Hi, replaced my gpu, and I cant see the lightdm login page when I boot on manjaro now. I think the right driver is installed, I was able to do ctrl alt f+number to access a terminal and I did the command I saw was recommended on the wiki for mhwd (sudo mhwd -a pci nonfree 0300) but it said the right driver was installed, I could not start lightdm but just starting “sway” (the i3 wayland window manager) worked, I moved my x configuration files (etc/x11/) and left it empty and then I was able to start lightdm from one of the tty after rebooting though it is in qwerty mode and I use an azerty keyboard, I was able to log in normally and the system seems to behave mostly fine, pulseaudio is not working. I have no idea what log is needed. Thanks for the help. system info
Hi @gtrjrkjrfkdk,
You’ve definitely got mixed up drivers there. Please provide the output for:
mhwd --listinstalled
And
mhwd --list
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2021.12.18 false PCI
and
mhwd --list
> 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:05:00.0 (0300:1002:73ff) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
I dont know if its relevant but I had to install a specific nvidia driver recently as I had issues with xrander Xrandr can no longer find my second monitor - #2 by megavolt
That’s definitely not the right driver for your new card. Remove it and reboot.
sudo mhwd -r pci video-nvidia-470xx
Well, to start with, if you’re replacing the nvidia with an AMD, as your title says, then the nvidia drivers’ll do you no good. So you can remove them:
mhwd --remove pci video-nvidia-470xx
Followed by rebooting.
I removed video-nvidia-470xx rebooted and still the same issue, black screen, my monitor shows a message saying there’s no signal and I start lightdm with a terminal I accessed by doing ctrl alt f number
mhwd --list
OK, let’s try removing and reinstalling the driver, then.
To remove it:
mhwd --remove pci video-linux
And then, as per the Wiki, install the free drivers again:
mhwd --auto pci free 0300
Then reboot again, and see.
I suggest looking for errors.
journalctl --boot=0 --priority=3 --catalog
* mhwd --remove pci video-linux
> Removing video-linux...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-linux/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0380
Processing classid: 0302
checking dependencies...
:: lib32-libva optionally requires lib32-libva-vdpau-driver: vdpau back-end for nvidia
:: lib32-mesa optionally requires lib32-mesa-vdpau: for accelerated video playback
:: lib32-vulkan-icd-loader optionally requires lib32-vulkan-driver: packaged vulkan driver
:: libva optionally requires libva-vdpau-driver: backend for Nvidia and AMD GPUs
:: mesa optionally requires mesa-vdpau: for accelerated video playback
:: mesa optionally requires libva-mesa-driver: for accelerated video playback
:: steam-manjaro optionally requires vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires lib32-vulkan-driver: packaged vulkan driver (32bit)
:: vlc optionally requires libva-vdpau-driver: vdpau backend nvidia
:: vulkan-icd-loader optionally requires vulkan-driver: packaged vulkan driver
Packages (14) lib32-libvdpau-1.4-2 lib32-libva-vdpau-driver-0.7.4-6 lib32-mesa-vdpau-21.3.7-2 lib32-vulkan-intel-21.3.7-2 lib32-vulkan-radeon-21.3.7-2 libva-mesa-driver-21.3.7-2 libva-vdpau-driver-0.7.4-6 mesa-vdpau-21.3.7-2 vulkan-intel-21.3.7-2 vulkan-radeon-21.3.7-2 xf86-video-amdgpu-22.0.0-1 xf86-video-ati-1:19.1.0.r9.g5eba006e-2 xf86-video-intel-1:2.99.917+916+g31486f40-2 xf86-video-nouveau-1.0.17-2
Total Removed Size: 76.63 MiB
:: Do you want to remove these packages? [Y/n]
removing lib32-mesa-vdpau...
removing lib32-libva-vdpau-driver...
removing lib32-libvdpau...
removing lib32-vulkan-radeon...
removing lib32-vulkan-intel...
removing mesa-vdpau...
removing libva-vdpau-driver...
removing libva-mesa-driver...
removing vulkan-radeon...
removing vulkan-intel...
removing xf86-video-nouveau...
removing xf86-video-intel...
removing xf86-video-amdgpu...
removing xf86-video-ati...
(1/1) Arming ConditionNeedsUpdate...
> Successfully removed video-linux
then
> Using config 'video-linux' for device: 0000:05:00.0 (0300:1002:73ff) Display controller ATI Technologies Inc Navi 23 [Radeon RX 6600/6600 XT/6600M]
> Installing video-linux...
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
core downloading...
extra downloading...
community downloading...
multilib downloading...
resolving dependencies...
Total Download Size: 0.04 MiB
Total Installed Size: 76.63 MiB
:: Retrieving packages...
lib32-mesa-vdpau-21.3.7-2-x86_64 downloading...
libva-mesa-driver-21.3.7-2-x86_64 downloading...
vulkan-intel-21.3.7-2-x86_64 downloading...
lib32-vulkan-intel-21.3.7-2-x86_64 downloading...
lib32-vulkan-radeon-21.3.7-2-x86_64 downloading...
xf86-video-intel-1:2.99.917+916+g31486f40-2-x86_64 downloading...
xf86-video-ati-1:19.1.0.r9.g5eba006e-2-x86_64 downloading...
xf86-video-nouveau-1.0.17-2-x86_64 downloading...
xf86-video-amdgpu-22.0.0-1-x86_64 downloading...
lib32-libva-vdpau-driver-0.7.4-6-x86_64 downloading...
lib32-libvdpau-1.4-2-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing xf86-video-ati...
installing xf86-video-amdgpu...
installing xf86-video-intel...
>>> This driver now uses DRI3 as the default Direct Rendering
Infrastructure. You can try falling back to DRI2 if you run
into trouble. To do so, save a file with the following
content as /etc/X11/xorg.conf.d/20-intel.conf :
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "DRI" "2" # DRI3 is now default
#Option "AccelMethod" "sna" # default
#Option "AccelMethod" "uxa" # fallback
EndSection
Optional dependencies for xf86-video-intel
libxrandr: for intel-virtual-output [installed]
libxinerama: for intel-virtual-output [installed]
libxcursor: for intel-virtual-output [installed]
libxtst: for intel-virtual-output [installed]
libxss: for intel-virtual-output [installed]
installing xf86-video-nouveau...
installing vulkan-intel...
Optional dependencies for vulkan-intel
vulkan-mesa-layers: additional vulkan layers
installing vulkan-radeon...
Optional dependencies for vulkan-radeon
installing libva-mesa-driver...
installing libva-vdpau-driver...
installing mesa-vdpau...
installing lib32-vulkan-intel...
Optional dependencies for lib32-vulkan-intel
lib32-vulkan-mesa-layers: additional vulkan layers
installing lib32-vulkan-radeon...
Optional dependencies for lib32-vulkan-radeon
installing lib32-libvdpau...
installing lib32-libva-vdpau-driver...
installing lib32-mesa-vdpau...
xf86-video-ati: install reason has been set to 'explicitly installed'
xf86-video-amdgpu: install reason has been set to 'explicitly installed'
xf86-video-intel: install reason has been set to 'explicitly installed'
xf86-video-nouveau: install reason has been set to 'explicitly installed'
vulkan-intel: install reason has been set to 'explicitly installed'
vulkan-radeon: install reason has been set to 'explicitly installed'
libva-mesa-driver: install reason has been set to 'explicitly installed'
libva-vdpau-driver: install reason has been set to 'explicitly installed'
mesa-vdpau: install reason has been set to 'explicitly installed'
lib32-vulkan-intel: install reason has been set to 'explicitly installed'
lib32-vulkan-radeon: install reason has been set to 'explicitly installed'
lib32-libva-vdpau-driver: install reason has been set to 'explicitly installed'
lib32-mesa-vdpau: install reason has been set to 'explicitly installed'
> Successfully installed video-linux
I rebooted, then maybe it was a blip but I got a black screen when grub should have come up, rebooted again, grub reappeared, and no change from previous situation, black screen.
In that case, let’s check the logs. In a terminal, run and provide the output of:
journalctl --boot --priority=3
Mar 27 13:57:43 gregoire-x58aud3r kernel: sd 6:0:0:0: [sde] No Caching mode page found
Mar 27 13:57:43 gregoire-x58aud3r kernel: sd 6:0:0:0: [sde] Assuming drive cache: write through
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: Failed to start Light Display Manager.
Now about lightdm specifically:
journalctl --boot --unit=lightdm
Mar 27 13:57:44 gregoire-x58aud3r systemd[1]: Starting Light Display Manager...
Mar 27 13:57:44 gregoire-x58aud3r systemd[1]: Started Light Display Manager.
Mar 27 13:57:44 gregoire-x58aud3r systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Mar 27 13:57:44 gregoire-x58aud3r systemd[1]: lightdm.service: Failed with result 'exit-code'.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: Stopped Light Display Manager.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: Starting Light Display Manager...
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: Started Light Display Manager.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: lightdm.service: Failed with result 'exit-code'.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
Mar 27 13:57:45 gregoire-x58aud3r systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: Stopped Light Display Manager.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: Starting Light Display Manager...
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: Started Light Display Manager.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: lightdm.service: Failed with result 'exit-code'.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Mar 27 13:57:46 gregoire-x58aud3r systemd[1]: lightdm.service: Start request repeated too quickly.
Can you try putting those files back?
Or else, try reinstalling lightdm:
pamac reinstall lightdm
Reinstalled it, rebooted, no change.
Preparing...
Warning: lightdm-1:1.30.0-4 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To reinstall (1):
lightdm 1:1.30.0-4 extra 223.5 kB
Total download size: 223.5 kB
Apply transaction ? [y/N] y
Download of lightdm (1:1.30.0-4) started
Download of lightdm (1:1.30.0-4) finished
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Reinstalling lightdm (1:1.30.0-4)... [1/1]
Creating system user accounts... [1/6]
Reloading system manager configuration... [2/6]
Creating temporary files... [3/6]
Arming ConditionNeedsUpdate... [4/6]
Reloading system bus configuration... [5/6]
Checking which packages need to be rebuilt [6/6]
foreign chm2pdf-python3
foreign python-casttube
foreign python-proton-client
foreign python-pychromecast6
foreign python-sphinxcontrib-programoutput
foreign python-vdf
I put the files back, lightdm does not start after grub, and also I cant start lightdm from one of the ctrl alt f+number terminal but sway works (sort of).
Well, I honestly have no idea further then, except possibly forcing to overwrite conflicts on reinstall:
pamac reinstall --overwrite lightdm
that command is not working for me
Reinstall packages
pamac reinstall <package(s),group(s)>
options:
--overwrite <glob> : overwrite conflicting files, multiple patterns can be specified by separating them with a comma
--download-only, -w : download all packages but do not install/upgrade anything
--as-deps : mark all packages installed as a dependency
--as-explicit : mark all packages explicitly installed
--no-confirm : bypass any and all confirmation messages
Hmmm, the only other thing I can think of is:
pamac reinstall lightdm --overwrite /etc/*
If that doesn’t work, I have NO idea further.
