As said in the title manjaro is seeing my hard drive as removable off of a fresh install and I don’t know how to fix it or why it shows up as removable as i am very new to manjaro and linux
At very first read this and come back with more informations
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=a85ae9ab-85d5-4bec-b061-2004804205fd rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X570 AORUS XTREME v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS XTREME v: x.x serial: <filter>
UEFI: American Megatrends v: F20 date: 07/07/2020
RAM: total: 62.75 GiB used: 3.62 GiB (5.8%)
Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: 0
microcode: 8701021 cache: L2: 8 MiB bogomips: 224124
Speed: 3625 MHz min/max: 2200/3500 MHz boost: enabled Core speeds (MHz):
1: 3625 2: 2060 3: 2200 4: 2195 5: 2202 6: 2204 7: 2198 8: 2200 9: 3840
10: 2141 11: 2061 12: 1983 13: 2062 14: 2199 15: 2200 16: 2199 17: 2199
18: 2196 19: 2198 20: 2199 21: 2276 22: 2189 23: 2200 24: 2046 25: 2199
26: 2200 27: 2200 28: 2199 29: 2200 30: 2198 31: 2057 32: 2054
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:2208 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: DP-4 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: SteelSeries ApS SteelSeries GameDAC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-3.2:6 chip-ID: 1038:1282
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:d107 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Local Storage: total: 8.2 TiB used: 12.17 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD8001FZBX-00ASYA0 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Glide
size: 14.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 12.01 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a85ae9ab-85d5-4bec-b061-2004804205fd
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: ACA7-E92C
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-4: /run/media/kaleb/BRUH raw-size: 14.46 GiB size: 14.45 GiB (99.95%)
used: 161.1 MiB (1.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: BRUH
uuid: 88C9-A964
ID-5: /run/media/kaleb/Game Storage raw-size: 7.28 TiB
size: 7.28 TiB (100.00%) used: 3.8 MiB (0.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1 label: Game Storage uuid: 129d27cd-a021-4be5-ad6e-5894cdf3d8fa
ID-6: /run/timeshift/backup raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-7: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-8: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-5: 3-3:2 info: Realtek 4-Port USB 2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0bda:5423 class-ID: 0900
Device-1: 3-3.1:6 info: SanDisk Cruzer Glide type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5575 class-ID: 0806 serial: <filter>
Device-2: 3-6:3 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-3:2 info: Realtek 2-Port USB 3.1 Hub ports: 2 rev: 3.1
speed: 5 Gb/s chip-ID: 0bda:0423 class-ID: 0900
Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: SteelSeries ApS SteelSeries Rival 650 Wireless
type: HID,Mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 200mA chip-ID: 1038:172b class-ID: 0300
serial: <filter>
Device-2: 5-2:3 info: Razer USA Huntsman type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0227 class-ID: 0300
Hub-9: 5-3:4 info: Texas Instruments TUSB2036 Hub ports: 3 rev: 1.1
speed: 12 Mb/s chip-ID: 0451:2036 class-ID: 0900
Device-1: 5-3.2:6 info: SteelSeries ApS SteelSeries GameDAC type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1038:1282 class-ID: 0300
serial: <filter>
Device-2: 5-3.3:5 info: SteelSeries ApS SteelSeries GameDAC type: HID
power: 100mA chip-ID: 1038:1280 class-ID: 0300
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 34.0 C mobo: 16.8 C gpu: nvidia temp: 26 C
Processes: 755 Uptime: 13h 24m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1236 lib: 355
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
Probably you enabled SATA hot-plugging in your mother board? I remember it was doing that at some point on my KDE install after I enabled hot-plugging for all ports (to test a dozen HDD I had lying around).
Yep that did it, for some reason that was enabled.
Thanks for the solution
