I’m no pc guru so don’t get mad at me if I’m missing somethings obvious. I’m on latest cinnamon and I can’t send my laptop to sleep. What’s more is that after that power settings won’t open and I can’t adjust brightness also. It all worked before the update to cinnamon 5. What more info can I provide?
Then why using unstable branch?
see here
do you have swap partiton or did you deswap it?
The latest cinnamon release is 5.0.2 do you have this as both suspend and hibernate work here.
It depends on the branch. Testing only has few packages updated, Unstable has more.
If you look at the tags he used one of them is “unstable”
