Ok so Ive given it a go and I got errors again …
[sudo] password for rob:
error: target not found: pulseaudio-jack
I figured that I would try and find where the pulseaudio-jack file was located by using the “find” and “locate” commands … but I had no luck with that n think my inputs were probable wrong cos as u guessed - Errors
zsh: correct 'locate' to '_locate' [nyae]? y
_arguments:comparguments:327: can only be called from completion function
~ find pulseaudio-jack 1 ✘
find: ‘pulseaudio-jack’: No such file or directory
~ find -pulseaudio-jack 1 ✘
find: unknown predicate `-pulseaudio-jack'
~ find -pulseaudio-jack "query" 1 ✘
~ find /dev -pulseaudio 1 ✘
find: unknown predicate `-pulseaudio'
~ find /dev -pulseaudio -name 1 ✘
~ find -iname "pulseaudio" 1 ✘
~ find -iname "pulseaudio-jack"
Anywho I found a page on these forums that tell u how to locate files How can i locate where is installed a app? … n if I run - pacman -Ql pulseaudio I get
pulseaudio /etc/pulse/
pulseaudio /etc/pulse/daemon.conf
pulseaudio /etc/pulse/default.pa
pulseaudio /etc/pulse/system.pa
pulseaudio /etc/xdg/
pulseaudio /etc/xdg/Xwayland-session.d/
pulseaudio /etc/xdg/Xwayland-session.d/00-pulseaudio-x11
pulseaudio /etc/xdg/autostart/
pulseaudio /etc/xdg/autostart/pulseaudio.desktop
pulseaudio /usr/
pulseaudio /usr/bin/
pulseaudio /usr/bin/pa-info
pulseaudio /usr/bin/pacmd
pulseaudio /usr/bin/pasuspender
pulseaudio /usr/bin/pax11publish
pulseaudio /usr/bin/pulseaudio
pulseaudio /usr/bin/start-pulseaudio-x11
pulseaudio /usr/lib/
pulseaudio /usr/lib/pulse/
pulseaudio /usr/lib/pulse/gsettings-helper
pulseaudio /usr/lib/pulseaudio/
pulseaudio /usr/lib/pulseaudio/libpulsecore-16.0.so
pulseaudio /usr/lib/pulseaudio/modules/
pulseaudio /usr/lib/pulseaudio/modules/libalsa-util.so
pulseaudio /usr/lib/pulseaudio/modules/libcli.so
pulseaudio /usr/lib/pulseaudio/modules/liboss-util.so
pulseaudio /usr/lib/pulseaudio/modules/libprotocol-cli.so
pulseaudio /usr/lib/pulseaudio/modules/libprotocol-http.so
pulseaudio /usr/lib/pulseaudio/modules/libprotocol-native.so
pulseaudio /usr/lib/pulseaudio/modules/libprotocol-simple.so
pulseaudio /usr/lib/pulseaudio/modules/libwebrtc-util.so
pulseaudio /usr/lib/pulseaudio/modules/module-allow-passthrough.so
pulseaudio /usr/lib/pulseaudio/modules/module-alsa-card.so
pulseaudio /usr/lib/pulseaudio/modules/module-alsa-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-alsa-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-always-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-always-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-augment-properties.so
pulseaudio /usr/lib/pulseaudio/modules/module-card-restore.so
pulseaudio /usr/lib/pulseaudio/modules/module-cli-protocol-tcp.so
pulseaudio /usr/lib/pulseaudio/modules/module-cli-protocol-unix.so
pulseaudio /usr/lib/pulseaudio/modules/module-cli.so
pulseaudio /usr/lib/pulseaudio/modules/module-combine-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-combine.so
pulseaudio /usr/lib/pulseaudio/modules/module-console-kit.so
pulseaudio /usr/lib/pulseaudio/modules/module-dbus-protocol.so
pulseaudio /usr/lib/pulseaudio/modules/module-default-device-restore.so
pulseaudio /usr/lib/pulseaudio/modules/module-detect.so
pulseaudio /usr/lib/pulseaudio/modules/module-device-manager.so
pulseaudio /usr/lib/pulseaudio/modules/module-device-restore.so
pulseaudio /usr/lib/pulseaudio/modules/module-echo-cancel.so
pulseaudio /usr/lib/pulseaudio/modules/module-filter-apply.so
pulseaudio /usr/lib/pulseaudio/modules/module-filter-heuristics.so
pulseaudio /usr/lib/pulseaudio/modules/module-gsettings.so
pulseaudio /usr/lib/pulseaudio/modules/module-hal-detect.so
pulseaudio /usr/lib/pulseaudio/modules/module-http-protocol-tcp.so
pulseaudio /usr/lib/pulseaudio/modules/module-http-protocol-unix.so
pulseaudio /usr/lib/pulseaudio/modules/module-intended-roles.so
pulseaudio /usr/lib/pulseaudio/modules/module-ladspa-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-loopback.so
pulseaudio /usr/lib/pulseaudio/modules/module-match.so
pulseaudio /usr/lib/pulseaudio/modules/module-mmkbd-evdev.so
pulseaudio /usr/lib/pulseaudio/modules/module-native-protocol-fd.so
pulseaudio /usr/lib/pulseaudio/modules/module-native-protocol-tcp.so
pulseaudio /usr/lib/pulseaudio/modules/module-native-protocol-unix.so
pulseaudio /usr/lib/pulseaudio/modules/module-null-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-null-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-oss.so
pulseaudio /usr/lib/pulseaudio/modules/module-pipe-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-pipe-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-position-event-sounds.so
pulseaudio /usr/lib/pulseaudio/modules/module-remap-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-remap-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-rescue-streams.so
pulseaudio /usr/lib/pulseaudio/modules/module-role-cork.so
pulseaudio /usr/lib/pulseaudio/modules/module-role-ducking.so
pulseaudio /usr/lib/pulseaudio/modules/module-rygel-media-server.so
pulseaudio /usr/lib/pulseaudio/modules/module-simple-protocol-tcp.so
pulseaudio /usr/lib/pulseaudio/modules/module-simple-protocol-unix.so
pulseaudio /usr/lib/pulseaudio/modules/module-sine-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-sine.so
pulseaudio /usr/lib/pulseaudio/modules/module-stream-restore.so
pulseaudio /usr/lib/pulseaudio/modules/module-suspend-on-idle.so
pulseaudio /usr/lib/pulseaudio/modules/module-switch-on-connect.so
pulseaudio /usr/lib/pulseaudio/modules/module-switch-on-port-available.so
pulseaudio /usr/lib/pulseaudio/modules/module-systemd-login.so
pulseaudio /usr/lib/pulseaudio/modules/module-tunnel-sink-new.so
pulseaudio /usr/lib/pulseaudio/modules/module-tunnel-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-tunnel-source-new.so
pulseaudio /usr/lib/pulseaudio/modules/module-tunnel-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-udev-detect.so
pulseaudio /usr/lib/pulseaudio/modules/module-virtual-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-virtual-source.so
pulseaudio /usr/lib/pulseaudio/modules/module-virtual-surround-sink.so
pulseaudio /usr/lib/pulseaudio/modules/module-volume-restore.so
pulseaudio /usr/lib/pulseaudio/modules/module-x11-bell.so
pulseaudio /usr/lib/pulseaudio/modules/module-x11-cork-request.so
pulseaudio /usr/lib/pulseaudio/modules/module-x11-publish.so
pulseaudio /usr/lib/pulseaudio/modules/module-x11-xsmp.so
pulseaudio /usr/lib/systemd/
pulseaudio /usr/lib/systemd/user/
pulseaudio /usr/lib/systemd/user/pulseaudio-x11.service
pulseaudio /usr/lib/systemd/user/pulseaudio.service
pulseaudio /usr/lib/systemd/user/pulseaudio.socket
pulseaudio /usr/lib/udev/
pulseaudio /usr/lib/udev/rules.d/
pulseaudio /usr/lib/udev/rules.d/90-pulseaudio.rules
pulseaudio /usr/share/
pulseaudio /usr/share/GConf/
pulseaudio /usr/share/GConf/gsettings/
pulseaudio /usr/share/GConf/gsettings/pulseaudio.convert
pulseaudio /usr/share/bash-completion/
pulseaudio /usr/share/bash-completion/completions/
pulseaudio /usr/share/bash-completion/completions/pacmd
pulseaudio /usr/share/bash-completion/completions/pasuspender
pulseaudio /usr/share/glib-2.0/
pulseaudio /usr/share/glib-2.0/schemas/
pulseaudio /usr/share/glib-2.0/schemas/org.freedesktop.pulseaudio.gschema.xml
pulseaudio /usr/share/locale/
pulseaudio /usr/share/locale/af/
pulseaudio /usr/share/locale/af/LC_MESSAGES/
pulseaudio /usr/share/locale/af/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/as/
pulseaudio /usr/share/locale/as/LC_MESSAGES/
pulseaudio /usr/share/locale/as/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/be/
pulseaudio /usr/share/locale/be/LC_MESSAGES/
pulseaudio /usr/share/locale/be/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/bg/
pulseaudio /usr/share/locale/bg/LC_MESSAGES/
pulseaudio /usr/share/locale/bg/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/bn_IN/
pulseaudio /usr/share/locale/bn_IN/LC_MESSAGES/
pulseaudio /usr/share/locale/bn_IN/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ca/
pulseaudio /usr/share/locale/ca/LC_MESSAGES/
pulseaudio /usr/share/locale/ca/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/cs/
pulseaudio /usr/share/locale/cs/LC_MESSAGES/
pulseaudio /usr/share/locale/cs/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/da/
pulseaudio /usr/share/locale/da/LC_MESSAGES/
pulseaudio /usr/share/locale/da/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/de/
pulseaudio /usr/share/locale/de/LC_MESSAGES/
pulseaudio /usr/share/locale/de/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/de_CH/
pulseaudio /usr/share/locale/de_CH/LC_MESSAGES/
pulseaudio /usr/share/locale/de_CH/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/el/
pulseaudio /usr/share/locale/el/LC_MESSAGES/
pulseaudio /usr/share/locale/el/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/eo/
pulseaudio /usr/share/locale/eo/LC_MESSAGES/
pulseaudio /usr/share/locale/eo/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/es/
pulseaudio /usr/share/locale/es/LC_MESSAGES/
pulseaudio /usr/share/locale/es/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/fi/
pulseaudio /usr/share/locale/fi/LC_MESSAGES/
pulseaudio /usr/share/locale/fi/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/fr/
pulseaudio /usr/share/locale/fr/LC_MESSAGES/
pulseaudio /usr/share/locale/fr/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/gl/
pulseaudio /usr/share/locale/gl/LC_MESSAGES/
pulseaudio /usr/share/locale/gl/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/gu/
pulseaudio /usr/share/locale/gu/LC_MESSAGES/
pulseaudio /usr/share/locale/gu/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/he/
pulseaudio /usr/share/locale/he/LC_MESSAGES/
pulseaudio /usr/share/locale/he/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/hi/
pulseaudio /usr/share/locale/hi/LC_MESSAGES/
pulseaudio /usr/share/locale/hi/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/hr/
pulseaudio /usr/share/locale/hr/LC_MESSAGES/
pulseaudio /usr/share/locale/hr/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/hu/
pulseaudio /usr/share/locale/hu/LC_MESSAGES/
pulseaudio /usr/share/locale/hu/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/id/
pulseaudio /usr/share/locale/id/LC_MESSAGES/
pulseaudio /usr/share/locale/id/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/it/
pulseaudio /usr/share/locale/it/LC_MESSAGES/
pulseaudio /usr/share/locale/it/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ja/
pulseaudio /usr/share/locale/ja/LC_MESSAGES/
pulseaudio /usr/share/locale/ja/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ka/
pulseaudio /usr/share/locale/ka/LC_MESSAGES/
pulseaudio /usr/share/locale/ka/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/kk/
pulseaudio /usr/share/locale/kk/LC_MESSAGES/
pulseaudio /usr/share/locale/kk/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/kn/
pulseaudio /usr/share/locale/kn/LC_MESSAGES/
pulseaudio /usr/share/locale/kn/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ko/
pulseaudio /usr/share/locale/ko/LC_MESSAGES/
pulseaudio /usr/share/locale/ko/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/lt/
pulseaudio /usr/share/locale/lt/LC_MESSAGES/
pulseaudio /usr/share/locale/lt/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ml/
pulseaudio /usr/share/locale/ml/LC_MESSAGES/
pulseaudio /usr/share/locale/ml/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/mr/
pulseaudio /usr/share/locale/mr/LC_MESSAGES/
pulseaudio /usr/share/locale/mr/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/nl/
pulseaudio /usr/share/locale/nl/LC_MESSAGES/
pulseaudio /usr/share/locale/nl/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/nn/
pulseaudio /usr/share/locale/nn/LC_MESSAGES/
pulseaudio /usr/share/locale/nn/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/oc/
pulseaudio /usr/share/locale/oc/LC_MESSAGES/
pulseaudio /usr/share/locale/oc/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/or/
pulseaudio /usr/share/locale/or/LC_MESSAGES/
pulseaudio /usr/share/locale/or/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/pa/
pulseaudio /usr/share/locale/pa/LC_MESSAGES/
pulseaudio /usr/share/locale/pa/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/pl/
pulseaudio /usr/share/locale/pl/LC_MESSAGES/
pulseaudio /usr/share/locale/pl/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/pt/
pulseaudio /usr/share/locale/pt/LC_MESSAGES/
pulseaudio /usr/share/locale/pt/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/pt_BR/
pulseaudio /usr/share/locale/pt_BR/LC_MESSAGES/
pulseaudio /usr/share/locale/pt_BR/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ru/
pulseaudio /usr/share/locale/ru/LC_MESSAGES/
pulseaudio /usr/share/locale/ru/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/si/
pulseaudio /usr/share/locale/si/LC_MESSAGES/
pulseaudio /usr/share/locale/si/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/sk/
pulseaudio /usr/share/locale/sk/LC_MESSAGES/
pulseaudio /usr/share/locale/sk/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/sr/
pulseaudio /usr/share/locale/sr/LC_MESSAGES/
pulseaudio /usr/share/locale/sr/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/sr@latin/
pulseaudio /usr/share/locale/sr@latin/LC_MESSAGES/
pulseaudio /usr/share/locale/sr@latin/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/sv/
pulseaudio /usr/share/locale/sv/LC_MESSAGES/
pulseaudio /usr/share/locale/sv/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/ta/
pulseaudio /usr/share/locale/ta/LC_MESSAGES/
pulseaudio /usr/share/locale/ta/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/te/
pulseaudio /usr/share/locale/te/LC_MESSAGES/
pulseaudio /usr/share/locale/te/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/tr/
pulseaudio /usr/share/locale/tr/LC_MESSAGES/
pulseaudio /usr/share/locale/tr/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/uk/
pulseaudio /usr/share/locale/uk/LC_MESSAGES/
pulseaudio /usr/share/locale/uk/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/zh_CN/
pulseaudio /usr/share/locale/zh_CN/LC_MESSAGES/
pulseaudio /usr/share/locale/zh_CN/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/locale/zh_TW/
pulseaudio /usr/share/locale/zh_TW/LC_MESSAGES/
pulseaudio /usr/share/locale/zh_TW/LC_MESSAGES/pulseaudio.mo
pulseaudio /usr/share/man/
pulseaudio /usr/share/man/man1/
pulseaudio /usr/share/man/man1/pacmd.1.gz
pulseaudio /usr/share/man/man1/pasuspender.1.gz
pulseaudio /usr/share/man/man1/pax11publish.1.gz
pulseaudio /usr/share/man/man1/pulseaudio.1.gz
pulseaudio /usr/share/man/man1/start-pulseaudio-x11.1.gz
pulseaudio /usr/share/man/man5/
pulseaudio /usr/share/man/man5/default.pa.5.gz
pulseaudio /usr/share/man/man5/pulse-cli-syntax.5.gz
pulseaudio /usr/share/man/man5/pulse-daemon.conf.5.gz
pulseaudio /usr/share/pulseaudio/
pulseaudio /usr/share/pulseaudio/alsa-mixer/
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic-always.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf.common
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf.common
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-chat.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-mono.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker-always.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-0.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-1.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-10.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-2.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-3.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-4.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-5.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-6.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-7.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-8.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-9.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-input.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-output.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/steelseries-arctis-output-chat-common.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/steelseries-arctis-output-game-common.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-input.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-output-mono.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-output-stereo.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/paths/virtual-surround-7.1.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/audigy.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/cmedia-high-speed-true-hdaudio.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/dell-dock-tb16-usb-audio.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/force-speaker-and-int-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/force-speaker.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/hp-tbt-dock-120w-g2.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/hp-tbt-dock-audio-module.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/kinect-audio.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/maudio-fasttrack-pro.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-audio4dj.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-audio8dj.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-komplete-audio6.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-korecontroller.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio10.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio2.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio6.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktorkontrol-s4.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/sb-omni-surround-5.1.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/sennheiser-gsx.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/simple-headphones-mic.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/steelseries-arctis-common-usb-audio.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/texas-instruments-pcm2902.conf
pulseaudio /usr/share/pulseaudio/alsa-mixer/profile-sets/usb-gaming-headset.conf
But if I run pacman -Ql pulseaudio-jack I get
error: package 'pulseaudio-jack' was not found
So Im a bit stumped again
