Installing on a lenovo legion laptop
Hello, I’m trying to install Manjaro on a new laptop and I’m getting “Bootloader installation error” . From the logs I see that grub-install failed with code 127, but nothing more. How can I get more info to debug?
I ran manjaro-chroot -a to take a look and figure stuff out but the installation is all kinds of wierd. pacman keeps failing with signature errors on everything, grub is installed but grub-install does not exist, grub-mkconfig exists but /boot/grub/grub.cfg was not generated and the journal is empty…
Logs: http://termbin.com/ixiv0
iso: manjaro-kde-24.0.3-240702-linux69.iso
laptop: Lenovo Legion 16ARP9
CPU: Ryzen 7 7735HS
GPU: GeForce RTX 4070
I’m assuming you verified the .ISO? If not, do so — this is important. Sounds like a corrupted download; this can happen sometimes.
sha256sum -c manjaro-kde-24.0.3-240702-linux69.iso.sha256
:smiley:
It looks like Calamares failed to create a GUID Partition Table (GPT) properly, and subsequent partitions also failed. The question from @BG405 is warranted:
Although this might be part of an ongoing saga with Calamares and/or udev2 that I keep noticing.
I suggest a complete new install after downloading the latest full ISO.
What I might do is install using the manual partitioning method, no encryption (this can be done later, manually). Use EXT4 and not BTRFS, and triple check all configuration before committing to the install.
That is all. Cheers.
This is the latest full kde iso and it passed the hash check, maybe I should try a different DE image?
I’ll try the manual partitioning, but as I see it chroot worked after the install failed, so there is a filesystem there.
Update: manual partitioning didnt help.
Skimming over the provided log in the paste link.
The file system is created as expected and mounted and filled
2024-07-26 - 18:56:48 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-26 - 18:56:48 [6]:     .. Job description from pretty_name "mount" = "Mounting partitions."
2024-07-26 - 18:56:48 [6]:     .. Running ("mount", "-t", "ext4", "/dev/nvme0n1p2", "/tmp/calamares-root-fpt_n3ug/")
2024-07-26 - 18:56:48 [6]:     .. Running ("udevadm", "settle")
2024-07-26 - 18:56:48 [6]:     .. Running ("sync")
2024-07-26 - 18:56:48 [6]:     .. Running ("mount", "-t", "vfat", "/dev/nvme0n1p1", "/tmp/calamares-root-fpt_n3ug/boot/efi")
The mhwd script fails - it that is a deal breaker I cannot deduce as there is a fallback to the opensource AMD driver as the Ryzen 7 7735HS is an APU providing AMD Radeon™ 680M .
The next error is bootloader please see → [root tip] [How To] Troubleshoot Calamares installer errors.
Try running the installer with opensource drivers.
You can always add the nvidia driver later.
There is a slightly newer iso 24.0.4 on Manjaro Linux - Browse /kde at SourceForge.net
Opensource driver log: http://termbin.com/0l5a
Its the same result.
The bootloader topic doesn’t seam relevant, boot mode is UEFI, on a side note I haven’t seen a BIOS stripped down so much before, I don’t think there is even an option for legacy.
As this shaping up to be a gpu driver issue, I noticed in the BIOS there is a big switch for hybrid / discreet GPU, until now it was set to hybrid.
I’ll try the newer image next, and experiment with the GPU switch in BIOS.
The ISO you are using 240702 appear to fail with the Nvidia driver installation by the mhwd script.
I suggest you fetch the latest ISO using the sourceforge link mentioned above.
Setting the firmware to hybrid allows the system to boot with free drivers.
Setting to discrete you need the boot with proprietary mode.
It seems the command grub-install referenced in the setup logic is missing
/usr/sbin/chroot: failed to run command 'grub-install': No such file or directory
This means the ISO is incomplete - not your fault - I don’t know what went wrong - I believe it should have been addressed back in May when the stable ISO was done after Plasma 6 release.
Before running the installer - open a terminal and sync the package install-grub, then run the installer
sudo pacman -Syu install-grub
Full content of OP's log posted to termbin
for more stable/permanent reference:
=== START CALAMARES 3.2.62-9
2024-07-27 - 07:51:24 [6]: void CalamaresApplication::init()
    Calamares version: 3.2.62-9
2024-07-27 - 07:51:24 [6]:     .. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, oc, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
2024-07-27 - 07:51:24 [6]: bool CalamaresUtils::initQmlModulesDir()
    Using Calamares QML directory "/usr/share/calamares/qml"
2024-07-27 - 07:51:24 [6]: Calamares::Branding::Branding(const QString&, QObject*)
    Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2024-07-27 - 07:51:24 [2]: Calamares::Branding::Branding(const QString&, QObject*)
    WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
    Loaded branding component "manjaro"
2024-07-27 - 07:51:24 [6]:     .. No translation for "tz_" "C" using default (en)
2024-07-27 - 07:51:24 [6]:     .. No translation for "calamares_" "C" using default (en)
2024-07-27 - 07:51:24 [6]:     .. STARTUP: initSettings, initQmlPath, initBranding done
2024-07-27 - 07:51:24 [6]:     .. STARTUP: initModuleManager: module init started
2024-07-27 - 07:51:24 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
    WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2024-07-27 - 07:51:24 [2]: WARNING:     ..  Module descriptor contains extra keys:
     "requires"
2024-07-27 - 07:51:24 [6]: void Calamares::ModuleManager::doInit()
    Found 57 modules
2024-07-27 - 07:51:24 [6]: void CalamaresApplication::initView()
    STARTUP: initModuleManager: all modules init done
    STARTUP: initJobQueue done
2024-07-27 - 07:51:24 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
    Available desktop QSize(2560, 1556) minimum size QSize(1024, 520)
2024-07-27 - 07:51:24 [6]:     .. Proposed window size: 1024 560
2024-07-27 - 07:51:24 [6]: QString CalamaresUtils::searchQmlFile(QmlSearch, const QString&)
    Looking for QML for "calamares-sidebar"
2024-07-27 - 07:51:24 [6]:     .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
    STARTUP: CalamaresWindow created; loadModules started
2024-07-27 - 07:51:24 [6]: void Config::initLanguages()
    Trying to match locale "C"
    Trying to match locale QLocale(C, Default, Default)
2024-07-27 - 07:51:24 [6]:     .. Trying to match approximate locale QLocale::C
2024-07-27 - 07:51:24 [6]:     .. Trying to match English (US)
2024-07-27 - 07:51:24 [6]: void Config::setLocaleIndex(int)
    Index 14 Selected locale "en"
2024-07-27 - 07:51:24 [6]:     .. Loaded QRC translation "tz_" "en"
2024-07-27 - 07:51:24 [6]:     .. Loaded QRC translation "calamares_" "en"
2024-07-27 - 07:51:24 [2]:   OpenType support missing for "Mukti Narrow", script 12
2024-07-27 - 07:51:24 [2]:   OpenType support missing for "Droid Sans", script 11
2024-07-27 - 07:51:24 [6]: virtual void Calamares::ViewModule::loadSelf()
    ViewModule "welcome@welcome" loading complete.
2024-07-27 - 07:51:24 [6]: QStringList loadLocales(const QString&)
    Loading locales from "/usr/share/i18n/SUPPORTED"
2024-07-27 - 07:51:24 [6]:     ..  Read 498 lines
2024-07-27 - 07:51:24 [6]:     ..  After filtering 323 lines
    ViewModule "locale@locale" loading complete.
2024-07-27 - 07:51:24 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
    Loaded 180 keyboard models
2024-07-27 - 07:51:24 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
    Variants now total= 0 selected= -1
2024-07-27 - 07:51:24 [6]:     .. Loaded QRC translation "kb_" "en"
2024-07-27 - 07:51:24 [6]: void Config::detectCurrentKeyboardLayout()
    ("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
2024-07-27 - 07:51:25 [6]: virtual void Calamares::ViewModule::loadSelf()
    ViewModule "keyboard@keyboard" loading complete.
2024-07-27 - 07:51:25 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
    KPMCore backend starting ..
2024-07-27 - 07:51:25 [6]: Loaded backend plugin:  "pmsfdiskbackendplugin"
2024-07-27 - 07:51:25 [6]:     .. Backend @0x653ca15ac5d0 "pmsfdiskbackendplugin" "1"
2024-07-27 - 07:51:25 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
    WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
    ViewModule "partition@partition" loading complete.
2024-07-27 - 07:51:25 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
    WARNING: Legacy *users* key "userShell" overrides hostname-settings.
    ViewModule "users@users" loading complete.
2024-07-27 - 07:51:25 [6]: virtual void Config::setConfigurationMap(const QVariantMap&)
    Using module ID "packagechooser@packagechooser"
2024-07-27 - 07:51:25 [6]: void fillModel(PackageListModel*, const QVariantList&)
    Loading PackageChooser model items from config
2024-07-27 - 07:51:25 [6]:     .. Loaded PackageChooser with 3 entries.
2024-07-27 - 07:51:25 [2]: QPixmap::scaled: Pixmap is a null pixmap
    ViewModule "packagechooser@packagechooser" loading complete.
    ViewModule "summary@summary" loading complete.
2024-07-27 - 07:51:25 [6]: void Calamares::ModuleManager::loadModules()
    Module "partition@partition" already loaded.
2024-07-27 - 07:51:25 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
    QML import paths:
     "/usr/bin"
     "qrc:/qt-project.org/imports"
     "/usr/lib/qt/qml"
    QML load on startup, API 2.
2024-07-27 - 07:51:25 [2]: QThread::setPriority: Cannot set priority, thread is not running
2024-07-27 - 07:51:25 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
    WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2024-07-27 - 07:51:25 [6]: virtual void Calamares::CppJobModule::loadSelf()
    CppJobModule "machineid@machineid" loading complete.
    Module "locale@locale" already loaded.
    Module "keyboard@keyboard" already loaded.
    CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
    CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
    CppJobModule "initcpio@initcpio" loading complete.
    Module "users@users" already loaded.
    CppJobModule "umount@umount" loading complete.
2024-07-27 - 07:51:25 [2]: void Config::setConfigurationMap(const QVariantMap&)
    WARNING: Configuring the finished module with deprecated restartNowEnabled settings
    ViewModule "finished@finished" loading complete.
2024-07-27 - 07:51:25 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
    GeoIP result for welcome= "HU"
2024-07-27 - 07:51:25 [6]: void Config::setLocaleIndex(int)
    Index 29 Selected locale "hu"
2024-07-27 - 07:51:25 [6]:     .. No translation for "tz_" "hu" using default (en)
2024-07-27 - 07:51:25 [6]:     .. Loaded QRC translation "calamares_" "hu"
2024-07-27 - 07:51:25 [6]:     .. No translation for "kb_" "hu" using default (en)
2024-07-27 - 07:51:25 [6]: void CalamaresApplication::initViewSteps()
    STARTUP: loadModules for all modules done
2024-07-27 - 07:51:25 [6]: void Calamares::ModuleManager::checkRequirements()
    Checking module requirements ..
    STARTUP: Window now visible and ProgressTreeView populated
2024-07-27 - 07:51:25 [6]:     .. 9 view steps loaded.
2024-07-27 - 07:51:25 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
    QML component complete, API 2
2024-07-27 - 07:51:25 [6]: bool GeneralRequirements::checkHasPower()
    A battery exists, checking for mains power.
2024-07-27 - 07:51:25 [2]: file:///usr/share/calamares/branding/manjaro/slideshow/sponsor/SponsoredBy.qml: No such file or directory
2024-07-27 - 07:51:25 [6]:     .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2024-07-27 - 07:51:25 [6]: void Config::xkbApply()
    xkbmap selection changed to:  "us" - ""
2024-07-27 - 07:51:25 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
    GeneralRequirements output:
     storage :   8482560409
     enoughStorage :   true
     RAM :   1073741824
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
2024-07-27 - 07:51:25 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
    Got 5 requirement results from "welcome"
2024-07-27 - 07:51:25 [6]: getting temp failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 07:51:25 [6]: getting powered on time failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 07:51:25 [6]: getting power cycles failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 07:51:25 [6]: smartctl initialization failed for  "/dev/sda" :  No such file or directory
2024-07-27 - 07:51:25 [6]: error during smart output parsing for  "/dev/sda" :  Success
2024-07-27 - 07:51:25 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
    Removing unsuitable devices: 2 candidates.
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "/dev/nvme0n1")
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "")
2024-07-27 - 07:51:25 [6]:     .. Target cmd: ("blkid", "") Exit code: 2 (no output)
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "/dev/nvme0n1p1")
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "/dev/nvme0n1p2")
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "/dev/nvme0n1p3")
2024-07-27 - 07:51:25 [6]:     .. Running ("blkid", "/dev/sda")
2024-07-27 - 07:51:25 [6]:     .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sda"
2024-07-27 - 07:51:25 [6]:     .. there are 1 devices left.
2024-07-27 - 07:51:25 [6]: void PartitionCoreModule::doInit()
    LIST OF DETECTED DEVICES:
2024-07-27 - 07:51:25 [6]:     .. node	capacity	name	prettyName
2024-07-27 - 07:51:25 [6]:     .. "/dev/nvme0n1" 512105932800 DevName$e00b8a2b DevNamePretty$1cccc6b
2024-07-27 - 07:51:25 [6]:     .. 1 devices detected.
2024-07-27 - 07:51:26 [6]: void Calamares::RequirementsChecker::reportProgress()
    Remaining modules: 1
     "partition"
2024-07-27 - 07:51:27 [6]:     .. Running ("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p2")
2024-07-27 - 07:51:27 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
    Checking device "/dev/nvme0n1p2" for fstab (fs= "ext4" )
2024-07-27 - 07:51:27 [6]:     .. Running ("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-SmeoHm")
2024-07-27 - 07:51:27 [6]:     .. Running ("udevadm", "settle")
2024-07-27 - 07:51:27 [6]:     .. Running ("sync")
2024-07-27 - 07:51:27 [6]:     .. got 12 fstab entries from 12 lines in "/tmp/calamares-SmeoHm/etc/fstab"
2024-07-27 - 07:51:27 [6]:     .. Running ("umount", "-R", "/tmp/calamares-SmeoHm")
2024-07-27 - 07:51:27 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
    Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2024-07-27 - 07:51:27 [6]:     ..  os-prober lines after cleanup:
     "/dev/nvme0n1p2:Manjaro Linux (24.0.3):ManjaroLinux:linux"
2024-07-27 - 07:51:27 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
    system is EFI and new EFI system partition has been found.
2024-07-27 - 07:51:27 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
    Got 1 requirement results from "partition"
2024-07-27 - 07:51:27 [6]: void ChoicePage::updateDeviceStatePreview()
    Updating partitioning state widgets.
2024-07-27 - 07:51:27 [6]: void ChoicePage::setupActions()
    Setting up actions for "/dev/nvme0n1" with 1 entries.
2024-07-27 - 07:51:27 [6]:     ..  Can not resize "/dev/nvme0n1" , filesystem "unknown" does not support resize.
2024-07-27 - 07:51:27 [6]:     ..  Checking if "/dev/nvme0n1" can be replaced.
2024-07-27 - 07:51:27 [6]:     ..  NO, insufficient storage
     Required  storage B: 9019431321 "(7.9GiB)"
     Available storage B: 1048576 "(0GiB)"
2024-07-27 - 07:51:27 [6]:     ..  Can not resize "/dev/nvme0n1p1" , filesystem "fat32" does not support resize.
2024-07-27 - 07:51:27 [6]:     ..  Checking if "/dev/nvme0n1p1" can be replaced.
     Available storage B: 314572800 "(0GiB)"
2024-07-27 - 07:51:27 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2024-07-27 - 07:51:27 [6]:     .. contains resizable "/dev/nvme0n1p2"
2024-07-27 - 07:51:27 [6]:     ..  Checking if "/dev/nvme0n1p2" can be replaced.
2024-07-27 - 07:51:27 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for replace install.
2024-07-27 - 07:51:27 [6]:     .. contains replaceable "/dev/nvme0n1p2"
     Required  storage B: 11166914969 "(10.4GiB)"
     Available storage B: 9448928256 "(8GiB)" for "/dev/nvme0n1p3" length: 18454938 sectorsUsed: 0 fsType: "linuxswap"
2024-07-27 - 07:51:27 [6]:     ..  Checking if "/dev/nvme0n1p3" can be replaced.
2024-07-27 - 07:51:27 [6]:     ..  Partition "/dev/nvme0n1p3" authorized for replace install.
2024-07-27 - 07:51:27 [6]:     .. contains replaceable "/dev/nvme0n1p3"
     Available storage B: 4240896 "(0GiB)"
2024-07-27 - 07:51:27 [6]: ChoicePage::setupActions()::<lambda()>
    Setting texts for 1 non-empty osprober entry
2024-07-27 - 07:51:27 [6]: void ChoicePage::continueApplyDeviceChoice()
    Previous device -1 new device 0
2024-07-27 - 07:51:27 [6]: void ChoicePage::applyActionChoice(InstallChoice)
    Prev -1 InstallChoice Config::Erase "erase"
2024-07-27 - 07:51:27 [6]: PartitionTable* CreatePartitionTableJob::createTable()
    CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2024-07-27 - 07:51:27 [6]: void Calamares::RequirementsChecker::finished()
    All requirements have been checked.
2024-07-27 - 07:51:27 [6]: void Calamares::RequirementsModel::describe() const
    Requirements model has 6 items
2024-07-27 - 07:51:27 [6]:     .. requirement 0 "storage" satisfied? true mandatory? true
2024-07-27 - 07:51:27 [6]:     .. requirement 1 "ram" satisfied? true mandatory? true
2024-07-27 - 07:51:27 [6]:     .. requirement 2 "power" satisfied? true mandatory? false
2024-07-27 - 07:51:27 [6]:     .. requirement 3 "internet" satisfied? true mandatory? false
2024-07-27 - 07:51:27 [6]:     .. requirement 4 "root" satisfied? true mandatory? true
2024-07-27 - 07:51:27 [6]:     .. requirement 5 "partitions" satisfied? true mandatory? true
2024-07-27 - 07:51:27 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
    WARNING: system is EFI but no EFI system partitions found.
2024-07-27 - 07:51:28 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2024-07-27 - 07:51:28 [6]: void PartitionCoreModule::dumpQueue() const
    # Queue:
2024-07-27 - 07:51:28 [6]:     .. ## Device: "/dev/nvme0n1"
2024-07-27 - 07:51:28 [6]:     .. - CreatePartitionTableJob
2024-07-27 - 07:51:28 [6]:     .. - CreatePartitionJob
2024-07-27 - 07:51:28 [6]:     .. - SetPartFlagsJob
2024-07-27 - 07:51:28 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
    Updating partitioning preview widgets.
2024-07-27 - 07:51:32 [6]: void Config::setLocaleIndex(int)
    Index 15 Selected locale "en_GB"
2024-07-27 - 07:51:32 [6]:     .. Loaded QRC translation "tz_" "en_GB"
2024-07-27 - 07:51:32 [6]:     .. Loaded QRC translation "calamares_" "en_GB"
2024-07-27 - 07:51:32 [6]:     .. Loaded QRC translation "kb_" "en_GB"
2024-07-27 - 07:51:32 [6]: ChoicePage::setupActions()::<lambda()>
2024-07-27 - 07:51:34 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
    Mapping "en_GB" in "HU" to locale.
2024-07-27 - 07:51:34 [6]:     .. Got best match for "en_GB" as "en_GB.UTF-8"
2024-07-27 - 09:51:34 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2024-07-27 - 09:51:34 [6]:     .. Got best match for "en_GB" as "en_GB.UTF-8"
2024-07-27 - 09:51:38 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
    Mapping "en_GB" in "PL" to locale.
2024-07-27 - 09:51:38 [6]:     .. Got best match for "en_GB" as "en_GB.UTF-8"
2024-07-27 - 09:51:55 [6]: void Config::guessLocaleKeyboardLayout()
    Got locale language "en_GB.UTF-8"
2024-07-27 - 09:51:55 [6]:     .. looking for locale part "GB"
2024-07-27 - 09:51:55 [6]:     .. matched "gb"
2024-07-27 - 09:51:56 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
    Next level: "en"
2024-07-27 - 09:51:56 [6]: void Config::xkbApply()
    xkbmap selection changed to:  "gb" - ""
2024-07-27 - 09:52:02 [6]: void Config::xkbApply()
2024-07-27 - 09:52:13 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2024-07-27 - 09:52:13 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2024-07-27 - 09:52:13 [6]: getting temp failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:13 [6]: getting powered on time failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:13 [6]: getting power cycles failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:13 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2024-07-27 - 09:52:13 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2024-07-27 - 09:52:13 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2024-07-27 - 09:52:13 [6]: qint64 PartitionActions::swapSuggestion(qint64, Config::SwapChoice)
    Suggested swap size: 8 GiB
2024-07-27 - 09:52:13 [6]: void PartitionCoreModule::dumpQueue() const
    # Queue:
2024-07-27 - 09:52:13 [6]:     .. ## Device: "/dev/nvme0n1"
2024-07-27 - 09:52:13 [6]:     .. - CreatePartitionTableJob
2024-07-27 - 09:52:13 [6]:     .. - CreatePartitionJob
2024-07-27 - 09:52:13 [6]:     .. - SetPartFlagsJob
2024-07-27 - 09:52:17 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2024-07-27 - 09:52:17 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2024-07-27 - 09:52:17 [6]: getting temp failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:17 [6]: getting powered on time failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:17 [6]: getting power cycles failed for  "/dev/nvme0n1" :  Success
2024-07-27 - 09:52:17 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2024-07-27 - 09:52:17 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2024-07-27 - 09:52:18 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2024-07-27 - 09:52:18 [6]: qint64 PartitionActions::swapSuggestion(qint64, Config::SwapChoice)
    Suggested swap size: 33 GiB
2024-07-27 - 09:52:18 [6]: void PartitionCoreModule::dumpQueue() const
    # Queue:
2024-07-27 - 09:52:18 [6]:     .. ## Device: "/dev/nvme0n1"
2024-07-27 - 09:52:18 [6]:     .. - CreatePartitionTableJob
2024-07-27 - 09:52:18 [6]:     .. - CreatePartitionJob
2024-07-27 - 09:52:18 [6]:     .. - SetPartFlagsJob
2024-07-27 - 09:52:56 [6]: void Config::updateGlobalStorage(const QStringList&) const
    QPair("packagechooser","packagechooser") selected "libreoffice-still"
2024-07-27 - 09:52:56 [2]: QObject::setParent: Cannot set parent, new parent is in a different thread
2024-07-27 - 09:52:56 [6]: virtual QString PartitionViewStep::prettyStatus() const
    Summary for Partition 1 Config::Erase
2024-07-27 - 09:52:56 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
    Checking LVM use on 1 devices
2024-07-27 - 09:52:56 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
    Building partition information map
2024-07-27 - 09:52:56 [6]:     .. partitions on "/dev/nvme0n1"
2024-07-27 - 09:52:56 [6]:     ..  mapping for "" "unallocated"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$1fb27792"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "unknown"
     fsName :   "unknown"
     filesystem-uuid (uuid) :   "FSUUID$90c9a5b1"
     claimed :   "false"
2024-07-27 - 09:52:56 [6]:     ..  mapping for "" "New Partition"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/boot/efi"
     fs: :   "fat32"
     fsName :   "fat32"
     claimed :   "true"
     partlabel :   "root"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "ext4"
     fsName :   "ext4"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     fsName :   "linuxswap"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "unknown"
     fsName :   "unknown"
     claimed :   "false"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     fs: :   "fat32"
     fsName :   "fat32"
     claimed :   "true"
     partlabel :   "root"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "ext4"
     fsName :   "ext4"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     claimed :   "true"
2024-07-27 - 09:52:56 [2]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "unknown"
     fsName :   "unknown"
     claimed :   "false"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     fs: :   "fat32"
     fsName :   "fat32"
     claimed :   "true"
     partlabel :   "root"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "ext4"
     fsName :   "ext4"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "unknown"
     fsName :   "unknown"
     claimed :   "false"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     fs: :   "fat32"
     fsName :   "fat32"
     claimed :   "true"
     partlabel :   "root"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "ext4"
     fsName :   "ext4"
     claimed :   "true"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     claimed :   "true"
2024-07-27 - 09:52:56 [6]: void ensureSize(QWidget*, QScrollArea*, Calamares::ViewStep*)
    Summary widget is larger than viewport, enlarge by 104 to QSize(834, 625)
2024-07-27 - 09:53:01 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
2024-07-27 - 09:53:01 [6]: void Calamares::JobThread::finalize()
    There are 36 jobs, total weight 33
2024-07-27 - 09:53:01 [6]:     .. Job 1 "Manage auto-mount settings" +wt 0.1 tot.wt 0.1
2024-07-27 - 09:53:01 [6]:     .. Job 2 "Clear all temporary mounts." +wt 0.1 tot.wt 0.2
2024-07-27 - 09:53:01 [6]:     .. Job 3 "Clear mounts for partitioning operations on /dev/nvme0n1" +wt 0.1 tot.wt 0.3
2024-07-27 - 09:53:01 [6]:     .. Job 4 "Create new gpt partition table on /dev/nvme0n1." +wt 0.1 tot.wt 0.4
2024-07-27 - 09:53:01 [6]:     .. Job 5 "Create new 300MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2)." +wt 0.1 tot.wt 0.5
2024-07-27 - 09:53:01 [6]:     .. Job 6 "Set flags on 300MiB fat32 partition." +wt 0.1 tot.wt 0.6
2024-07-27 - 09:53:01 [6]:     .. Job 7 "Create new 453676MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2) with entries root." +wt 0.1 tot.wt 0.7
2024-07-27 - 09:53:01 [6]:     .. Job 8 "Create new 34403MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2)." +wt 0.1 tot.wt 0.8
2024-07-27 - 09:53:01 [6]:     .. Job 9 "Set partition information" +wt 0.1 tot.wt 0.9
2024-07-27 - 09:53:01 [6]:     .. Job 10 "Manage auto-mount settings" +wt 0.1 tot.wt 1
2024-07-27 - 09:53:01 [6]:     .. Job 11 "mount" +wt 1 tot.wt 2
2024-07-27 - 09:53:01 [6]:     .. Job 12 "unpackfs" +wt 12 tot.wt 14
2024-07-27 - 09:53:01 [6]:     .. Job 13 "networkcfg" +wt 1 tot.wt 15
2024-07-27 - 09:53:01 [6]:     .. Job 14 "Generate machine-id." +wt 1 tot.wt 16
2024-07-27 - 09:53:01 [6]:     .. Job 15 "fstab" +wt 1 tot.wt 17
2024-07-27 - 09:53:01 [6]:     .. Job 16 "Set timezone to Europe/Warsaw" +wt 1 tot.wt 18
2024-07-27 - 09:53:01 [6]:     .. Job 17 "Set keyboard model to pc105, layout to us-" +wt 1 tot.wt 19
2024-07-27 - 09:53:01 [6]:     .. Job 18 "localecfg" +wt 1 tot.wt 20
2024-07-27 - 09:53:01 [6]:     .. Job 19 "Configuring encrypted swap." +wt 1 tot.wt 21
2024-07-27 - 09:53:01 [6]:     .. Job 20 "Configuring LUKS key file." +wt 1 tot.wt 22
2024-07-27 - 09:53:01 [6]:     .. Job 21 "initcpiocfg" +wt 1 tot.wt 23
2024-07-27 - 09:53:01 [6]:     .. Job 22 "Creating initramfs with mkinitcpio." +wt 1 tot.wt 24
2024-07-27 - 09:53:01 [6]:     .. Job 23 "Configure <pre>sudo</pre> users." +wt 0.166667 tot.wt 24.1667
2024-07-27 - 09:53:01 [6]:     .. Job 24 "Preparing groups." +wt 0.166667 tot.wt 24.3333
2024-07-27 - 09:53:01 [6]:     .. Job 25 "Create user slawo" +wt 0.166667 tot.wt 24.5
2024-07-27 - 09:53:01 [6]:     .. Job 26 "Set password for user slawo" +wt 0.166667 tot.wt 24.6667
2024-07-27 - 09:53:01 [6]:     .. Job 27 "Set password for user root" +wt 0.166667 tot.wt 24.8333
2024-07-27 - 09:53:01 [6]:     .. Job 28 "Set hostname Yukihime" +wt 0.166667 tot.wt 25
2024-07-27 - 09:53:01 [6]:     .. Job 29 "displaymanager" +wt 1 tot.wt 26
2024-07-27 - 09:53:01 [6]:     .. Job 30 "mhwdcfg" +wt 1 tot.wt 27
2024-07-27 - 09:53:01 [6]:     .. Job 31 "hwclock" +wt 1 tot.wt 28
2024-07-27 - 09:53:01 [6]:     .. Job 32 "services" +wt 1 tot.wt 29
2024-07-27 - 09:53:01 [6]:     .. Job 33 "grubcfg" +wt 1 tot.wt 30
2024-07-27 - 09:53:01 [6]:     .. Job 34 "bootloader" +wt 1 tot.wt 31
2024-07-27 - 09:53:01 [6]:     .. Job 35 "postcfg" +wt 1 tot.wt 32
2024-07-27 - 09:53:01 [6]:     .. Job 36 "Unmount file systems." +wt 1 tot.wt 33
2024-07-27 - 09:53:01 [6]: virtual void Calamares::JobThread::run()
    Starting job "Manage auto-mount settings" ( 1 / 36 )
2024-07-27 - 09:53:01 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
    Set automount to disable
2024-07-27 - 09:53:01 [6]: void CalamaresUtils::Partition::querySolidAutoMount(QDBusConnection&, AutoMountInfo&)
    Solid not available: "Not connected to D-Bus server"
    Starting job "Clear all temporary mounts." ( 2 / 36 )
    Starting job "Clear mounts for partitioning operations on /dev/nvme0n1" ( 3 / 36 )
2024-07-27 - 09:53:01 [6]: QStringList getPartitionsForDevice(const QString&)
    Reading from "/proc/partitions" looking for "nvme0n1"
2024-07-27 - 09:53:01 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
    ClearMountsJob finished. Here's what was done:
2024-07-27 - 09:53:01 [6]:     .. Running ("udevadm", "settle")
2024-07-27 - 09:53:01 [6]:     .. Running ("sync")
2024-07-27 - 09:53:02 [6]: virtual void Calamares::JobThread::run()
    Starting job "Create new gpt partition table on /dev/nvme0n1." ( 4 / 36 )
2024-07-27 - 09:53:02 [6]: virtual Calamares::JobResult CreatePartitionTableJob::exec()
    Creating new partition table of type "gpt" , uncommitted partitions:
2024-07-27 - 09:53:02 [6]:     .. "unallocated"
2024-07-27 - 09:53:02 [6]:     .. "New Partition"
2024-07-27 - 09:53:02 [6]:     .. Running ("lsblk")
2024-07-27 - 09:53:02 [6]:     .. lsblk output:
 NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0         7:0    0 149.6M  1 loop /run/miso/sfs/livefs
loop1         7:1    0 938.4M  1 loop /run/miso/sfs/mhwdfs
loop2         7:2    0   1.6G  1 loop /run/miso/sfs/desktopfs
loop3         7:3    0 814.8M  1 loop /run/miso/sfs/rootfs
sda           8:0    1  14.4G  0 disk /run/miso/bootmnt
|-sda1        8:1    1   3.6G  0 part
`-sda2        8:2    1     4M  0 part
nvme0n1     259:0    0 476.9G  0 disk
|-nvme0n1p1 259:1    0   300M  0 part
|-nvme0n1p2 259:2    0 467.8G  0 part
`-nvme0n1p3 259:3    0   8.8G  0 part
2024-07-27 - 09:53:02 [6]:     .. Running ("mount")
2024-07-27 - 09:53:02 [6]:     .. mount output:
 proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=15955836k,nr_inodes=3988959,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/sda on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8)
cowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)
overlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=24020172k,mode=755,inode64)
/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime,errors=continue,threads=single)
overlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,uuid=on,xino=off)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=38,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=9932)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=1048576,inode64)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/credentials/systemd-journald.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-udev-load-credentials.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/credentials/systemd-tmpfiles-setup-dev-early.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-sysctl.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-tmpfiles-setup-dev.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/credentials/systemd-vconsole-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)
tmpfs on /run/credentials/systemd-tmpfiles-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3202688k,nr_inodes=800672,mode=700,uid=1000,gid=1000,inode64)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
    Starting job "Create new 300MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2)." ( 5 / 36 )
2024-07-27 - 09:53:03 [6]: virtual void Calamares::JobThread::run()
    Starting job "Set flags on partition /dev/nvme0n1p1." ( 6 / 36 )
2024-07-27 - 09:53:03 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
    Setting flags on "/dev/nvme0n1" partition "/dev/nvme0n1p1"
     "boot"
    Starting job "Create new 453676MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2) with entries root." ( 7 / 36 )
2024-07-27 - 09:53:05 [6]: virtual void Calamares::JobThread::run()
    Starting job "Create new 34403MiB partition on /dev/nvme0n1 (SAMSUNG MZVL2512HDJD-00BL2)." ( 8 / 36 )
2024-07-27 - 09:53:06 [6]: virtual void Calamares::JobThread::run()
    Starting job "Set partition information" ( 9 / 36 )
2024-07-27 - 09:53:06 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
2024-07-27 - 09:53:06 [6]:     .. partitions on "/dev/nvme0n1"
2024-07-27 - 09:53:06 [6]:     ..  mapping for "" "unallocated"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "unknown"
     fsName :   "unknown"
     claimed :   "false"
2024-07-27 - 09:53:06 [6]:     ..  mapping for "/dev/nvme0n1p1" "/dev/nvme0n1p1"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     fs: :   "fat32"
     fsName :   "fat32"
     filesystem-uuid (uuid) :   "FSUUID$e1038eb4"
     claimed :   "true"
2024-07-27 - 09:53:06 [6]:     ..  mapping for "/dev/nvme0n1p2" "/dev/nvme0n1p2"
     partlabel :   "root"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "ext4"
     fsName :   "ext4"
     filesystem-uuid (uuid) :   "FSUUID$d8f77a22"
     claimed :   "true"
2024-07-27 - 09:53:06 [6]:     ..  mapping for "/dev/nvme0n1p3" "/dev/nvme0n1p3"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     filesystem-uuid (uuid) :   "FSUUID$1deaeb8d"
     claimed :   "true"
2024-07-27 - 09:53:06 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
    Saving partition information map to GlobalStorage["partitions"]
    FillGlobalStorageJob writing empty bootLoader value
    Starting job "Manage auto-mount settings" ( 10 / 36 )
2024-07-27 - 09:53:06 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
    Restore automount settings
2024-07-27 - 09:53:07 [6]: virtual void Calamares::JobThread::run()
    Starting job "mount" ( 11 / 36 )
2024-07-27 - 09:53:07 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/mount/main.py"
2024-07-27 - 09:53:07 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:53:07 [6]:     .. Job description from pretty_name "mount" = "Mounting partitions."
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "ext4", "/dev/nvme0n1p2", "/tmp/calamares-root-z3ry4jze/")
2024-07-27 - 09:53:07 [6]:     .. Running ("udevadm", "settle")
2024-07-27 - 09:53:07 [6]:     .. Running ("sync")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "vfat", "/dev/nvme0n1p1", "/tmp/calamares-root-z3ry4jze/boot/efi")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-z3ry4jze/dev")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "proc", "proc", "/tmp/calamares-root-z3ry4jze/proc")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "tmpfs", "tmpfs", "/tmp/calamares-root-z3ry4jze/run")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-z3ry4jze/run/udev")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "sysfs", "sys", "/tmp/calamares-root-z3ry4jze/sys")
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "efivarfs", "efivarfs", "/tmp/calamares-root-z3ry4jze/sys/firmware/efi/efivars")
    Starting job "unpackfs" ( 12 / 36 )
    Job file "/usr/lib/calamares/modules/unpackfs/main.py"
2024-07-27 - 09:53:07 [6]:     .. Job description from pretty_name "unpackfs" = "Filling up filesystems."
2024-07-27 - 09:53:07 [6]:     .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmph2vm2nkw/rootfs")
2024-07-27 - 09:53:07 [6]:     .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs")
2024-07-27 - 09:53:07 [6]:     .. Running ("rsync", "-aHAXr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--exclude", "/sys/firmware/efi/efivars/", "--progress", "/tmp/tmph2vm2nkw/rootfs/", "/tmp/calamares-root-z3ry4jze")
2024-07-27 - 09:53:21 [6]:     .. Target cmd: ("rsync", "-aHAXr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--exclude", "/sys/firmware/efi/efivars/", "--progress", "/tmp/tmph2vm2nkw/rootfs/", "/tmp/calamares-root-z3ry4jze") Exit code: 23 (no output)
2024-07-27 - 09:53:21 [6]:     .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmph2vm2nkw/desktopfs")
2024-07-27 - 09:53:21 [6]:     .. Running ("udevadm", "settle")
2024-07-27 - 09:53:21 [6]:     .. Running ("sync")
2024-07-27 - 09:53:22 [6]:     .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs")
2024-07-27 - 09:53:22 [6]:     .. Running ("rsync", "-aHAXr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--exclude", "/sys/firmware/efi/efivars/", "--progress", "/tmp/tmph2vm2nkw/desktopfs/", "/tmp/calamares-root-z3ry4jze")
2024-07-27 - 09:53:55 [6]: virtual void Calamares::JobThread::run()
    Starting job "networkcfg" ( 13 / 36 )
2024-07-27 - 09:53:55 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/networkcfg/main.py"
2024-07-27 - 09:53:55 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:53:55 [6]:     .. Job description from pretty_name "networkcfg" = "Saving network configuration"
    Starting job "Generate machine-id." ( 14 / 36 )
2024-07-27 - 09:53:55 [6]:     .. Running ("systemd-machine-id-setup")
2024-07-27 - 09:53:55 [6]:     .. Running ("ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id")
    Starting job "fstab" ( 15 / 36 )
    Job file "/usr/lib/calamares/modules/fstab/main.py"
2024-07-27 - 09:53:55 [6]:     .. Job description from pretty_name "fstab" = "Writing fstab."
    Starting job "Set timezone to Europe/Warsaw" ( 16 / 36 )
2024-07-27 - 09:53:55 [6]:     .. Running ("rm", "-f", "/etc/localtime")
2024-07-27 - 09:53:55 [6]:     .. Running ("ln", "-s", "/usr/share/zoneinfo/Europe/Warsaw", "/etc/localtime")
    Starting job "Set keyboard model to pc105, layout to us-" ( 17 / 36 )
2024-07-27 - 09:53:55 [6]: virtual Calamares::JobResult SetKeyboardLayoutJob::exec()
    Executing SetKeyboardLayoutJob
2024-07-27 - 09:53:55 [6]: bool SetKeyboardLayoutJob::writeVConsoleData(const QString&, const QString&) const
    Writing vconsole data to "/tmp/calamares-root-z3ry4jze/etc/vconsole.conf"
2024-07-27 - 09:53:55 [6]: QString SetKeyboardLayoutJob::findConvertedKeymap(const QString&) const
    Looking for converted keymap in "/tmp/calamares-root-z3ry4jze/lib/kbd/keymaps/xkb"
2024-07-27 - 09:53:55 [6]: QString findLegacyKeymap(const QString&, const QString&, const QString&)
    Looking for legacy keymap "us" "pc105" "" in QRC
2024-07-27 - 09:53:55 [6]:     .. Found legacy keymap "us" with score 11
2024-07-27 - 09:53:55 [6]:     .. Found legacy keymap "us-acentos" with score 11
2024-07-27 - 09:53:55 [6]:     .. Found legacy keymap "dvorak" with score 11
2024-07-27 - 09:53:55 [6]:     .. Written KEYMAP= "us" to vconsole.conf 0
2024-07-27 - 09:53:55 [6]: bool SetKeyboardLayoutJob::writeX11Data(const QString&) const
    Writing X11 configuration to "/tmp/calamares-root-z3ry4jze/etc/X11/xorg.conf.d/00-keyboard.conf"
2024-07-27 - 09:53:55 [6]:     .. Written XkbLayout "us" ; XkbModel "pc105" ; XkbVariant "" to X.org file "/tmp/calamares-root-z3ry4jze/etc/X11/xorg.conf.d/00-keyboard.conf" 0
2024-07-27 - 09:53:55 [6]: bool SetKeyboardLayoutJob::writeDefaultKeyboardData(const QString&) const
    Writing default keyboard data to "/tmp/calamares-root-z3ry4jze/etc/default/keyboard"
2024-07-27 - 09:53:55 [6]:     .. Written XKBMODEL "pc105" ; XKBLAYOUT "us" ; XKBVARIANT "" to /etc/default/keyboard file "/tmp/calamares-root-z3ry4jze/etc/default/keyboard" 0
    Starting job "localecfg" ( 18 / 36 )
    Job file "/usr/lib/calamares/modules/localecfg/main.py"
2024-07-27 - 09:53:55 [6]:     .. Job description from pretty_name "localecfg" = "Configuring locales."
2024-07-27 - 09:53:55 [6]:     .. Running ("locale-gen")
2024-07-27 - 09:53:57 [6]: [PYTHON JOB]: "/tmp/calamares-root-z3ry4jze/etc/locale.gen done"
2024-07-27 - 09:53:57 [6]: [PYTHON JOB]: "/tmp/calamares-root-z3ry4jze/etc/locale.conf done"
2024-07-27 - 09:53:57 [6]: [PYTHON JOB]: "/tmp/calamares-root-z3ry4jze/etc/default done"
2024-07-27 - 09:53:57 [6]: virtual void Calamares::JobThread::run()
    Starting job "Configuring encrypted swap." ( 19 / 36 )
2024-07-27 - 09:53:57 [6]: void write_openswap_conf(const QString&, QStringList&, const LOSHInfo&)
    Will not write an invalid configuration to "/etc/openswap.conf"
    Starting job "Configuring LUKS key file." ( 20 / 36 )
2024-07-27 - 09:53:57 [6]: virtual Calamares::JobResult LuksBootKeyFileJob::exec()
    There are 0 LUKS partitions
2024-07-27 - 09:53:57 [6]:     .. Nothing to do for LUKS.
    Starting job "initcpiocfg" ( 21 / 36 )
2024-07-27 - 09:53:57 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/initcpiocfg/main.py"
2024-07-27 - 09:53:57 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:53:57 [6]:     .. Job description from pretty_name "initcpiocfg" = "Configuring mkinitcpio."
2024-07-27 - 09:53:57 [6]:     .. Running ("sh", "-c", "which plymouth")
    Starting job "Creating initramfs with mkinitcpio." ( 22 / 36 )
2024-07-27 - 09:53:57 [6]: virtual Calamares::JobResult InitcpioJob::exec()
    Updating initramfs with kernel "linux69"
2024-07-27 - 09:53:57 [6]:     .. Running ("mkinitcpio", "-p", "linux69")
2024-07-27 - 09:54:23 [6]: virtual void Calamares::JobThread::run()
    Starting job "Configure <pre>sudo</pre> users." ( 23 / 36 )
    Starting job "Preparing groups." ( 24 / 36 )
    Starting job "Create user slawo" ( 25 / 36 )
2024-07-27 - 09:54:23 [6]: virtual Calamares::JobResult CreateUserJob::exec()
    [CREATEUSER]: creating user
2024-07-27 - 09:54:23 [6]:     .. Running ("useradd", "-m", "-U", "-s", "/bin/bash", "-c", "Slawomir", "slawo")
2024-07-27 - 09:54:23 [6]:     .. Running "usermod" "-aG" "lp,network,power,sys,wheel" "slawo"
2024-07-27 - 09:54:23 [6]:     .. Running ("chown", "-R", "slawo:slawo", "/home/slawo")
    Starting job "Set password for user slawo" ( 26 / 36 )
2024-07-27 - 09:54:23 [6]:     .. Running "usermod" "-p" <password> "slawo"
    Starting job "Set password for user root" ( 27 / 36 )
2024-07-27 - 09:54:23 [6]:     .. Running "usermod" "-p" <password> "root"
    Starting job "Set hostname Yukihime" ( 28 / 36 )
    Starting job "displaymanager" ( 29 / 36 )
2024-07-27 - 09:54:23 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/displaymanager/main.py"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:54:23 [6]:     .. Job description from __doc__ "displaymanager" = "Configure display managers."
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "lightdm selected but not installed"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "gdm selected but not installed"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "mdm selected but not installed"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "lxdm selected but not installed"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "slim selected but not installed"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "Using rootMountPoint '/tmp/calamares-root-z3ry4jze'"
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: ".. selected DE plasma"
2024-07-27 - 09:54:23 [2]: boost::python::api::object CalamaresPython::GlobalStoragePythonWrapper::value(const std::string&) const
    WARNING: Unknown GS key autoLoginUser
2024-07-27 - 09:54:23 [6]: [PYTHON JOB]: "Unsetting autologin."
    Starting job "mhwdcfg" ( 30 / 36 )
    Job file "/usr/lib/calamares/modules/mhwdcfg/main.py"
2024-07-27 - 09:54:23 [6]:     .. Job description from __doc__ "mhwdcfg" = "Configure the hardware"
2024-07-27 - 09:54:23 [6]:     .. Running ("mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-07-27 - 09:54:26 [6]:     .. Running ("mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-07-27 - 09:54:27 [6]:     .. Running ("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-07-27 - 09:54:27 [6]:     .. Target cmd: ("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") Exit code: 1 output:
 e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
e[1me[31m> e[mUsing config 'video-linux' for device: 0000:01:00.0 (0300:10de:2860) Display controller nVidia Corporation
e[1me[31m> e[mUsing config 'video-linux' for device: 0000:05:00.0 (0300:1002:1681) Display controller ATI Technologies Inc
e[1me[31m> e[mInstalling video-linux...
e[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'extra' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'multilib' does not exist (use '-Sy' to download)
e[me[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0380
e[me[0;32mProcessing classid: 0302
e[me[0;32m:: Synchronizing package databases...
e[me[0;32m mhwd downloading...
e[me[0;32merror: target not found: vulkan-nouveau
e[me[0;32mwarning: libva-mesa-driver-1:24.1.1-1 is up to date -- skipping
e[me[0;32merror: target not found: libva-vdpau-driver
e[me[0;32merror: target not found: lib32-vulkan-nouveau
e[me[0;32merror: target not found: lib32-libva-vdpau-driver
e[me[0;32mError: pacman failed!
e[me[1me[31mError: e[mscript failed!
2024-07-27 - 09:54:27 [6]:     .. Running ("mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-07-27 - 09:54:28 [6]:     .. Running ("mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-07-27 - 09:54:29 [6]: virtual void Calamares::JobThread::run()
    Starting job "hwclock" ( 31 / 36 )
2024-07-27 - 09:54:29 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/hwclock/main.py"
2024-07-27 - 09:54:29 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:54:29 [6]:     .. Job description from pretty_name "hwclock" = "Setting hardware clock."
2024-07-27 - 09:54:29 [6]:     .. Running ("hwclock", "--systohc", "--utc")
2024-07-27 - 09:54:30 [6]: [PYTHON JOB]: "Hwclock set using RTC method."
2024-07-27 - 09:54:30 [6]: virtual void Calamares::JobThread::run()
    Starting job "services" ( 32 / 36 )
2024-07-27 - 09:54:30 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/services/main.py"
2024-07-27 - 09:54:30 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-07-27 - 09:54:30 [6]:     .. Job description from pretty_name "services" = "Configure systemd services"
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "bluetooth.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "cronie.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "ModemManager.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "NetworkManager.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "cups.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "haveged.service")
2024-07-27 - 09:54:30 [6]:     .. Target cmd: ("systemctl", "enable", "haveged.service") Exit code: 1 output:
 Failed to enable unit: Unit haveged.service does not exist
2024-07-27 - 09:54:30 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service haveged"
2024-07-27 - 09:54:30 [2]: WARNING: [PYTHON JOB]: "systemctl enable call in chroot returned error code 1"
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "systemd-timesyncd.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "sddm.service")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "graphical.target")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "fstrim.timer")
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "enable", "pacman-filesdb-refresh.timer")
2024-07-27 - 09:54:30 [6]:     .. Target cmd: ("systemctl", "enable", "pacman-filesdb-refresh.timer") Exit code: 1 output:
 Failed to enable unit: Unit pacman-filesdb-refresh.timer does not exist
2024-07-27 - 09:54:30 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .timer pacman-filesdb-refresh"
2024-07-27 - 09:54:30 [6]:     .. Running ("systemctl", "disable", "pacman-init.service")
    Starting job "grubcfg" ( 33 / 36 )
    Job file "/usr/lib/calamares/modules/grubcfg/main.py"
2024-07-27 - 09:54:30 [6]:     .. Job description from pretty_name "grubcfg" = "Configure GRUB."
2024-07-27 - 09:54:30 [6]:     .. Running ("sh", "-c", "which dracut")
2024-07-27 - 09:54:30 [6]:     .. Target cmd: ("sh", "-c", "which dracut") Exit code: 1 output:
 which: no dracut in (/usr/sbin:/usr/bin:/sbin:/bin:/root/bin)
2024-07-27 - 09:54:30 [6]:     .. Running ("sh", "-c", "which plymouth")
    Starting job "bootloader" ( 34 / 36 )
    Job file "/usr/lib/calamares/modules/bootloader/main.py"
2024-07-27 - 09:54:30 [6]:     .. Job description from pretty_name "bootloader" = "Install bootloader."
2024-07-27 - 09:54:30 [6]: [PYTHON JOB]: "Bootloader: grub (efi)"
2024-07-27 - 09:54:30 [6]:     .. Running ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force")
2024-07-27 - 09:54:30 [6]:     .. Target cmd: ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force") Exit code: 127 output:
2024-07-27 - 09:54:30 [2]: WARNING: [PYTHON JOB]: "Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force' returned non-zero exit status 127."
2024-07-27 - 09:54:30 [6]: [PYTHON JOB]: "stdout:/usr/sbin/chroot: failed to run command 'grub-install': No such file or directory"
2024-07-27 - 09:54:30 [6]: [PYTHON JOB]: "stderr:None"
    Skipping non-emergency job "postcfg"
2024-07-27 - 09:54:30 [6]:     ..  Skipping non-emergency job "Unmount file systems."
2024-07-27 - 09:54:30 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
    ERROR: Installation failed: "Bootloader installation error"
2024-07-27 - 09:54:30 [6]:     .. - message: "Bootloader installation error"
2024-07-27 - 09:54:30 [6]:     .. - details: The bootloader could not be installed. The installation command <pre>grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force</pre> returned error code 127.
2024-07-27 - 09:54:30 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
    Calamares will quit when the dialog closes.
2024-07-27 - 09:54:30 [6]: void Config::doNotify(bool, bool)
    Notification not sent; completion: failed
2024-07-27 - 09:54:30 [6]: void {anonymous}::PowerManagementInterface::uninhibitSleep()
    Sleep was never inhibited.
The latest SourceForge image with the install-grub update did the trick.
Thank you for the help everyone.
