Issue with booting iso
Hello team,
I made a bootable USB with the latest manjaro plasma iso, which gets stuck on loading screen.
Steps to reproduce:
  • Made bootable USB drive with Balena Etcher
  • Restart PC with USB connected
  • On manjaro booting screen, selected “Boot with open source drivers”
  • PC gets stuck on black screen with HP logo and Manjaro logo under it. Unfortunately I can’t attach the picture of this screen it gets stuck, on post I get error
    “An error occurred: Sorry, you can’t embed media items in a post.”
Also tried creating a virtual machine on virtual box with the same iso but I get failure error.
Attempted downloading via torrent and directly on browser.
Could you please assist? I really would like to install Manjaro plasma on my machine.
~$ inxi -Fxz
  Kernel: 5.4.0-137-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
  Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
  Type: Laptop System: HP product: HP Laptop 15-bs1xx v: Type1ProductConfigId
  serial: <filter>
  Mobo: HP model: 8444 v: 67.27 serial: <filter> UEFI: Insyde v: F.42
  date: 08/06/2018
  ID-1: BAT1 charge: 5.9 Wh condition: 6.0/31.1 Wh (19%)
  model: COMPAL PABAS0241231 status: Unknown
  Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
  arch: Broadwell rev: 4 L2 cache: 3072 KiB
  bogomips: 15963
  Speed: 798 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 799 2: 798 3: 798
  4: 798
  Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.13 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.6
  direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:03.0
  Device-2: Intel Wildcat Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.4.0-137-generic
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 07:00.0
  Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard
  driver: rtw_pci v: N/A port: 3000 bus ID: 0d:00.0
  Device-3: Realtek 802.11n WLAN Adapter type: USB driver: btusb bus ID: 1-4:2
  IF-ID-1: docker0 state: down mac: <filter>
  Local Storage: total: 223.57 GiB used: 141.14 GiB (63.1%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
  temp: 26 C
  ID-1: / size: 218.51 GiB used: 141.14 GiB (64.6%) fs: ext4 dev: /dev/sda2
  System Temperatures: cpu: 37.5 C mobo: N/A
  Processes: 204 Uptime: 7m Memory: 3.75 GiB used: 1.55 GiB (41.3%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
  inxi: 3.0.38
Thanks in advance
secure boot disabled in bios;
fast boot disabled in bios - you may not have this option;
fast startup disabled in windows, if you are dual booting;
RAID disabled, and AHCI enabled - if you are using windows and you are on RAID, dont switch to AHCI, otherwise you will not be able to boot into windows…
use Ventoy to flash iso…
and provide some basic specs: what cpu and gpu are you using
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
Done, please let me know if you need some more info.
Is there any way to make it work?
Which version of Manjaro are you using ?
Try using dd to write the official ISO to the USB instead of Programs to create an ISO from files…
Get the following when checking checksum
$ sha1sum -c manjaro-kde-22.0.3-230213-linux61.iso.sha512
sha1sum: manjaro-kde-22.0.3-230213-linux61.iso.sha512: no properly formatted SHA1 checksum lines found
It looks like you checked the checksum file instead of the .iso
Check the .iso file and compare the checksum you get with that published on the web site.
… and use the correct digest …
man sha1sum
sha1sum - compute and check SHA1 message digest
man sha512sum
sha512sum - compute and check SHA512 message digest
Can you try to use a older iso KDE 21.3.7: Manjaro Linux - Browse /kde at SourceForge.net
You are trying to check a sha512 checksum with a program to check sha1 checksums :woman_facepalming:
So try to use the correct util like @Nachlese pointed out :wink:
sha512sum -c ....
Keep in mind that both the *.iso.sha512 text file and the ISO file itself need to be in same directory as you execute those commands…
Tried with version 21.3.7 and it works. Manage to boot with bootable usb.
Q: Does that mean my pc will break if I eventually update it to version 22?
No, the system will not break.
You only need to update the system.
