Issue appeared again, fails to upgrade to new kernel using pacman -Syu or GUI updater
Hello,
I reported an issue a few weeks ago.
The thread is now closed.
The workaround suggested by Aragorn worked then.
But the issue came back trying to upgrade 6.1.53 to 6.1.55.
I repeated the instruction give in the topic mentioned above, but this time it did not fix the issue.
Performing the kernel upgrade by pacman -Syu leads me into rescue console after reboot.
The only fix is to use:
pacman -U /var/cache/pacman/pkg/[laster kernel installed]
pacman -U /var/cache/pacman/pkg/[laster kernel header installed]
Thanks and best regards
Kitsab
can you please return
inxi -Fza
sudo mhwd-kernel -li
sudo mhwd -li
ls /etc/mkinitcpio.d/*.preset
ls /lib/modules/
Hello,
inxi -Fza:
  Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=97b6c723-cf01-4b6e-986c-4bf634f8675f rw quiet splash apparmor=1
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010
    serial: <superuser required>
  Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <superuser required>
    UEFI: HUAWEI v: 2.26 date: 05/13/2022
  ID-1: BATT charge: 83.2 Wh (96.3%) condition: 86.4/83.1 Wh (104.0%)
    volts: 12.9 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
    serial: <filter> status: full cycles: 100
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1983 high: 3200 min/max: 1200/4462 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 3200
    3: 3200 4: 1913 5: 1200 6: 1352 7: 1200 8: 1200 9: 1200 10: 3200 11: 2870
    12: 3200 13: 1200 14: 1200 15: 1200 16: 3200 bogomips: 102251
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Wingtech driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 44.0 C
  Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:5476
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x092f serial: <filter> built: 2021
    res: 2520x1680 dpi: 189 gamma: 1.2 size: 338x226mm (13.31x8.9")
    diag: 407mm (16") ratio: 3:2 modes: max: 2520x1680 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.49 6.1.53-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :0.0
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Wingtech
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Wingtech
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Wingtech
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 214.67 GiB (45.0%)
    model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 11120000 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 374.33 GiB size: 367.39 GiB (98.15%)
    used: 214.59 GiB (58.4%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
    used: 81.9 MiB (16.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 340 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 53.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (rpm): N/A
  Processes: 380 Uptime: 3m wakeups: 238 Memory: total: 16 GiB note: est.
  available: 14.98 GiB used: 2.25 GiB (15.0%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1423 libs: 373 tools: gnome-software,pamac,yaourt
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.30
Currently running: 6.1.53-1-MANJARO (linux61)
   * linux61
sudo mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
Warning: No installed USB configs
/etc/mkinitcpio.d/linux61.preset
ls /lib/modules/
6.1.53-1-MANJARO  extramodules-6.1-MANJARO
Thanks
Kitsab
you can add
sudo mhwd-kernel -i linux65
sudo pacman -S linux65-headers linux61-headers
see this to see Grub on boot
check if you can boot with linux65
Hello,
after installing kernel 6.5 by mhwd-kernel -i linux65 and pacman -S linux65-headers linux61-headers
The kernel is not able to boot, displaying the error: β€œ/vmlinuz-6.5-x86_x64” not found - Error: You must load the kernel at fist.
I managed to boot the system using Manjaro extended boot options and booting the last installed kernel.
I checked grub.cfg and /boot/efi
The file exists in boot efi folder, as well as the file from bootable kernel 6.1.5.3
The file ist correctly configured in grub.cfg as well as boot file for kernel 6.1.5.3
I also tried to use grub-update, but not affecting the kernel 6.5 vmlinuz missing issue.
grub.cfg kernel 6.5
        savedefault
        load_video
        set gfxpayload=keep
        insmod gzio
        insmod part_gpt
        insmod ext2
        search --no-floppy --fs-uuid --set=root 938c3df0-6625-4def-8d13-52998f7d88f7
        linux   /vmlinuz-6.5-x86_64 root=UUID=97b6c723-cf01-4b6e-986c-4bf634f8675f rw  quiet splash apparmor=1 security=apparmor u>
        initrd  /amd-ucode.img /initramfs-6.5-x86_64.img
grub.cfg kernel 6.1:
               load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
                linux   /vmlinuz-6.1-x86_64 root=UUID=97b6c723-cf01-4b6e-986c-4bf634f8675f rw  quiet splash apparmor=1 security=ap>
                initrd  /initramfs-6.1-x86_64-fallback.img
is there a way to fix this, I don’t understand why 6.1.5.3 is found and 6.5 is not found.
ls -la /boot:
drwxr-xr-x  7 root root     4096 13. Okt 00:39 .
drwxr-xr-x 17 root root     4096  4. Okt 20:51 ..
-rw-r--r--  1 root root    51200 20. Jan 2023  amd-ucode.img
drwx------  5 root root     4096  1. Jan 1970  efi
drwxr-xr-x  7 root root     4096 13. Okt 00:39 grub
-rw-------  1 root root 41902726 13. Okt 00:24 initramfs-6.1-x86_64-fallback.img
-rw-------  1 root root 15367584 13. Okt 00:24 initramfs-6.1-x86_64.img
-rw-------  1 root root 44639701 13. Okt 00:39 initramfs-6.5-x86_64-fallback.img
-rw-------  1 root root 15529574 13. Okt 00:39 initramfs-6.5-x86_64.img
-rw-r--r--  1 root root       21 13. Sep 14:00 linux61-x86_64.kver
-rw-r--r--  1 root root       20 23. Sep 12:24 linux65-x86_64.kver
drwx------  2 root root    16384 22. Feb 2023  lost+found
drwxr-xr-x  2 root root     4096 13. Feb 2023  memtest86+
drwxr-xr-x  2 root root     4096  4. Okt 20:52 syslinux
-rw-r--r--  1 root root 11525312 13. Okt 00:24 vmlinuz-6.1-x86_64
-rw-r--r--  1 root root 12828320 13. Okt 00:39 vmlinuz-6.5-x86_64
mount |grep boot:
 οŒ’ ξ‚° ο€£ /boot ξ‚° mount |grep boot        ξ‚² βœ”
/dev/nvme0n1p5 on /boot type ext4 (rw,noatime)
/dev/nvme0n1p4 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
blkid |grep …
/dev/nvme0n1p4: UUID="8DA1-7455" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="79ded0ad-b700-4f93-ad5f-03e9cf1b0e4a"
/dev/nvme0n1p5: UUID="938c3df0-6625-4def-8d13-52998f7d88f7" BLOCK_SIZE="4096" TYPE="ext4" PTTYPE="dos" PARTUUID="d741ad5b-cea1-457a-9014-cd25b169e90b"
Thanks for your support.
Best regards
Kitsab
have you installed other DE linux ?
is there another disk or partition with flag boot or esp ?
on boot screen grub , UUID are same from your files reports ?
redo a grub restaure
boot on USB iso manjaro
inxi -Fza
sudo blkid -fs
sudo parted -l
sudo manjaro-chroot -a
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose
efibootmgr -v
mkinitcpio -P
sync
exit
EDIT: Read next post first please, maybe this is obsolete
Hello,
I have installed 2 OSes Windows 10 and Manjaro, no other linux distro because Manjaro is the best :slight_smile:
Yes the Windows Partition got a boot flag bot EFI Boot is configured to use the grub boot partition.
Yes I checked UUIDs and they are matching grub.cfg entries.
*on the end of the last command there is an error pointing out kernel 6.5 does not exist …
** After reboot into the grub main entry was configured to boot kernel 6.1.53-1
uname -a:
Linux Mate16 6.1.53-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Sep 13 14:10:57 UTC 2023 x86_64 GNU/Linux
inxi -Fza:
  Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2204 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=nonfree
    nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010 serial: <filter>
  Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <filter>
  ID-1: BATT charge: 86.7 Wh (100.0%) condition: 86.7/83.1 Wh (104.3%)
    volts: 13.1 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
  Speed (MHz): avg: 1450 high: 3200 min/max: 1200/4462 boost: enabled
    base/boost: 3200/4450 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 1200 4: 1200
    5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 3200 11: 1200 12: 3200
    13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 102248
    class-ID: 0300 temp: 41.0 C
  Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-3:2
    chip-ID: 13d3:5476 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2520x1680 s-dpi: 96 s-size: 666x444mm (26.22x17.48")
    s-diag: 800mm (31.51")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x092f serial: <filter>
    built: 2021 res: 2520x1680 hz: 60 dpi: 189 gamma: 1.2
    size: 338x226mm (13.31x8.9") diag: 407mm (16") ratio: 3:2 modes:
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo
    missing.
    class-ID: 0403
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
    class-ID: 0403
  Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Local Storage: total: 535.53 GiB used: 0 KiB (0.0%)
    rev: 11120000 temp: 31.9 C scheme: GPT
  SMART: yes health: PASSED on: 21d 21h cycles: 1,367
    read-units: 20,052,565 [10.2 TB] written-units: 14,581,210 [7.46 TB]
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: ASolid model: USB
    size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> scheme: MBR
  Message: No partition data found.
  System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Processes: 344 Uptime: 7m wakeups: 656 Memory: 14.99 GiB
  used: 2.41 GiB (16.1%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1144 libs: 317 tools: pamac pm: flatpak pkgs: 0 Shell: Bash (su)
  v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.25
blkid:
/dev/nvme0n1p9: UUID="938c3df0-6625-4def-8d13-52998f7d88f7" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="8ec1e6bb-8fc4-4615-9bf3-4380d116c6f8"
/dev/nvme0n1p11: LABEL="Onekey" BLOCK_SIZE="512" UUID="D6589C1D589BFB07" TYPE="ntfs" PARTUUID="2521c89e-c35c-4b37-a417-c5b6b6bf17c6"
/dev/nvme0n1p7: UUID="a6c3fee3-eab2-480f-b6fc-6a70baa6d41c" TYPE="swap" PARTUUID="cb5a8ec8-bdc6-8e44-af57-99b4b6e7b2b2"
/dev/nvme0n1p3: LABEL="Windows" BLOCK_SIZE="512" UUID="F8AA9971AA992D5E" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2ee7fc4e-34c0-4480-a0d5-bb36e6aeccaa"
/dev/nvme0n1p1: LABEL_FATBOOT="SYSTEM" LABEL="SYSTEM" UUID="6E98-9E43" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="f82d5fca-ad08-4bb1-9f58-534f22720d6c"
/dev/nvme0n1p10: LABEL_FATBOOT="WINPE" LABEL="WINPE" UUID="C099-E722" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="edf4a0b4-0d40-43ac-a09c-5bef1771b9df"
/dev/nvme0n1p6: LABEL="Manjaro" UUID="97b6c723-cf01-4b6e-986c-4bf634f8675f" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="d9377f31-5e66-f54e-bf45-33895b1a7b72"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="5fa5f308-f8a2-4c0b-9538-d8dc50eee515"
parted -l:
 1      1049kB  211MB   210MB   fat32           EFI system partition          boot, esp
 2      211MB   228MB   16.8MB                  Microsoft reserved partition  msftres
10      228MB   764MB   537MB   fat32                                         msftdata
11      764MB   20.1GB  19.3GB  ntfs                                          msftdata
 4      20.1GB  20.6GB  537MB   fat32                                         msftdata
 5      20.6GB  21.2GB  537MB   ext4
 9      21.2GB  21.7GB  537MB   ext4
 3      21.7GB  92.4GB  70.6GB  ntfs            Basic data partition          msftdata
 6      92.4GB  494GB   402GB   ext4
 7      494GB   512GB   17.8GB  linux-swap(v1)                                swap
manjaro-chroot -a:
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p6]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: mount point does not exist.
       dmesg(1) may have more information after failed mount system call.
 --> mount: [/mnt/boot]
checked /etc/fstab to find efi mountpoint UUID
mount /dev/nvme0n1p4 /boot/efi
mount:
/dev/nvme0n1p6 on / type ext4 (rw,relatime)
/dev/nvme0n1p9 on /boot type ext4 (rw,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=7827312k,nr_inodes=1956828,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
shm on /dev/shm type tmpfs (rw,nosuid,nodev,relatime,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
tmp on /tmp type tmpfs (rw,nosuid,nodev,inode64)
overlay on /etc/resolv.conf type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off)
/dev/nvme0n1p4 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose:
(output redirected to text file and put from cat grub.txt)
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 2001,0002,2002,2003,0000
Boot0000* EFI Hard Drive (WDC PC SN730 SDBPNTY-512G)	PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-1B-44-8B-48-DD-8F-F0)/HD(4,GPT,79ded0ad-b700-4f93-ad5f-03e9cf1b0e4a,0x256c800,0x100000)RC
Boot0002  Windows Boot Manager	HD(1,GPT,f82d5fca-ad08-4bb1-9f58-534f22720d6c,0x800,0x64000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000000120100000010000000040000007fff0400
Boot0003* EFI USB Device (ASolid  USB)	UsbWwid(24a9,205a,0,5106280)/CDROM(1,0x78400c,0x8000)RC
Boot2001* EFI USB Device	RC
Boot2002* EFI DVD/CDROM	RC
Boot2003* EFI Network	RC
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0001,2001,0002,2002,2003,0000
Boot0001* manjaro	HD(4,GPT,79ded0ad-b700-4f93-ad5f-03e9cf1b0e4a,0x256c800,0x100000)/File(\EFI\manjaro\grubx64.efi)
BootCurrent: 0003
Timeout: 0 seconds
BootCurrent: 0003
Timeout: 0 seconds
efibootmgr -v:
BootCurrent: 0003
Timeout: 0 seconds
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 04 02 / 01 01 06 00 00 00 / 03 17 10 00 01 00 00 00 00 1b 44 8b 48 dd 8f f0 / 04 01 2a 00 04 00 00 00 00 c8 56 02 00 00 00 00 00 00 10 00 00 00 00 00 ad d0 de 79 00 b7 93 4f ad 5f 03 e9 cf 1b 0e 4a 02 02 / 7f ff 04 00
    data: 52 43
      dp: 04 01 2a 00 04 00 00 00 00 c8 56 02 00 00 00 00 00 00 10 00 00 00 00 00 ad d0 de 79 00 b7 93 4f ad 5f 03 e9 cf 1b 0e 4a 02 02 / 04 04 36 00 5c 00 45 00 46 00 49 00 5c 00 6d 00 61 00 6e 00 6a 00 61 00 72 00 6f 00 5c 00 67 00 72 00 75 00 62 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
      dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 40 06 00 00 00 00 00 ca 5f 2d f8 08 ad b1 4b 9f 58 53 4f 22 72 0d 6c 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
    data: 57 49 4e 44 4f 57 53 00 01 00 00 00 88 00 00 00 78 00 00 00 42 00 43 00 44 00 4f 00 42 00 4a 00 45 00 43 00 54 00 3d 00 7b 00 39 00 64 00 65 00 61 00 38 00 36 00 32 00 63 00 2d 00 35 00 63 00 64 00 64 00 2d 00 34 00 65 00 37 00 30 00 2d 00 61 00 63 00 63 00 31 00 2d 00 66 00 33 00 32 00 62 00 33 00 34 00 34 00 64 00 34 00 37 00 39 00 35 00 7d 00 00 00 00 12 01 00 00 00 10 00 00 00 04 00 00 00 7f ff 04 00
      dp: 03 10 1a 00 00 00 a9 24 5a 20 35 00 31 00 30 00 36 00 32 00 38 00 30 00 35 00 / 04 02 18 00 01 00 00 00 0c 40 78 00 00 00 00 00 00 80 00 00 00 00 00 00 / 7f ff 04 00
    data: 52 43
      dp: 7f ff 04 00
    data: 52 43
      dp: 7f ff 04 00
    data: 52 43
      dp: 7f ff 04 00
    data: 52 43
mkinitcpio -P:
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.1.53-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux65.preset: 'default'
  -> -k /boot/vmlinuz-6.5-x86_64 -g /boot/initramfs-6.5-x86_64.img --microcode /boot/amd-ucode.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-6.5-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux65.preset: 'fallback'
  -> -k /boot/vmlinuz-6.5-x86_64 -g /boot/initramfs-6.5-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
Thanks and best regars
Kitsab
Hello,
stephane you suggested to do this:
did you maybe mistype?
After modifiying it to this it wokred in combination with further steps from your next post:
uname -a:
Linux Mate16 6.5.5-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sat Sep 23 12:48:15 UTC 2023 x86_64 GNU/Linux
Kitsab
