Installer fails with calamares crash
Hi guys,
I’m trying to install latest Manjaro Gnome from bootable USB on my acer acer vn7-591g but as soon as I finish filling out the installer settings and pass the summary screen the installer crashes without any additional prompt.
  • I’ve tried with two different USB drives and used rufus/balena/ventoy to prepare installation USBs - neither version worked.
  • Tried ISOs of 22.0-230101 and 22.0-221224
  • Fast startup is disabled, don’t have intel optane drive.
  • Tried installing manjaro as a dual-boot on a separate partition but I’ve also tried formatting everything and doing a clean install.
Looking at the journalctl output it seems that calamares crashes and that causes the installer window to disappear.
Does anyone have more ideas what else I could do to be able to finally install and enjoy Manjaro? :slight_smile: Thanks in advance!
journalctl -p3 output
Jan 14 23:12:32 manjaro-gnome kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20220331/psargs-330)
Jan 14 23:12:32 manjaro-gnome kernel: ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda): invalid fs_name
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda): failed to read boot sector
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda): failed to recognize exfat type
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda2): invalid boot record signature
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda2): failed to read boot sector
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sda2): failed to recognize exfat type
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sdb): invalid fs_name
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sdb): failed to read boot sector
Jan 14 23:12:32 manjaro-gnome kernel: exFAT-fs (sdb): failed to recognize exfat type
Jan 14 23:12:39 manjaro-gnome bluetoothd[1012]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jan 14 23:12:39 manjaro-gnome bluetoothd[1012]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 14 23:12:39 manjaro-gnome bluetoothd[1012]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 14 23:12:55 manjaro-gnome gdm-autologin][1370]: gkr-pam: couldn't unlock the login keyring.
Jan 14 23:12:55 manjaro-gnome systemd[1375]: Failed to start Application launched by gnome-session-binary.
Jan 14 23:12:58 manjaro-gnome kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 619444 [ PRIVRING ]
Jan 14 23:13:01 manjaro-gnome kernel: /dev/sdb1: Can't open blockdev
Jan 14 23:13:01 manjaro-gnome systemd[1375]: Failed to start Application launched by gnome-session-binary.
Jan 14 23:14:31 manjaro-gnome systemd-coredump[4127]: [🡕] Process 3299 (calamares) of user 0 dumped core.
                                                      Stack trace of thread 3299:
                                                      #0  0x00007f54f1a4064c n/a (libc.so.6 + 0x8864c)
                                                      #1  0x00007f54f19f0958 raise (libc.so.6 + 0x38958)
                                                      #2  0x00007f54f19da53d abort (libc.so.6 + 0x2253d)
                                                      #3  0x00007f54c25f2d31 n/a (crocus_dri.so + 0x9bd31)
                                                      #4  0x00007f54c35c1162 n/a (crocus_dri.so + 0x106a162)
                                                      #5  0x00007f54c26b8466 n/a (crocus_dri.so + 0x161466)
                                                      #6  0x00007f54f3a3dfd4 n/a (libQt5QuickWidgets.so.5 + 0xbfd4)
                                                      #7  0x00007f54f3527384 _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1af384)
                                                      #8  0x00007f54f34f0b1c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b1c)
                                                      #9  0x00007f54f2084f98 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cf98)
                                                      #10 0x00007f54f35220b3 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb (libQt5Widgets.so.5 + 0x1aa0b3)
                                                      #11 0x00007f54f35260b8 _ZN14QWidgetPrivate11show_helperEv (libQt5Widgets.so.5 + 0x1ae0b8)
                                                      #12 0x00007f54f352652a _ZN14QWidgetPrivate12showChildrenEb (libQt5Widgets.so.5 + 0x1ae52a)
inxi -v7azy output
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_GNOME_220 quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: Acer product: Aspire VN7-591G v: V1.17
    serial: <superuser required>
  Mobo: Acer model: Aspire VN7-591G v: V1.17 serial: <superuser required>
    UEFI: Insyde v: 1.17 date: 03/22/2018
  ID-1: BAT0 charge: 28.3 Wh (75.9%) condition: 37.3/52.5 Wh (71.1%)
    volts: 12.6 min: 11.4 model: LGC AC14A8L type: Li-ion serial: <filter>
    status: not charging
  RAM: total: 15.55 GiB used: 6.44 GiB (41.4%)
  Info: model: Intel Core i7-4710HQ bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x24
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 798 high: 800 min/max: 800/3500 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 800
    5: 800 6: 799 7: 798 8: 798 bogomips: 39926
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb ept ept_ad erms est f16c flexpriority fma fpu fsgsbase fxsr
    ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
    pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
    smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-5.75
    process: Intel 45nm built: 2010 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GM107M [GeForce GTX 860M] vendor: Acer Incorporated ALI
    driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2022-12)
    arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1392 class-ID: 0302 temp: 47.0 C
  Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-9:5
    chip-ID: 04f2:b474 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp LQ156D1JW04 built: 2014 res: 3840x2160
    dpi: 282 gamma: 1.2 size: 346x194mm (13.62x7.64") diag: 397mm (15.6")
    ratio: 16:9 modes: 3840x2160
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
    driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 168c:0034 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: down mac: <filter>
  Device-1: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-10:7 chip-ID: 04ca:300d class-ID: e001
  Local Storage: total: 247.53 GiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: DB6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT microDuo
    size: 14.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 1100 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.43 GiB fs: iso9660
  ID-2: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: CA18-E175
  ID-3: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sda3 maj-min: 8:3 size: 152.26 GiB fs: ntfs label: N/A
    uuid: 9C8C20648C203B62
  ID-5: /dev/sda4 maj-min: 8:4 size: 540 MiB fs: ntfs label: N/A
    uuid: D4F093DEF093C560
  ID-6: /dev/sdb1 maj-min: 8:17 size: 14.62 GiB fs: exfat label: Ventoy
    uuid: 4E21-0000
  ID-7: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: B228-8EFB
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 3-1:2 info: Kingston DT microDuo type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
    chip-ID: 0951:16a1 class-ID: 0806 serial: <filter>
  Device-2: 3-4:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-3: 3-7:4 info: Synaptics touchpad type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 06cb:2970 class-ID: 0300
  Device-4: 3-9:5 info: Chicony HD WebCam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b474
    class-ID: 0e02
  Device-5: 3-10:7 info: Lite-On Atheros AR3012 Bluetooth type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: nouveau temp: 48.0 C
  Processes: 270 Uptime: 38m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: N/A Packages: pm: pacman pkgs: 1281 libs: 311
  tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.24
Did you check the hash of the iso file you downloaded?
I think I’m having the same problem on Manjaro Xfce installing to a ThinkPad T61, crash after summary screen in calamares
Occasionally I’ll get a different result, Xorg crashes and I have to log back in
I managed to get the install going past this point, once, then accidentally ctrl-c’d the relevant terminal window (doh)
I’ve checked the ISO hash, it’s fine, and this install USB worked a treat on my ThinkPad T420s. I was wondering if it had something to do with MBR boot given this laptop is old enough to not support UEFI, but OPs laptop looks modern in this sense
Hi, thanks for the replies.
@Jim.B Yes, I’ve checked the hash thinking it might have been corrupted iso but it was matching the reference hash.
@spephton in my case I consistently get the same results, tried installing multiple times via GUI and the result is always calamares crash after summary screen. I’m using UEFI as well.
Hey,
I have a similar issue when I try to install Manjaro Gnome on my Surface Pro 6. For me, it’s OOM error 'tho.
I’m seeing the same on an older Dell XPS 15. I have booted off a USB stick (manjaro-gnome-22.0.1-minimal-230124-linux61.iso) in UEFI mode (with secure boot disabled). I have tried with open source and proprietary drivers and various partition combinations, but consistently get the behaviour described by OP (calamares crash stacktrace looks the same too).
I confirmed that the ISO was written properly to the USB stick,
$ sudo head -c $(stat -c '%s' manjaro-gnome-22.0.1-minimal-230124-linux61.iso) /dev/sdc | sha1sum
325320c0fd014fffccfa9d48db616b81e85c4ad0  -
$ cat manjaro-gnome-22.0.1-minimal-230124-linux61.iso.sha1
325320c0fd014fffccfa9d48db616b81e85c4ad0  manjaro-gnome-22.0.1-minimal-230124-linux61.iso
Did you ever manage to get around this? I’m about to try installing from the “full” installation (as opposed to the “minimal” one).
I have the same problem.
I use Manjaro Linux on a handful of different DELL laptops, but also a DELL desktop (Optiplex).
Now I am trying to install Manjaro on another DELL Optiplex, but Calamares crash.
I have used the same DVD in all of them, so there is no fault in the DVD itself.
Can Manjaro be installed without Calamares?
/ Hans Gatu
I tried to install a different Linux distro, that also use Calamares installer, based on Debian.
It installed without any issues, so maybe there is a bug in Manjaro’s Calamares code.
/ Hans Gatu
