It don't recognize my headphones anymore
Please, help, I’m a little bit desperate.
I’m not exactly new to Linux, or Manjaro, but I never needed solve problem with sound before and my knowledge or talent with computers are very limited, unfortunatly. I’m with a new computer, and it’s been difficult to get used to it, and since I bought it I installed my linux in it, and t is showing some problems recognizing audio, like, there is the HDMI port of the monitor and the profile was all the time changing it to the HDMI profile, but my monitor don’t have speakers or audio port, so i was using the headphone in the front of the PC with the profile “digital stereo out” (in my system it is in portuguese, I’m translating here as I can) as “headphones”, but every game that I started playing it changed automaticaly to the HDMI profile, I was getting really frustrated, and then I connected to the rear phone entrance of the pc, and connected in the profile “digital stereo out” as “line out”, and it worked for some hours, I could play two games without problems, BUT when I turned off the computer, hours later I turned on again it was not working anymore, and it doesn’t matter if I connect in front or rear, even if the profile doesn’t change, it always says “disconected” in every profile I choose, even with my headphone plugged into it. I don’t know what is happening. I was so happy when I bought the computer, now it’s been a headache.
!!ALSA Information Script v 0.5.1
!!Script ran on: Mon Aug 29 02:01:39 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      To be filled by O.E.M.
Product Name:      To be filled by O.E.M.
Product Version:   To be filled by O.E.M.
Firmware Version:  4.6.5
System SKU:        To be filled by O.E.M.
Board Vendor:
Board Name:
!!ACPI Device Status Information
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:01/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 15
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
!!Kernel Information
Kernel release:    5.15.60-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.15.60-1-MANJARO
Library version:    1.2.7.2
Utilities version:  1.2.7
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xf7d00000 irq 30
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 05)
	Subsystem: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20]
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC883
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10ec0883
Subsystem Id: 0x10ec0883
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
    rates [0x560]: 44100 48000 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3
  Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x11: Stereo
  Device: name="ALC883 Analog", type="Audio", device=0
  Converter: stream=0, channel=0
  PCM:
    formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=16, device=0
  Control: name="IEC958 Playback Pro Mask", index=16, device=0
  Control: name="IEC958 Playback Default", index=16, device=0
  Control: name="IEC958 Playback Switch", index=16, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="ALC883 Digital", type="SPDIF", device=1
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    bits [0x1e]: 16 20 24 32
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x08, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x10 0x10]
  SDI-Select: 0
  PCM:
    rates [0x160]: 44100 48000 96000
    bits [0x6]: 16 20
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC883 Alt Analog", type="Audio", device=2
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    bits [0x6]: 16 20
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100391: Stereo Digital
  Control: name="IEC958 Capture Switch", index=0, device=0
  Control: name="IEC958 Capture Default", index=0, device=0
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Control: name="CD Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="CD Playback Switch", index=0, device=0
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=5, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0
  Amp-Out vals:  [0x19 0x19]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Side Playback Volume", index=0, device=0
  Connection: 2
     0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0000003e: IN OUT HP Detect Trigger
  Pin Default 0x01014030: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=06, enabled=1
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Pin Default 0x01011031: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0x3, Sequence = 0x1
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=08, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Pin Default 0x01016032: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Orange
    DefAssociation = 0x3, Sequence = 0x2
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=07, enabled=1
  Connection: 5
     0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Side Playback Switch", index=0, device=0
  Pin Default 0x01012033: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Grey
    DefAssociation = 0x3, Sequence = 0x3
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=09, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0000173e: IN OUT HP Detect Trigger
    Vref caps: HIZ 50 GRD 80
  Pin Default 0x01a19850: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x5, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Unsolicited: tag=02, enabled=1
  Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Pin Default 0x02a19c80: [Jack] Mic at Ext Front
    DefAssociation = 0x8, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=03, enabled=1
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x01813050: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
  Pin-ctls: 0x20: IN VREF_HIZ
  Unsolicited: tag=04, enabled=1
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pin Default 0x02214c40: [Jack] HP Out at Ext Front
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Unsolicited: tag=01, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e 0x0f 0x26*
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x99331150: [Fixed] CD at Int ATAPI
    Conn = ATAPI, Color = Black
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
  Pin Default 0x00000100: [Jack] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital
  Pincap 0x00000010: OUT
  Pin Default 0x01441170: [Jack] SPDIF Out at Ext Rear
    Conn = RCA, Color = Black
    DefAssociation = 0x7, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400200: Mono Digital
  Pin Default 0x01c46160: [Jack] SPDIF In at Ext Rear
    Conn = RCA, Color = Orange
    DefAssociation = 0x6, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=17
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Amp-In vals:  [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Amp-Out caps: N/A
  Connection: 11
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Amp-Out caps: N/A
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  Connection: 2
     0x25 0x0b
Codec: Intel CougarPoint HDMI
Address: 3
Vendor Id: 0x80862805
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled GenLevel
  Digital category: 0x2
  PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled
  PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Pincap 0x09000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x02
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Control: name="IEC958 Playback Con Mask", index=1, device=0
  Control: name="IEC958 Playback Pro Mask", index=1, device=0
  Control: name="IEC958 Playback Default", index=1, device=0
  Control: name="IEC958 Playback Switch", index=1, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x03
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Control: name="IEC958 Playback Con Mask", index=2, device=0
  Control: name="IEC958 Playback Pro Mask", index=2, device=0
  Control: name="IEC958 Playback Default", index=2, device=0
  Control: name="IEC958 Playback Switch", index=2, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x04
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 12 Aug 28 22:59 /dev/snd/controlC0
crw-rw----  1 root audio 116, 10 Aug 28 22:59 /dev/snd/hwC0D0
crw-rw----  1 root audio 116, 11 Aug 28 22:59 /dev/snd/hwC0D3
crw-rw----  1 root audio 116,  3 Aug 28 22:59 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116,  2 Aug 28 23:00 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116,  5 Aug 28 23:00 /dev/snd/pcmC0D1c
crw-rw----  1 root audio 116,  4 Aug 28 22:59 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116,  6 Aug 28 22:59 /dev/snd/pcmC0D2c
crw-rw----  1 root audio 116,  7 Aug 28 22:59 /dev/snd/pcmC0D3p
crw-rw----  1 root audio 116,  8 Aug 28 22:59 /dev/snd/pcmC0D7p
crw-rw----  1 root audio 116,  9 Aug 28 22:59 /dev/snd/pcmC0D8p
crw-rw----  1 root audio 116,  1 Aug 28 22:59 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Aug 28 22:59 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Aug 28 22:59 .
drwxr-xr-x 3 root root 320 Aug 28 22:59 ..
lrwxrwxrwx 1 root root  12 Aug 28 22:59 pci-0000:00:1b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC883 Analog [ALC883 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC883 Digital [ALC883 Digital]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [PG_HDMI]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC883 Alt Analog [ALC883 Alt Analog]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xf7d00000 irq 30'
  Mixer name	: 'Realtek ALC883'
  Components	: 'HDA:10ec0883,10ec0883,00100002 HDA:80862805,80860101,00100000'
  Controls      : 80
  Simple ctrls  : 27
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 31
  Mono: Playback 25 [81%] [-9.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-46.50dB] [off]
  Front Right: Playback 0 [0%] [-46.50dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 254 [100%] [-0.20dB]
  Front Right: Playback 254 [100%] [-0.20dB]
Simple mixer control 'Front',0
  Mono:
  Front Left: Playback 31 [100%] [0.00dB] [on]
  Front Right: Playback 31 [100%] [0.00dB] [on]
Simple mixer control 'Front Mic',0
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Center',0
  Mono: Playback 31 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
  Mono:
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
Simple mixer control 'CD',0
  Mono:
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined cswitch cswitch-joined
  Capture channels: Mono
  Mono: Playback [off] Capture [off]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',16
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 31
  Front Left: Capture 16 [52%] [12.00dB] [on]
  Front Right: Capture 16 [52%] [12.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-12.00dB] [off]
  Front Right: Capture 0 [0%] [-12.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Rear Mic' 'Front Mic' 'Line' 'CD'
  Item0: 'Rear Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Rear Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Center Playback Volume'
		value 31
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
	control.6 {
		iface MIXER
		name 'LFE Playback Volume'
		value 31
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
	control.7 {
		iface MIXER
		name 'Center Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		name 'LFE Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'Side Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Side Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 -4650
			dbvalue.1 -4650
	control.12 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.13 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.14 {
		iface MIXER
		name 'Rear Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.15 {
		iface MIXER
		name 'Rear Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.16 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.17 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.18 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.19 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.20 {
		iface MIXER
		name 'CD Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.21 {
		iface MIXER
		name 'CD Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.22 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.23 {
		iface MIXER
		name 'Input Source'
		value 'Rear Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Rear Mic'
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.24 {
		iface MIXER
		name 'Input Source'
		index 1
		value 'Rear Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Rear Mic'
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.25 {
		iface MIXER
		name 'Capture Volume'
		value.0 16
		value.1 16
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -1200
			dbmax 3450
			dbvalue.0 1200
			dbvalue.1 1200
	control.26 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.27 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -1200
			dbmax 3450
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.28 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.29 {
		iface MIXER
		name 'Rear Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.30 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.31 {
		iface MIXER
		name 'Line Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.32 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.33 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.34 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		index 16
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.35 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		index 16
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.36 {
		iface MIXER
		name 'IEC958 Playback Default'
		index 16
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.37 {
		iface MIXER
		name 'IEC958 Playback Switch'
		index 16
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.39 {
		iface MIXER
		name 'IEC958 Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.40 {
		iface MIXER
		name 'IEC958 Capture Default'
		comment {
			access read
			type IEC958
			count 1
	control.41 {
		iface MIXER
		name 'Master Playback Volume'
		value 25
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 -900
	control.42 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.43 {
		iface CARD
		name 'Rear Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.44 {
		iface CARD
		name 'Front Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.45 {
		iface CARD
		name 'Line Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.46 {
		iface CARD
		name 'CD Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.47 {
		iface CARD
		name 'Line Out Front Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.48 {
		iface CARD
		name 'Line Out Surround Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.49 {
		iface CARD
		name 'Line Out CLFE Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.50 {
		iface CARD
		name 'Line Out Side Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.51 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.52 {
		iface CARD
		name 'SPDIF Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.53 {
		iface CARD
		name 'SPDIF In Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.54 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access read
			type INTEGER
			count 8
			range '0 - 36'
	control.55 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.56 {
		iface PCM
		device 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.57 {
		iface PCM
		device 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.58 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.59 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.60 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.61 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.62 {
		iface MIXER
		comment {
			access 'read write'
			type IEC958
			count 1
	control.63 {
		iface MIXER
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.64 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.65 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.66 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.67 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.68 {
		iface MIXER
		index 1
		value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.69 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.70 {
		iface PCM
		device 7
		name ELD
		value '100007006710000100000000000000006b5af6ff50475f48444d490907070000'
		comment {
			type BYTES
			count 32
	control.71 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.72 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.73 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.74 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.75 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.76 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.77 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.78 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.79 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.80 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 254
		value.1 254
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 -20
			dbvalue.1 -20
--endcollapse--
!!All Loaded Modules
aesni_intel
at24
blake2b_generic
btrfs
cdc_ether
coretemp
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
fat
fuse
ghash_clmulni_intel
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
intel_cstate
intel_gtt
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip_tables
joydev
ledtrig_audio
libcrc32c
libphy
lpc_ich
mac_hid
mdio_devres
mei
mei_hdcp
mei_me
mii
mousedev
ns
pcspkr
qrtr
r8169
raid6_pq
rapl
realtek
rfkill
rndis_host
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_timer
soundcore
ttm
uinput
usbhid
usbnet
vfat
video
x86_pkg_temp_thermal
x_tables
xor
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x14 0x01014030
0x15 0x01011031
0x16 0x01016032
0x17 0x01012033
0x18 0x01a19850
0x19 0x02a19c80
0x1a 0x01813050
0x1b 0x02214c40
0x1c 0x99331150
0x1d 0x00000100
0x1e 0x01441170
0x1f 0x01c46160
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D3/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D3/driver_pin_configs:
/sys/class/sound/hwC0D3/user_pin_configs:
/sys/class/sound/hwC0D3/init_verbs:
/sys/class/sound/hwC0D3/hints:
!!ALSA/HDA dmesg
[    0.155992] ACPI: Added _OSI(Linux-Dell-Video)
[    0.155992] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.155992] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    3.167949] AES CTR mode by8 optimization enabled
[    3.177865] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[    3.217267] i915 0000:00:02.0: vgaarb: deactivate vga console
[    3.238682] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[    3.238754] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.355609] fbcon: i915drmfb (fb0) is primary device
[    3.355615] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    3.408143] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC883: line_outs=4 (0x14/0x16/0x15/0x17/0x0) type:line
[    3.408149] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.408151] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.408153] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.408154] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[    3.408155] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.408156] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    3.408158] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    3.408159] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    3.408160] snd_hda_codec_realtek hdaudioC0D0:      CD=0x1c
[    3.408161] snd_hda_codec_realtek hdaudioC0D0:    dig-in=0x1f
[    3.426616] BTRFS info (device sdb1): flagging fs with big metadata feature
[    3.452313] random: crng init done
[    3.462253] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    3.465464] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    3.465525] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    3.465580] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    3.465629] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    3.469474] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    3.472768] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    3.472836] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    3.472885] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[    3.472927] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[    3.472979] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[    3.504785] audit: type=1130 audit(1661738352.685:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sorry about any gramatical errors, English is not my native language.
provide system info + logs:
inxi -Faz
journalctl -b0 -p4 --no-pager
before I saw your answer, I tried unninstalling PipeWire, as I saw in other forums, and something happened that KDEPlasma is not initializating.
I can’t enter because I put my password but the ‘enter’ key is not responding. I’m going to reinstall Manjaro now :disappointed_relieved:
you removed all of your desktop together with pipewire … wait dont reinstall now… you can repair it from the live usb …
Ok, how can I do It? I’m going to prepare the liveUSB
ok so boot in the live usb - dont reinstall anything and in meantime im going to check on the forum, recently there was another user who did the same when uninstalling pipewire …
edit: let me know when youre ready
I’m ready to boot. Should I do it with proprietary or opensource drivers?
boot with open source, when in the live usb desktop, connect to internet, then open terminal and chroot:
sudo manjaro-chroot -a
and post the output from this command
    ~  sudo manjaro-chroot -a         ✔
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
==> ERROR: No Linux partitions detected!
I think it searched on the usb unit
are you using luks/encryption or btrfs?
it is btfrs
root is in SSD
and /home is in HD
post output from:
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
we need to chroot manually
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME                                          255 ✘
PATH       PTTYPE PARTTYPE                             FSTYPE   PARTTYPENAME
/dev/loop0                                             squashfs
/dev/loop1                                             squashfs
/dev/loop2                                             squashfs
/dev/loop3                                             squashfs
/dev/sda   gpt
/dev/sda1  gpt    0657fd6d-a4ab-43c4-84e5-0933c84b4f4f swap     Linux swap
/dev/sda2  gpt    c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat     EFI System
/dev/sda3  gpt    0fc63daf-8483-4772-8e79-3d69d8477de4 btrfs    Linux filesystem
/dev/sdb   gpt
/dev/sdb1  gpt    0fc63daf-8483-4772-8e79-3d69d8477de4 btrfs    Linux filesystem
/dev/sdc   dos                                         iso9660
/dev/sdc1  dos    0x0                                  iso9660  Empty
/dev/sdc2  dos    0xef                                 vfat     EFI (FAT-12/16/32)
now run these commands:
sudo mount /dev/sda3 /mnt
sudo mount -o subvol=@ /dev/sda3 /mnt
sudo mount /dev/sda2 /mnt/boot/efi
sudo manjaro-chroot /mnt
and post the output of these commands
sudo mount /dev/sda3 /mnt         ✔
    /  sudo mount -o subvol=@ /dev/sda3 /mnt                                                          ✔
mount: /mnt: /dev/sda3 already mounted on /run/media/manjaro/696eca54-4651-41a9-ac29-f11c0595d1d0.
       dmesg(1) may have more information after failed mount system call.
    /  sudo mount /dev/sda2 /mnt/boot/efi                                                          32 ✘
mount: /mnt/boot/efi: mount point does not exist.
    /  sudo manjaro-chroot /mnt         32 ✘
mount: /mnt/proc: mount point does not exist.
==> ERROR: failed to setup API filesystems in chroot /mnt
umount: bad usage
Try 'umount --help' for more information.
was following the manjaro wiki on how to chroot manually with btrfs …
so we have to do it from the broken login screen …
so reboot and boot normally into your installation and in the stuck login screen (the picture above) enter into tty: ctrl+alt+f2 - or f1-f6 keys … it will prompt you for your username, so instead of it use username: root
then enter your password, and you should be in the tty terminal
when you are there, let me know, we will install back the desktop + pipewire
I’m ready
good now run this command:
pamac install plasma kio-extras pipewire manjaro-kde-settings plasma5-themes-breath
then reboot:
systemctl reboot
The first line in portuguese (above “1: bluedevil”) says “There is 46 members in group plasma”.
The last line says “Select (defaut=1all)”
May I simply press enter? Or should I write “padrão”(defaut)?
