Is it possible to make this Ubuntu script for printer work on Manjaro?
Is it possible to make this ubunto script for printer work om Manjaro
#!/bin/bash
#Version 3.3 updated on September 13, 2019
#http://help.ubuntu.ru/wiki/canon_capt
#http://forum.ubuntu.ru/index.php?topic=189049.0
#Translated into English and modified by @hieplpvip
#Check if we are running as root
[ $USER != 'root' ] && exec sudo "$0"
#Current user
LOGIN_USER=$(logname)
[ -z "$LOGIN_USER" ] && LOGIN_USER=$(who | head -1 | awk '{print $1}')
#Load the file containing the path to the desktop
if [ -f ~/.config/user-dirs.dirs ]; then
	source ~/.config/user-dirs.dirs
else
	XDG_DESKTOP_DIR="$HOME/Desktop"
fi
#Driver version
DRIVER_VERSION='2.71-1'
DRIVER_VERSION_COMMON='3.21-1'
#Links to driver packages
declare -A URL_DRIVER=([amd64_common]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-common_3.21-1_amd64.deb' \
[amd64_capt]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-capt_2.71-1_amd64.deb' \
[i386_common]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-common_3.21-1_i386.deb' \
[i386_capt]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-capt_2.71-1_i386.deb')
#Links to autoshutdowntool
declare -A URL_ASDT=([amd64]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/autoshutdowntool_1.00-1_amd64_deb.tar.gz' \
[i386]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/autoshutdowntool_1.00-1_i386_deb.tar.gz')
#ppd files and printer models mapping
declare -A LASERSHOT=([LBP-810]=1120 [LBP1120]=1120 [LBP1210]=1210 \
[LBP2900]=2900 [LBP3000]=3000 [LBP3010]=3050 [LBP3018]=3050 [LBP3050]=3050 \
[LBP3100]=3150 [LBP3108]=3150 [LBP3150]=3150 [LBP3200]=3200 [LBP3210]=3210 \
[LBP3250]=3250 [LBP3300]=3300 [LBP3310]=3310 [LBP3500]=3500 [LBP5000]=5000 \
[LBP5050]=5050 [LBP5100]=5100 [LBP5300]=5300 [LBP6000]=6018 [LBP6018]=6018 \
[LBP6020]=6020 [LBP6020B]=6020 [LBP6200]=6200 [LBP6300n]=6300n [LBP6300]=6300 \
[LBP6310]=6310 [LBP7010C]=7018C [LBP7018C]=7018C [LBP7200C]=7200C [LBP7210C]=7210C \
[LBP9100C]=9100C [LBP9200C]=9200C)
#Sort printer names
NAMESPRINTERS=$(echo "${!LASERSHOT[@]}" | tr ' ' '\n' | sort -n -k1.4)
#Models supported by autoshutdowntool
declare -A ASDT_SUPPORTED_MODELS=([LBP6020]='MTNA002001 MTNA999999' \
[LBP6020B]='MTMA002001 MTMA999999' [LBP6200]='MTPA00001 MTPA99999' \
[LBP6310]='MTLA002001 MTLA999999' [LBP7010C]='MTQA00001 MTQA99999' \
[LBP7018C]='MTRA00001 MTRA99999' [LBP7210C]='MTKA002001 MTKA999999')
#OS architecture
if [ "$(uname -m)" == 'x86_64' ]; then
	ARCH='amd64'
else
	ARCH='i386'
fi
#Determine the init system
if [[ $(ps -p1 | grep systemd) ]]; then
	INIT_SYSTEM='systemd'
else
	INIT_SYSTEM='upstart'
fi
#Move to the current directory
cd "$(dirname "$0")"
function valid_ip() {
	local ip=$1
	local stat=1
	if [[ $ip =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]; then
		ip=($(echo "$ip" | tr '.' ' '))
		[[ ${ip[0]} -le 255 && ${ip[1]} -le 255 && ${ip[2]} -le 255 && ${ip[3]} -le 255 ]]
		stat=$?
	fi
	return $stat
function check_error() {
	if [ $2 -ne 0 ]; then
		case $1 in
			'WGET') echo "Error while downloading file $3"
				[ -n "$3" ] && [ -f "$3" ] && rm "$3";;
			'PACKAGE') echo "Error installing package $3";;
			*) echo 'Error';;
		esac
		echo 'Press any key to exit'
		read -s -n1
		exit 1
	fi
function canon_unistall() {
	if [ -f /usr/sbin/ccpdadmin ]; then
		installed_model=$(ccpdadmin | grep LBP | awk '{print $3}')
		if [ -n "$installed_model" ]; then
			echo "Found printer $installed_model"
			echo "Closing captstatusui"
			killall captstatusui 2> /dev/null
			echo 'Stopping ccpd'
			service ccpd stop
			echo 'Removing the printer from the ccpd daemon configuration file'
			ccpdadmin -x $installed_model
			echo 'Removing the printer from CUPS'
			lpadmin -x $installed_model
		fi
	fi
	echo 'Removing driver packages'
	dpkg --purge cndrvcups-capt
	dpkg --purge cndrvcups-common
	echo 'Removing unused libraries and packages'
	apt-get -y autoremove
	echo 'Deleting settings'
	[ -f /etc/init/ccpd-start.conf ] && rm /etc/init/ccpd-start.conf
	[ -f /etc/udev/rules.d/85-canon-capt.rules ] && rm /etc/udev/rules.d/85-canon-capt.rules
	[ -f "${XDG_DESKTOP_DIR}/captstatusui.desktop" ] && rm "${XDG_DESKTOP_DIR}/captstatusui.desktop"
	[ -f /usr/bin/autoshutdowntool ] && rm /usr/bin/autoshutdowntool
	[ $INIT_SYSTEM == 'systemd' ] && update-rc.d -f ccpd remove
	echo 'Uninstall completed'
	read -s -n1
	return 0
function canon_install() {
	echo
	PS3='Please choose your priter: '
	select NAMEPRINTER in $NAMESPRINTERS
	do
		[ -n "$NAMEPRINTER" ] && break
	done
	echo "Selected printer: $NAMEPRINTER"
	echo
	PS3='How is the printer connected to the computer: '
	select CONECTION in 'Via USB' 'Through network (LAN, NET)'
	do
		if [ "$REPLY" == "1" ]; then
			CONECTION="usb"
			while true
			do
				#Looking for a device connected to the USB port
				NODE_DEVICE=$(ls -1t /dev/usb/lp* 2> /dev/null | head -1)
				if [ -n "$NODE_DEVICE" ]; then
					#Find the serial number of that device
					PRINTER_SERIAL=$(udevadm info --attribute-walk --name=$NODE_DEVICE | sed '/./{H;$!d;};x;/ATTRS{product}=="Canon CAPT USB \(Device\|Printer\)"/!d;' | awk -F'==' '/ATTRS{serial}/{print $2}')
					#If the serial number is found, that device is a Canon printer
					[ -n "$PRINTER_SERIAL" ] && break
				fi
				echo -ne "Turn on the printer and plug in USB cable\r"
				sleep 2
			done
			PATH_DEVICE="/dev/canon$NAMEPRINTER"
			break
		elif [ "$REPLY" == "2" ]; then
			CONECTION="lan"
			read -p 'Enter the IP address of the printer: ' IP_ADDRES
			until valid_ip "$IP_ADDRES"
			do
				echo 'Invalid IP address format, enter four decimal numbers'
				echo -n 'from 0 to 255, separated by dots: '
				read IP_ADDRES
			done
			PATH_DEVICE="net:$IP_ADDRES"
			echo 'Turn on the printer and press any key'
			read -s -n1
			sleep 5
			break
		fi
	done
	echo '************Driver Installation************'
	COMMON_FILE=cndrvcups-common_${DRIVER_VERSION_COMMON}_${ARCH}.deb
	CAPT_FILE=cndrvcups-capt_${DRIVER_VERSION}_${ARCH}.deb
	if [ ! -f $COMMON_FILE ]; then
		sudo -u $LOGIN_USER wget -O $COMMON_FILE ${URL_DRIVER[${ARCH}_common]}
		check_error WGET $? $COMMON_FILE
	fi
	if [ ! -f $CAPT_FILE ]; then
		sudo -u $LOGIN_USER wget -O $CAPT_FILE ${URL_DRIVER[${ARCH}_capt]}
		check_error WGET $? $CAPT_FILE
	fi
	apt-get -y update
	apt-get -y install libglade2-0 libcanberra-gtk-module
	check_error PACKAGE $?
	echo 'Installing common module for CUPS driver'
	dpkg -i $COMMON_FILE
	check_error PACKAGE $? $COMMON_FILE
	echo 'Installing CAPT Printer Driver Module'
	dpkg -i $CAPT_FILE
	check_error PACKAGE $? $CAPT_FILE
	#Replace /etc/init.d/ccpd
	echo '#!/bin/bash
# startup script for Canon Printer Daemon for CUPS (ccpd)
### BEGIN INIT INFO
# Provides:          ccpd
# Required-Start:    $local_fs $remote_fs $syslog $network $named
# Should-Start:      $ALL
# Required-Stop:     $syslog $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Description:       Start Canon Printer Daemon for CUPS
### END INIT INFO
# If the CUPS print server is not running, wait until it starts
if [ `ps awx | grep cupsd | grep -v grep | wc -l` -eq 0 ]; then
	while [ `ps awx | grep cupsd | grep -v grep | wc -l` -eq 0 ]
	do
		sleep 3
	done
	sleep 5
fi
ccpd_start ()
	echo -n "Starting ${DAEMON}: "
	start-stop-daemon --start --quiet --oknodo --exec ${DAEMON}
ccpd_stop ()
	echo -n "Shutting down ${DAEMON}: "
	start-stop-daemon --stop --quiet --oknodo --retry TERM/30/KILL/5 --exec ${DAEMON}
DAEMON=/usr/sbin/ccpd
case $1 in
	start)
		ccpd_start
	stop)
		ccpd_stop
	status)
		echo "${DAEMON}:" $(pidof ${DAEMON})
	restart)
		while true
		do
			ccpd_stop
			ccpd_start
			# if the ccpd process does not appear after 5 seconds, we restart it again
			for (( i = 1 ; i <= 5 ; i++ ))
			do
				sleep 1
				set -- $(pidof ${DAEMON})
				[ -n "$1" -a -n "$2" ] && exit 0
			done
		done
		echo "Usage: ccpd {start|stop|status|restart}"
		exit 1
esac
exit 0' > /etc/init.d/ccpd
	#Installation utilities for managing AppArmor
	apt-get -y install apparmor-utils
	#Set AppArmor security profile for cupsd to complain mode
	aa-complain /usr/sbin/cupsd
	echo 'Restarting CUPS'
	service cups restart
	if [ $ARCH == 'amd64' ]; then
		echo 'Installing 32-bit libraries required to run 64-bit printer driver'
		apt-get -y install libatk1.0-0:i386 libcairo2:i386 libgtk2.0-0:i386 libpango1.0-0:i386 libstdc++6:i386 libpopt0:i386 libxml2:i386 libc6:i386
	fi
	echo 'Installing the printer in CUPS'
	/usr/sbin/lpadmin -p $NAMEPRINTER -P /usr/share/cups/model/CNCUPSLBP${LASERSHOT[$NAMEPRINTER]}CAPTK.ppd -v ccp://localhost:59687 -E
	echo "Setting $NAMEPRINTER as the default printer"
	/usr/sbin/lpadmin -d $NAMEPRINTER
	echo 'Registering the printer in the ccpd daemon configuration file'
	/usr/sbin/ccpdadmin -p $NAMEPRINTER -o $PATH_DEVICE
	#Verify printer installation
	installed_printer=$(ccpdadmin | grep $NAMEPRINTER | awk '{print $3}')
	if [ -n "$installed_printer" ]; then
		if [ "$CONECTION" == "usb" ]; then
			echo 'Creating a rule for the printer'
			#A rule is created to provides an alternative name (a symbolic link) to our printer so as not to depend on the changing values of lp0, lp1,...
			echo 'KERNEL=="lp[0-9]*", SUBSYSTEMS=="usb", ATTRS{serial}=='$PRINTER_SERIAL', SYMLINK+="canon'$NAMEPRINTER'"' > /etc/udev/rules.d/85-canon-capt.rules
			#Update the rules
			udevadm control --reload-rules
			#Check the created rule
			until [ -e $PATH_DEVICE ]
			do
				echo -ne "Turn off the printer, wait 2 seconds, then turn on the printer\r"
				sleep 2
			done
		fi
		echo -e "\e[2KRunning ccpd"
		service ccpd restart
		#Autoload ccpd
		if [ $INIT_SYSTEM == 'systemd' ]; then
			update-rc.d ccpd defaults
		else
			echo 'description "Canon Printer Daemon for CUPS (ccpd)"
author "LinuxMania <customer@linuxmania.jp>"
start on (started cups and runlevel [2345])
stop on runlevel [016]
expect fork
respawn
exec /usr/sbin/ccpd start' > /etc/init/ccpd-start.conf
		fi
		#Create captstatusui shortcut on desktop
		echo '#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Name='$NAMEPRINTER'
GenericName=Status monitor for Canon CAPT Printer
Exec=captstatusui -P '$NAMEPRINTER'
Terminal=false
Type=Application
Icon=/usr/share/icons/Humanity/devices/48/printer.svg' > "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
		chmod 775 "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
		chown $LOGIN_USER:$LOGIN_USER "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
		#Install autoshutdowntool for supported models
		if [[ "${!ASDT_SUPPORTED_MODELS[@]}" =~ "$NAMEPRINTER" ]]; then
			SERIALRANGE=(${ASDT_SUPPORTED_MODELS[$NAMEPRINTER]})
			SERIALMIN=${SERIALRANGE[0]}
			SERIALMAX=${SERIALRANGE[1]}
			if [[ ${#PRINTER_SERIAL} -eq ${#SERIALMIN} && $PRINTER_SERIAL > $SERIALMIN && $PRINTER_SERIAL < $SERIALMAX || $PRINTER_SERIAL == $SERIALMIN || $PRINTER_SERIAL == $SERIALMAX ]]; then
				echo "Installing the autoshutdowntool utility"
				ASDT_FILE=autoshutdowntool_1.00-1_${ARCH}_deb.tar.gz
				if [ ! -f $ASDT_FILE ]; then
					wget -O $ASDT_FILE ${URL_ASDT[$ARCH]}
					check_error WGET $? $ASDT_FILE
				fi
				tar --gzip --extract --file=$ASDT_FILE --totals --directory=/usr/bin
			fi
		fi
		#Start captstatusui
		if [[ -n "$DISPLAY" ]] ; then
			sudo -u $LOGIN_USER nohup captstatusui -P $NAMEPRINTER > /dev/null 2>&1 &
			sleep 5
		fi
		echo 'Installation completed. Press any key to exit'
		read -s -n1
		exit 0
	else
		echo 'Driver for $NAMEPRINTER is not installed!'
		read -s -n1
		exit 1
	fi
function canon_help {
	clear
	echo 'Installation Notes
If you have already installed driver for this series,
uninstall it before using this script.
If the driver packages are not found, they will be automatically
downloaded from the Internet and saved in the script folder.
To update the driver, first uninstall the old version using this script,
then install a new one.
Notes on printing problems:
If the printer stops printing, run captstatusui via the shortcut
on desktop or from terminal: captstatusui -P <printer_name>
The captstatusui window shows the current status of the printer.
If an error occurs, its description is displayed.
Here you can try pressing button "Resume Job" to continue printing
or "Cancel Job" button to cancel the job.
If this does not help, try running canon_restart.sh
Printer configuration command: cngplp
Additional settings command: captstatusui -P <printer_name>
Turn on auto-off (not for all models): autoshutdowntool
To log the installation process, run the script like this:
logsave log.txt ./canon_lbp_setup.sh
clear
echo 'Installing the Linux CAPT Printer Driver v'${DRIVER_VERSION}' for Canon LBP printers on Ubuntu (both 32-bit and 64-bit)
Supported printers:'
echo "$NAMESPRINTERS" | sed ':a; /$/N; s/\n/, /; ta' | fold -s
PS3='Please enter your choice: '
select opt in 'Install' 'Uninstall' 'Help' 'Exit'
do
	if [ "$opt" == 'Install' ]; then
		canon_install
		break
	elif [ "$opt" == 'Uninstall' ]; then
		canon_unistall
		break
	elif [ "$opt" == 'Help' ]; then
		canon_help
	elif [ "$opt" == 'Exit' ]; then
		break
	fi
done
You’d have to modify already all the apt-get code with equivalent pacman's.
thanks for info
Unfortunately i am not a programmer and for me it look like Alien language, thats why I beging any programmer/Manjaro Guru to help me from MY Big Love Linux Heart to his/her Linux Heart
Problem is you give a script from 2019 that we don’t know the use and purpose, only you have the model of printer this script was destined for, and if you cannot understand the script itself, it would be hard for someone else to troubleshoot it for you in case it doesn’t work as planned.
In 2 years, a lot can change in Linux world, maybe the issue or feature this script was created for has already been brought by a driver or kernel update.
Simplest thing would be to explain exactly what is your issue, what you want to achieve.
You probably have these drivers in AUR - there are some cndrvcups* packages.
this script is to install Canon LBP 6200 Printer on Ubuntu base Os.
Problem is that the driver’s does not exist for Arc / Manjaro
So I think maybe if comvert the script and driver to Arc/Manjaro could read it, maybe it would work. There are i script called (pamac build capt-src in AUR) but is not working for some reason to print, but works fine to install. Cups Fine the Printer and so on but no printing.
Why because the installation suggestion in this does not work.
So this is just my 2 cent of thinking…
The AUR package AUR (en) - capt-src might provide the necessary drivers. However, from the comments, you can see that they might not work in the future (or even now already?).
Exactly, this is why i am here for begging for help to solve this
The script seems really ancient. It’s easy to change the apt-get calls to pacman but it’s also using init.d for startup and not systemd which will take a lot of time to rewrite.
I guess the AUR package I mentioned already does this.
Interesting you mention this.
So why does is not work??? ( I know impossible to answer for you)
i mean Cups isntall all and all is correct but still nothing if I use AUR package.
Unfortunately, your statement “why does it not work” does not give me enough information.
  1. What exactly is your problem?
  2. What have you tried so far?
Ohh Sorry
in this link you can see some of the steps i did.
But basically i make the ( pamac build capt-src ) and i follow the instruction and i make the install and Manjaro discover the printer and use the driver i just install with Capt-src and put it om USB connection witch is correct.
But when i want to print something Nothing happens.
I see. But why do you open a new topic and don’t continue in your original one? This way, I’m asking the same basic things like the other user.
My though is that topic is specific about the script and not primary installing, even it’s the end goal.
