Is there a way to switch off kernel 6.9.0? I’m somehow stuck with it now, but I’d like to downgrade.
@skatkov Boot into that Kernel you want to use and then remove linux69
At the GRUB menu, choose “Advanced options for Manjaro Linux”. Choose an earlier kernel, boot up into it, and then remove 6.9.0.
Pump the shift or esc key while booting to show the menu.
You should also remove, ex, 6.7 while you are at it.
Realtime kernels are different than the regular kernel verisons. 6.7 is the current developer release: realtime:start [Wiki]
