Hi guys, I’m new to Linux.
I’m really enjoying Manjaro XFCE, life has changed completely.
Question
What should I do to make the 2560x1080 resolution option appear on display settings in Manjaro XFCE Minimal?
In addition to the updates on Pamac after installing Manjaro do I need to do anything else? Do I need to install anything that doesn’t come with Manjaro? If so, how do I do this?
Setup
- LG Ultrawide 25 monitor (I use only the monitor screen)
- ASUS N53ta Laptop - ATI Radeon® HD 6720G2 Graphics with 2GB DDR3 VRAM
Approaches I’ve tried and failed
- Setting a new mode via xrandr
- I tried to look for a driver on the AMD website but found nothing that appears to be compatible.
- I tried to change the Kernel version to 4.19 and boot but it didn’t change anything.
Context
I used to plug the monitor into the laptop (hdmi) and in Windows 10 it automatically displayed the desired resolution 2560x1080 (21: 9)
After installing the Manjaro XFCE Minimal when I plug in the monitor, the highest resolution that appears to me is 1920x1080
System information
Kernel: 4.19.141-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=0656753a-2c28-42e2-bcd0-0353336aa290 rw quiet udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N53Ta v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N53Ta v: 1.0 serial: <filter> UEFI: American Megatrends
v: N53Ta.209 date: 12/10/2011
ID-1: BAT0 charge: 26.8 Wh condition: 40.8/48.4 Wh (84%) volts: 11.0/11.1
model: ASUSTek M50--24 type: Li-ion serial: N/A status: Discharging
Topology: Quad Core model: AMD A6-3420M APU with Radeon HD Graphics bits: 64
type: MCP arch: Fusion family: 12 (18) model-id: 1 stepping: N/A
microcode: 3000027 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 11979
Speed: 799 MHz min/max: 800/1500 MHz boost: enabled Core speeds (MHz):
1: 802 2: 803 3: 804 4: 804
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Sumo [Radeon HD 6520G] vendor: ASUSTeK driver: radeon
v: kernel bus ID: 00:01.0 chip ID: 1002:9647
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: ASUSTeK driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6741
Device-3: Alcor Micro ASUS USB2.0 WebCam type: USB driver: uvcvideo
bus ID: 4-2:2 chip ID: 058f:a004
Display: x11 server: X.Org 1.20.8 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 72 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 4.19.141-2-MANJARO LLVM 10.0.1)
v: 3.3 Mesa 20.1.6 compat-v: 3.1 direct render: Yes
Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series] driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:1714
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k4.19.141-2-MANJARO
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel port: e000 bus ID: 02:00.0 chip ID: 168c:0032
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: 1.0.1.1-NAPI port: d000 bus ID: 03:00.0 chip ID: 1969:1083
Local Storage: total: 465.76 GiB used: 6.38 GiB (1.4%)
ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%) used: 6.38 GiB (1.4%)
fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 41.6 C mobo: N/A
GPU: device: radeon temp: 36 C device: radeon temp: 41 C
Processes: 163 Uptime: 2h 07m Memory: 3.34 GiB used: 888.9 MiB (26.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 905 lib: 274
Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
