When I trying to make it - I getting sth like this:
inxi
Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=/dev/nvme0n1p5
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 33.8 Wh (100.0%) condition: 33.8/48.1 Wh (70.3%)
volts: 12.6 min: 11.7 model: FX50442 type: Li-ion serial: N/A status: full
RAM: total: 5.72 GiB used: 5.13 GiB (89.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2065 high: 2769 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2765 2: 2769
3: 1231 4: 1231 5: 2718 6: 2723 7: 1350 8: 1736 bogomips: 33552
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.59-1-MANJARO) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
chip-ID: 10ec:c821 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: outline-tun0 state: down mac: N/A
IP v4: <filter> scope: global
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 942.7 GiB used: 289.5 GiB (30.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Fujitsu model: MJA2500BH G2
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
ID-1: / raw-size: 150 GiB size: 147.34 GiB (98.23%) used: 69.09 GiB (46.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: fb5baf93-430b-40a5-b6b4-ad738ae73226
ID-2: /boot/efi raw-size: 95 MiB size: 93.5 MiB (98.44%) used: 5.2 MiB
(5.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: AB27-C898
ID-3: /run/media/cha0s_f4me/af4fd68f-5479-4e7b-96d2-d5362baa16e6
raw-size: 30 GiB size: 29.36 GiB (97.87%) used: 7.87 GiB (26.8%) fs: ext4
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: af4fd68f-5479-4e7b-96d2-d5362baa16e6
ID-4: /run/media/cha0s_f4me/bb2d2f7b-29b2-4a8f-8d35-67c1eebbb97a
raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 12.1 GiB (12.4%) fs: ext4
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: bb2d2f7b-29b2-4a8f-8d35-67c1eebbb97a
ID-5: /run/media/cha0s_f4me/second_disk raw-size: 465.76 GiB size: 465.76
GiB (100.00%) used: 200.44 GiB (43.0%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: second_disk uuid: C86245836245776A
ID-1: swap-1 type: file size: 10 GiB used: 1.96 GiB (19.6%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 300 MiB fs: vfat label: NO_LABEL
uuid: E82C-FF85
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:20 info: JMicron / USA JM20329 SATA Bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 152d:2329 class-ID: 0806
serial: <filter>
Device-2: 1-4:3 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-2: 3-2:3 info: Logitech USB Receiver type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c547 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 64.6 C mobo: N/A gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): cpu: 3200
Processes: 350 Uptime: 56m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1394 apt: 0 pacman: 1383 lib: 363 flatpak: 0 snap: 11 Shell: Zsh
v: 5.9 running-in: konsole inxi: 3.3.20
