I’m primarily using Linux for work, sometimes gaming. For gaming, I would like to keep my 6600 XT, but for work, it’s sometimes required to have CUDA capability. So I wonder if it’s possible to have both GPUs in my system and switch between them for different tasks.
Thanks in advance for any kind of response!
Edit: inxi -Fazy
output:
Summary
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=41600e73-c3ec-4481-bede-1e252c347923 rw quiet apparmor=1
security=apparmor udev.log_priority=3 amdgpu.runpm=0 pcie_aspm=off
amdgpu.gpu_recovery=1 amdgpu.lockup_timeout=3000
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF B450M-PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2409
date: 12/02/2020
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
status: discharging
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2500 high: 4026 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2075 2: 4026
3: 2054 4: 2195 5: 2200 6: 2304 7: 2200 8: 3597 9: 2200 10: 2200 11: 2200
12: 2758 bogomips: 86269
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 09:00.0 chip-ID: 1002:73ff
class-ID: 0300
Device-2: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 17ef:4831
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: vesa dri: radeonsi gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell P2319H
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell S2319H
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.3.0-devel (git-75990e5564) renderer: AMD Radeon
RX 6600 XT (navi23 LLVM 15.0.7 DRM 3.49 6.1.38-1-MANJARO)
direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
Device-4: Blue Microphones Yeti Nano
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: b58e:0005 class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
chip-ID: 10ec:818b class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-4d194edfcefc state: down mac: <filter>
IF-ID-2: br-933ce09a1c5c state: down mac: <filter>
IF-ID-3: br-a580f76f80b8 state: down mac: <filter>
IF-ID-4: br-cc892718ad0e state: down mac: <filter>
IF-ID-5: br-d45c8f5c6eec state: down mac: <filter>
IF-ID-6: br-eb0905d03f35 state: down mac: <filter>
IF-ID-7: docker0 state: down mac: <filter>
IF-ID-8: virbr0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0b05:190e
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.8 TiB used: 1.03 TiB (57.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV500480G
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 56R6 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD502HJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 436.13 GiB size: 428.21 GiB (98.18%)
used: 364.24 GiB (85.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 386 Uptime: 11h 21m wakeups: 105 Memory: total: 32 GiB
available: 31.26 GiB used: 18.54 GiB (59.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 2467 pm: pacman pkgs: 2444 libs: 544 tools: pamac,yay pm: snap
pkgs: 23 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.28
