It may not be a problem, but I’ll ask regardless as it has caused some confusion on my end whilst dealing with the previous kernel.
Issue
Whilst installing the linux66 kernel (not linux66-rt), there’s additional package install of linux66-rt-headers. Why? Isn’t that a different kernel? And why not linux66-headers?
$ sudo mhwd-kernel -i linux66
:: Synchronising package databases...
core is up to date
unity7 is up to date
extra 8.3 MiB 127 KiB/s 01:07 [##########################################] 100%
community is up to date
multilib is up to date
resolving dependencies...
Packages (2) linux66-6.6.32-1 linux66-rt-headers-6.6.30_rt30-1
Looking up the package manager, it appears that linux66 does have dedicated headers, which are excluded from this install.
core/linux66-headers 6.6.32-1
Header files and scripts for building modules for Linux66 kernel
core/linux66-rt-headers 6.6.30_rt30-1
Header files and scripts for building modules for Linux66-rt kernel
And the 66 and 66-rt appear to be listed as separate things.
You’re sure, this foreign repository isn’t interfering?
I cannot reproduce the problem, looks fine here:
mesa-nonfree is up to date
core is up to date
extra is up to date
Package (2) New Version Net Change Download Size
core/linux66 6.6.33-1 134,53 MiB 128,87 MiB
core/linux66-headers 6.6.33-1 119,20 MiB 24,44 MiB
Total Download Size: 153,30 MiB
Total Installed Size: 253,73 MiB
I highly doubt it.
Please post output of:
$ LANG=C pacman -Si linux66-headers
It should show 6.6.32-1 for stable branch as can also be seen here
That’s great to hear! Means I merely have something to resolve.
Requested output:
Repository : core
Version : 6.6.32-1
Description : Header files and scripts for building modules for Linux66 kernel
Architecture : x86_64
URL : https://www.kernel.org/
Licenses : GPL2
Groups : None
Provides : linux-headers=6.6.32
Depends On : gawk python libelf pahole
Optional Deps : None
Conflicts With : None
Replaces : None
Download Size : 24.45 MiB
Installed Size : 119.24 MiB
Packager : Manjaro Build Server <build@manjaro.org>
Build Date : Mon 27 May 2024 03:16:16 BST
Validated By : MD5 Sum SHA-256 Sum Signature
Now that you mention the unity7 I never really questioned it before.
Not sure if I even got anything installed from it. Is there any way to check? If I’ve got nothing from it, I would want to give it a try removing it.
Update:
Did a local query by group. Not sure if that’s it:
This is quite bizarre seeing ubuntu thing in here. I’m using KDE Plasma, not GNome, so I’m not expecting these packages here. Unless it’s some left overs from Unity game engine install I had forever ago.
[unity7]
SigLevel = Required DatabaseOptional
Server = https://manjaro.github.io/unity-for-manjaro/x86_64/
from the pacman.conf, ran sudo pacman -Syuu for good measure & rebooted, but still getting the same packages:
[sudo] password for username:
core is up to date
extra is up to date
Total Download Size: 24.54 MiB
Total Installed Size: 254.09 MiB
:: Proceed with installation? [Y/n] n
So it may not be the external repository (unless those installed packages are what cause interference - I will try to dig around to see what they’re for)
does indicate you haven’t merged your .pacnew offerings in quite a while. Particularly /etc/pacman.conf which has changed a bit since then. pacdiff -o will list these.
Thanks for pointing to this! Had no idea I had so many pending config changes.
There’re a lot of configs to resolve & I have no idea what some of the options differences or even configs do. It will take some time to research it & get that fixed.
For now I resolved the differences between the pacman configs, the ones left unresolved are:
The pacman diff didn’t seem significant. Apart removing some colour options (which I kept), adding these (or just the siglevel options under them)
[unity7]
[extra]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[community]
I have retried the install of kernel package again, but that didn’t change the -rt headers being installed. Maybe that needs a reboot or something more. I’ll try it again after resolving more of these merge conflicts, but I’ll get to that on the following days.
You can do it with pacman as well - but then you have to take care of regenerating the initrd and updating grub yourself. mhwd-kernel does this for you
I does for me. It seems to guess what additional packages for the chosen kernel you might want to install based on your current package situation for your current kernel.
On one of my machines it always wants to installl linux66-nvidia-390xx because it has linux61-nvidia-390xx present for its current linux61 kernel.
@DurpiuKalnas Do you by any chance run an -rt kernel at the moment? Please post output of:
I’m no longer sure, but it doesn’t seem so as the -rt ones have those suffixes:
$ uname -a
Linux laptop-machine 6.7.7-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Mar 1 18:26:06 UTC 2024 x86_64 GNU/Linux
$ mhwd-kernel -li
Currently running: 6.7.7-1-MANJARO (linux67)
* linux67
remove the linux66-rt-headers if you don’t want or need them
If I can’t track down the issue for why this is happening, I’m guessing I’ll need to do this. Though, I prefer to dig around as I fear this mistake could be part of some larger issue slowly degrading the system.
unless you know that you need this unity7 repo … remove it.
I have found out what it’s used for. The removal doesn’t seem to be straightforward, but I did try commenting it out. However, that did not resolve the wrongly picked up headers issue.
You should be able to - everything that was ever installed or removed is recorded in the pacman log.
It is a simple text file.
You could, for example, use: less /var/log/pacman.log
and then use the search function to scan for rt-headers
(that is: Shift+/ followed by the search term )
and look at the context around it.
… or use grep directly on the content of the file grep rt-headers /var/log/pacman.log
even a text editor will do - although that file could be very large and a text editor is not an ideal tool …
Plasma has got a log viewer tool as far as I know.
The package got installed at some point - the event should be recorded.
Kernel headers are only needed for building some AUR packages - for example kernel modules that are not part of the standard kernel.
It’s just used during the compilation phase. Later the presence or absence is irrelevant.
Removing headers has zero impact on the system.
Since you don’t even have the corresponding kernel installed, this particular -rt-headers package can go for sure.
Besides: this will likely still be in the pacman cache and can thus easily be reinstalled even if it would not be available anymore in the repositories.
Check: ls -al /var/cache/pacman/pkg/*-rt-headers*
or: don’t bother and
just remove it - since you neither want nor need it.
well - if you did, the repo is no longer used when updating
Not sure whether you would need to remove anything.
But, based on the content of that repo, it was not even expected that this had anything to do with the -rt-headers “issue”.
It does indeed, but not worth bothering with IMHO. I couldn’t get it to show anything but the last few dozen lines. I’d stick with the terminal.
I’ll also point out that the non-RT Linux67 is EOL and no longer in the repos.
