I just switched from Linux Mint to Manjaro. However, it feels extremely slow and sluggish. Even opening the file manager sometimes takes a long time.
Please tell me what can I do to speed it up? Also, how do I post system info here? I am running a Ryzen 1700
Check if baloo is the reason by
balooctl check
balooctl disable
nano --backup ~/.config/baloofilerc
balooctl purge
balooctl enable
Alright. I will check. Also, how do I post system information?
Why asking the same question twice when was answered in the provided link? Please read that and do accordingly.
nl.smart:
inxi -F
There are reasons why we actually use
inxi -Fazy
Apologies. I didn’t see the answer given above as it seemed to be an automated reply. I am trying to post system info right now. Thank you.
I can’t seem to post the system information. Is says “Sorry links are not allowed”
Is explained how to use formatted text …
Not a link! Copy an paste the whole output here. Use the symbol </> Preformatted text
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=19d7a8d1-9834-4ea6-a322-f3c22dd25c66 rw quiet apparmor=1
security=apparmor resume=UUID=1d929796-cb4c-4c51-873c-6fa128b0196d
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5602 date: 07/14/2020
Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 4 MiB
bogomips: 95850
Speed: 2995 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz):
1: 2995 2: 1275 3: 1275 4: 1274 5: 1362 6: 1699 7: 1357 8: 1373 9: 1275
10: 1274 11: 1359 12: 1864 13: 1372 14: 1359 15: 2760 16: 1274
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 07:00.0
chip-ID: 10de:1c02 class-ID: 0300
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:2 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3600x1200 s-dpi: 90 s-size: 1016x346mm (40.0x13.6")
s-diag: 1073mm (42.3")
Monitor-1: DVI-D-0 res: 1680x1050 hz: 60 dpi: 90
size: 473x296mm (18.6x11.7") diag: 558mm (22")
Monitor-2: DP-2 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.73 TiB used: 369.3 GiB (13.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000VX007-2AY102
type: HDD rpm: 5425 serial: <filter> rev: CV11 scheme: GPT
ID-1: / raw-size: 251.42 GiB size: 246.41 GiB (98.01%)
used: 28.08 GiB (11.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 510 MiB size: 509 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb4 maj-min: 8:20
ID-3: /home raw-size: 1004.49 GiB size: 987.65 GiB (98.32%)
used: 173.25 GiB (17.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 45.8 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 294 Uptime: 22m wakeups: 0 Memory: 31.35 GiB
used: 1.71 GiB (5.4%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1269 lib: 359 flatpak: 0 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
I would say, same as @Wollie , that you check baloo service.
But seeing your specs, I would also like to recommend that you add a SSD to your machine (NVMe if possible) for the OS. Then you are going to feel quite an improvement.
It was most likely the file indexer. Thank you.
system
Closed
24 August 2021 09:07
14
