Interrupted Kernel Update
On November 11th I ran sudo pacman -Syu and mid-download my monitors went black for a moment and I was kicked back to the login screen. After logging in I tried running sudo pacman -Syu again but got an error message. Therefore, I thought it might be best to restart my PC and try again. However, upon boot I was greeted with this error message:
error: file ‘/boot/vmlinuz-5.15-x86_64’ not found.
error: you need to load the kernel first.
After using a flashdrive to boot into chroot I tinkered with the problem for a few hours, and now I’m stuck.
I did manage to get the boot screen to change, though. Now it gets stuck at:
root: clean, 1059582/15269888 files, 33350243/61048752 blocks
So I ran journalctl --boot=-1 --priority=3 --cata through tty with hopes of diagnosing the problem, but frankly, I have no idea what to do. This is what it returned:
systemd-modules-load[367]: Failed to find module ‘nvidia’
systemd-modules-load[367]: Failed to find module ’nvidia-drm’
systemd-modules-load[367]: Failed to find module ’nvidia-uvm’
(udev-worker)[469]: vhba_ctl: /usr/lib/udev/rules.d/60-linux419-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME=“vhba_ctl”
(udev-worker)[469]: vhba_ctl: /usr/lib/udev/rules.d/60-linux515-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME=“vhba_ctl”
(udev-worker)[451]: vhba_ctl: /usr/lib/udev/rules.d/60-linux419-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME=“vhba_ctl”
(udev-worker)[451]: vhba_ctl: /usr/lib/udev/rules.d/60-linux515-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME=“vhba_ctl”
kernel: kvm: disabled by bios
kernel: hid-generic 0003:0D8C:0066.0001: No inputs registered, leaving
kernel: watchdog: watchdog0: watchdog did not stop!
Now, this is after I messed around and ran a bunch of commands, so I’m not really sure what’s going on anymore. My apologies. However, from what I can tell, this is likely a graphics driver problem. For instance, when running nvidia-smi I get:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver.
Make sure that the latest NVIDIA driver is installed and running.
All help is appreciated. Thanks.
Hi @Entinel, and welcome!
As you probably know, that doesn’t tell us much. But, considering:
I’m guessing it might be a hardware problem.
I suggest using the chroot environment, to get the output of:
journalctl --priority=4 --no-pager
and
mhwd-kernel --listinstalled
and
mhwd --list
and
mhwd --listinstalled
and
…and provide it here. Then we can see what there is to see.
Edit:
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
What if instead you’d rather read for few hours – there is one “interrupted kernel update” post every couple of days. One was just yesterday I think.
And please don’t say your case is somehow special, because it isn’t. It’s the same thing as other thousand posts. All that is needed is: (in chroot) upgrade the system and reinstall missing kernels.
Also, it would help if you write line by line what you actually did so far.
Currently running: 6.5.5-1-MANJARO (linux65)
   * linux419
   * linux515
mhwd --list
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> 0000:27:00.0 (0300:10de:1c82) Display controller nVidia Corporation:
          video-nvidia            2023.03.23               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> Installed PCI configs:
12System:
  12Kernel 6.5.5-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
    12clocksource tsc 12available hpet,acpi_pm
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2304 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop Xfce 12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Micro-Star 12model X370 GAMING M7 ACK (MS-7A35) 12v 1.0
    12serial <filter> 12BIOS American Megatrends LLC. 12v 1.H3 12date 07/20/2022
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 16 GiB 12available 15.54 GiB 12used 1.36 GiB (8.7%)
  12Array-1 12capacity 128 GiB 12slots 4 12modules 2 12EC None 12max-module-size 32 GiB
    12note est.
  12Device-1 DIMM 0 12type DDR4 12detail synchronous unbuffered (unregistered)
    12size 8 GiB 12speed 2400 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
    12data 64 12total 64 12manufacturer G.Skill 12part-no F4-2400C16-8GIS 12serial N/A
  12Device-2 DIMM 1 12type no module installed
  12Device-3 DIMM 0 12type DDR4 12detail synchronous unbuffered (unregistered)
  12Device-4 DIMM 1 12type no module installed
12CPU:
  12Info 12model AMD Ryzen 5 3600X 12socket AM4 12bits 64 12type MT MCP 12arch Zen 2 12gen 3
    12level v3 12note check 12built 2020-22 12process TSMC n7 (7nm) 12family 0x17 (23)
    12model-id 0x71 (113) 12stepping 0 12microcode 0x8701021
  12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
    12desc d-6x32 KiB; i-6x32 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 32 MiB 12desc 2x16 MiB
  12Speed (MHz) 12avg 2733 12high 3800 12min/max 2200/4409 12boost enabled
    12base/boost 3800/4400 12scaling 12driver acpi-cpufreq 12governor schedutil
    12volts 1.1 V 12ext-clock 100 MHz 12cores 121 3800 122 3800 123 2200 124 3800 125 2200
    126 2200 127 2200 128 2200 129 3800 1210 2200 1211 2200 1212 2200 12bogomips 91062
  12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
  12Vulnerabilities
  12Type gather_data_sampling 12status Not affected
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12status Not affected
  12Type retbleed 12mitigation untrained return thunk; SMT enabled with STIBP
    protection
  12Type spec_rstack_overflow 12mitigation safe RET
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA GP107 [GeForce GTX 1050 Ti] 12vendor Micro-Star MSI
    12driver nouveau 12v kernel 12non-free 545.xx+ 12status current (as of 2023-11;
    EOL~2026-12-xx) 12arch Pascal 12code GP10x 12process TSMC 16nm 12built 2016-2021
    12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16 12link-max 12gen 3 12speed 8 GT/s 12ports
    12active DP-1,HDMI-A-1 12empty DVI-D-1 12bus-ID 27:00.0 12chip-ID 10de:1c82
    12class-ID 0300 12temp 34.0 C
  12Display 12server X.org 12v 1.21.1.9 12driver 12X 12loaded nvidia 12gpu nouveau
    12display-ID :0.0
  12Monitor-1 DP-1 12model Acer KG241Q P 12serial <filter> 12built 2020 12res 1920x1080
    12dpi 94 12gamma 1.2 12size 521x293mm (20.51x11.54") 12diag 598mm (23.5") 12ratio 16:9
    12modes 12max 1920x1080 12min 720x400
  12Monitor-2 HDMI-A-1 12model Acer KG240 A 12serial <filter> 12built 2017
    12res 1920x1080 12dpi 92 12gamma 1.2 12size 531x299mm (20.91x11.77") 12diag 609mm (24")
    12ratio 16:9 12modes 12max 1920x1080 12min 720x400
  12API EGL 12v 1.5 12hw 12drv nvidia nouveau 12platforms 12device 0 12drv nouveau 12device 1
    12drv swrast 12gbm 12drv nouveau 12surfaceless 12drv nouveau 12inactive wayland,x11
  12API OpenGL 12v 4.5 12compat-v 4.3 12vendor mesa 12v 23.1.9-manjaro1.1
    12note incomplete (EGL sourced) 12renderer NV137, llvmpipe (LLVM 16.0.6 256 bits)
  12API Vulkan 12Message No Vulkan data available.
12Audio:
  12Device-1 NVIDIA GP107GL High Definition Audio 12vendor Micro-Star MSI
    12driver snd_hda_intel 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16 12link-max
    12gen 3 12speed 8 GT/s 12bus-ID 27:00.1 12chip-ID 10de:0fb9 12class-ID 0403
  12Device-2 AMD Starship/Matisse HD Audio 12vendor Micro-Star MSI
    12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
    12bus-ID 29:00.4 12chip-ID 1022:1487 12class-ID 0403
  12Device-3 C-Media Schiit Modi 3 12driver hid-generic,snd-usb-audio,usbhid
    12type USB 12rev 2.0 12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-2:2
    12chip-ID 0d8c:0066 12class-ID 0300
  12API ALSA 12v k6.5.5-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
  12Server-2 PipeWire 12v 0.3.84 12status off 12tools pw-cli
  12Server-3 PulseAudio 12v 16.1 12status off 12with 121 pulseaudio-alsa 12type plugin
    122 pulseaudio-jack 12type module 12tools pacat,pactl,pavucontrol
12Network:
  12Device-1 Qualcomm Atheros Killer E2500 Gigabit Ethernet 12vendor Micro-Star MSI
    12driver alx 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port f000
    12bus-ID 21:00.0 12chip-ID 1969:e0b1 12class-ID 0200
  12IF eno1 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type dynamic noprefixroute 12scope global
  12IP v6 <filter> 12type noprefixroute 12scope link
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 2.53 TiB 12used 679.48 GiB (26.2%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 970 EVO Plus 250GB
    12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12tech SSD 12serial <filter> 12fw-rev 2B2QEXM7 12temp 37.9 C
  12SMART yes 12health PASSED 12on 357d 0h 12cycles 1,019
    12read-units 26,629,694 [13.6 TB] 12written-units 29,460,956 [15.0 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Seagate 12model ST2000DM006-2DM164
    12family BarraCuda 3.5 (CMR) 12size 1.82 TiB 12block-size 12physical 4096 B
    12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12tech HDD 12rpm 7200 12serial <filter>
    12fw-rev CC26 12temp 29 C
  12SMART yes 12state enabled 12health PASSED 12on 2y 162d 12h 12cycles 2326
    12read 82.57 TiB 12written 11.05 TiB 12Pre-Fail 12attribute Spin_Retry_Count
    12value 100 12worst 100 12threshold 97
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Samsung 12model SSD 860 EVO 250GB
    12family based SSDs 12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 2B6Q 12temp 28 C
  12SMART yes 12state enabled 12health PASSED 12on 127d 12h 12cycles 476
    12written 329.02 GiB
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor Samsung 12model SSD 860 EVO 250GB
    12sata 3.2 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 4B6Q 12temp 28 C
  12SMART yes 12state enabled 12health PASSED 12on 2y 7d 11h 12cycles 1838
    12written 9.58 TiB
  12ID-5 /dev/sdd 12maj-min 8:48 12vendor PNY 12model USB 3.0 FD 12size 28.9 GiB
    12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 3.2 12spd 5 Gb/s 12lanes 1
    12mode 3.2 gen-1x1 12tech N/A 12serial <filter> 12fw-rev PMAP
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 232.88 GiB 12size 228.17 GiB (97.98%) 12used 122.5 GiB (53.7%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label root
    12uuid 6d328056-a293-4d86-867a-3874678d7b0d
  12ID-2 /mnt/sda1 12raw-size 1.82 TiB 12size 1.79 TiB (98.37%)
    12used 556.98 GiB (30.4%) 12fs ext4 12block-size 4096 B 12dev /dev/sda1 12maj-min 8:1
    12label N/A 12uuid 6b6c9b51-8cb5-4015-a1c4-a699211b05ee
  12ID-3 /mnt/sdb1 12raw-size 232.88 GiB 12size 228.17 GiB (97.98%)
    12used 2 MiB (0.0%) 12fs ext4 12block-size 4096 B 12dev /dev/sdb1 12maj-min 8:17
    12label N/A 12uuid 58f8a27b-7cae-4193-99fd-8a9d6767117a
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/sdc1 12maj-min 8:33 12size 450 MiB 12fs ntfs 12label Recovery
    12uuid CA5ADD345ADD1E4F
  12ID-2 /dev/sdc2 12maj-min 8:34 12size 99 MiB 12fs fat (32 bit) 12label N/A
    12uuid 86DE-DAE8
  12ID-3 /dev/sdc3 12maj-min 8:35 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-4 /dev/sdc4 12maj-min 8:36 12size 232.33 GiB 12fs ntfs 12label N/A
    12uuid 3282E17282E13B4D
  12ID-5 /dev/sdd1 12maj-min 8:49 12size 3.5 GiB 12fs N/A 12label MANJARO_XFCE_2304
    12uuid 2023-10-15-11-55-04-00
  12ID-6 /dev/sdd2 12maj-min 8:50 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid DE4F-2104
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 14 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-2:2 12info C-Media Schiit Modi 3 12type audio,HID
    12driver hid-generic,snd-usb-audio,usbhid 12interfaces 3 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 500mA 12chip-ID 0d8c:0066
    12class-ID 0300
  12Device-2 1-9:3 12info Logitech G502 Proteus Spectrum Optical Mouse
    12type mouse,HID 12driver hid-generic,usbhid 12interfaces 2 12rev 2.0
    12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 300mA 12chip-ID 046d:c332
    12class-ID 0300 12serial <filter>
  12Hub-2 2-0:1 12info super-speed hub 12ports 8 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
    12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
  12Device-1 2-6:2 12info PNY USB 3.0 FD 12type mass storage 12driver usb-storage
    12interfaces 1 12rev 3.2 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1
    12power 504mA 12chip-ID 154b:00ed 12class-ID 0806 12serial <filter>
  12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 2 12rev 2.0
  12Hub-4 4-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
  12Hub-5 5-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
  12Device-1 5-2:2 12info Corsair STRAFE RGB Gaming Keyboard 12type keyboard,HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12power 500mA 12chip-ID 1b1c:1b20 12class-ID 0300
    12serial <filter>
  12Hub-6 6-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Sensors:
  12System Temperatures 12cpu 38.0 C 12mobo N/A 12gpu nouveau 12temp 34.0 C
  12Fan Speeds (rpm) N/A
12Info:
  12Processes 0 12Uptime 6m 12wakeups 0 12Init systemd 12v 254 12default graphical
  12tool systemctl 12Compilers 12gcc 13.2.1 12alt 11/12 12clang 16.0.6 12Packages 1693
  12pm pacman 12pkgs 1688 12libs 496 12tools pamac,yay 12pm flatpak 12pkgs 5
  12Client Unknown Client: systemd 12inxi 3.3.31
The first command you asked for takes up too many characters. I’ve reached the limit.
Let’s try limiting it then:
journalctl --boot=-1 --priority=4 --no-pager
I’ve added the --boot= argument and set it to -1 for the previous boot. Feel free to adjust this as necessary.
Ok! Here are the last 3 boots.
Nov 16 16:07:44 tyler-ab350 kernel:   #7  #8  #9 #10 #11
Nov 16 16:07:44 tyler-ab350 kernel: pci 0000:21:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Nov 16 16:07:44 tyler-ab350 kernel: nvme nvme0: missing or invalid SUBNQN field.
Nov 16 16:07:44 tyler-ab350 kernel: ata3.00: supports DRM functions and may not be fully accessible
Nov 16 16:07:44 tyler-ab350 kernel: ata4.00: supports DRM functions and may not be fully accessible
Nov 16 16:07:44 tyler-ab350 kernel: ata6: failed to resume link (SControl 0)
Nov 16 16:07:44 tyler-ab350 kernel: vhba: loading out-of-tree module taints kernel.
Nov 16 16:07:44 tyler-ab350 systemd-modules-load[357]: Failed to find module 'nvidia'
Nov 16 16:07:44 tyler-ab350 systemd-modules-load[357]: Failed to find module 'nvidia-drm'
Nov 16 16:07:44 tyler-ab350 systemd-modules-load[357]: Failed to find module 'nvidia-uvm'
Nov 16 16:07:44 tyler-ab350 (udev-worker)[449]: vhba_ctl: /usr/lib/udev/rules.d/60-linux419-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
Nov 16 16:07:44 tyler-ab350 (udev-worker)[449]: vhba_ctl: /usr/lib/udev/rules.d/60-linux515-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
Nov 16 16:07:45 tyler-ab350 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Nov 16 16:07:45 tyler-ab350 (udev-worker)[464]: vhba_ctl: /usr/lib/udev/rules.d/60-linux419-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
Nov 16 16:07:45 tyler-ab350 (udev-worker)[464]: vhba_ctl: /usr/lib/udev/rules.d/60-linux515-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
Nov 16 16:07:45 tyler-ab350 kernel: kvm: disabled by bios
Nov 16 16:07:45 tyler-ab350 kernel: hid-generic 0003:0D8C:0066.0001: No inputs registered, leaving
Nov 16 20:57:39 tyler-ab350 (modprobe)[733]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 16 20:57:39 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 774, but reception only permitted for main PID 736
Nov 16 20:57:39 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 775, but reception only permitted for main PID 736
Nov 16 20:57:39 tyler-ab350 kernel: kauditd_printk_skb: 55 callbacks suppressed
Nov 16 20:57:39 tyler-ab350 systemd[1]: Cannot find unit for notify message of PID 869, ignoring.
Nov 16 20:58:05 tyler-ab350 systemd-xdg-autostart-generator[1203]: Configuration file /home/tyler/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 20:58:05 tyler-ab350 systemd-xdg-autostart-generator[1203]: Configuration file /home/tyler/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 21:08:17 tyler-ab350 (modprobe)[1285]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 16 21:08:18 tyler-ab350 kernel: watchdog: watchdog0: watchdog did not stop!
journalctl --boot=-2 --priority=4 --no-pager
Nov 16 12:54:32 tyler-ab350 kernel:   #7  #8  #9 #10 #11
Nov 16 12:54:32 tyler-ab350 kernel: pci 0000:21:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Nov 16 12:54:32 tyler-ab350 kernel: nvme nvme0: missing or invalid SUBNQN field.
Nov 16 12:54:32 tyler-ab350 kernel: ata3.00: supports DRM functions and may not be fully accessible
Nov 16 12:54:32 tyler-ab350 kernel: ata4.00: supports DRM functions and may not be fully accessible
Nov 16 12:54:32 tyler-ab350 kernel: ata6: failed to resume link (SControl 0)
Nov 16 12:54:32 tyler-ab350 systemd-modules-load[366]: Failed to find module 'vhba'
Nov 16 12:54:32 tyler-ab350 systemd-modules-load[366]: Failed to find module 'nvidia'
Nov 16 12:54:32 tyler-ab350 systemd-modules-load[366]: Failed to find module 'nvidia-drm'
Nov 16 12:54:32 tyler-ab350 systemd-modules-load[366]: Failed to find module 'nvidia-uvm'
Nov 16 12:54:33 tyler-ab350 kernel: hid-generic 0003:0D8C:0066.0001: No inputs registered, leaving
Nov 16 12:54:33 tyler-ab350 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Nov 16 12:54:33 tyler-ab350 kernel: kvm: disabled by bios
Nov 16 12:54:34 tyler-ab350 (modprobe)[775]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 16 12:54:34 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 827, but reception only permitted for main PID 777
Nov 16 12:54:34 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 832, but reception only permitted for main PID 777
Nov 16 12:54:34 tyler-ab350 kernel: kauditd_printk_skb: 55 callbacks suppressed
Nov 16 12:54:34 tyler-ab350 systemd[1]: Cannot find unit for notify message of PID 921, ignoring.
Nov 16 17:56:52 tyler-ab350 systemd-xdg-autostart-generator[1201]: Configuration file /home/tyler/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 17:56:52 tyler-ab350 systemd-xdg-autostart-generator[1201]: Configuration file /home/tyler/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 18:04:30 tyler-ab350 (modprobe)[10717]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 16 18:04:32 tyler-ab350 kernel: watchdog: watchdog0: watchdog did not stop!
--boot=-3 --priority=4 --no-pager
Nov 11 05:30:11 tyler-ab350 kernel:   #7  #8  #9 #10 #11
Nov 11 05:30:11 tyler-ab350 kernel: pci 0000:21:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Nov 11 05:30:11 tyler-ab350 kernel: nvme nvme0: missing or invalid SUBNQN field.
Nov 11 05:30:11 tyler-ab350 kernel: ata3.00: supports DRM functions and may not be fully accessible
Nov 11 05:30:11 tyler-ab350 kernel: ata4.00: supports DRM functions and may not be fully accessible
Nov 11 05:30:11 tyler-ab350 kernel: ata6: failed to resume link (SControl 0)
Nov 11 05:30:11 tyler-ab350 systemd-modules-load[362]: Failed to find module 'vhba'
Nov 11 05:30:12 tyler-ab350 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Nov 11 05:30:12 tyler-ab350 kernel: kvm: disabled by bios
Nov 11 05:30:12 tyler-ab350 kernel: nvidia: loading out-of-tree module taints kernel.
Nov 11 05:30:12 tyler-ab350 kernel: nvidia: module license 'NVIDIA' taints kernel.
Nov 11 05:30:12 tyler-ab350 kernel: Disabling lock debugging due to kernel taint
Nov 11 05:30:12 tyler-ab350 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  535.129.03  Thu Oct 19 18:56:32 UTC 2023
Nov 11 05:30:12 tyler-ab350 kernel: hid-generic 0003:0D8C:0066.0001: No inputs registered, leaving
Nov 11 05:30:13 tyler-ab350 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Nov 11 05:30:13 tyler-ab350 (modprobe)[837]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 11 05:30:13 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 890, but reception only permitted for main PID 839
Nov 11 05:30:13 tyler-ab350 systemd[1]: snapd.service: Got notification message from PID 897, but reception only permitted for main PID 839
Nov 11 05:30:13 tyler-ab350 kernel: kauditd_printk_skb: 55 callbacks suppressed
Nov 11 05:30:13 tyler-ab350 systemd[1]: Cannot find unit for notify message of PID 982, ignoring.
Nov 11 05:30:24 tyler-ab350 lightdm[1250]: gkr-pam: unable to locate daemon control file
Nov 11 05:30:24 tyler-ab350 systemd-xdg-autostart-generator[1326]: Configuration file /home/tyler/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 11 05:30:24 tyler-ab350 systemd-xdg-autostart-generator[1326]: Configuration file /home/tyler/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 11 10:33:22 tyler-ab350 lightdm[961]: display_manager_add_seat: assertion '!priv->stopping' failed
Nov 11 10:33:22 tyler-ab350 systemd[1]: lightdm.service: Failed with result 'exit-code'.
Nov 11 10:33:30 tyler-ab350 lightdm[3786]: gkr-pam: unable to locate daemon control file
Nov 11 10:34:04 tyler-ab350 systemd-coredump[3947]: Failed to send coredump datagram: Broken pipe
Nov 11 10:34:04 tyler-ab350 (modprobe)[3985]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Nov 11 10:34:05 tyler-ab350 kernel: watchdog: watchdog0: watchdog did not stop!
From what I can see, the
…one booted normally.
Also from what I can see, the Nvidia driver is the actual problem:
So I think your best bet is:
Hope this helps!
to add to what @Mirdarthos said:
Essentially do
what @anon51566685 said above
chroot and run the update again.
And just to be sure, install one or two, possibly newer, kernels
explicitely
and delete the ones you don’t use, to save you from possibly running into space constraints on the /boot partition.
We don’t know what you mean with:
and it is unlikely to be important to know :grinning:
Just give (text of all the commands and subsequent messages) feedback when you have issues with (re)running the update in chroot.
