So i boot into a blank screen as of today? Please help.
I tried switching to tty2 and running startx. I could only take a photo of the results as i cant copy anything.
Just to get your startx
working:
startkde
has long been replaced by startplasma-x11
As to the original problem: check journal for errors and check sddm.service
(display manager) which is responsible for starting up x11.
well iv tried executing startplasma-x11 in my console and tty2
i get this in my normal console (tty1)
â°gregâ~â±ââ» startplasma-x11
Warning: Unable to load any usable ISO8859 font
âxmessageâ ("-geometry", â500x100â, âPlasma seems to be already running on this display.\nâ) exited with code 11
and on tty2
$DISPLAY is not set or cannont connect to Xserver
I have run cp /etc/skel/.xinitrc ~/.xinitrc , it did change my startkde to startplasma-x11. I have rebooted but it still fails.
Not sure how to reset my sddm back to default without a GUI?
i checked journalctl -b | grep -i âsddm.serviceâ but there is nothing there.
tried âstartxâ in my console
â°gregâ~â±â» journalctl -b | grep -i âsddm.serviceâ
â°gregâ~â±ââ» startx/usr/lib/Xorg.wrap: Only console users are allowed to run the X server
^Cxinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
Couldnât get a file descriptor referring to the console.
â°gregâ~â±ââ»
in tty2
It kinda loaded something but just a blank/black screen with a mouse cursor
I have managed to change my sddm back to âbreathâ but it still fails to show plasma when rebooted.
@freggel.doe
ah thank you for the link, as described on that link the problem is event calendar. I have removed it and we are back up and running but i use event calendar a whole load, so what do i use now?
In such cases itâs better to check for all errors since booting up:
$ journalctl -b -p err
and if looking at a special service:
$ systemctl status sddm.service
Ah, nice. Glad you solved it.
Probably waiting for a fix/workaround is enough as the problem seems to be âuniversalâ (as in: hitting all installations atm). One never knows how long that might take though
So it seems the dev of event calendar has already fixed the problem. Black Screen on Login / Crash on Arch/Manjaro (Qt 5.15.1) (EventCalendar v68 and below) · Issue #154 · Zren/plasma-applet-eventcalendar · GitHub
So the problem was that there was a conflict between a widget installed by the ânormalâ widget install method (panel context, add widget, etc) and/or the main package manager method (yay -S plasma5-applets-eventcalendar). It seems that if you installed it via the âpanel add widgetâ then it was never updated, which leaves me wondering, do widgets / sddmâs / icon packs etc, those kinda of installers get updated at all?
