Ideally I would like to have 5.4 as it is listed as recommended but I started with the wrong feet and now the only kernel version that works when I select it from GRUB is 5.8. If 5.4 is not possible to work for me, how can I upgrade to 5.10?
All the other kernels I select from GRUB produce black screen. In this black screen, when I press Ctrl-Alt-Del it shows something like this for a fraction of second:
watchdoc0: watchdog did not stop
rebooting system
Then the system reboots.
I did not want to change the kernel initially but I have to since I get this window when doing an update to the latest stable update of Manjaro (31 dec 2020) and I cannot start the update:
Translated:
The dependencies can not be satisfied:
Removal of linux58-nvidia-440xx affects dependency ‘linux58-nvidia-440xx’ which is necessary
If possible, remove linux-latest-nvidia-440xx and retry
I would like to keep everything stable. What should be my reaction to this window?
Do you still have installed a kernel and video driver for it that work together well? Then you can press the Shift key repeatedly at the startup of the system and then in the menu there is a submenu that shows that kernel too as an option. You can boot with that kernel and then you can do any changes you need to your installed drivers list within that boot. HTH and Happy New Year!
