I got this while updating with pamac:
Erneuere pamac-cli (9.5.10-2 -> 9.5.12-1)...
Erneuere pamac-gtk (9.5.10-2 -> 9.5.12-1)...
Installiere web-installer-url-handler (1.0.2-1)...
Konfiguriere web-installer-url-handler...
touch: '/.config/mimeapps.list' kann nicht berührt werden: Datei oder Verzeichnis nicht gefunden
/usr/bin/xdg-mime: Zeile 873: /.config/mimeapps.list.new: Datei oder Verzeichnis nicht gefunden
So it can’t touch mimeapps.list and then fails to access mimeapps.list.new.
Now the questions are:
- Do I need
web-installer-url-handler or is that an obsolete package?
- Shouldn’t it be
~/.config/mimeapps.list and ~/.config/mimeapps.list.new?
- How do I fix this now manually after the update?
Any help regarding the web-installer-url-handler please?
manjaro-hello and software-center-web-jak depend on web-installer-url-handler. What about it?
Oh, sorry I didn’t look at the error very closely earlier.
What happens if you run:
xdg-mime default web-installer-url-handler.desktop x-scheme-handler/web-pamac
The good thing is that there is no error:
$ xdg-mime default web-installer-url-handler.desktop x-scheme-handler/web-pamac
On the other hand if manjaro-hello really is just a helper application for newcomers I also just may remove it from my system. I mean I launched it the other day to see what it was and I hadn’t seen it before that. So I may as well be happy without it… No idea…
I’m a bit reluctant to uninstalling something as I never know if that also uninstalls something I may need at one point or is required already despite it not being marked as a dependency (I’ve seen things…).
