Hello
i downloaded the iso and checked the SHA1
the issue is that after trying to make the bootable usb both with Rufus and etcher,
all i get is a single folder on the usb named EFI with a single file in a sub-directory ‘Boot’ named bootx64.efi.
the whole usb appears to windos as 3.97 mb in size while it’s a 16GB one,
the size of the file mentioned above is 148kb.
it seems similar to the issue mentioned in this thread:
forum. manjaro. org/t/problems-creating-bootable-usbs-for-testing/27318
could it be that it’s just invisible to windows since it in EXT now?
as far as i can remember from other installations i should have in the usb a few visible folders:
boot,EFI,manjaro,[BOOT]
and a few files:
.miso
boot.catalog
efi.img
(i can see them in 7zip)
any ideas?
EDIT:
tried with two different usb sticks.
