Installing drivers on a Pantum printer
Hello everyone. Tell me how to install drivers on the Pantum P2518 printer if we don’t have drivers for arch?
pantum_driver  1.1.5-0.1                                                     AUR
    Pantum M6200-M6500-M6550-M6600-MS6000 Series LINUX Driver V1.1.5
pantum-p2200-p2500-driver  1.1.106-1                                         AUR
    Pantum P2200 and P2500 series drivers
pantum-p1000-p2000-p3000-m5100-m5200-ppd-driver  1.00_1-4                    AUR
    PPDs, drivers, for Pantum P1000, P2000, P3000, M5100, M5200 printers
pantum-driver  1.1.123-1                                                     AUR
    Linux driver for Pantum printers V1.1.123 (check PKGBUILD for
    compatible printer models)
I’m new to Linux, what is this?
That is something specific to Arch and Manjaro as a derivative of Arch - the AUR.
That is where you’ll likely find the driver for your printer.
Inform yourself a bit about the distribution you are using and how to use the AUR.
Some preconditions need to be met before you can use AUR - one is to install the package group base-devel.
If you are new to linux, start with linux mint or xubuntu.
