post output from:
pacman -Qs 'pulse|pipewire'
pacman -Qs 'pulse|pipewire' ✔
local/gst-plugin-pipewire 1:0.3.56-1
Multimedia graph framework - pipewire plugin
local/lib32-libcanberra 1:0.30+r2+gc0620e4-1
A small and lightweight implementation of the XDG Sound Theme Specification (32-bit)
local/lib32-libpulse 16.1-1
A featureful, general-purpose sound server (32-bit client libraries)
local/libcanberra 1:0.30+r2+gc0620e4-1
local/libpulse 16.1-1
A featureful, general-purpose sound server (client library)
local/manjaro-pipewire 20220217-2
Manjaro meta package for complete PipeWire support.
local/paprefs 1.2-1
Configuration dialog for PulseAudio
local/pasystray 0.8.0-2
PulseAudio system tray (a replacement for padevchooser)
local/pavucontrol 1:5.0+r35+g964f298-1
PulseAudio Volume Control
local/pipewire 1:0.3.56-1
Low-latency audio/video router and processor
local/pipewire-alsa 1:0.3.56-1.0
Low-latency audio/video router and processor - ALSA configuration
local/pipewire-jack 1:0.3.56-1.0
Low-latency audio/video router and processor - JACK support
local/pipewire-pulse 1:0.3.56-1.0
Low-latency audio/video router and processor - PulseAudio replacement
local/pipewire-zeroconf 1:0.3.56-1
Low-latency audio/video router and processor - Zeroconf support
local/plasma-pa 5.24.6-1 (plasma)
Plasma applet for audio volume management using PulseAudio
local/pulseaudio-alsa 1:1.2.7.1-1
ALSA Configuration for PulseAudio
local/pulseaudio-ctl 1.70-1
Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
local/pulseaudio-equalizer-ladspa 3.0.2-5
A 15-band equalizer for PulseAudio
local/pulseaudio-qt 1.3-1
Qt bindings for libpulse
local/wireplumber 0.4.11-4
Session / policy manager implementation for PipeWire
local/wireplumber-docs 0.4.11-4
Session / policy manager implementation for PipeWire - documentation
remove these:
pamac remove paprefs pasystray pavucontrol pulseaudio-alsa pulseaudio-ctl pulseaudio-equalizer-ladspa
then open this file:
kate /etc/environment
and add there this line:
QT_LOGGING_RULES='*=false'
it will disable the useless kwin/qt logs
then reboot and if the audio still doesnt work provide output from:
journalctl -b0 -p4 --no-pager
sudo dmesg -l err,warn,emerg,alert
It didn’t work. here is the output:
journalctl -b0 -p4 --no-pager ✔
ago 29 14:41:16 bellatrix kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
ago 29 14:41:16 bellatrix kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
ago 29 14:41:16 bellatrix kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_PR.CPU0._PPC], AE_NOT_FOUND (20220331/psargs-330)
ago 29 14:41:16 bellatrix kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
ago 29 14:41:16 bellatrix kernel: pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
ago 29 14:41:16 bellatrix kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
ago 29 14:41:16 bellatrix kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
ago 29 14:41:16 bellatrix kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
ago 29 14:41:16 bellatrix kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
ago 29 14:41:17 bellatrix kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
ago 29 14:41:17 bellatrix kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
ago 29 14:41:17 bellatrix kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
ago 29 14:41:17 bellatrix kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
ago 29 14:41:17 bellatrix kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
ago 29 14:41:17 bellatrix kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
ago 29 14:41:17 bellatrix kernel: at24 0-0050: supply vcc not found, using dummy regulator
ago 29 14:41:20 bellatrix kernel: kauditd_printk_skb: 23 callbacks suppressed
ago 29 14:41:29 bellatrix kernel: kauditd_printk_skb: 6 callbacks suppressed
ago 29 14:45:42 bellatrix backlighthelper[717]: org.kde.powerdevil: no kernel backlight interface found
ago 29 14:45:44 bellatrix wireplumber[842]: Failed to set scheduler settings: Operação não permitida
ago 29 14:45:49 bellatrix kernel: kauditd_printk_skb: 10 callbacks suppressed
[sudo] senha para thrinaxodon:
[ 0.115265] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.142455] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.152638] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.CPU0._PPC], AE_NOT_FOUND (20220331/psargs-330)
[ 0.152638] ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 0.181082] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
[ 0.674980] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 0.674989] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 0.675242] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 0.675252] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 0.675376] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 0.675385] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 0.676285] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 0.676294] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 2.910343] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
[ 2.910354] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 2.910358] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 2.910361] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 2.910364] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 3.259164] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.301451] at24 0-0050: supply vcc not found, using dummy regulator
[ 6.412624] kauditd_printk_skb: 23 callbacks suppressed
[ 14.996629] kauditd_printk_skb: 6 callbacks suppressed
[ 275.212696] kauditd_printk_skb: 10 callbacks suppressed
you have this:
lets disable this, maybe it will help:
open again this file:
kate /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT
- inside the quotes add these 2 parameters:
pci=nommconf pcie_aspm=off
dont remove any parameters, just add them to the existing ones
then save the file, update grub:
sudo update-grub
reboot and see if it helped
done. The problem persists. I was searching another ideas and maybe disabling pipewire and reinstalling pulseaudio could work, idk
theres nothing in logs … so we can try installing pulse and then disabling pipewire services …
and when you were in the live usb session did you try if the headphones work there?
yeah, I tryed and the headphones still didn’t work
so switching back to pulse wont work …
plug the speakers into pc and go to system settings/ audio and are the headphones detected there ? if yes try different profiles …
the headphones aren’t detected in system settings/ audio, and i’ve tested all profiles and a different headphone, that’s why i was so desperate
thanks for your help, you were very kind to me.
wanted to suggest to try different headphones to test …
reboot and enter into bios and check if fast boot is disabled - however you may not have this option …
you can then go through bios settings and see if there are some settings/options related to audio
Fastboot is disabled(may I enable It?). The audio options are “HD Audio” (enabled), and HDMI Audio, was enabled but I disabled it.
no fast boot should be disabled …
and disabling the hdmi didnt work?
It still don’t recognize the headphones and There is no analogical profile. Maybe If we could make PipeWire create an analogical profile, or reinstall pulseaudio, maybe It should help
you can also try following things:
get yourself a usb to audio jack adapter, they are cheap and see if it works - if it does, then your jack in your pc is probably broken
check for a bios update for your motherboard
boot into a different live usb like linux mint and test if the headphones work there, to see if its a arch thing or a linux thing …
i dont know if creating a analog profile is possible … it look like the linux just doesnt detect the jack port in your pc, so try the options above, especially the one with linux mint
we can install again pulse and disable pipewire, but i dont think it will work, but we can try, but first try the live usb of linux mint for example
thank you, i’m going to try this
I tried with liveUSB of Manjaro XFCE and got the same problem, now tested with KDE Neon (It is Ubuntu based) and it worked very well, simply detectected the headphones with no problem, so I’m going to take it. Thanks for all your help. I love Manjaro, but I need sound to watch my classes.
But again, thanks for all your help and the time you dedicated to do It. Bye.
I don’t know where you were looking for this alleged lack of jack detection but it can’t have been in the ALSA data in OP
!!ALSA/HDA dmesg
[ 3.408143] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC883: line_outs=4 (0x14/0x16/0x15/0x17/0x0) type:line
[ 3.408149] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.408151] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.408153] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.408154] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 3.408155] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.408156] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 3.408158] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 3.408159] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 3.408160] snd_hda_codec_realtek hdaudioC0D0: CD=0x1c
[ 3.408161] snd_hda_codec_realtek hdaudioC0D0: dig-in=0x1f
ALSA data in post #1 shows Headphone output is muted
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xf7d00000 irq 30'
Mixer name : 'Realtek ALC883'
Simple mixer control 'Headphone',0
Front Left: Playback 0 [0%] [-46.50dB] [off]
Front Right: Playback 0 [0%] [-46.50dB] [off]
Probably muted by Auto-Mute Mode
Simple mixer control 'Auto-Mute Mode',0
Item0: 'Enabled'
Analog audio to headphones/speakers might be blocked or difficult to access due to this:
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
