Hi all,
I’m trying to install mod_fcgid but it terminates with the error
==> ERRORE: Una o più firme PGP non possono essere verificate!
What can I do?
The complete command transcript is:
~ sudo -s 1 ✘
[emer mirto]# pamac install mod_fcgid
Avviso: mod_fcgid è disponibile solamente nell'AUR
Preparazione...
Clonazione mod_fcgid file di costruzione in corso...
Running as unit: run-u336.service
fatal: non è un repository Git (né lo è alcun genitore fino al punto di mount /var/cache/private)
Mi fermo al limite del filesystem (l'opzione GIT_DISCOVERY_ACROSS_FILESYSTEM non è impostata).
Finished with result: exit-code
Main processes terminated with: code=exited/status=128
Service runtime: 5ms
CPU time consumed: 5ms
Memory peak: 628.0K
Memory swap peak: 0B
Running as unit: run-u337.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 60ms
CPU time consumed: 9ms
Memory peak: 1.6M
Running as unit: run-u338.service
hint: Using 'master' as the name for the initial branch. This default branch name
hint: is subject to change. To configure the initial branch name to use in all
hint: of your new repositories, which will suppress this warning, call:
hint:
hint: git config --global init.defaultBranch <name>
hint:
hint: Names commonly chosen instead of 'master' are 'main', 'trunk' and
hint: 'development'. The just-created branch can be renamed via this command:
hint:
hint: git branch -m <name>
Service runtime: 503ms
CPU time consumed: 34ms
Memory peak: 1.4M
Creazione informazioni mod_fcgid...
Running as unit: run-u341.service
Service runtime: 859ms
CPU time consumed: 973ms
Memory peak: 1.1M
Controllo delle dipendenze di mod_fcgid in corso...
Risoluzione delle dipendenze...
Controllo conflitti tra i pacchetti...
Da costruire (1):
mod_fcgid 2.3.9-5 AUR
Modifica file di costruzione : [e]
Applica la transazione ? [e/s/N] s
Costruzione in corso di mod_fcgid...
Running as unit: run-u343.service
Press ^] three times within 1s to disconnect TTY.
==> Creazione del pacchetto: mod_fcgid 2.3.9-5 (ven 24 mag 2024, 10:35:36)
==> Controllo delle dipendenze durante l'avvio in corso...
==> Controllo delle dipendenze durante la compilazione in corso...
==> Download dei sorgenti in corso...
-> Download di mod_fcgid-2.3.9.tar.bz2 in corso...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 276 100 276 0 0 4582 0 --:--:-- --:--:-- --:--:-- 4600
100 80205 100 80205 0 0 200k 0 --:--:-- --:--:-- --:--:-- 1005k
-> Download di mod_fcgid-2.3.9.tar.bz2.asc in corso...
100 280 100 280 0 0 4005 0 --:--:-- --:--:-- --:--:-- 4057
100 836 100 836 0 0 3138 0 --:--:-- --:--:-- --:--:-- 3138
-> È stato trovato 30_fix-bts-691929.patch
-> È stato trovato large-file-upload.patch
==> Validazione di source file con sha1sums...
mod_fcgid-2.3.9.tar.bz2 ... Verificato
mod_fcgid-2.3.9.tar.bz2.asc ... Ignorato
30_fix-bts-691929.patch ... Verificato
large-file-upload.patch ... Verificato
==> Validazione delle firme dei sorgenti con gpg in corso...
mod_fcgid-2.3.9.tar.bz2 ... cat: errore di scrittura: Pipe interrotta
LA FIRMA NON È STATA TROVATA
NON RIUSCITO
Service runtime: 1.563s
CPU time consumed: 1.016s
Memory peak: 256.0K
Errore: Impossibile costruire mod_fcgid
[emer mirto]#
