After the recent upgrade I got a lot of visual problems in KDE
Many of them are random and hard to catch a print such as:
- Blur turning on and off randomly
- Elements, icons and LatteDock bugging (print here)
- Panels flashing the shadow randomly
- Several “holes” in the windows appearing very quickly, but they are not black and correspond to the background
As I said, it is very random, they can go for hours without appearing, but when they do, they are very annoying and persist on the screen.
Something similar here but I have no idea if it’s mesa and if I downgrade will solve this
Details of my system
System: Kernel: 5.10.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2
info: latte-dock, docker wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: S400CA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: S400CA v: 1.0 serial: <filter> UEFI: American Megatrends v: S400CA.210 date: 01/27/2014
Battery: ID-1: BAT0 charge: 34.4 Wh condition: 35.2/45.3 Wh (78%) volts: 11.2/11.2 model: ASUSTek X402--40 type: Li-ion
serial: N/A status: Unknown cycles: 450
CPU: Info: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge rev: 9 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13573
Speed: 2295 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 2295 2: 2297 3: 2295 4: 2307
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166 class ID: 0300
Device-2: Chicony UVC 1.00 device HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-1.2:3 chip ID: 04f2:b354
class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel resolution: 1: 1366x768~60Hz
2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Sound Server: ALSA v: k5.10.18-1-MANJARO
Network: Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave driver: ath9k v: kernel port: f040
bus ID: 02:00.0 chip ID: 168c:0032 class ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK driver: alx v: kernel port: e000 bus ID: 03:00.0
chip ID: 1969:1091 class ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth68c590c state: up speed: 10000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus ID: 3-3:4
chip ID: 0a12:0001 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 223.57 GiB used: 135.89 GiB (60.8%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: B1D2 scheme: GPT
Partition: ID-1: / size: 42.71 GiB used: 38.75 GiB (90.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 98.4 MiB used: 255 KiB (0.3%) fs: vfat dev: /dev/sda4
ID-3: /home size: 174.21 GiB used: 97.14 GiB (55.8%) fs: ext4 dev: /dev/sda3
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 73.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4000
Info: Processes: 258 Uptime: 2h 28m wakeups: 1 Memory: 7.66 GiB used: 4.87 GiB (63.5%) Init: systemd v: 247
target: graphical.target Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1774 pacman: 1752 flatpak: 14 snap: 8
Shell: fish v: 3.1.2 default: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
