Dear guys, I am sorry for posting a question that could be answered. I tried searching a little bit but wasn’t successful in finding it. Please, help me with the problem as it is very annoying.
I am a Manjaro KDE edition user. And it has a problem with my Bluetooth headphones. The problem is random quick interruptions when listening to music or watching a video. I mean the sound is flowing well most of the time but sometimes it stops and immediately goes on. Quick pauses happen and they are really annoying.
I suggested that it is due pulse-audio server and decided to delete it and install pipewire. I did it but the problem remains. I am a quite novice with such things in Linux. So, I need help as I just fall in love with Manjaro and do not want to change a distro.
Thank you!
KDE version: 5.22.5
Kernel: 5.13
Yes, I’ve read it. Thank you. The problem with interference with wi-fi sounds most promising. But I am using a 5GHz band range and the problem still remains. Moreover, there is no difference between 2.4 and 5 GHz band range in my case. Sound glitches still occur.
Hello @gliese3
Is it the issue you can hear on this clip?
I have the latest stable on my Raspberry Pi 4 8GB Argon One M.2 case, so booting up from SSD
Kernel: 5.10.73-4-MANJARO-ARM aarch64 bits: 64 compiler: N/A
parameters: coherent_pool=1M 8250.nr_uarts=0
snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1
video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=E4:5F:01:00:5A:43
vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000
root=PARTUUID=d905149e-02 rw rootwait console=ttyS0,115200 console=tty1
selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0
kgdboc=ttyS0,115200 usbhid.mousepoll=8 audit=0
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro ARM base: Arch Linux
Type: ARM Device System: Raspberry Pi 4 Model B Rev 1.4 details: BCM2835
rev: d03114 serial: <filter>
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K230
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech MX Ergo Multi-Device Trackball
status: Discharging
RAM: total: 7.7 GiB used: 4.91 GiB (63.8%) gpu: 76 MiB
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: Quad Core model: N/A variant: cortex-a72 bits: 64 type: MCP
arch: ARMv8 family: 8 model-id: 0 stepping: 3 bogomips: 432
Speed: 600 MHz min/max: 600/1500 MHz Core speeds (MHz): 1: 1200 2: 1200
3: 1200 4: 1200
Features: asimd cpuid crc32 evtstrm fp
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 status: Vulnerable
Device-1: bcm2711-vc5 driver: vc4_drm v: N/A bus-ID: N/A chip-ID: brcm:gpu
class-ID: gpu
Device-2: bcm2711-hdmi0 driver: N/A bus-ID: N/A chip-ID: brcm:soc
class-ID: hdmi
Device-3: bcm2711-hdmi1 driver: N/A bus-ID: N/A chip-ID: brcm:soc
class-ID: hdmi
Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev resolution: <missing: xdpyinfo>
Device-1: bcm2835-audio driver: bcm2835_audio bus-ID: N/A
chip-ID: brcm:bcm2835_audio class-ID: bcm2835_audio
class-ID: hdmi
class-ID: hdmi
Device-4: Realtek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.1.1.4:10
chip-ID: 0bda:4809 class-ID: 0300
Sound Server-1: ALSA v: k5.10.73-4-MANJARO-ARM running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fe300000 class-ID: mmcnr
IF: wlan0 state: down mac: <filter>
Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fd580000 class-ID: ethernet
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000
class-ID: serial
Local Storage: total: 4.22 TiB used: 283.58 GiB (6.6%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Toshiba model: SA16G
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WDS120G2G0B-00EPW0 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba model: EXTERNAL USB
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 5438 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: MK5055GSX
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.03 scheme: MBR
Optical-1: /dev/sr0 vendor: Dell model: DVD+/-RW DW316 rev: A1C0
dev-links: cdrom
Features: speed: 62 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 111.56 GiB size: 109.75 GiB (98.38%) used: 7.52 GiB (6.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: ROOT_MNJRO
uuid: d1684ccb-e8af-4276-8262-57c7ab0fa08e
ID-2: /boot raw-size: 213.6 MiB size: 213.4 MiB (99.89%)
used: 52.2 MiB (24.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
label: BOOT_MNJRO uuid: 4EDD-A307
ID-3: /run/media/scarodj/Laponia raw-size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 248.41 GiB (53.3%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: Laponia uuid: 794EBEBC08A283D9
ID-4: /run/media/scarodj/Shitebi raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 27.59 GiB (0.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Shitebi
uuid: 544124f0-963f-465c-9972-5aa6348072ed
ID-1: swap-1 type: zram size: 11.44 GiB used: 489.8 MiB (4.2%) priority: 100
dev: /dev/zram0
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 256 MiB fs: vfat label: boot
uuid: 8D64-2011
ID-2: /dev/mmcblk0p2 maj-min: 179:2 size: 14.23 GiB fs: ext4 label: rootfs
uuid: 3857a514-b0f4-49ce-8430-34762068bb6f
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-3: 1-1.1:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-4: 1-1.1.1:5 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-1.1.1.1:8 info: Initio INIC-1608 SATA bridge type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 13fd:1840 class-ID: 0806 serial: <filter>
Device-2: 1-1.1.1.3:9 info: Dell Dell DVD+/-RW Drive DW316
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 413c:9016 class-ID: 0802
serial: <filter>
Device-3: 1-1.1.1.4:10 info: Realtek USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0bda:4809 class-ID: 0300
Device-4: 1-1.1.4:12 info: Lab126 Fire type: <vendor specific> driver: usbfs
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 1949:0222
class-ID: 0000 serial: <filter>
Hub-5: 1-1.4:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 214b:7250 class-ID: 0900
Device-1: 1-1.4.2:6 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 2-1:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-8: 2-1.1:4 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-1.1.2:5 info: Toshiba America MQ04UBF100 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0900 class-ID: 0806 serial: <filter>
Device-2: 2-2:3 info: ASMedia Forty type: Mass Storage driver: uas
interfaces: 1 rev: 3.1 speed: 5 Gb/s chip-ID: 174c:1156 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 193 Uptime: 2d 5h 4m Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 802 lib: 223 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.07
Whenever I boot up Raspberry Pi OS from the internal SD card it works perfect (with the exception of the have-to-rfkill-wifi bug they will not fix)
In my case and from the user observing the symptom perspective, it seems like either
- bluez or pipewire give too little processor priority to the thread, but it’s little to not related to CPU usage and mplayer does not warn the sound card is stuck as it usually does, or
- bluez is giving the radio the least power so the headseat cannot “listen” to it.
Same here, I’ve fallen in love with the distro for many reasons that simplify my computing journey, but if it can’t play music over bluetooth it’s practically rendered useless for me. Sadness!
First off, welcome to the forum @gliese3, and please read the thread on “How to provide good information” so other people more knowledgable than I am can help you out.
I’m getting this same exact issue too on my self-built Ryzen 5 desktop from three years ago with my brand-new Razer Opus headset. The dropouts become more frequent when I use JamesDSP or more apps playing audio at the same time. (I once used PulseEffects, but it got renamed to EasyEffects and is now Pipewire-exclusive.)
I’ve spent the last few hours trying to fix this issue, and any solutions I get from searching either reduced the frequency of dropouts or did nothing to eliminate them. I was considering to replace PulseAudio with Pipewire in an attempt to solved those annoying dropouts, but then I found this thread. Unfortunately, I couldn’t think of anymore solutions to this, but I just want to say that I’m not alone having this issue.
Here is my inxi output
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=0428519d-a16b-4103-bdda-c83d853f7601 rw idle=nomwait
processor.max_cstate=5 rcu_nocbs=0-11 spectre_v2=off mds=off
fbcon=scrollback:4096k sysrq_always_enabled=1 apparmor=1 security=apparmor
udev.log_priority=3 nowatchdog
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: X370 Killer SLI/ac serial: <filter>
UEFI: American Megatrends v: P5.10 date: 12/17/2018
RAM: total: 15.56 GiB used: 5.45 GiB (35.0%)
Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001137 cache: L2: 3 MiB
bogomips: 76674
Speed: 2577 MHz min/max: 1550/2800 MHz boost: enabled Core speeds (MHz):
1: 2577 2: 2501 3: 2512 4: 2587 5: 2598 6: 2477 7: 2574 8: 2505 9: 2707
10: 2717 11: 2564 12: 2622
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 26:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7:6 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.14.13-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.4 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: N/A alternate: snd_hda_intel bus-ID: 26:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.14.13-1-MANJARO running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 1e:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp30s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: f000 bus-ID: 1f:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp31s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:2 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 661 GiB (56.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-1: / raw-size: 64 GiB size: 62.75 GiB (98.04%) used: 57.72 GiB (92.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: Manjaro
uuid: 0428519d-a16b-4103-bdda-c83d853f7601
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 26.4 MiB (27.8%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9E33-370C
ID-3: /mnt/Data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 603.26 GiB (64.8%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Data
uuid: 707817287816EC9A
Kernel: swappiness: 1 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: N/A
uuid: 7EC2AF0BC2AEC72D
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 168.29 GiB fs: ntfs label: Win10SSD
uuid: 8AB836A9B8369423
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 1-7:6 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-2: 1-9:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Microsoft Comfort Curve Keyboard 2000 V1.0
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 100mA chip-ID: 045e:00dd class-ID: 0300
Device-2: 3-4:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 2129 fan-3: 0 fan-4: 1238 fan-5: 1037
gpu: amdgpu fan: 853
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.28 gpu: amdgpu watts: 12.24
Processes: 382 Uptime: 6h 19m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1860
pacman: 1846 lib: 475 flatpak: 14 Shell: Zsh v: 5.8 running-in: yakuake
inxi: 3.3.07
Hi @scarodj!
Thank you for the reply! Yes, the troubles are similar to those I’ve heard in the clip. But in my case, they have lower frequency and intensity. Actually, sometimes I couldn’t hear them for hours but sometimes they could arise several times per minute. I couldn’t find the tendency yet.
Honestly, I had the similar thoughts. It seems that CPU loading may affect the frequency of glitches. I will try to play with the renice command.
Are writing about Arduino? Do you try other distros?
Hi @acarasimon96!
Thank you for the advice! I attached the inxi information to the bottom.
In some way, I am also glad that I am not alone with the problem. I tried to find a solution via google but no one couldn’t fix my problem. So, I decided to ask for help here.
The problem is worse in the way that I can’t track it properly. It is quite random. The last thing I’ve done so far is update my kernel to 5.14.10-1 version. It seems like the problem arises rarely after that but I am not sure.
inxi
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
root=UUID=676870ef-db68-4b42-b120-ffb239d553a0 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=none
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: DTCN24WW(V1.10) date: 12/25/2020
ID-1: BAT1 charge: 45.7 Wh (90.5%) condition: 50.5/56.5 Wh (89.4%)
volts: 12.4 min: 11.6
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x39 0x43 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 62
RAM: total: 13.53 GiB used: 5.36 GiB (39.6%)
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 3 MiB bogomips: 28454
Speed: 1601 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1601 2: 1470 3: 1392 4: 1743 5: 1759 6: 1828
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 136.3 GiB (28.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
lanes: 4 type: SSD serial: <filter> rev: 3L1QFXV7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 136.3 GiB (28.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 676870ef-db68-4b42-b120-ffb239d553a0
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 19E1-F8D3
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /swap raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-6: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-2:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-3:3 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:244c
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 3-4:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:c123
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.4 C mobo: 46.0 C gpu: amdgpu temp: 46.0 C
Processes: 299 Uptime: 57m wakeups: 2090 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1529 lib: 440
flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.08
Same here. It goes from hours of uninterrupted, passing through the more frequent small to annoying interruption every other song to the rare round of interruptions I was able to capture there.
No, it’s Raspberry Pi 4 (8GB edition) I have only tried Raspberry Pi OS, but I’ll try Ubuntu 64-bit next. I was thinking of creating a thread on the ARM sub-forum but I see the same issue happens with completely different systems.
Oh, I am sorry. I meant Raspberry. Just doing some projects with Arduino right now.
Ok, understood. I tried some other distro (EndeavourOS, Pop!_OS) and the same thing happened everywhere, the same interruptions. I tried also different options for Bluetooth but it didn’t work. Maybe, I am not lucky with my headphones. Anyway, sound problems occur quite rare recently. I can live with it but I changed my distro to EndeavourOS with KDE.
Thank you for the reply! Good luck!
Hello,
I’m glad the issue is somewhat tolerable for you, good luck with EndevourOS. My workaround has been to use my smartphone for music for now.
I’ve been testing media (air waves) interference. I tried to listen at midnight when I know no one is using wifi at home and other business around have closed and there where no interruptions. Turn on wifi and produce some traffic and the interruptions happen.
It is my understanding that both Bluetooth and Wifi are shared media with collision avoidance for which they use packets that request time slots to other devices. Could it be that bluez is failing to request the needed time slots? I will try to reach out to the project itself.
I have bluez-5.62-1 in Manjaro stable, what version does your EndevourOS have?
Hi!
I don’t think the problem is due to wi-fi collisions. I tried Bluetooth headphones in almost wi-fi-free zone. No way.
I use the same Arch repos as Manjaro, I think. At least, I have the same version of bluez as you do.
P. S. Another big problem I had with Manjaro is total freezes. The system just stopped and I could do nothing. They were quite rare, say once per week but it was terribly annoying. I couldn’t find out what was the problem. With EndevourOS I have no such problem at least during a month. I came to the conclusion that I should use pure Arch and try to install everything I need by myself. Maybe, it will be my next step. Anyway, I just fall in love with Arch repos, super quick and easy possibility to install the software I want and KDE project. I am so thankful to all the guys doing such an amazing job!
