[2021-11-26T21:22:08+0000] [ALPM] upgraded pipewire (1:0.3.38-1 -> 1:0.3.40-1)
File: /
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 8,1 Inode: 2 Links: 17
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2022-02-04 00:40:33.431954513 +0000
Modify: 2022-06-15 18:54:53.323085596 +0100
Change: 2022-06-15 18:54:53.323085596 +0100
Birth: 2021-11-17 02:08:36.000000000 +0000
Ill give it a go thx
I’ll second what @banjo said. Go through your pipewire list and remove any aur/git packages. AFAIK it’s a very bad idea to have repo and aur versions of the same package installed on top of each other.
https://arcolinux.com/clean-up-your-computer-and-delete-the-pacman-cache/
Would running the -S and the -U command help? … Or does this link have nothing to do with what were are talking about?
Ill give that a goo too
Thx for your help peeps … I let you know how it goes.
Enjoy your day
first open the add/remove software click installed and foreign and post what you have installed here
or run this command:
pamac list -qm
Hi,
anbox-modules-dkms-git
balena-etcher
breath2-wallpaper
dvbsnoop
gnome-icon-theme
gnome-icon-theme-symbolic
gst-plugins-pulseeffects-legacy-git
lib32-lzo
libkipi
librepfunc
linux513
mingw-w64-tools
pacmixer
playonlinux
python2-wxpython3
spice-guest-tools-windows
ttf-ms-fonts
virtio-win
w_scan_cpp
woeusb
you need to run system update… first remove the 513 kernel:
sudo pacman -R linux513
Ok … old kernel removed
Updated system …
Its saying I gotta reboot, but before I do that … Do I assume the route to take now would be to go back and remove any pipewire aur/git packages as you suggested before?
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ce855673-fe32-42db-ad8d-b31e5de8e913 rw radeon.si_support=1
radeon.cik_support=1 apparmor=1 security=apparmor
resume=UUID=757b5e60-6999-41b8-a9df-8c2136460b4a udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P8H61-M LE/USB3 v: Rev x.0x
serial: <superuser required> BIOS: American Megatrends v: 4601
date: 09/18/2013
Info: model: Intel Core i5-2500 bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1599 high: 1608 min/max: 1600/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1596 3: 1596
4: 1608 bogomips: 26347
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
STIBP: disabled, RSB filling
Device-1: AMD Hawaii PRO [Radeon R9 290/390] driver: radeon v: kernel
alternate: amdgpu arch: GCN 2 process: GF/TSMC 16-28nm built: 2013-17 pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1,DVI-D-2 bus-ID: 01:00.0
chip-ID: 1002:67b1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: LG (GoldStar) 42LF66
serial: <filter> built: 2007 res: 1920x1080 hz: 60 dpi: 49 gamma: 1.2
size: 1000x550mm (39.37x21.65") diag: 802mm (31.6") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD HAWAII (LLVM 13.0.1 DRM 2.50 5.15.46-1-MANJARO)
v: 4.5 Mesa 22.1.1 direct render: Yes
Device-1: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
driver: snd_hda_intel v: kernel bus-ID: 2-1.3:3 pcie: gen: 2
chip-ID: 047f:c056 class-ID: 0300 speed: 5 GT/s serial: <filter> lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aac8
class-ID: 0403
Device-2: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: Plantronics Plantronics Blackwire 3220 Series type: USB
driver: plantronics,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 1-1.1:3 chip-ID: 148f:5370 class-ID: 0000 serial: <filter>
IF: wlp0s26u1u1 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 2-1.6:6 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 2.04 TiB used: 1.51 TiB (74.1%)
ID-1: /dev/sda maj-min: 8:0 model: SATA3 120GB SSD size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 7A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 71E0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-9YN162
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC4H scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-1: / raw-size: 102.99 GiB size: 100.81 GiB (97.89%)
used: 69.26 GiB (68.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 43.0 C mobo: N/A gpu: radeon temp: 64.0 C
Processes: 289 Uptime: 5h 15m wakeups: 0 Memory: 15.59 GiB
used: 3.62 GiB (23.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1751
pacman: 1708 lib: 499 flatpak: 24 snap: 19 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
yes reboot … and you dont have the same aur and official repo packages, so dont need to remove anything
Ok, Thank you
Gotta get my dinner on but will report back to advise what happened.
Thanks again for your time
I wonder why do you need 90% of those packages…doubt you know either. AUR should be locked with password on Manjaro tbh.
Yes that probably is a good idea
On the contrary tho … I do know why at least 50% of them are installed for … Gaming/emulation being the most prevalent … Im learning
What a mess if misinformation.
@GCandy77 you should have done your due diligence and checked why pipewire
package was installed on your system (what other package is requiring it):
$ pactree -r pipewire
This would have told you, kwin
(an essential part of your KDE installation) is requiring pipewire-media-session
and therefor pipewire
… even if you’re still using pulseaudio
as your audio server.
You can disable it’s socket/service as mentioned above - but you won’t be able to remove it (since that package is a requirement).
Its steam & Kwin But thx for the handy command
pipewire
├─lib32-pipewire
│ └─steam-native
├─mpd
├─pipewire-media-session
│ └─kwin
│ └─plasma-workspace
│ ├─kdeplasma-addons
│ ├─kget
│ ├─khotkeys
│ ├─plasma-browser-integration
│ ├─plasma-nm
│ ├─plasma-pa
│ ├─powerdevil
│ ├─sddm-breath-theme
│ │ └─manjaro-kde-settings
│ └─systemsettings
│ ├─kgamma5
│ ├─kinfocenter
│ ├─plasma-desktop
│ └─sddm-kcm
└─xdg-desktop-portal
└─flatpak
└─libpamac-flatpak-plugin
One last thing before I try to remove n re-install packages.
I had a suggestion Via a chap called Nayr438 on the LTT forums to run these commands (I trust this person and they have helped me a lot in the past)
sudo pacman -S wireplumber pipewire-pulse pipewire-jack pipewire-alsa pipewire gst-plugin-pipewire
sudo pacman -S lib32-pipewire-jack lib32-pipewire
[sudo] password for rob:
warning: pipewire-1:0.3.52-1 is up to date -- reinstalling
resolving dependencies...
:: wireplumber and pipewire-media-session are in conflict. Remove pipewire-media-session? [y/N] n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
~ sudo pacman -S lib32-pipewire-jack lib32-pipewire 1 ✘ 5s
warning: lib32-pipewire-1:0.3.52-1 is up to date -- reinstalling
:: pipewire-jack and jack2 are in conflict (jack). Remove jack2? [y/N] n
I said no to both of the requests as I wasnt to sure and I remember someone saying that pipewire-media-session was needed n to keep it. But I noticed “wireplumber” looked it up n found this that suggests that I should remove it as its not currently supported. Tbh I dont not remember installing Wireplumber?
Could this be the reason I cannot seem to use Pipewire properly or should I just stick with what was suggested by brahma before?
if you want to uninstall something, uninstall pulse and use pipewire
run this:
sudo pacman -S manjaro-pipewire
it will give you pulse dependency issues, so uninstall them first, then run again the command for installing pipewire, and choose wireplumber instead of pipewire session, then reboot
I was half way thru your suggestion before you added how to do it via terminal n I got these errors pop up …
I then saw your edit and went thru the process and got these errors this time
:: manjaro-pipewire and manjaro-pulse are in conflict. Remove manjaro-pulse? [y/N] y
:: manjaro-pipewire and pulseaudio-zeroconf are in conflict. Remove pulseaudio-zeroconf? [y/N] y
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y
:: pipewire-pulse and pulseaudio-bluetooth are in conflict. Remove pulseaudio-bluetooth? [y/N] y
:: removing pulseaudio breaks dependency 'pulseaudio=16.0-1' required by pulseaudio-jack
:: removing pulseaudio breaks dependency 'pulseaudio=16.0-1' required by pulseaudio-lirc
:: removing pulseaudio breaks dependency 'pulseaudio=16.0-1' required by pulseaudio-rtp
So I did what I thought would be the obvious next move (Remove pulseaudio-jack) n then got these errors … just to add to the pain
Should I say yes to these commands that were suggested to install pipewire on another forum to see what happens?
i told you to remove the pulse dependencies first:
sudo pacman -R pulseaudio-jack pulseaudio-lirc pulseaudio-rtp
reboot
You did … but I didnt know how to via terminal … My apologies & giving it a go soon
