I’m still progressing in the goal to setup a working opencl in pre broadwell Cpus and Intel-opencl is now installed and it seems works correctly on libreoffice
But i still have plenty of issues on differents softwares that uses Opencl:
Blender is not launching (working perfectly without intel-opencl)
blender: symbol lookup error: /usr/lib/libOpenImageDenoise.so.1: undefined symbol: _ZN3tbb10interface78internal15task_arena_base24internal_max_concurrencyEPKNS0_10task_arenaE
darktable works correctly but into the darkroom it displays a black image (only in raw files )
(works perfectly without opencl )
the same problem with davinci resolve that run correctly but cannot display videos …
is someone have an idea or a clue and maybe we will have in a near future a easy solution to enable opencl on old machines ?
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
