Trying to use jupyter-console
I get the following output and exit
0.00s - Debugger warning: It seems that frozen modules are being used, which may
0.00s - make the debugger miss breakpoints. Please pass -Xfrozen_modules=off
0.00s - to python to disable frozen modules.
0.00s - Note: Debugging will proceed. Set PYDEVD_DISABLE_FILE_VALIDATION=1 to disable this validation.
Jupyter console 6.6.3
Python 3.11.6 (main, Nov 14 2023, 09:36:21) [GCC 13.2.1 20230801]
Type 'copyright', 'credits' or 'license' for more information
IPython 8.19.0 -- An enhanced Interactive Python. Type '?' for help.
File "/usr/bin/jupyter-console", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.11/site-packages/jupyter_core/application.py", line 307, in launch_instance
loop.run_until_complete(coro)
File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/lib/python3.11/site-packages/jupyter_core/application.py", line 294, in _async_launch_instance
app.start()
File "/usr/lib/python3.11/site-packages/jupyter_console/app.py", line 148, in start
self.shell.mainloop()
File "/usr/lib/python3.11/site-packages/jupyter_console/ptshell.py", line 676, in mainloop
asyncio.run(self._main_task())
File "/usr/lib/python3.11/asyncio/runners.py", line 186, in run
raise RuntimeError(
RuntimeError: asyncio.run() cannot be called from a running event loop
sys:1: RuntimeWarning: coroutine 'ZMQTerminalInteractiveShell._main_task' was never awaited
Here is the output of the inxi
command
system:
Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2067097a-1b2e-4759-8bf3-1b5398b38c34 rw quiet
resume=UUID=9ed2f32f-2361-4e95-8608-3b42c3ba2478
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP ProBook 450 G3 v: N/A
Mobo: HP model: 8101 v: KBC Version 40.73 serial: <superuser required>
UEFI: HP v: N78 Ver. 01.61 date: 10/03/2023
ID-1: BAT0 charge: 26.7 Wh (79.7%) condition: 33.5/44.4 Wh (75.5%)
volts: 16.4 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 51
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1154 high: 1184 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1121 2: 1184 3: 1132
4: 1180 bogomips: 19204
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-3 code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie:
gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380 temp: 50.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-6:3 chip-ID: 05c8:0383 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: intel dri: i965 gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x36ed built: 2014
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: radeonsi x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.48 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon R7 M340 (RADV ICELAND) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:6900 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel
v: 23.1.9-manjaro1.1 device-ID: 8086:1916 surfaces: xcb,xlib
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: Hewlett-Packard driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 288.8 GiB (31.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 49.4 GiB size: 48.32 GiB (97.82%) used: 38.02 GiB (78.7%)
fs: ext4 dev: /dev/sda10 maj-min: 8:10
ID-2: /boot/efi raw-size: 360 MiB size: 356 MiB (98.89%)
used: 90.1 MiB (25.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 281.86 GiB size: 277.25 GiB (98.36%)
used: 249.44 GiB (90.0%) fs: ext4 dev: /dev/sda11 maj-min: 8:11
ID-1: swap-1 type: partition size: 16.62 GiB used: 1.34 GiB (8.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 49.0 C pch: 49.0 C mobo: N/A gpu: amdgpu
temp: 50.0 C
Fan Speeds (rpm): N/A
Processes: 255 Uptime: 2d 4h 20m wakeups: 3 Memory: total: 8 GiB note: est.
available: 7.66 GiB used: 4.93 GiB (64.4%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1871 libs: 367 tools: octopi,pacaur Shell: Bash
v: 5.2.21 running-in: konsole inxi: 3.3.31
How to fix this ?
