Issues installing via ISO's with kernels newer than 5.4
If I try to install isos with newer kernels it doesn’t install…the installer tries to start and disappears…the live environment is also not working properly…no internet
Tried installing Fedora 32(newer kernel), exact same issue there!
(I installed 20.1 mikah with 5.4 kernel, working properly)
My System:
i7 3770s
Mobo- Intel dh61h0
Nvidia GTX 1050 ti
Hello,
Yes, i can use all kernels above 5.4 and also i can install the latest ISO with 5.8, or the minimal version with 5.4 kernel.
Can you share from terminal:
inxi -Fxza --no-host
Did you try to save some logs from the previous intents of the installation process?
Should I run this from the working Manjaro machine?with kernel 5.4?
(With 5.8 kernel the terminal doesn’t work properly in live environment)
IMAGE FROM 5.8 LIVE ENVIRONMENT (Logs app)
Yes, you can provide the inxi -Fxza --no-host from the working live session too.
Also you can provide the logs as text format, not screenshots. I can’t search in screenshots.
If they are very long, use this service to post them https://pastebin.com/ then link them here.
if the ISO with the 5.4 kernel is old, like 19 version, there might be issues. many things changed since. You could try the minimal version of the latest ISO that come with 5.4 kernel.
  Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  misobasedir=manjaro misolabel=MANJARO_GNOMEM_201 quiet
  systemd.show_status=1 apparmor=1 security=apparmor
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Desktop Mobo: Intel model: DH61HO v: AAG62445-102 serial: <filter>
  UEFI: Intel v: HOH6110H.86A.0816.2018.1031.1524 date: 10/31/2018
  Topology: Quad Core model: Intel Core i7-3770S bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 20
  L2 cache: 8192 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 49509
  Speed: 1597 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1596 2: 1596
  3: 1596 4: 1597 5: 1597 6: 1597 7: 1594 8: 1597
  Type: l1tf
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
  SMT vulnerable
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ZOTAC driver: nvidia
  v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82
  Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: nvidia
  resolution: <xdpyinfo missing>
  OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
  direct render: Yes
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ZOTAC
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k5.4.64-1-MANJARO
  vendor: Intel driver: r8169 v: kernel port: d000 bus ID: 03:00.0
  chip ID: 10ec:8168
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
  driver: r8188eu bus ID: 1-1.1:3 chip ID: 0bda:8179 serial: <filter>
  IF: wlp0s26u1u1 state: down mac: <filter>
  Device-3: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
  type: USB driver: r8152 bus ID: 4-3:2 chip ID: 2357:0601 serial: <filter>
  IF: enp4s0u3 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.93 TiB used: 111.58 GiB (5.6%)
  ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
  block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: KC45 scheme: GPT
  ID-2: /dev/sdb vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  serial: <filter> rev: 023 scheme: GPT
  ID-3: /dev/sdc type: USB vendor: Seagate model: BUP Slim BK
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  serial: <filter> rev: 0304 scheme: MBR
  ID-4: /dev/sdd type: USB model: TO Exter nal USB 3.0 size: 111.80 GiB
  block size: physical: 4096 B logical: 512 B serial: <filter> rev: 0204
  scheme: GPT
  ID-1: / raw size: N/A size: 11.70 GiB used: 559.9 MiB (4.7%) fs: overlay
  source: ERR-102
  ID-1: /dev/dm-0 size: 1.85 GiB fs: <superuser/root required> label: N/A
  uuid: N/A
  ID-2: /dev/sda1 size: 465.76 GiB fs: ntfs label: New Volume
  uuid: A67ACCA77ACC7599
  ID-3: /dev/sdb1 size: 100.0 MiB fs: vfat label: SYSTEM uuid: CCB8-59E3
  ID-4: /dev/sdb2 size: 391.96 GiB fs: ntfs label: N/A
  uuid: ACA0ECC1A0EC92DE
  ID-5: /dev/sdb3 size: 505.0 MiB fs: ntfs label: N/A uuid: 80580F7C580F7068
  ID-6: /dev/sdb4 size: 73.21 GiB fs: ext4 label: N/A
  uuid: c76655e4-412f-4e7c-bcc6-c990096661de
  ID-7: /dev/sdd1 size: 111.76 GiB fs: exfat label: Ventoy uuid: 4E21-0000
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 38 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
  Processes: 240 Uptime: 1m Memory: 15.60 GiB used: 839.7 MiB (5.3%)
  Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1021 lib: 280
  Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
Ok, so you are using the latest minimal ISO with 5.4 kernel. To troubleshoot the installation, please follow this and provide that information if the install fails again:
legacy mode is disabled in bios…i can install every iso with kernel 5.4…but any isos with newer kernel is the problem…i thought my machine is very old…but you are using 1st gen i7 and u can run 5.8 kernel fine…
so what is the problem with my system
i am trying to get the info from logs app in 5.8 live environment
and in live environment(5.8) nothing works properly…no internet…the terminal even malfunctions
i currently have 20.1 with 5.4…i can manually install and use 5.8.6 properly…just sometimes it gets stuck during boot with boot logo…then after 2…3 hard restart it then starts normally with 5.8…
my super duper strange machine!!!
Is hard to speculate. Could be just a simple glitch, or a setting in the BIOS, or ISO corrupted … You have to check that possibility too.
i have tried installing 20.0, 20.0.2, 20.0.3, 20.1rc4, 20.1rc5 (tried fedora 32) …everywhere exactly same issue…newer kernels not working properly for some reason(I think)!
If you can get the logs of calamares, then we might be able to identify the issue.
Have you tried to update the BIOS too?
While it seems there is some 2019 release
https://downloadcenter.intel.com/product/66983/Intel-Desktop-Board-DH61HO
I have no experience with this model. Proceed with caution if you decide to do that.
my bios is uptodate…last update released 2nd half of 2018
xorg (live session with 5.8…logs app)
[    47.876] (--) Log file renamed from "/var/log/Xorg.pid-4408.log" to "/var/log/Xorg.0.log"
[    47.876] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    47.877]
X.Org X Server 1.20.8
[    47.877] Build Operating System: Linux Manjaro Linux
[    47.877] Current Operating System: Linux manjaro-gnome 5.8.6-1-MANJARO #1 SMP PREEMPT Thu Sep 3 14:19:36 UTC 2020 x86_64
[    47.877] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MANJARO_GNOMEM_201 quiet systemd.show_status=1 apparmor=1 security=apparmor
[    47.877] Build Date: 01 August 2020  07:25:56AM
[    47.877]
[    47.877] Current version of pixman: 0.40.0
[    47.877] 	Before reporting problems, check http://wiki.x.org
[    47.877] Markers: (--) probed, (**) from config file, (==) default setting,
[    47.877] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 14 12:26:36 2020
[    47.878] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    47.878] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    47.881] (==) ServerLayout "layout"
[    47.881] (**) |-->Screen "Screen0" (0)
[    47.881] (**) |   |-->Monitor "Monitor0"
[    47.882] (**) |   |-->Device "Device0"
[    47.882] (==) Automatically adding devices
[    47.882] (==) Automatically enabling devices
[    47.882] (==) Automatically adding GPU devices
[    47.882] (==) Automatically binding GPU devices
[    47.882] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    47.882] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[    47.882] 	Entry deleted from font path.
[    47.882] 	(Run 'mkfontdir' on "/usr/share/fonts/misc").
[    47.882] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    47.882] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    47.882] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    47.882] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    47.882] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    47.882] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    47.882] (==) FontPath set to:
[    47.883] (==) ModulePath set to "/usr/lib/xorg/modules"
[    47.883] (**) Extension "COMPOSITE" is enabled
[    47.883] (II) The server relies on udev to provide the list of input devices.
[    47.883] (II) Module ABI versions:
[    47.883] 	X.Org ANSI C Emulation: 0.4
[    47.883] 	X.Org Video Driver: 24.1
[    47.883] 	X.Org XInput driver : 24.1
[    47.883] 	X.Org Server Extension : 10.0
[    47.883] (++) using VT number 2
[    47.885] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    47.886] (II) xfree86: Adding drm device (/dev/dri/card0)
[    47.887] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[    47.888] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    47.888] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    47.888] (--) PCI:*(1@0:0:0) 10de:1c82:19da:a454 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    47.888] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    47.888] (II) LoadModule: "glx"
[    47.889] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    47.894] (II) Module glx: vendor="X.Org Foundation"
[    47.894] 	compiled for 1.20.8, module version = 1.0.0
[    47.894] 	ABI class: X.Org Server Extension, version 10.0
[    47.894] (II) LoadModule: "nvidia"
[    47.894] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    47.894] (II) Module nvidia: vendor="NVIDIA Corporation"
[    47.894] 	compiled for 1.6.99.901, module version = 1.0.0
[    47.894] 	Module class: X.Org Video Driver
[    47.894] (II) NVIDIA dlloader X Driver  450.66  Wed Aug 12 19:44:12 UTC 2020
[    47.894] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    47.894] (II) systemd-logind: releasing fd for 226:0
[    47.895] (II) Loading sub module "fb"
[    47.895] (II) LoadModule: "fb"
[    47.895] (II) Loading /usr/lib/xorg/modules/libfb.so
[    47.901] (II) Module fb: vendor="X.Org Foundation"
[    47.901] 	compiled for 1.20.8, module version = 1.0.0
[    47.901] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    47.901] (II) Loading sub module "wfb"
[    47.901] (II) LoadModule: "wfb"
[    47.901] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    47.909] (II) Module wfb: vendor="X.Org Foundation"
[    47.909] 	compiled for 1.20.8, module version = 1.0.0
[    47.909] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    47.909] (II) Loading sub module "ramdac"
[    47.909] (II) LoadModule: "ramdac"
[    47.909] (II) Module "ramdac" already built-in
[    47.911] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    47.911] (==) NVIDIA(0): RGB weight 888
[    47.911] (==) NVIDIA(0): Default visual is TrueColor
[    47.911] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    47.911] (**) Option "AllowNVIDIAGpuScreens"
[    47.911] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[    47.911] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[    47.911] (**) NVIDIA(0): Enabling 2D acceleration
[    47.911] (II) Loading sub module "glxserver_nvidia"
[    47.911] (II) LoadModule: "glxserver_nvidia"
[    47.911] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[    47.920] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    47.920] 	compiled for 1.6.99.901, module version = 1.0.0
[    47.920] 	Module class: X.Org Server Extension
[    47.920] (II) NVIDIA GLX Module  450.66  Wed Aug 12 19:41:37 UTC 2020
[    47.920] (II) NVIDIA: The X server supports PRIME Render Offload.
[    48.594] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    48.594] (--) NVIDIA(0):     DFP-0 (boot)
[    48.594] (--) NVIDIA(0):     DFP-1
[    48.594] (--) NVIDIA(0):     DFP-2
[    48.594] (--) NVIDIA(0):     DFP-3
[    48.594] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:1:0:0 (GPU-0)
[    48.594] (--) NVIDIA(0): Memory: 4194304 kBytes
[    48.594] (--) NVIDIA(0): VideoBIOS: 86.07.39.00.30
[    48.594] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    48.624] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): connected
[    48.624] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): Internal TMDS
[    48.624] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): 330.0 MHz maximum pixel clock
[    48.624] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    48.624] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    48.624] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    48.624] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    48.624] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    48.624] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    48.624] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    48.624] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    48.624] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    48.628] (==) NVIDIA(0):
[    48.628] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    48.628] (==) NVIDIA(0):     will be used as the requested mode.
[    48.629] (II) NVIDIA(0): Validated MetaModes:
[    48.629] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[    48.629] (II) NVIDIA(0): Virtual screen size determined to be 1600 x 900
[    48.633] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[    48.633] (--) NVIDIA(0):     option
[    48.633] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    48.633] (II) NVIDIA:     access.
[    48.635] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    48.635] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    48.635] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    48.635] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    48.635] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    48.635] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    48.635] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    48.635] (II) NVIDIA(0):     Config Options in the README.
[    48.899] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[    48.949] (==) NVIDIA(0): Disabling shared memory pixmaps
[    48.949] (==) NVIDIA(0): Backing store enabled
[    48.949] (==) NVIDIA(0): Silken mouse disabled
[    48.950] (**) NVIDIA(0): DPMS enabled
[    48.950] (WW) NVIDIA(0): Option "NoLogo" is not used
[    48.950] (II) Loading sub module "dri2"
[    48.950] (II) LoadModule: "dri2"
[    48.950] (II) Module "dri2" already built-in
[    48.950] (II) NVIDIA(0): [DRI2] Setup complete
[    48.950] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    48.950] (II) Initializing extension Generic Event Extension
[    48.950] (II) Initializing extension SHAPE
[    48.950] (II) Initializing extension MIT-SHM
[    48.950] (II) Initializing extension XInputExtension
[    48.950] (II) Initializing extension XTEST
[    48.950] (II) Initializing extension BIG-REQUESTS
[    48.950] (II) Initializing extension SYNC
[    48.950] (II) Initializing extension XKEYBOARD
[    48.950] (II) Initializing extension XC-MISC
[    48.950] (II) Initializing extension SECURITY
[    48.950] (II) Initializing extension XFIXES
[    48.950] (II) Initializing extension RENDER
[    48.950] (II) Initializing extension RANDR
[    48.950] (II) Initializing extension COMPOSITE
[    48.950] (II) Initializing extension DAMAGE
[    48.950] (II) Initializing extension MIT-SCREEN-SAVER
[    48.950] (II) Initializing extension DOUBLE-BUFFER
[    48.950] (II) Initializing extension RECORD
[    48.950] (II) Initializing extension DPMS
[    48.950] (II) Initializing extension Present
[    48.950] (II) Initializing extension DRI3
[    48.950] (II) Initializing extension X-Resource
[    48.950] (II) Initializing extension XVideo
[    48.950] (II) Initializing extension XVideo-MotionCompensation
[    48.950] (II) Initializing extension GLX
[    48.950] (II) Indirect GLX disabled.
[    48.950] (II) GLX: Another vendor is already registered for screen 0
[    48.950] (II) Initializing extension XFree86-VidModeExtension
[    48.950] (II) Initializing extension XFree86-DGA
[    48.950] (II) Initializing extension XFree86-DRI
[    48.950] (II) Initializing extension DRI2
[    48.950] (II) Initializing extension NV-GLX
[    48.950] (II) Initializing extension NV-CONTROL
[    48.950] (II) Initializing extension XINERAMA
[    49.018] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    49.018] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    49.018] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    49.018] (**) Power Button: Applying InputClass "system-keyboard"
[    49.018] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    49.018] (II) LoadModule: "libinput"
[    49.018] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    49.023] (II) Module libinput: vendor="X.Org Foundation"
[    49.023] 	compiled for 1.20.8, module version = 0.30.0
[    49.023] 	Module class: X.Org XInput Driver
[    49.023] 	ABI class: X.Org XInput driver, version 24.1
[    49.023] (II) Using input driver 'libinput' for 'Power Button'
[    49.024] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[    49.024] (**) Power Button: always reports core events
[    49.024] (**) Option "Device" "/dev/input/event1"
[    49.024] (**) Option "_source" "server/udev"
[    49.031] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    49.031] (II) event1  - Power Button: device is a keyboard
[    49.031] (II) event1  - Power Button: device removed
[    49.031] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    49.031] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    49.031] (**) Option "xkb_model" "pc105+inet"
[    49.031] (**) Option "xkb_layout" "us"
[    49.031] (WW) Option "xkb_variant" requires a string value
[    49.031] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    49.052] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    49.052] (II) event1  - Power Button: device is a keyboard
[    49.052] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    49.052] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    49.053] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    49.053] (**) Power Button: Applying InputClass "system-keyboard"
[    49.053] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    49.053] (II) Using input driver 'libinput' for 'Power Button'
[    49.054] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 37 paused 0
[    49.054] (**) Power Button: always reports core events
[    49.054] (**) Option "Device" "/dev/input/event0"
[    49.054] (**) Option "_source" "server/udev"
[    49.055] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    49.055] (II) event0  - Power Button: device is a keyboard
[    49.055] (II) event0  - Power Button: device removed
[    49.055] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    49.055] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    49.055] (**) Option "xkb_model" "pc105+inet"
[    49.055] (**) Option "xkb_layout" "us"
[    49.055] (WW) Option "xkb_variant" requires a string value
[    49.055] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    49.056] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    49.056] (II) event0  - Power Button: device is a keyboard
[    49.057] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[    49.057] (II) No input driver specified, ignoring this device.
[    49.057] (II) This device may have been added with another device file.
[    49.057] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[    49.058] (II) This device may have been added with another device file.
[    49.058] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[    49.058] (II) No input driver specified, ignoring this device.
[    49.058] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[    49.059] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[    49.059] (II) No input driver specified, ignoring this device.
[    49.059] (II) This device may have been added with another device file.
[    49.059] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[    49.060] (II) config/udev: Adding input device DragonRise Inc.   Generic   USB  Joystick   (/dev/input/event2)
[    49.060] (II) No input driver specified, ignoring this device.
[    49.060] (II) This device may have been added with another device file.
[    49.061] (II) config/udev: Adding input device DragonRise Inc.   Generic   USB  Joystick   (/dev/input/js0)
[    49.061] (II) No input driver specified, ignoring this device.
[    49.061] (II) This device may have been added with another device file.
[    49.062] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
[    49.062] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    49.062] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    49.062] (**) Logitech USB Keyboard: Applying InputClass "system-keyboard"
[    49.062] (**) Logitech USB Keyboard: Applying InputClass "Keyboard Defaults"
[    49.062] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[    49.063] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 38 paused 0
[    49.063] (**) Logitech USB Keyboard: always reports core events
[    49.063] (**) Option "Device" "/dev/input/event3"
[    49.063] (**) Option "_source" "server/udev"
[    49.065] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    49.065] (II) event3  - Logitech USB Keyboard: device is a keyboard
[    49.065] (II) event3  - Logitech USB Keyboard: device removed
[    49.065] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31D.0002/input/input3/event3"
[    49.065] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 8)
[    49.065] (**) Option "xkb_model" "pc105+inet"
[    49.065] (**) Option "xkb_layout" "us"
[    49.065] (WW) Option "xkb_variant" requires a string value
[    49.065] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    49.067] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    49.067] (II) event3  - Logitech USB Keyboard: device is a keyboard
[    49.068] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event4)
[    49.068] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    49.068] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    49.069] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    49.069] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[    49.069] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[    49.070] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 39 paused 0
[    49.070] (**) Logitech USB Keyboard Consumer Control: always reports core events
[    49.070] (**) Option "Device" "/dev/input/event4"
[    49.070] (**) Option "_source" "server/udev"
[    49.072] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    49.072] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    49.072] (II) event4  - Logitech USB Keyboard Consumer Control: device removed
[    49.072] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31D.0003/input/input4/event4"
[    49.072] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 9)
[    49.072] (**) Option "xkb_model" "pc105+inet"
[    49.072] (**) Option "xkb_layout" "us"
[    49.072] (WW) Option "xkb_variant" requires a string value
[    49.072] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    49.074] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    49.074] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    49.075] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event5)
[    49.075] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    49.075] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    49.075] (**) Logitech USB Keyboard System Control: Applying InputClass "system-keyboard"
[    49.075] (**) Logitech USB Keyboard System Control: Applying InputClass "Keyboard Defaults"
[    49.075] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[    49.076] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 40 paused 0
[    49.076] (**) Logitech USB Keyboard System Control: always reports core events
[    49.076] (**) Option "Device" "/dev/input/event5"
[    49.076] (**) Option "_source" "server/udev"
[    49.078] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    49.078] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[    49.078] (II) event5  - Logitech USB Keyboard System Control: device removed
[    49.078] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31D.0003/input/input5/event5"
[    49.078] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 10)
[    49.078] (**) Option "xkb_model" "pc105+inet"
[    49.078] (**) Option "xkb_layout" "us"
[    49.078] (WW) Option "xkb_variant" requires a string value
[    49.078] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    49.079] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    49.079] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[    49.080] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event6)
[    49.080] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    49.080] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[    49.080] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[    49.081] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 41 paused 0
[    49.081] (**) Logitech USB Optical Mouse: always reports core events
[    49.081] (**) Option "Device" "/dev/input/event6"
[    49.081] (**) Option "_source" "server/udev"
[    49.083] (II) event6  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[    49.083] (II) event6  - Logitech USB Optical Mouse: device set to 1000 DPI
[    49.083] (II) event6  - Logitech USB Optical Mouse: device is a pointer
[    49.083] (II) event6  - Logitech USB Optical Mouse: device removed
[    49.083] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C05A.0004/input/input6/event6"
[    49.083] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 11)
[    49.083] (**) Option "AccelerationScheme" "none"
[    49.083] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[    49.083] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[    49.083] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[    49.085] (II) event6  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[    49.085] (II) event6  - Logitech USB Optical Mouse: device set to 1000 DPI
[    49.085] (II) event6  - Logitech USB Optical Mouse: device is a pointer
[    49.086] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[    49.086] (II) No input driver specified, ignoring this device.
[    49.086] (II) This device may have been added with another device file.
[    49.086] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event14)
[    49.087] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event15)
[    49.087] (II) No input driver specified, ignoring this device.
[    49.087] (II) This device may have been added with another device file.
[    49.087] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event16)
[    49.088] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event17)
[    49.088] (II) No input driver specified, ignoring this device.
[    49.088] (II) This device may have been added with another device file.
[    49.088] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    49.806] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): connected
[    49.806] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): Internal TMDS
[    49.806] (--) NVIDIA(GPU-0): Samsung S22B300 (DFP-0): 330.0 MHz maximum pixel clock
[    49.806] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    49.806] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    49.806] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    49.806] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    49.806] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    49.806] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    49.806] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    49.806] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    49.807] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Live log
Running MHWD...
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-440xx-prime/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-440xx/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
e[1me[31m> e[mUsing config 'video-nvidia-450xx' for device: 0000:01:00.0 (0300:10de:1c82) Display controller nVidia Corporation GP107 [GeForce GTX 1050 Ti]
e[1me[31m> e[mInstalling video-nvidia-450xx...
e[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'extra' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'community' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'multilib' does not exist (use '-Sy' to download)
e[me[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-450xx/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0302
e[me[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32m:: Synchronizing package databases...
e[me[0;32mdownloading mhwd.db...
e[me[0;32mresolving dependencies...
e[me[0;32mlooking for conflicting packages...
e[me[0;32m
e[me[0;32mPackages (3) lib32-nvidia-450xx-utils-450.66-1  linux58-nvidia-450xx-450.66-9  nvidia-450xx-utils-450.66-1
e[me[0;32m
e[me[0;32mTotal Download Size:   131.60 MiB
e[me[0;32mTotal Installed Size:  367.82 MiB
e[me[0;32m
e[me[0;32m:: Proceed with installation? [Y/n]
e[me[0;32m:: Retrieving packages...
e[me[0;32mdownloading nvidia-450xx-utils-450.66-1-x86_64.pkg.tar.zst...
e[me[0;32mdownloading lib32-nvidia-450xx-utils-450.66-1-x86_64.pkg.tar.zst...
e[me[0;32mdownloading linux58-nvidia-450xx-450.66-9-x86_64.pkg.tar.xz...
e[me[0;32mchecking keyring...
e[me[0;32mchecking package integrity...
e[me[0;32mloading package files...
e[me[0;32mchecking for file conflicts...
e[me[0;32mchecking available disk space...
e[me[0;32m:: Processing package changes...
e[me[0;32minstalling nvidia-450xx-utils...
e[me[0;32me[1;1me[1;32m==>e[1;0me[1;1m If you run into trouble with CUDA not being available, run nvidia-modprobe first.e[1;0m
e[me[0;32mOptional dependencies for nvidia-450xx-utils
e[me[0;32m    gtk3: nvidia-settings [installed]
e[me[0;32m    xorg-server-devel: nvidia-xconfig
e[me[0;32m    opencl-nvidia: OpenCL support
e[me[0;32minstalling lib32-nvidia-450xx-utils...
e[me[0;32mOptional dependencies for lib32-nvidia-450xx-utils
e[me[0;32m    lib32-opencl-nvidia-450xx
e[me[0;32minstalling linux58-nvidia-450xx...
e[me[0;32mIn order to use nvidia module, reboot the system.
e[me[0;32m:: Running post-transaction hooks...
e[me[0;32m(1/6) Creating system user accounts...
e[me[0;32mCreating group nvidia-persistenced with gid 143.
e[me[0;32mCreating user nvidia-persistenced (NVIDIA Persistence Daemon) with uid 143 and gid 143.
e[me[0;32m(2/6) Reloading system manager configuration...
e[me[0;32m(3/6) Arming ConditionNeedsUpdate...
e[me[0;32m(4/6) Updating module dependencies...
e[me[0;32m(5/6) Updating Kernel initcpios for Nvidia-DRM...
e[me[0;32m==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
e[me[0;32m  -> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
e[me[0;32m==> Starting build: 5.8.6-1-MANJARO
e[me[0;32m  -> Running build hook: [base]
e[me[0;32m  -> Running build hook: [udev]
e[me[0;32m  -> Running build hook: [autodetect]
e[me[0;32m  -> Running build hook: [modconf]
e[me[0;32m  -> Running build hook: [block]
e[me[0;32m==> WARNING: Possibly missing firmware for module: xhci_pci
e[me[0;32m  -> Running build hook: [filesystems]
e[me[0;32m  -> Running build hook: [keyboard]
e[me[0;32m  -> Running build hook: [fsck]
e[me[0;32m==> Generating module dependencies
e[me[0;32m==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
e[me[0;32m==> Image generation successful
e[me[0;32m==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
e[me[0;32m  -> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
e[me[0;32m==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
e[me[0;32m(6/6) Updating the desktop file MIME type cache...
e[me[0;32mnvidia-450xx-utils: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-nvidia-450xx-utils: install reason has been set to 'explicitly installed'
e[me[0;32mlinux58-nvidia-450xx: install reason has been set to 'explicitly installed'
e[me[0;32mxorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
e[me[1me[31m> e[mSuccessfully installed video-nvidia-450xx
MHWD DONE
You provided the MHWD install log from Live Session, not the calamares log.
MHWD is not meant to be used like that in Live Session. You chose the nonfree driver at grub and then the script MHWD prepares the live session to use the proper drivers, so when you make the actual install, same drivers are used.
how to provide calamares log? terminal is unusable in live session
So, we are not communicating very efective it seems :slight_smile: or you did not read this part of my comment
There is a link there that explains in detail all that.
Why is that? I can use it perfectly fine.
no no…i know how to provide the calamares log :sweat_smile:
but with 5.8 the terminal is unsuable…if i type sudo -E calamres -d the cursor just jumps to the 2nd line and nothing happens
calamares log from 5.4 live session? would that b helpful?
If that is a successful install will not help us trace the issue with the 5.8 kernel install.
