in a new session, it is detected by ‘Device Notifier’ which offers the option to mount it. So far so good! However, after I have unmounted the usb disk, ‘Device Notifier’ will not detect any usb disks that I connect to pc. I would then have to log-out and back in for it to see the drive.
My current workaround is to Mount/Unmount usb disks from ‘Dolphin’ file manager but I am worried that this may not be recommended practice since there is a specific app for this task.
Any help towards resolving this issue will be appreciated!
ps: Since this my first post here, I would like to say a big THANK YOU to the developers of Manjaro!
Well, I am aware of that option in ‘System Settings’, however it seems like another workaround in my case, since I don’t really want ‘automatic mounting’. Thank you for your help.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
