Installer stops after language settings
Have tried a number of times to install Manjaro KDE Stable but consistently end up with the installer shutting down after language setting.
The PC is a Lenovo Ideascentre 630 and had Win 10 and Manjaro installed on the original HDD. Changed that to a SSD, installed Win 11, Linux Mint and Refind, all working fine.
Have tried many ways to install Manjaro with different USB sticks, different USB slots, different downloads including Manjaro iso downloader/writer and Ventoy with forced EFI as descibed in (Live plasma iso can't boot from Ventoy)
I am stuck here and hope someone can help me solve this problem.
… and you did check and verify the integrity of the downloaded ISO?
(the checksum …)
which you then wrote to the install media using multiple methods?
I have an external SSD with several Linux ISO managed by Ventoy (latest release). It never showed issues while installing one of them.
So i would suggest following @anon33601770 and download it again with verification of the ISO file.
It may save unnecessary effort downloading a fresh copy of Manjaro if you first verify the ISO you have. The checksum (SHA256) file for your chosen edition can be found at the official Manjaro download page:
Basically you have said “I tried this and that but it didn’t work” (paraphrasing). Before we can know exactly what your issue is, more information is needed.
Welcome to the Manjaro community.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Agreed.
Forgetting from time to time that not everyone has a high bandwidth connection where the ISO is downloaded in less than three minutes.
My bad
I think your issue is with the integrity of the ISO - I cannot be sure though, but it is the most common cause of weird issues with the installer.
We have a couple of tools which can download and verify a Manjaro ISO.
I would typically use, after navigating to the desired download directory:
wget https://download.manjaro.org/kde/24.2.1/manjaro-kde-24.2.1-241216-linux612.iso
then
wget https://download.manjaro.org/kde/24.2.1/manjaro-kde-24.2.1-241216-linux612.iso.sha256
… followed with:
sha256sum -c --ignore-missing manjaro-kde-24.2.1-241216-linux612.iso.sha256
This method hasn’t failed me yet. I got the links from the Download Page as shown in @soundofthunder’s post above.
For this reason - though sadly not highlighted - I generally prefer to use torrents for large downloads on a slower connection.
So next to ‘Download’ there’s a 'More ’ tab which adds the options for Torrents, Image, Signature and Checksum - also a toggle for ‘Full === Minimal’.
Thank’s for your input, have tried out BG405’s way, put iso on a Ventoy stick with GPT ticked and sad to say same thing happens.
Tried to include the output fro inxi… but get the message;
An error occurred: Sorry, you can’t include links in your posts.
but you can - just format them as “preformatted text” → this symbol: </>
Ok I will try again, output from inxi…
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    lang=en_US keytable=no tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 rdinit=/vtoy/vtoy
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop System: LENOVO product: 90HC001NMW v: ideacentre 620S-03IKL
    serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: LENOVO model: 36E2 v: SDK0J40700 WIN 3258103362950 serial: N/A
    part-nu: LENOVO_MT_90HC_BU_LENOVO_FM_ideacentre 620S-03IKL
    uuid: b6f9b698-e6df-11e7-bb2d-2285f029bf01 UEFI: LENOVO v: O3GKT22A
    date: 04/08/2019
  System RAM: total: 8 GiB available: 7.65 GiB used: 2.66 GiB (34.8%)
    igpu: 32 MiB
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1K43CB1-CRC serial: <filter>
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
    bus-ID: 00:1c.3
  Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
    bus-ID: 00:1c.4
  Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
    bus-ID: 00:1c.5
  Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
    bus-ID: 00:1c.6
  Info: model: Intel Core i5-7400T socket: U3E1 bits: 64 type: MCP
    arch: Kaby Lake gen: core 7 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3000 base/boost: 2300/3000 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19204
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
    vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-2
    empty: DP-1,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:5912
    class-ID: 0300
  Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: BenQ T2200HD serial: <filter>
    built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 chroma: red: x: 0.651
    y: 0.337 green: x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314
    y: 0.329 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1280x1024, 1152x864, 1024x768, 800x600, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:5912 memory: 3.73 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 630 (KBL GT2) driver: N/A device-ID: 8086:5912
    surfaces: xcb,xlib
  Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
  Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 8086:3166 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 8087:0a2a
    class-ID: e001
  Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 2944 chunk-size: N/A
  Components: Online: N/A Spare:
  0: nvme0n1 maj-min: 259:0 size: 13.41 GiB state: S
  Local Storage: total: 486.63 GiB used: 146.69 GiB (30.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: MEMPEK1W016GAL
    size: 13.41 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
    lanes: 2 tech: SSD serial: <filter> fw-rev: K3110311 temp: 46.9 C
  SMART: yes health: PASSED on: 42d 22h cycles: 563
    read-units: 5,384,090 [2.75 TB] written-units: 4,004,610 [2.05 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 500GB SSD
    family: Driven SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 0615 temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 57 hrs cycles: 48
    written: 349 GiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
    size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
    scheme: MBR
  ID-1: /run/media/manjaro/Data raw-size: 279.18 GiB size: 279.18 GiB (100.00%)
    used: 146.69 GiB (52.5%) fs: ntfs block-size: 4096 B dev: /dev/sda7
    maj-min: 8:7 label: Data uuid: B8349AEA349AAB40
  ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 4.03 GiB fs: iso9660
  ID-2: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 7237-C4BF
  ID-3: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-4: /dev/sda3 maj-min: 8:3 size: 107.71 GiB fs: ntfs label: Win11
    uuid: 44A8395BA8394D24
  ID-5: /dev/sda4 maj-min: 8:4 size: 644 MiB fs: ntfs label: N/A
    uuid: DEC24689C246663D
  ID-6: /dev/sda5 maj-min: 8:5 size: 39.06 GiB fs: ntfs label: Manjaro
    uuid: DECE6BB5CE6B851D
  ID-7: /dev/sda6 maj-min: 8:6 size: 39.06 GiB fs: ext4 label: N/A
    uuid: b5e216a8-cdd7-4369-a8f7-8ab80081dc98
  ID-8: /dev/sdb1 maj-min: 8:17 size: 7.42 GiB fs: exfat label: Ventoy
    uuid: 1CEB-F69E
  ID-9: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 223C-F3F8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-2: 1-3:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-3: 1-6:4 info: SiGma Micro Keyboard TRACER Gamma Ivory
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1c4f:0002 class-ID: 0300
  Device-4: 1-7:5 info: SiGma Micro XM102K Optical Wheel Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 1c4f:0034 class-ID: 0301
  Device-5: 1-8:6 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1248 libs: 327 tools: pamac pm: flatpak pkgs: 0
   Processes:
  CPU top: 5 of 220
  1: cpu: 13.7% command: firefox pid: 3250 mem: 444.8 MiB (5.6%)
  2: cpu: 9.6% command: firefox pid: 3678 mem: 276.0 MiB (3.5%)
  3: cpu: 3.6% command: kwin_x11 pid: 1499 mem: 176.2 MiB (2.2%)
  4: cpu: 3.3% command: Xorg pid: 1366 mem: 92.7 MiB (1.1%)
  5: cpu: 0.9% command: kwrite pid: 4618 mem: 140.6 MiB (1.7%)
  Memory top: 5 of 220
  1: mem: 444.8 MiB (5.6%) command: firefox pid: 3250 cpu: 13.7%
  2: mem: 311.4 MiB (3.9%) command: plasmashell pid: 1530 cpu: 0.5%
  3: mem: 276.0 MiB (3.5%) command: firefox pid: 3678 cpu: 9.6%
  4: mem: 176.2 MiB (2.2%) command: kwin_x11 pid: 1499 cpu: 3.6%
  5: mem: 173.6 MiB (2.2%) command: firefox pid: 3658 cpu: 0.1%
  Processes: 220 Power: uptime: 31m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.01 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Sudo (sudo) v: 1.9.16p2 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
So Linux works on this machine, and only the installer fails with what you selected.
Try to gather information:
  • Does the Linux from the live ISO work reliably (without installing)?
  • Do the other installations (Manjaro/Mint) have special kernel parameters to make them work?
  • Is this a UEFI-Install ? (Are the other systems also UEFI installed ?)
  • What kernels do these installations have?
  • Can you enable swap before starting the installer?
  • Do you select anything special in the installer
  • What happens if you start the installer from the command line?
  • Are there any actionable error messages then? (please post in full here)
  • :footprints:
  • Does the Linux from the live ISO work reliably (without installing)? Yes
  • Do the other installations (Manjaro/Mint) have special kernel parameters to make them work? No
  • Is this a UEFI-Install ? (Are the other systems also UEFI installed ?) Yes
  • Standard kernels*
  • Can you enable swap before starting the installer? Do not know how to do that
  • Do you select anything special in the installer - Start installer, it comes up with Norwegian as I want and opens next window a split second before shutting down, consistently.
  • Can’t find any help on this with dual boot setup.
Started Calamares from command line and got this message;
calamares         127 ✘
/dev/mapper/control: open failed: Permission denied
Failure to communicate with kernel device-mapper driver.
Incompatible libdevmapper 1.02.203 (2024-12-09) and kernel driver (unknown version).
11:23:13 [1]: ERROR (Qt): ASSERT: "efiSectorCount > 0" in file /build/calamares/src/calamares-3.3.12/src/modules/partition/core/PartitionActions.cpp, line 125
zsh: IOT instruction (core dumped)  calamares
Moderator edit: Fixed formatting typos. Please review [HowTo] Post command output and file content as formatted text
Calamares does not support LVM nor does it support RAID constructs.
You may succeed if you assemble the RAID beforehand - then target /dev/mapper/md127 for installation - but it is unsupported.
If you have no data and just want to install Manjaro I suggest you wipe disk signatures before launching the installer.
Use lsblk to identify your physical devices
lsblk
Devices will have names like nvme* or sd*
Use sgdisk to wipe all signatures
sudo sgdisk /dev/nvmeYn1 --zap-all
Or in case of sata
sudo sgdisk /dev/sdx --zap-all
It doesn’t?
I thought it even offered it as a choice during install.
But I’d have to boot and look and test to verify this.
If lvm is a problem:
wipe the disk - run gparted (or dd … or anything that can wipe out the disk)
and then run the installer afterwards.
Nope - not in the default Manjaro installer.
It is possible if you know how to setup LVM or RAID manually - but it is generally unsupported.
Calamares is an installer framework - so it is possible to create custom modules for Calamares to achieve such setup - and other distributions may have done so - Manjaro is not one of those.
o.k. - I just looked at it and you are right!
So the only option (to me) seems to be to wipe the disk (to remove any notion of an LVM)
and then start over.
I am confused here, again…
NAME       MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0        7:0    0  90.1M  1 loop /run/miso/sfs/livefs
loop1        7:1    0   1.1G  1 loop /run/miso/sfs/mhwdfs
loop2        7:2    0   1.8G  1 loop /run/miso/sfs/desktopfs
loop3        7:3    0 858.9M  1 loop /run/miso/sfs/rootfs
sda          8:0    0 465.8G  0 disk
├─sda1       8:1    0   100M  0 part
├─sda2       8:2    0    16M  0 part
├─sda3       8:3    0 107.7G  0 part
├─sda4       8:4    0   644M  0 part
├─sda5       8:5    0  39.1G  0 part
├─sda6       8:6    0  39.1G  0 part
└─sda7       8:7    0 279.2G  0 part
sdb          8:16   1   7.5G  0 disk
├─sdb1       8:17   1   7.4G  0 part
│ └─ventoy 254:0    0     4G  1 dm   /run/miso/bootmnt
└─sdb2       8:18   1    32M  0 part
nvme0n1    259:0    0  13.4G  0 disk
└─md127      9:127  0     0B  0 md
the above seems to be the output of
lsblk
What is confusing about it to you?
A more helpful, more verbose, command would be:
lsblk -f
or
blkid
… the lvm you mentioned could be on the nvme ssd (probably …)
or on any or all of the /dev/sda
loop (0 through 3) is the mounted file systems on the ISO you booted up
and
/dev/sdb is the drive you booted from - your Ventoy drive
