this is kind of related to:
Continuing the discussion from Problem with dkms with v4l2loopback-dkms RT kernel manjaro:
I want to use an iphone as webcam with my Manjaro maschine usind Iriunwebcam.
The Iriunwebcam program on my Computer provides this alert
initialization failed
You may want to run
sudo rmmod v4l2loopback; sudo modprobe v4l2loopback
which says:
rmmod: ERROR: Module v4l2loopback is not currently loaded
modprobe: FATAL: Module v4l2loopback not found in directory /lib/modules/5.15.60-1-MANJARO
I can identify a package named v4l2loopback-dkms being installed. Apparently modprobe can not find it. Probably it’s me being inexperienced with kernel modules & how to install/load them.
can somebody push me into the right direction? Do I simply need to cp any of this
$ locate v4l2loopback
/usr/bin/v4l2loopback-ctl
/usr/share/licenses/v4l2loopback
/usr/share/licenses/v4l2loopback/COPYING
/usr/share/man/man1/v4l2loopback-ctl.1.gz
/usr/src/v4l2loopback-0.12.5
/usr/src/v4l2loopback-0.12.5/Makefile
/usr/src/v4l2loopback-0.12.5/dkms.conf
/usr/src/v4l2loopback-0.12.5/v4l2loopback.c
/usr/src/v4l2loopback-0.12.5/v4l2loopback_formats.h
… into the mentioned /lib/modules/5.15.60-1-MANJARO folder?
or build it (if so, would that be a make operation inside /usr/src/v4l2loopback-0.12.5/)?
