Yesterday the updates came and I updated the system.
But after restarting my computer and trying to start PHPStorm, I realized that it won’t start. Also, I was unable to install a newer Linux kernel, as I understand, a bug in one of these packages. Since now I did not update them, but updated all the others and PHPStorm works.
I wrote about this bug in jetbrains, but have not received a response yet. Most likely, nevertheless, this error is connected precisely with a bug in the new version of Java.
https://youtrack.jetbrains.com/issue/WI-70969/PHPStorm-is-not-loading
Start in console:
phpstorm ![]()
CompileCommand: exclude com/intellij/openapi/vfs/impl/FilePartNodeRoot.trieDescend
Error occurred during initialization of VM
java.lang.UnsupportedClassVersionError: com/intellij/util/lang/PathClassLoader has been compiled by a more recent version of the Java Runtime (class file ve
rsion 61.0), this version of the Java Runtime only recognizes class file versions up to 55.0
at java.lang.ClassLoader.defineClass1(java.base@11.0.18/Native Method)
at java.lang.ClassLoader.defineClass(java.base@11.0.18/ClassLoader.java:1017)
at java.security.SecureClassLoader.defineClass(java.base@11.0.18/SecureClassLoader.java:174)
at jdk.internal.loader.BuiltinClassLoader.defineClass(java.base@11.0.18/BuiltinClassLoader.java:800)
at jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(java.base@11.0.18/BuiltinClassLoader.java:698)
at jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(java.base@11.0.18/BuiltinClassLoader.java:621)
at jdk.internal.loader.BuiltinClassLoader.loadClass(java.base@11.0.18/BuiltinClassLoader.java:579)
at jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(java.base@11.0.18/ClassLoaders.java:178)
at java.lang.ClassLoader.loadClass(java.base@11.0.18/ClassLoader.java:522)
at java.lang.Class.forName0(java.base@11.0.18/Native Method)
at java.lang.Class.forName(java.base@11.0.18/Class.java:398)
at java.lang.ClassLoader.initSystemClassLoader(java.base@11.0.18/ClassLoader.java:1976)
at java.lang.System.initPhase3(java.base@11.0.18/System.java:2074)
This happened after the last system update of packages on Manjaro Linux (v22.0.0)
I had to roll back using TimeShift. God thank you for making it, Manjaro Linux, BTRFS and SSD.
