Der
27 October 2020 04:01
1
Hi, this morning I installed Manjaro KDE plasma on my desktop computer. Internet is connected when I ran all setup by bootable USB, but after I reboot my computer, the internet fail to connect. I can’t find a way to solve this problem. I’m using cable instead of wi-fi.
I used Manjaro on my laptop for 5 months, all internet connection went well without any settings. I’m not really understand how it goes. But i think I found the enjoyment to learn Linux.
Please someone, help me.
Thanks!
Der
27 October 2020 04:34
3
I don’t have internet connection but I tried to copy the info by using phone and usb. Sorry it’s kinda messy here
$ inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=8cb8b4a7-4277-4a46-8f6d-31630f0382c7 rw quiet apparmor=1
security=apparmor resume=UUID=09e6fb4f-e055-4aab-8a4f-77cb27650e48
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: A68HM GRENADE (MS-7891) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.0 date: 03/27/2015
Topology: Quad Core model: AMD Athlon X4 860K bits: 64 type: MCP
arch: Steamroller family: 15 (21) model-id: 30 (48) stepping: 1
microcode: 6003106 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 29553
Speed: 3891 MHz min/max: 1700/3700 MHz boost: enabled Core speeds (MHz):
1: 3515 2: 3494 3: 3891 4: 3892
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 938.95 GiB used: 7.82 GiB (0.8%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Generic model: Flash Disk size: 7.44 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 8.07
scheme: MBR
ID-1: / raw size: 30.00 GiB size: 29.40 GiB (98.01%) used: 7.63 GiB (25.9%)
fs: ext4 dev: /dev/sda2
ID-2: /home raw size: 701.31 GiB size: 689.30 GiB (98.29%)
used: 148.4 MiB (0.0%) fs: ext4 dev: /dev/sda5
ID-3: /opt raw size: 30.00 GiB size: 29.40 GiB (98.01%)
used: 44.0 MiB (0.1%) fs: ext4 dev: /dev/sda1
Processes: 173 Uptime: 1h 08m Memory: 7.79 GiB used: 838.6 MiB (10.5%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1191 lib: 343
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
j8a
27 October 2020 12:03
4
Hi, @Der
Please, take a look at this post and whether you are agree reinstall the network drivers.
https://forum.manjaro.org/t/ethernet-connection-fails-after-reboot/27785/2
Hope it help, regards.
Fabby
27 October 2020 15:36
5
@j8a
That’s a cabled network solution, not a WiFi solution.
@Der
Welcome to Manjaro!
Your current output shows that you have no WiFi adapter at all.
Can you provide the output to lspci and lsusb and if it’s not in there too, the WiFi adapter:
died and you need to replace it.
the cable / card itself came loose from the MoBo and you have to reseat it.
j8a
27 October 2020 15:57
6
Hi @Fabby , I agree with you and the post that I wrote refers to an ethernet cabled conection problem. I think your help could be useful too.
Regards,
