Hy,
Tried to install sass but i stumped dependencies problem. So i followed some guides and posts and removed jdk-openjdk and after that another dependencies problem jre-openjdk and jre-openjdk-headless are in conflict so tried to reinstall that but same error again and again
outputs:
~ pamac install dart-sass ✔
Preparing...
Authenticating as: David (futui)
Password:
Resolving dependencies...
Checking inter-conflicts...
Error: unresolvable package conflicts detected
Error: Failed to prepare transaction:
conflicting dependencies:
- jdk-openjdk and jre-openjdk are in conflict
~ 1 ✘ 8s
~ sudo pacman -R jre-openjdk jdk-openjdk INT ✘
[sudo] password for futui:
checking dependencies...
:: libbluray optionally requires java-runtime: BD-J library
:: libjpeg-turbo optionally requires java-runtime>11: for TurboJPEG Java wrapper
:: libjxl optionally requires java-runtime: for JNI bindings
:: opencv optionally requires java-runtime: Java interface
Packages (2) jdk-openjdk-21.u35-3 jre-openjdk-21.u35-3
Total Removed Size: 309,56 MiB
:: Do you want to remove these packages? [Y/n] n
~ sudo pacman -R jdk-openjdk 1 ✘ 2m 25s
Packages (1) jdk-openjdk-21.u35-3
Total Removed Size: 308,99 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing jdk-openjdk [######################################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Refreshing PackageKit...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
~ pamac install dart-sass ✔ 4s
Preparing...
Password:
- jre-openjdk and jre-openjdk-headless are in conflict
~ paru -R jre-openjdk-headless 1 ✘ 7s
zsh: correct 'paru' to 'ptar' [nyae]? n
zsh: command not found: paru
~ sudo pacman -R jdk-openjdk-headless 127 ✘
error: target not found: jdk-openjdk-headless
~ sudo pacman -R jre-openjdk-headless 1 ✘
:: removing jre-openjdk-headless breaks dependency 'jre21-openjdk-headless=21.u35-3' required by jre-openjdk
~ sudo pacman -R jre-openjdk-headless jre21-openjdk-headless=21.u35-3 1 ✘
error: target not found: jre21-openjdk-headless=21.u35-3
~ pamac install dart-sass 1 ✘
Preparing...
Password:
~ sudo pacman -Syu kpeoplevcard 1 ✘ 8s
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: kpeoplevcard-0.1-2 is up to date -- reinstalling
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] y
:: Replace grub-update with core/update-grub? [Y/n] y
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] y
:: Replace kgamma5 with extra/kgamma? [Y/n] y
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] y
:: Replace libkcddb with extra/libkcddb5? [Y/n] y
:: Replace libkdcraw with extra/libkdcraw5? [Y/n] y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jre-openjdk and jre-openjdk-headless are in conflict
~ sudo pacman syuu 1 ✘ 10s
error: no operation specified (use -h for help)
~ sudo pacman -Syuu 1 ✘
core is up to date
extra is up to date
y
so i tried updating the system and the same conflicts…i understand nothing now, help please?
This is what i have
Generated on 2024-01-05 22:07:1704485259
#################### inxi -Fxzc0 ########################
Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 Desktop: KDE Plasma
v: 5.27.9 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required> UEFI: LENOVO v: FCCN13WW
date: 06/29/2020
ID-1: BAT0 charge: 24.0 Wh (59.1%) condition: 40.6/45.5 Wh (89.2%) volts: 11.7 min: 11.4
model: Sunwoda L19D3PF4 status: not charging
Info: 6-core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
Speed (MHz): avg: 2078 high: 3371 min/max: 1400/3000 boost: enabled cores: 1: 3326 2: 3371
3: 3323 4: 3232 5: 1658 6: 1647 7: 1400 8: 1397 9: 1397 10: 1396 11: 1397 12: 1396
bogomips: 71900
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia
v: 535.129.03 arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 bus-ID: 05:00.0
temp: 47.0 C
Device-3: IMC Networks [] driver: uvcvideo type: USB bus-ID: 1-3:3
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: modesetting,nvidia dri: radeonsi gpu: amdgpu resolution: 1920x1080~60Hz
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4 direct-render: yes renderer: NVIDIA
GeForce GTX 1650/PCIe/SSE2
API: Vulkan v: 1.3.269 drivers: nvidia,radv surfaces: xcb,xlib devices: 2
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
API: ALSA v: k6.1.60-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.83 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8822ce v: N/A port: 2000 bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Realtek [] driver: btusb v: 0.8 type: USB bus-ID: 3-3:2
Local Storage: total: 238.47 GiB used: 105.4 GiB (44.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ256HAJD-000L2 size: 238.47 GiB temp: 32.9 C
ID-1: / size: 233.38 GiB used: 105.4 GiB (45.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 56.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A
Processes: 294 Uptime: 20m Memory: total: 8 GiB note: est. available: 7.14 GiB
used: 4.98 GiB (69.7%) Init: systemd Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1676
Client: KDE Plasma v: 5.27.9 inxi: 3.3.31
And yes, i searched the forum.
Moderator edit: Removed useless screenshot
