Installing go to meetings programm for manjaro kde here https://aur.archlinux.org/packages/go-to-meeting-nativefier/
I installed to my Manjaro yay package and wanted to install the gotomeeting program but every time when it wants to end i get a syntax error:
 SyntaxError: Unexpected token {
    at new Script (vm.js:51:7)
    at createScript (vm.js:136:10)
    at Object.runInThisContext (vm.js:197:10)
    at Module._compile (internal/modules/cjs/loader.js:618:28)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
    at Module.load (internal/modules/cjs/loader.js:566:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
    at Module.require (internal/modules/cjs/loader.js:598:17)
    at require (internal/modules/cjs/helpers.js:11:18)
==> ERROR: A failure occurred in build().
    Aborting...
How should I proceed?
You will need to talk to the packager
thanks for answer now ill try
sorry i didn t understand your action at all(could you write it a little easier for me?(sorry,i am beginner)
That means:
There is currently a problem installing 3rd-party applications.
Please be patient while we solve the issue.
So therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Go to the AUR page for this package, report the issue.
