Intel-ivsc-firmware - Webcam not recognised on Samsung Galaxy Book 3
Can you tell me what you did?
I tried installing it from the script, but it failed with:
# Install package from the AUR/repos: intel-ivsc-firmware
AUR Explicit (1): intel-ivsc-firmware-r2.764bd6e-1
:: (0/1) Failed to download PKGBUILD: intel-ivsc-firmware
 -> error fetching intel-ivsc-firmware: Cloning into 'intel-ivsc-firmware'...
fatal: unable to connect to aur.archlinux.org:
aur.archlinux.org[0: 95.216.144.15]: errno=No route to host
aur.archlinux.org[1: 2a01:4f9:c010:50::1]: errno=Network is unreachable
         context: exit status 128
I also tried the yay commands, but they also failed:
yay -S intel-ivsc-firmware
Any suggestions?
I suggest opening a new thread regarding this. The one you necro-bumped, which isn’t allowed, it a year old already!
When you do so, please also provide the info:
@gerep
I have moved your post to its own dedicated topic to attract wider attention to it. In the meantime, please help others to help you by providing an better description of your issue using many more words.
In this case, the following command might help; let the command finish completely (in might take a minute):
pamac upgrade -a --force-refresh --dry-run
and then if that completes without error:
After successful completion you might try again to build the package:
pamac build intel-ivsc-firmware
I hope this helps.
PS: Feel free to change the thread title, if needed.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
My bad, could’ve moved it myself, thanks @soundofthunder!
@gerep, I’ve got a sneaky suspicion your system is out-of-date.
I think you need to update your mirrors:
sudo pacman-mirrors --fasttrack 5
Then update your system:
pamac upgrade
Followed by rebooting and trying the installation again:
And seeing if it works.
Note that this might have many .pacnew files as a side-effect. To deal with those, see:
I’m sorry, but I just noticed you created this new post while I was making this one :slight_smile:
Should we continue there or here?
I’ll try the update commands you suggested.
The embedded camera is not working anywhere.
I tried using Cheese and other meeting applications and browsers, and all say, “Camera not found”.
I’m sorry if this is too much information.
inxi -zv8
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7a40bd80-7d01-4849-834d-9d9734a432e0 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: SAMSUNG product: 960XFH v: P07ALQ
  Mobo: SAMSUNG model: NP960XFH-XA1BR
    v: SGLB450A1K-C01-G001-S0007+10.0.22621 serial: <superuser required>
    part-nu: SCAI-ICPS-A5A5-RPLH-PALQ uuid: <superuser required> UEFI: American
    Megatrends LLC. v: P07ALQ.190.240418.PS date: 04/18/2024
  ID-1: BAT1 charge: 73.7 Wh (99.1%) condition: 74.4/73.7 Wh (100.9%)
    volts: 17.5 min: 15.5 model: SAMSUNG Electronics SR Real Battery
    type: Li-ion serial: <filter> status: not charging cycles: 57
  System RAM: total: 32 GiB available: 30.91 GiB used: 7.25 GiB (23.5%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: spec: 6400 MT/s actual: 6000 MT/s volts: curr: 0.5
    min: 0.5 max: 0.5 width (bits): data: 16 total: 16 manufacturer: Samsung
    part-no: K3KL9L90CM-MGCT serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: 13th Gen Intel Core i7-13700H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x4123
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 783 min/max: 400/4800:5000:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 783 2: 783 3: 783 4: 783
    5: 783 6: 783 7: 783 8: 783 9: 783 10: 783 11: 783 12: 783 13: 783 14: 783
    15: 783 16: 783 17: 783 18: 783 19: 783 20: 783 bogomips: 116780
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Samsung Co
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 7 (10nm)
    built: 2022+ ports: active: HDMI-A-1 off: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:a7a0
    class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
    vendor: Samsung Co driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:28a1 class-ID: 0302
  Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
    dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung LU28R55 serial: <filter>
    built: 2023 res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 154 gamma: 1.2
    chroma: red: x: 0.678 y: 0.314 green: x: 0.267 y: 0.620 blue: x: 0.145
    y: 0.059 white: x: 0.314 y: 0.329 size: 632x360mm (24.88x14.17")
    diag: 727mm (28.6") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95
  Monitor-2: eDP-1 note: disabled pos: primary model: Samsung 0x4185
    built: 2022 res: 3840x2160 dpi: 213 gamma: 1.2 chroma: red: x: 0.682
    y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white: x: 0.306
    y: 0.322 size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 2880x1800
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 15.09 GiB unified: yes
    gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
  Device-1: Intel Raptor Lake IPU vendor: Samsung Co driver: intel-ipu6
    alternate: intel_ipu6 bus-ID: 00:05.0 chip-ID: 8086:a75d class-ID: 0480
  Device-2: Intel Raptor Lake-P/U/H cAVS vendor: Samsung Co
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.4 TiB used: 127.5 GiB (8.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Micron model: MTFDHBA512QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: 0013P6LN temp: 55.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00B
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: GXA7FK2Q temp: 47.9 C
    scheme: GPT
  ID-1: / raw-size: 944.87 GiB size: 928.96 GiB (98.32%)
    used: 127.32 GiB (13.7%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3
    label: N/A uuid: 7a40bd80-7d01-4849-834d-9d9734a432e0
  ID-2: /boot/efi raw-size: 1022 MiB size: 1020 MiB (99.80%)
    used: 187.8 MiB (18.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
    label: N/A uuid: 391F-3024
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p4 maj-min: 259:4 label: N/A
    uuid: 4332f6fe-6778-463b-8750-a654e71d2826
  ID-1: /dev/nvme0n1p1 maj-min: 259:6 size: 476.94 GiB fs: ext4 label: N/A
    uuid: a58d4bc2-22f5-4156-a117-44342004c96b
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 4 GiB fs: vfat label: N/A
    uuid: 391F-3028
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-4: 3-2:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 3-2.2:4 info: Keychron V1 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0311 class-ID: 0300
  Device-2: 3-3:3 info: Dell Universal Receiver type: keyboard,mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 413c:8505 class-ID: 0300
  Device-3: 3-5:5 info: LighTuning ETU905A80-E type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 1c7a:05a1 class-ID: ff00 serial: <filter>
  Device-4: 3-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Src: /sys System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
  Packages: 1140 pm: pacman pkgs: 1123 libs: 332 tools: pamac,yay pm: flatpak
    pkgs: 8 pm: snap pkgs: 9
    1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    4: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    6: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    7: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 407
  1: cpu: 100% command: ps pid: 6622 mem: 3.15 MiB (0.0%)
  2: cpu: 9.4% command: slack pid: 4694 mem: 522.1 MiB (1.6%)
  3: cpu: 8.8% command: brave pid: 1958 mem: 229.7 MiB (0.7%)
  4: cpu: 8.3% command: brave pid: 2297 mem: 646.6 MiB (2.0%)
  5: cpu: 7.9% command: brave pid: 1917 mem: 559.2 MiB (1.7%)
  Memory top: 5 of 407
  1: mem: 646.6 MiB (2.0%) command: brave pid: 2297 cpu: 8.3%
  2: mem: 559.2 MiB (1.7%) command: brave pid: 1917 cpu: 7.9%
  3: mem: 522.1 MiB (1.6%) command: slack pid: 4694 cpu: 9.4%
  4: mem: 380.5 MiB (1.2%) command: brave pid: 5063 cpu: 1.9%
  5: mem: 334.8 MiB (1.0%) command: brave pid: 5992 cpu: 4.3%
  Processes: 407 Power: uptime: 43m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.33 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: ghostty
    inxi: 3.3.37
lscpu
Architecture:                         x86_64
CPU op-mode(s):                       32-bit, 64-bit
Address sizes:                        39 bits physical, 48 bits virtual
Byte Order:                           Little Endian
CPU(s):                               20
On-line CPU(s) list:                  0-19
Vendor ID:                            GenuineIntel
Model name:                           13th Gen Intel(R) Core(TM) i7-13700H
CPU family:                           6
Model:                                186
Thread(s) per core:                   2
Core(s) per socket:                   14
Socket(s):                            1
Stepping:                             2
CPU(s) scaling MHz:                   14%
CPU max MHz:                          5000,0000
CPU min MHz:                          400,0000
BogoMIPS:                             5839,00
Flags:                                fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
Virtualization:                       VT-x
L1d cache:                            544 KiB (14 instances)
L1i cache:                            704 KiB (14 instances)
L2 cache:                             11,5 MiB (8 instances)
L3 cache:                             24 MiB (1 instance)
NUMA node(s):                         1
NUMA node0 CPU(s):                    0-19
Vulnerability Gather data sampling:   Not affected
Vulnerability Itlb multihit:          Not affected
Vulnerability L1tf:                   Not affected
Vulnerability Mds:                    Not affected
Vulnerability Meltdown:               Not affected
Vulnerability Mmio stale data:        Not affected
Vulnerability Reg file data sampling: Mitigation; Clear Register File
Vulnerability Retbleed:               Not affected
Vulnerability Spec rstack overflow:   Not affected
Vulnerability Spec store bypass:      Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1:             Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2:             Mitigation; Enhanced / Automatic IBRS; IBPB conditional; RSB filling; PBRSB-eIBRS SW sequence; BHI BHI_DIS_S
Vulnerability Srbds:                  Not affected
Vulnerability Tsx async abort:        Not affected
mhwd
Installed PCI configs:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
mhwd-kernel -li
Currently running: 6.12.4-1-MANJARO (linux612)
   * linux612
lsb_release -sirc
ManjaroLinux 24.2.1 Yonada
lspci -k
00:00.0 Host bridge: Intel Corporation Raptor Lake-P 6p+8e cores Host Bridge/DRAM Controller
	DeviceName: Onboard - Other
	Subsystem: Samsung Electronics Co Ltd Device c1cc
	Kernel driver in use: igen6_edac
	Kernel modules: igen6_edac
00:01.0 PCI bridge: Intel Corporation Raptor Lake PCI Express 5.0 Graphics Port (PEG010)
	Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-P [Iris Xe Graphics] (rev 04)
	DeviceName: Onboard - Video
	Kernel driver in use: i915
	Kernel modules: i915, xe
00:04.0 Signal processing controller: Intel Corporation Raptor Lake Dynamic Platform and Thermal Framework Processor Participant
	Kernel driver in use: proc_thermal_pci
	Kernel modules: processor_thermal_device_pci
00:05.0 Multimedia controller: Intel Corporation Raptor Lake IPU
	DeviceName: Onboard - Sound
	Kernel driver in use: intel-ipu6
	Kernel modules: intel_ipu6
00:06.0 PCI bridge: Intel Corporation Raptor Lake PCIe 4.0 Graphics Port
00:06.2 PCI bridge: Intel Corporation Device a73d
00:07.0 PCI bridge: Intel Corporation Raptor Lake-P Thunderbolt 4 PCI Express Root Port #0
00:07.2 PCI bridge: Intel Corporation Raptor Lake-P Thunderbolt 4 PCI Express Root Port #2
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module
00:0d.0 USB controller: Intel Corporation Raptor Lake-P Thunderbolt 4 USB Controller
	Kernel driver in use: xhci_hcd
00:0d.2 USB controller: Intel Corporation Raptor Lake-P Thunderbolt 4 NHI #0
	Subsystem: Device 2222:1111
	Kernel driver in use: thunderbolt
	Kernel modules: thunderbolt
00:0d.3 USB controller: Intel Corporation Raptor Lake-P Thunderbolt 4 NHI #1
00:10.0 Serial bus controller: Intel Corporation Alder Lake-P Serial IO I2C Controller #2 (rev 01)
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
00:12.0 Serial controller: Intel Corporation Alder Lake-P Integrated Sensor Hub (rev 01)
	Kernel driver in use: intel_ish_ipc
	Kernel modules: intel_ish_ipc
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
00:14.3 Network controller: Intel Corporation Raptor Lake PCH CNVi WiFi (rev 01)
	DeviceName: Onboard - Ethernet
	Subsystem: Intel Corporation Device 0094
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:19.0 Serial bus controller: Intel Corporation Alder Lake-P Serial IO I2C Controller #0 (rev 01)
00:1f.0 ISA bridge: Intel Corporation Raptor Lake LPC/eSPI Controller (rev 01)
00:1f.3 Multimedia audio controller: Intel Corporation Raptor Lake-P/U/H cAVS (rev 01)
	Kernel driver in use: sof-audio-pci-intel-tgl
	Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
	Kernel driver in use: intel-spi
	Kernel modules: spi_intel_pci
01:00.0 3D controller: NVIDIA Corporation AD107M [GeForce RTX 4050 Max-Q / Mobile] (rev a1)
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
	Subsystem: Samsung Electronics Co Ltd SSD 980 PRO
	Kernel driver in use: nvme
	Kernel modules: nvme
03:00.0 Non-Volatile memory controller: Micron Technology Inc 2210 NVMe SSD [Cobain] (rev 03)
	Subsystem: Micron Technology Inc Device 1100
When the camera is no found - then driver is missing.
I read somewhere that certain Intel camera boards has poor support in the Linux kernel (IPU type) and we have had a number of related issues over time.
âžś  ~ pamac build intel-ivsc-firmware
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Error: target not found: intel-ivsc-firmware
I ran the upgrade and rebooted before running the build command.
This is a bug in pamac CLI - it has been known for some time
When combining AUR and Manjaro - especially for such lowlevel as kernel modules - it is mandatory change branch to either unstable or testing branch.
sudo pacman-mirrors --api --set-branch unstable
sudo pacman -Syu git base-devel --needed
git clone https://aur.archlinux.org/intel-ivsc-firmware
cd intel-ivsc-firmware
makepkg -is
I’ve obviously solved that problem for you now. :slight_smile:
And, did you? This post isn’t very clear.
Try again; but, please provide the full output of the completed command:
Additional:
I notice the AUR package you are trying to install hasn’t been updated since 2022, and there a comment seems to suggest it needs to be updated for compatibility reasons.
That link for the repository does not exist anymore.
âžś  ~ pamac upgrade -a --force-refresh
Preparing...
Authenticating as: daniel
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Nothing to do.
pamac upgrade -a --force-refresh  3,60s user 0,79s system 36% cpu 11,901 total
Preparing...
Checking intel-ivsc-firmware dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  intel-ivsc-firmware  r2.764bd6e-1    AUR
Edit build files : [e]
Apply transaction ? [e/y/N] Y
Cloning intel-ivsc-firmware build files...
Error: Failed to prepare transaction: Failed to clone intel-ivsc-firmware build files
It is probably related to the repository not being available anymore if it is trying to get to: https://aur.archlinux.org/intel-ivsc-firmware
Yet, if you try with the correct URL, there it is; the page, at least.
You might check your mirrors:
I see several are currently offline.
Try sorting your mirrors, before attempting the build again:
sudo pacman-mirrors --continent
It still fails the same way:
I have updated the mirrors. I’m in Brazil, and they are not offline.
Let’s not spend more time on this.
I appreciate the patience and attention, but it looks like I’ll have to wait a while.
Works for me to build package from GitHub - intel/ivsc-firmware
$ pamac info intel-ivsc-firmware
Version               : r12.74a01d1-1
Description           : Intel Vision Sensing Controller firmware
URL                   : https://github.com/intel/ivsc-firmware
Licences              : custom
Repository            : AUR
Installed Size        : 11.5 MB
Groups                : --
Depends On            : --
Optional Dependencies : --
Make Dependencies     : git
Check Dependencies    : --
Required By           : --
Optional For          : --
Provides              : intel-ivsc-firmware
Replaces              : --
Conflicts With        : --
Packager              : Unknown Packager
Maintainer            : thesola10
First Submitted       : Sat 20 Aug 2022 21:54:24 BST
Last Modified         : Wed 24 Aug 2022 18:36:30 BST
Votes                 : 0
Out of Date           : Wed 31 Jul 2024 11:20:37 BST
Build Date            : Mon 27 Jan 2025 08:59:54 GMT
Install Date          : Mon 27 Jan 2025 09:00:05 GMT
Install Reason        : Explicitly installed
Validated By          : None
Backup files          : --
All I can say, after having looked at it and tried:
intel-ivsc-firmware
is needed by (depends on):
intel-ipu6-dkms-git
and both of these AUR packages did build and install flawlessly
when I built them using yay instead of pamac.
I did it in this order - the wrong way around …:
yay -S intel-ipu6-dkms-git
No problems here - but:
the camera is nowhere to be seen (is not detected at all)
The system does not see it - and that won’t change by installing these two packages. :man_shrugging:
To the extent they may be useful for the OP (or others) I’ll post these links I’ve found which (combined) seem to lead to a successful outcome:
Given the current status of the maintainer and repository (as mentioned above) these links may lead to the only workaround possible.
