[KDE] - Desktop - Long Time To Reboot Or Shutdown? Everything Else 100%
Hi,
Running “Manjaro KDE 64Bit” fully updated.
The desktop runs 100% perfectly.
When I reboot or shutdown the desktop it takes over a minute?
Not sure how to fix this issue?
Perhaps is issue with SSD - how would I run a disk check on an SSD where the OS is?
NOTE #1: System SSD is encrypted
Let me know, thanks!
Jesse
[jlp@SortaFastDesktop ~]$ inxi -F
  Host: SortaFastDesktop Kernel: 5.11.14-1-MANJARO x86_64 bits: 64
  Desktop: KDE Plasma 5.21.4 Distro: Manjaro Linux
  Type: Desktop Mobo: Gigabyte model: B85M-HD3 v: x.x serial: <superuser required>
  BIOS: American Megatrends v: F12 date: 08/13/2015
  Info: Quad Core model: Intel Core i5-4430 bits: 64 type: MCP cache: L2: 6 MiB
  Speed: 2098 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 2098 2: 1588 3: 2566
  4: 2081
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 460.67
  Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
  Device-1: Intel 8 Series/C220 Series High Definition Audio driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 14.2 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
  IF: enp3s0 state: down mac: 74:d4:35:9b:58:fd
  Device-2: Intel 82541PI Gigabit Ethernet driver: e1000
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 90:e2:ba:68:f9:0e
  Device-3: Intel Centrino Ultimate-N 6300 driver: iwlwifi
  IF: wlp6s0 state: down mac: 7e:4a:a1:dd:e6:c2
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb
  Local Storage: total: 1.84 TiB used: 174.79 GiB (9.3%)
  ID-1: /dev/sda vendor: A-Data model: SU800 size: 953.87 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD10EARX-32N0YB0 size: 931.51 GiB
  ID-1: / size: 937.89 GiB used: 174.79 GiB (18.6%) fs: ext4 dev: /dev/dm-0
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
  Processes: 248 Uptime: 1h 33m Memory: 15.59 GiB used: 5.02 GiB (32.2%) Shell: Bash
  inxi: 3.3.04
Did you create a mirror on the SSD and HDD?
If not, post the output of:
parted --list
:thinking:
Hi,
Thanks for the response!
No, I did not create a mirror on the SSD and HDD.
(SSD is OS and apps / HDD is personal data)
Requested info is below:
Thanks!
Jesse
[jlp@SortaFastDesktop ~]$ inxi --admin --verbosity=7 --filter --no-host --width
parted --list
  Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=f360282e-91b5-4661-b13f-681fdd0767cc ro quiet
  cryptdevice=UUID=075cfc6a-42b7-4126-aa11-30473e9f5346:luks-075cfc6a-42b7-4126-aa11-30473e9f5346
  root=/dev/mapper/luks-075cfc6a-42b7-4126-aa11-30473e9f5346 apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: B85M-HD3 v: x.x serial: <filter>
  RAM: total: 15.59 GiB used: 5.59 GiB (35.9%)
  Info: Quad Core model: Intel Core i5-4430 bits: 64 type: MCP arch: Haswell
  family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
  bogomips: 23952
  Speed: 3093 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3093 2: 3062
  3: 3088 4: 3092
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
  ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
  xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com.
  driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
  s-diag: 610mm (24")
  Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 93
  size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
  direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
  class-ID: 0403
  Sound Server-4: PipeWire v: 0.3.25 running: yes
  vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  Device-2: Intel 82541PI Gigabit Ethernet driver: e1000 v: kernel port: c000
  bus-ID: 05:00.0 chip-ID: 8086:107c class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-3: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel
  port: c000 bus-ID: 06:00.0 chip-ID: 8086:422b class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  IP v4: <filter> type: noprefixroute scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
  bus-ID: 3-5:2 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Device-1: luks-075cfc6a-42b7-4126-aa11-30473e9f5346 maj-min: 254:0
  type: LUKS dm: dm-0 size: 953.86 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 953.86 GiB
  Local Storage: total: 1.84 TiB used: 177.67 GiB (9.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 953.87 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
  serial: <filter> rev: 2FS scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EARX-32N0YB0
  serial: <filter> rev: AB51 scheme: MBR
  Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 D rev: 8L07
  dev-links: cdrom
  ID-1: / raw-size: 953.86 GiB size: 937.89 GiB (98.33%)
  used: 177.67 GiB (18.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-075cfc6a-42b7-4126-aa11-30473e9f5346 label: N/A
  uuid: f360282e-91b5-4661-b13f-681fdd0767cc
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
  Hub-6: 3-8:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-8.4:5 info: Realtek Mass Storage Device (Multicard Reader)
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 0bda:0151 class-ID: 0806
  serial: <filter>
  Hub-7: 3-9:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 12 Mb/s
  Device-1: 3-9.1:7 info: HP OfficeJet 3830 series type: Printer driver: usblp
  interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 2mA chip-ID: 03f0:e511
  class-ID: 0701 serial: <filter>
  Hub-8: 3-9.3:9 info: Terminus Hub ports: 4 rev: 2.0 speed: 12 Mb/s
  Device-1: 3-9.3.3:11
  info: Prototype product Vendor ID SmartJoy Dual Plus PS2 converter type: HID
  driver: smartjoyplus,usbhid interfaces: 1 rev: 1.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 6666:8802 class-ID: 0300
  Device-2: 3-11:6 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
  type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
  speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
  Hub-9: 3-12:8 info: Dell Keyboard Hub ports: 3 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 413c:1003 class-ID: 0900
  Device-1: 3-12.1:10 info: Dell Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
  chip-ID: 413c:2010 class-ID: 0300
  Hub-10: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 34 C
  Processes: 269 Uptime: 6h 47m wakeups: 0 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1442 lib: 430
  flatpak: 0 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
/dev/mapper/control: open failed: Permission denied
Failure to communicate with kernel device-mapper driver.
Incompatible libdevmapper 1.02.175 (2021-01-08) and kernel driver (unknown version).
Please:
  • Reboot your machine
  • Don’t log in
  • reboot again
  • Provide the output of:
    sudo parted --list
    last -Fx shutdown reboot | head
So far:
  • Your processor supports AES so that’s not it
:thinking:
[jlp@SortaFastDesktop ~]$ sudo parted --list
Model: ATA ADATA SU800 (scsi)
Disk /dev/sda: 1024GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
1      1049kB  1024GB  1024GB  primary               boot
Model: ATA WDC WD10EARX-32N (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
1      1049kB  1000GB  1000GB  primary
[jlp@SortaFastDesktop ~]$ last -Fx shutdown reboot | head
reboot   system boot  5.11.14-1-MANJAR Tue Apr 20 18:13:22 2021   still running
shutdown system down  5.11.14-1-MANJAR Tue Apr 20 18:12:32 2021 - Tue Apr 20 18:13:22 20
21  (00:00)
reboot   system boot  5.11.14-1-MANJAR Tue Apr 20 18:12:21 2021 - Tue Apr 20 18:12:32 20
21  (00:00)
shutdown system down  5.11.14-1-MANJAR Tue Apr 20 18:11:31 2021 - Tue Apr 20 18:12:21 20
21  (00:00)
reboot   system boot  5.11.14-1-MANJAR Tue Apr 20 09:51:21 2021 - Tue Apr 20 18:11:31 20
21  (08:20)
shutdown system down  5.11.14-1-MANJAR Tue Apr 20 09:50:29 2021 - Tue Apr 20 09:51:21 20
21  (00:00)
reboot   system boot  5.11.14-1-MANJAR Mon Apr 19 10:08:11 2021 - Tue Apr 20 09:50:29 20
21  (23:42)
shutdown system down  5.11.14-1-MANJAR Mon Apr 19 10:07:22 2021 - Mon Apr 19 10:08:11 20
21  (00:00)
reboot   system boot  5.11.14-1-MANJAR Mon Apr 19 10:05:13 2021 - Mon Apr 19 10:07:22 20
21  (00:02)
shutdown system down  5.11.14-1-MANJAR Mon Apr 19 10:03:45 2021 - Mon Apr 19 10:05:13 20
21  (00:01)
The last -Fx shutdown reboot | head shows:
And that’s just 11 seconds for a full system reboot? That’s not bad…
Where is the problem?
:open_mouth:
Hmmm…Odd…
Was taking over 45 seconds to fully reboot or shutdown.
Guess it is ok now
Jesse
To see if this is related to another KDE bug (which has been fixed upstream!), when you get the chance, try this:
  1. Log into Plasma
  2. Log out soon after
  3. Log back in
Repeat steps 2 and 3 several times. Does it at any point “stall” or seem to “hang”, and maybe take around 3 minutes to finally log back in?
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
