Thanks again. The problem seems to be caused by the amdgpu module:
Starting with modprobe.blacklist=amdgpu systemd.unit=multi-user.target does work.
modprobe -v amdgpu then freezes the system without further information about what is happening.
However, I do not get any graphical interface with the other mentioned modules.
Output of lspci -nn -v -k | sed -n "/VGA compatible controller/,/Kernel modules/p":
Subsystem: Lenovo Device [17aa:3809]
Flags: bus master, fast devsel, latency 0, IRQ 3, IOMMU group 5
Memory at b0000000 (64-bit, prefetchable) [size=256M]
Memory at c0000000 (64-bit, prefetchable) [size=2M]
I/O ports at 1000 [size=256]
Memory at c0700000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Capabilities: [64] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable- Count=4 Masked-
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [270] Secondary PCI Express
Capabilities: [2b0] Address Translation Service (ATS)
Capabilities: [2c0] Page Request Interface (PRI)
Capabilities: [2d0] Process Address Space ID (PASID)
Capabilities: [400] Data Link Feature <?>
Capabilities: [410] Physical Layer 16.0 GT/s <?>
Capabilities: [440] Lane Margining at the Receiver <?>
Kernel modules: amdgpu
xinit provides this, when failing to start:
X.Org X Server 1.21.1.2
[ 55.694] Current Operating System: Linux manjaro 5.15.7-1-MANJARO #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021 x86_64
[ 55.694] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2120 quiet systemd.show_status=1 apparmor=1 security=apparmor modprobe.blacklist=amdgpu systemd.unit=multi-user.target driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 55.696]
[ 55.697] Current version of pixman: 0.40.0
[ 55.698] Before reporting problems, check http://wiki.x.org
[ 55.698] Markers: (--) probed, (**) from config file, (==) default setting,
[ 55.700] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 29 14:08:20 2021
[ 55.703] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 55.703] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 55.710] (==) No Layout section. Using the first Screen section.
[ 55.710] (==) No screen section available. Using defaults.
[ 55.710] (**) |-->Screen "Default Screen Section" (0)
[ 55.710] (**) | |-->Monitor "<default monitor>"
[ 55.711] (==) No monitor specified for screen "Default Screen Section".
[ 55.711] (==) Automatically adding devices
[ 55.711] (==) Automatically enabling devices
[ 55.711] (==) Automatically adding GPU devices
[ 55.711] (==) Automatically binding GPU devices
[ 55.722] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 55.731] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 55.731] Entry deleted from font path.
[ 55.731] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 55.731] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 55.731] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 55.731] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 55.731] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 55.731] (II) The server relies on udev to provide the list of input devices.
[ 55.731] (II) Module ABI versions:
[ 55.731] X.Org ANSI C Emulation: 0.4
[ 55.731] X.Org Video Driver: 25.2
[ 55.731] X.Org XInput driver : 24.4
[ 55.731] X.Org Server Extension : 10.0
[ 55.732] (--) using VT number 2
[ 55.732] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 55.736] (--) PCI:*(4@0:0:0) 1002:1638:17aa:3809 rev 193, Mem @ 0xb0000000/268435456, 0xc0000000/2097152, 0xc0700000/524288, I/O @ 0x00001000/256, BIOS @ 0x????????/131072
[ 55.736] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 55.736] (II) LoadModule: "glx"
[ 55.737] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 55.758] (II) Module glx: vendor="X.Org Foundation"
[ 55.758] compiled for 1.21.1.2, module version = 1.0.0
[ 55.758] ABI class: X.Org Server Extension, version 10.0
[ 55.758] (==) Matched ati as autoconfigured driver 0
[ 55.758] (==) Matched modesetting as autoconfigured driver 1
[ 55.758] (==) Matched fbdev as autoconfigured driver 2
[ 55.758] (==) Matched vesa as autoconfigured driver 3
[ 55.758] (==) Assigned the driver to the xf86ConfigLayout
[ 55.758] (II) LoadModule: "ati"
[ 55.758] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 55.758] (II) Module ati: vendor="X.Org Foundation"
[ 55.758] compiled for 1.21.1.1, module version = 19.1.0
[ 55.758] Module class: X.Org Video Driver
[ 55.758] ABI class: X.Org Video Driver, version 25.2
[ 55.759] (II) LoadModule: "radeon"
[ 55.759] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 55.759] (II) Module radeon: vendor="X.Org Foundation"
[ 55.759] compiled for 1.21.1.1, module version = 19.1.0
[ 55.759] Module class: X.Org Video Driver
[ 55.759] ABI class: X.Org Video Driver, version 25.2
[ 55.759] (II) LoadModule: "modesetting"
[ 55.759] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 55.766] (II) Module modesetting: vendor="X.Org Foundation"
[ 55.766] compiled for 1.21.1.2, module version = 1.21.1
[ 55.766] Module class: X.Org Video Driver
[ 55.766] ABI class: X.Org Video Driver, version 25.2
[ 55.766] (II) LoadModule: "fbdev"
[ 55.766] (WW) Warning, couldn't open module fbdev
[ 55.766] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 55.766] (II) LoadModule: "vesa"
[ 55.766] (WW) Warning, couldn't open module vesa
[ 55.766] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 55.766] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 55.767] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 55.814] (EE) open /dev/dri/card0: No such file or directory
[ 55.814] (WW) Falling back to old probe method for modesetting
[ 55.814] (EE) Screen 0 deleted because of no matching config section.
[ 55.814] (II) UnloadModule: "modesetting"
[ 55.814] (EE) Device(s) detected, but none match those in the config file.
[ 55.814] (EE)
Fatal server error:
[ 55.814] (EE) no screens found(EE)
[ 55.814] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 55.814] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 55.814] (EE)
[ 55.903] (EE) Server terminated with error (1). Closing log file.
dmesg output of the booting process:
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2120 quiet systemd.show_status=1 apparmor=1 security=apparmor modprobe.blacklist=amdgpu systemd.unit=multi-user.target driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3376
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000099fffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009a00000-0x0000000009dfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000009e00000-0x0000000009efffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009f00000-0x0000000009f0efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000009f0f000-0x000000009ab68fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000009ab69000-0x000000009bd68fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009bd69000-0x00000000a9f7efff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a9f7f000-0x00000000acf7efff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000acf7f000-0x00000000adf7efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000adf7f000-0x00000000adffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000adfff000-0x00000000adffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ae000000-0x00000000afffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe0fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec20000-0x00000000fec20fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed81fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000003ce2fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000003ce300000-0x000000044fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 3.3 present.
[ 0.000000] DMI: LENOVO 82L7/LNVNB161216, BIOS GECN28WW(V1.12) 11/15/2021
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1896.630 MHz processor
[ 0.008313] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.008316] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.008323] last_pfn = 0x3ce300 max_arch_pfn = 0x400000000
[ 0.009154] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.009439] last_pfn = 0xae000 max_arch_pfn = 0x400000000
[ 0.014449] Using GB pages for direct mapping
[ 0.014929] RAMDISK: [mem 0x31909000-0x34c7bfff]
[ 0.014935] ACPI: Early table checksum verification disabled
[ 0.014940] ACPI: RSDP 0x00000000000FE020 000024 (v02 LENOVO)
[ 0.014945] ACPI: XSDT 0x00000000ADFCD188 00012C (v01 LENOVO CB-01 00000001 01000013)
[ 0.014951] ACPI: FACP 0x00000000ADFEB000 00010C (v05 LENOVO CB-01 00000001 01000013)
[ 0.014956] ACPI: DSDT 0x00000000ADFD8000 00CF99 (v01 LENOVO CB-01 00000001 01000013)
[ 0.014959] ACPI: FACS 0x00000000ADEB6000 000040
[ 0.014961] ACPI: UEFI 0x00000000ADF7E000 000236 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.014964] ACPI: SSDT 0x00000000ADFFC000 000BD9 (v02 LENOVO CB-01 00000001 INTL 20130117)
[ 0.014967] ACPI: SSDT 0x00000000ADFF4000 007229 (v02 LENOVO CB-01 00000001 MSFT 04000000)
[ 0.014969] ACPI: IVRS 0x00000000ADFF3000 0001A4 (v02 LENOVO CB-01 00000001 AMD 00000000)
[ 0.014971] ACPI: SSDT 0x00000000ADFEF000 003A21 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.014974] ACPI: MSDM 0x00000000ADFEE000 000055 (v03 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.014976] ACPI: ASF! 0x00000000ADFED000 0000A5 (v32 LENOVO CB-01 00000001 01000013)
[ 0.014979] ACPI: BOOT 0x00000000ADFEC000 000028 (v01 LENOVO CB-01 00000001 01000013)
[ 0.014981] ACPI: HPET 0x00000000ADFEA000 000038 (v01 LENOVO CB-01 00000001 01000013)
[ 0.014984] ACPI: APIC 0x00000000ADFE9000 000138 (v03 LENOVO CB-01 00000001 01000013)
[ 0.014986] ACPI: MCFG 0x00000000ADFE8000 00003C (v01 LENOVO CB-01 00000001 01000013)
[ 0.014988] ACPI: SLIC 0x00000000ADFE7000 000176 (v01 LENOVO CB-01 00000001 01000013)
[ 0.014991] ACPI: SSDT 0x00000000ADFD7000 000080 (v01 LENOVO CB-01 00000001 01000013)
[ 0.014993] ACPI: SSDT 0x00000000ADFD6000 0000F8 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.014995] ACPI: SSDT 0x00000000ADFD5000 000750 (v02 LENOVO CB-01 00000001 INTL 20130117)
[ 0.014998] ACPI: SSDT 0x00000000ADFCF000 005354 (v02 LENOVO CB-01 00000001 AMD 00000001)
[ 0.015000] ACPI: CRAT 0x00000000ADFCE000 000EE8 (v01 LENOVO CB-01 00000001 AMD 00000001)
[ 0.015003] ACPI: CDIT 0x00000000ADFFD000 000029 (v01 LENOVO CB-01 00000001 AMD 00000001)
[ 0.015005] ACPI: SSDT 0x00000000ADFCC000 000139 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015008] ACPI: SSDT 0x00000000ADFCB000 00028D (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015010] ACPI: SSDT 0x00000000ADFCA000 0001B0 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015012] ACPI: SSDT 0x00000000ADFC9000 000D53 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015015] ACPI: SSDT 0x00000000ADFC7000 0010C5 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015017] ACPI: SSDT 0x00000000ADFC3000 0034AA (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015020] ACPI: FPDT 0x00000000ADFC2000 000044 (v01 LENOVO CB-01 00000001 01000013)
[ 0.015022] ACPI: WSMT 0x00000000ADFC0000 000028 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.015024] ACPI: SSDT 0x00000000ADFE6000 000042 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015027] ACPI: SSDT 0x00000000ADFE5000 00020A (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015029] ACPI: SSDT 0x00000000ADFBF000 000C23 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015032] ACPI: SSDT 0x00000000ADFBE000 000298 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015034] ACPI: SSDT 0x00000000ADFBD000 00007D (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015036] ACPI: SSDT 0x00000000ADFBC000 000517 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.015038] ACPI: Reserving FACP table memory at [mem 0xadfeb000-0xadfeb10b]
[ 0.015040] ACPI: Reserving DSDT table memory at [mem 0xadfd8000-0xadfe4f98]
[ 0.015040] ACPI: Reserving FACS table memory at [mem 0xadeb6000-0xadeb603f]
[ 0.015041] ACPI: Reserving UEFI table memory at [mem 0xadf7e000-0xadf7e235]
[ 0.015042] ACPI: Reserving SSDT table memory at [mem 0xadffc000-0xadffcbd8]
[ 0.015043] ACPI: Reserving SSDT table memory at [mem 0xadff4000-0xadffb228]
[ 0.015044] ACPI: Reserving IVRS table memory at [mem 0xadff3000-0xadff31a3]
[ 0.015044] ACPI: Reserving SSDT table memory at [mem 0xadfef000-0xadff2a20]
[ 0.015045] ACPI: Reserving MSDM table memory at [mem 0xadfee000-0xadfee054]
[ 0.015046] ACPI: Reserving ASF! table memory at [mem 0xadfed000-0xadfed0a4]
[ 0.015047] ACPI: Reserving BOOT table memory at [mem 0xadfec000-0xadfec027]
[ 0.015047] ACPI: Reserving HPET table memory at [mem 0xadfea000-0xadfea037]
[ 0.015048] ACPI: Reserving APIC table memory at [mem 0xadfe9000-0xadfe9137]
[ 0.015049] ACPI: Reserving MCFG table memory at [mem 0xadfe8000-0xadfe803b]
[ 0.015050] ACPI: Reserving SLIC table memory at [mem 0xadfe7000-0xadfe7175]
[ 0.015050] ACPI: Reserving SSDT table memory at [mem 0xadfd7000-0xadfd707f]
[ 0.015051] ACPI: Reserving SSDT table memory at [mem 0xadfd6000-0xadfd60f7]
[ 0.015052] ACPI: Reserving SSDT table memory at [mem 0xadfd5000-0xadfd574f]
[ 0.015053] ACPI: Reserving SSDT table memory at [mem 0xadfcf000-0xadfd4353]
[ 0.015053] ACPI: Reserving CRAT table memory at [mem 0xadfce000-0xadfceee7]
[ 0.015054] ACPI: Reserving CDIT table memory at [mem 0xadffd000-0xadffd028]
[ 0.015055] ACPI: Reserving SSDT table memory at [mem 0xadfcc000-0xadfcc138]
[ 0.015056] ACPI: Reserving SSDT table memory at [mem 0xadfcb000-0xadfcb28c]
[ 0.015057] ACPI: Reserving SSDT table memory at [mem 0xadfca000-0xadfca1af]
[ 0.015057] ACPI: Reserving SSDT table memory at [mem 0xadfc9000-0xadfc9d52]
[ 0.015058] ACPI: Reserving SSDT table memory at [mem 0xadfc7000-0xadfc80c4]
[ 0.015059] ACPI: Reserving SSDT table memory at [mem 0xadfc3000-0xadfc64a9]
[ 0.015060] ACPI: Reserving FPDT table memory at [mem 0xadfc2000-0xadfc2043]
[ 0.015061] ACPI: Reserving WSMT table memory at [mem 0xadfc0000-0xadfc0027]
[ 0.015061] ACPI: Reserving SSDT table memory at [mem 0xadfe6000-0xadfe6041]
[ 0.015062] ACPI: Reserving SSDT table memory at [mem 0xadfe5000-0xadfe5209]
[ 0.015063] ACPI: Reserving SSDT table memory at [mem 0xadfbf000-0xadfbfc22]
[ 0.015064] ACPI: Reserving SSDT table memory at [mem 0xadfbe000-0xadfbe297]
[ 0.015065] ACPI: Reserving SSDT table memory at [mem 0xadfbd000-0xadfbd07c]
[ 0.015066] ACPI: Reserving SSDT table memory at [mem 0xadfbc000-0xadfbc516]
[ 0.015123] No NUMA configuration found
[ 0.015124] Faking a node at [mem 0x0000000000000000-0x00000003ce2fffff]
[ 0.015128] NODE_DATA(0) allocated [mem 0x3ce2fc000-0x3ce2fffff]
[ 0.015157] Zone ranges:
[ 0.015157] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.015159] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.015160] Normal [mem 0x0000000100000000-0x00000003ce2fffff]
[ 0.015162] Device empty
[ 0.015163] Movable zone start for each node
[ 0.015163] Early memory node ranges
[ 0.015164] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.015165] node 0: [mem 0x0000000000100000-0x00000000099fffff]
[ 0.015166] node 0: [mem 0x0000000009e00000-0x0000000009efffff]
[ 0.015167] node 0: [mem 0x0000000009f0f000-0x000000009ab68fff]
[ 0.015168] node 0: [mem 0x000000009bd69000-0x00000000a9f7efff]
[ 0.015169] node 0: [mem 0x00000000adfff000-0x00000000adffffff]
[ 0.015169] node 0: [mem 0x0000000100000000-0x00000003ce2fffff]
[ 0.015171] Initmem setup node 0 [mem 0x0000000000001000-0x00000003ce2fffff]
[ 0.015175] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.015189] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.015308] On node 0, zone DMA32: 1024 pages in unavailable ranges
[ 0.018325] On node 0, zone DMA32: 15 pages in unavailable ranges
[ 0.018743] On node 0, zone DMA32: 4608 pages in unavailable ranges
[ 0.018874] On node 0, zone DMA32: 16512 pages in unavailable ranges
[ 0.036298] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.036368] On node 0, zone Normal: 7424 pages in unavailable ranges
[ 0.036488] ACPI: PM-Timer IO Port: 0x408
[ 0.036496] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.036498] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.036499] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.036499] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.036500] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.036501] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.036501] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.036502] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.036503] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.036503] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.036504] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.036504] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.036505] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.036506] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.036506] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.036507] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.036521] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.036526] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.036528] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.036530] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.036533] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.036535] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.036540] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.036566] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.036568] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.036569] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.036570] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.036571] PM: hibernation: Registered nosave memory: [mem 0x09a00000-0x09dfffff]
[ 0.036573] PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f0efff]
[ 0.036574] PM: hibernation: Registered nosave memory: [mem 0x9ab69000-0x9bd68fff]
[ 0.036576] PM: hibernation: Registered nosave memory: [mem 0xa9f7f000-0xacf7efff]
[ 0.036577] PM: hibernation: Registered nosave memory: [mem 0xacf7f000-0xadf7efff]
[ 0.036577] PM: hibernation: Registered nosave memory: [mem 0xadf7f000-0xadffefff]
[ 0.036579] PM: hibernation: Registered nosave memory: [mem 0xae000000-0xafffffff]
[ 0.036579] PM: hibernation: Registered nosave memory: [mem 0xb0000000-0xf7ffffff]
[ 0.036580] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.036581] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfddfffff]
[ 0.036581] PM: hibernation: Registered nosave memory: [mem 0xfde00000-0xfdefffff]
[ 0.036582] PM: hibernation: Registered nosave memory: [mem 0xfdf00000-0xfdffffff]
[ 0.036582] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe0fffff]
[ 0.036583] PM: hibernation: Registered nosave memory: [mem 0xfe100000-0xfebfffff]
[ 0.036584] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec01fff]
[ 0.036584] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.036585] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.036585] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec1ffff]
[ 0.036586] PM: hibernation: Registered nosave memory: [mem 0xfec20000-0xfec20fff]
[ 0.036587] PM: hibernation: Registered nosave memory: [mem 0xfec21000-0xfed7ffff]
[ 0.036587] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed81fff]
[ 0.036588] PM: hibernation: Registered nosave memory: [mem 0xfed82000-0xfedfffff]
[ 0.036588] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.036589] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.036590] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.036591] [mem 0xb0000000-0xf7ffffff] available for PCI devices
[ 0.036592] Booting paravirtualized kernel on bare hardware
[ 0.036595] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.041175] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[ 0.041689] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[ 0.041696] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[ 0.041698] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.041727] Built 1 zonelists, mobility grouping on. Total pages: 3575231
[ 0.041728] Policy zone: Normal
[ 0.041730] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2120 quiet systemd.show_status=1 apparmor=1 security=apparmor modprobe.blacklist=amdgpu systemd.unit=multi-user.target driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 0.041884] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2120 driver=free", will be passed to user space.
[ 0.043340] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.044097] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.044339] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.079844] Memory: 14107684K/14528572K available (14344K kernel code, 2097K rwdata, 10880K rodata, 1864K init, 3784K bss, 420628K reserved, 0K cma-reserved)
[ 0.079852] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.079976] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.079988] ftrace: allocating 44508 entries in 174 pages
[ 0.097525] ftrace: allocated 174 pages with 5 groups
[ 0.097641] rcu: Preemptible hierarchical RCU implementation.
[ 0.097642] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.097643] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.097644] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.097645] Trampoline variant of Tasks RCU enabled.
[ 0.097645] Rude variant of Tasks RCU enabled.
[ 0.097646] Tracing variant of Tasks RCU enabled.
[ 0.097647] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.097647] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.100827] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[ 0.101099] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.101215] spurious 8259A interrupt: IRQ7.
[ 0.101226] Console: colour dummy device 80x25
[ 0.101239] printk: console [tty0] enabled
[ 0.101259] ACPI: Core revision 20210730
[ 0.101485] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.101503] APIC: Switch to symmetric I/O mode setup
[ 0.101844] AMD-Vi: Translation was enabled for IOMMU:0 but we are not in kdump mode
[ 0.102279] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
[ 0.102281] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
[ 0.102282] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
[ 0.102283] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
[ 0.102559] Switched APIC routing to physical flat.
[ 0.103315] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.118175] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x36ad7881975, max_idle_ns: 881590493029 ns
[ 0.118181] Calibrating delay loop (skipped), value calculated using timer frequency.. 3794.31 BogoMIPS (lpj=6322100)
[ 0.118183] pid_max: default: 32768 minimum: 301
[ 0.118207] LSM: Security Framework initializing
[ 0.118215] landlock: Up and running.
[ 0.118215] Yama: becoming mindful.
[ 0.118231] AppArmor: AppArmor initialized
[ 0.118269] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.118304] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.118557] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.118567] LVT offset 1 assigned for vector 0xf9
[ 0.118582] LVT offset 2 assigned for vector 0xf4
[ 0.118586] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.118587] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.118590] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.118593] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.118594] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.118595] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.118597] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.118597] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.118600] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.121888] Freeing SMP alternatives memory: 36K
[ 0.231899] smpboot: CPU0: AMD Ryzen 7 5800U with Radeon Graphics (family: 0x19, model: 0x50, stepping: 0x0)
[ 0.232041] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.232046] ... version: 0
[ 0.232047] ... bit width: 48
[ 0.232047] ... generic registers: 6
[ 0.232048] ... value mask: 0000ffffffffffff
[ 0.232048] ... max period: 00007fffffffffff
[ 0.232049] ... fixed-purpose events: 0
[ 0.232049] ... event mask: 000000000000003f
[ 0.232111] rcu: Hierarchical SRCU implementation.
[ 0.232525] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.232650] smp: Bringing up secondary CPUs ...
[ 0.232737] x86: Booting SMP configuration:
[ 0.232738] .... node #0, CPUs: #1
[ 0.234959] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.235023] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.267028] smp: Brought up 1 node, 16 CPUs
[ 0.267028] smpboot: Max logical packages: 1
[ 0.267028] smpboot: Total of 16 processors activated (60716.00 BogoMIPS)
[ 0.268426] devtmpfs: initialized
[ 0.268426] x86/mm: Memory block size: 128MB
[ 0.268781] ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0efff] (61440 bytes)
[ 0.268781] ACPI: PM: Registering ACPI NVS region [mem 0xacf7f000-0xadf7efff] (16777216 bytes)
[ 0.268781] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.268781] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.268781] pinctrl core: initialized pinctrl subsystem
[ 0.268781] PM: RTC time: 14:07:25, date: 2021-12-29
[ 0.268810] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.268986] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.269078] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.269170] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.269179] audit: initializing netlink subsys (disabled)
[ 0.269185] audit: type=2000 audit(1640786845.166:1): state=initialized audit_enabled=0 res=1
[ 0.269185] thermal_sys: Registered thermal governor 'fair_share'
[ 0.269185] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.269185] thermal_sys: Registered thermal governor 'step_wise'
[ 0.269185] thermal_sys: Registered thermal governor 'user_space'
[ 0.269185] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.269185] cpuidle: using governor ladder
[ 0.269185] cpuidle: using governor menu
[ 0.269185] Simple Boot Flag at 0x44 set to 0x1
[ 0.269185] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.269185] ACPI: bus type PCI registered
[ 0.269185] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.269185] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.269185] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.269185] PCI: Using configuration type 1 for base access
[ 0.269185] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.269185] mtrr: probably your BIOS does not setup all CPUs.
[ 0.269185] mtrr: corrected configuration.
[ 0.271981] Kprobes globally optimized
[ 0.271984] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.271984] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.271984] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.271984] ACPI: Added _OSI(Module Device)
[ 0.271984] ACPI: Added _OSI(Processor Device)
[ 0.271984] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.271984] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.271984] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.271984] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.271984] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.288388] ACPI: 20 ACPI AML tables successfully acquired and loaded
[ 0.289867] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.299592] ACPI: EC: EC started
[ 0.299593] ACPI: EC: interrupt blocked
[ 0.299749] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.299750] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
[ 0.299752] ACPI: Interpreter enabled
[ 0.299765] ACPI: PM: (supports S0 S4 S5)
[ 0.299765] ACPI: Using IOAPIC for interrupt routing
[ 0.299923] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.301155] ACPI: PM: Power Resource [PRWL]
[ 0.301225] ACPI: PM: Power Resource [P0NV]
[ 0.301641] ACPI: PM: Power Resource [P0U0]
[ 0.301657] ACPI: PM: Power Resource [P3U0]
[ 0.302107] ACPI: PM: Power Resource [P0U1]
[ 0.302123] ACPI: PM: Power Resource [P3U1]
[ 0.302414] ACPI: PM: Power Resource [PRBT]
[ 0.333937] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.333942] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.334083] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.334216] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.334226] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.334322] acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cd7ff])
[ 0.334440] PCI host bridge to bus 0000:00
[ 0.334442] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.334443] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.334444] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.334445] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[ 0.334446] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[ 0.334447] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[ 0.334447] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.334448] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.334449] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.334450] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.334450] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.334451] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.334452] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.334453] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.334453] pci_bus 0000:00: root bus resource [mem 0xb0000000-0xf7ffffff window]
[ 0.334454] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfeafffff window]
[ 0.334455] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xfed811ff window]
[ 0.334456] pci_bus 0000:00: root bus resource [mem 0xfed81900-0xfed81fff window]
[ 0.334456] pci_bus 0000:00: root bus resource [mem 0xfedc0000-0xfedc0fff window]
[ 0.334457] pci_bus 0000:00: root bus resource [mem 0xfedc6000-0xfedc6fff window]
[ 0.334458] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.334489] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[ 0.334597] pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
[ 0.334728] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[ 0.334842] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[ 0.334983] pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
[ 0.335039] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.335140] pci 0000:00:02.3: [1022:1634] type 01 class 0x060400
[ 0.335192] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[ 0.335290] pci 0000:00:02.4: [1022:1634] type 01 class 0x060400
[ 0.335341] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[ 0.335449] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[ 0.335547] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[ 0.335568] pci 0000:00:08.1: enabling Extended Tags
[ 0.335597] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.335726] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.335871] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.336026] pci 0000:00:18.0: [1022:166a] type 00 class 0x060000
[ 0.336105] pci 0000:00:18.1: [1022:166b] type 00 class 0x060000
[ 0.336181] pci 0000:00:18.2: [1022:166c] type 00 class 0x060000
[ 0.336257] pci 0000:00:18.3: [1022:166d] type 00 class 0x060000
[ 0.336332] pci 0000:00:18.4: [1022:166e] type 00 class 0x060000
[ 0.336407] pci 0000:00:18.5: [1022:166f] type 00 class 0x060000
[ 0.336484] pci 0000:00:18.6: [1022:1670] type 00 class 0x060000
[ 0.336560] pci 0000:00:18.7: [1022:1671] type 00 class 0x060000
[ 0.336664] pci 0000:01:00.0: [14c3:7961] type 00 class 0x028000
[ 0.336685] pci 0000:01:00.0: reg 0x10: [mem 0xc0200000-0xc02fffff 64bit pref]
[ 0.336699] pci 0000:01:00.0: reg 0x18: [mem 0xc0300000-0xc0303fff 64bit pref]
[ 0.336712] pci 0000:01:00.0: reg 0x20: [mem 0xc0304000-0xc0304fff 64bit pref]
[ 0.336786] pci 0000:01:00.0: supports D1 D2
[ 0.336786] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.336902] pci 0000:00:02.2: PCI bridge to [bus 01]
[ 0.336908] pci 0000:00:02.2: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.336958] pci 0000:02:00.0: [10ec:522a] type 00 class 0xff0000
[ 0.336974] pci 0000:02:00.0: reg 0x10: [mem 0xc0900000-0xc0900fff]
[ 0.337092] pci 0000:02:00.0: supports D1 D2
[ 0.337092] pci 0000:02:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.337197] pci 0000:00:02.3: PCI bridge to [bus 02]
[ 0.337201] pci 0000:00:02.3: bridge window [mem 0xc0900000-0xc09fffff]
[ 0.337528] pci 0000:03:00.0: [144d:a808] type 00 class 0x010802
[ 0.337544] pci 0000:03:00.0: reg 0x10: [mem 0xc0800000-0xc0803fff 64bit]
[ 0.337745] pci 0000:00:02.4: PCI bridge to [bus 03]
[ 0.337749] pci 0000:00:02.4: bridge window [mem 0xc0800000-0xc08fffff]
[ 0.337830] pci 0000:04:00.0: [1002:1638] type 00 class 0x030000
[ 0.337841] pci 0000:04:00.0: reg 0x10: [mem 0xb0000000-0xbfffffff 64bit pref]
[ 0.337848] pci 0000:04:00.0: reg 0x18: [mem 0xc0000000-0xc01fffff 64bit pref]
[ 0.337854] pci 0000:04:00.0: reg 0x20: [io 0x1000-0x10ff]
[ 0.337859] pci 0000:04:00.0: reg 0x24: [mem 0xc0700000-0xc077ffff]
[ 0.337867] pci 0000:04:00.0: enabling Extended Tags
[ 0.337915] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.337948] pci 0000:04:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.338007] pci 0000:04:00.1: [1002:1637] type 00 class 0x040300
[ 0.338016] pci 0000:04:00.1: reg 0x10: [mem 0xc07c8000-0xc07cbfff]
[ 0.338043] pci 0000:04:00.1: enabling Extended Tags
[ 0.338071] pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.338134] pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
[ 0.338151] pci 0000:04:00.2: reg 0x18: [mem 0xc0600000-0xc06fffff]
[ 0.338163] pci 0000:04:00.2: reg 0x24: [mem 0xc07cc000-0xc07cdfff]
[ 0.338174] pci 0000:04:00.2: enabling Extended Tags
[ 0.338272] pci 0000:04:00.3: [1022:1639] type 00 class 0x0c0330
[ 0.338282] pci 0000:04:00.3: reg 0x10: [mem 0xc0400000-0xc04fffff 64bit]
[ 0.338306] pci 0000:04:00.3: enabling Extended Tags
[ 0.338335] pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
[ 0.338402] pci 0000:04:00.4: [1022:1639] type 00 class 0x0c0330
[ 0.338413] pci 0000:04:00.4: reg 0x10: [mem 0xc0500000-0xc05fffff 64bit]
[ 0.338437] pci 0000:04:00.4: enabling Extended Tags
[ 0.338466] pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
[ 0.338531] pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000
[ 0.338539] pci 0000:04:00.5: reg 0x10: [mem 0xc0780000-0xc07bffff]
[ 0.338567] pci 0000:04:00.5: enabling Extended Tags
[ 0.338594] pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
[ 0.338656] pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
[ 0.338665] pci 0000:04:00.6: reg 0x10: [mem 0xc07c0000-0xc07c7fff]
[ 0.338692] pci 0000:04:00.6: enabling Extended Tags
[ 0.338719] pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
[ 0.338785] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.338788] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.338789] pci 0000:00:08.1: bridge window [mem 0xc0400000-0xc07fffff]
[ 0.338792] pci 0000:00:08.1: bridge window [mem 0xb0000000-0xc01fffff 64bit pref]
[ 0.365439] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.365443] ACPI: PCI: Interrupt link LNKA disabled
[ 0.365583] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.365585] ACPI: PCI: Interrupt link LNKB disabled
[ 0.365665] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.365665] ACPI: PCI: Interrupt link LNKC disabled
[ 0.365726] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.365726] ACPI: PCI: Interrupt link LNKD disabled
[ 0.365782] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.365783] ACPI: PCI: Interrupt link LNKE disabled
[ 0.365826] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.365827] ACPI: PCI: Interrupt link LNKF disabled
[ 0.365870] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.365871] ACPI: PCI: Interrupt link LNKG disabled
[ 0.365914] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.365915] ACPI: PCI: Interrupt link LNKH disabled
[ 0.367343] ACPI: EC: interrupt unblocked
[ 0.367344] ACPI: EC: event unblocked
[ 0.367348] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.367349] ACPI: EC: GPE=0x3
[ 0.367350] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[ 0.367352] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[ 0.367380] iommu: Default domain type: Translated
[ 0.367380] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.367390] pci 0000:04:00.0: vgaarb: setting as boot VGA device
[ 0.367390] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.367390] pci 0000:04:00.0: vgaarb: bridge control possible
[ 0.367390] vgaarb: loaded
[ 0.367390] SCSI subsystem initialized
[ 0.367390] libata version 3.00 loaded.
[ 0.367390] ACPI: bus type USB registered
[ 0.367390] usbcore: registered new interface driver usbfs
[ 0.367390] usbcore: registered new interface driver hub
[ 0.367390] usbcore: registered new device driver usb
[ 0.454434] pps_core: LinuxPPS API ver. 1 registered
[ 0.454435] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.454437] PTP clock support registered
[ 0.454442] EDAC MC: Ver: 3.0.0
[ 0.454951] NetLabel: Initializing
[ 0.454953] NetLabel: domain hash size = 128
[ 0.454954] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.454962] NetLabel: unlabeled traffic allowed by default
[ 0.454965] PCI: Using ACPI for IRQ routing
[ 0.457048] PCI: pci_cache_line_size set to 64 bytes
[ 0.457363] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.457364] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[ 0.457366] e820: reserve RAM buffer [mem 0x09a00000-0x0bffffff]
[ 0.457367] e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
[ 0.457367] e820: reserve RAM buffer [mem 0x9ab69000-0x9bffffff]
[ 0.457368] e820: reserve RAM buffer [mem 0xa9f7f000-0xabffffff]
[ 0.457369] e820: reserve RAM buffer [mem 0xae000000-0xafffffff]
[ 0.457369] e820: reserve RAM buffer [mem 0x3ce300000-0x3cfffffff]
[ 0.457374] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.457374] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.459707] clocksource: Switched to clocksource tsc-early
[ 0.464061] VFS: Disk quotas dquot_6.6.0
[ 0.464072] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.464139] AppArmor: AppArmor Filesystem Enabled
[ 0.464163] pnp: PnP ACPI init
[ 0.464270] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[ 0.464274] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.464276] system 00:00: [mem 0xfde00000-0xfdefffff] has been reserved
[ 0.464395] system 00:03: [io 0x0400-0x04cf] has been reserved
[ 0.464396] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.464397] system 00:03: [io 0x04d6] has been reserved
[ 0.464398] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.464399] system 00:03: [io 0x0c14] has been reserved
[ 0.464399] system 00:03: [io 0x0c50-0x0c52] has been reserved
[ 0.464400] system 00:03: [io 0x0c6c] has been reserved
[ 0.464401] system 00:03: [io 0x0c6f] has been reserved
[ 0.464402] system 00:03: [io 0x0cd0-0x0cdb] has been reserved
[ 0.464444] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.491348] pnp: PnP ACPI: found 5 devices
[ 0.497121] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.497179] NET: Registered PF_INET protocol family
[ 0.497390] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.498452] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.498558] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.498708] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.498755] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.498825] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.498863] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.498900] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.498955] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.498959] NET: Registered PF_XDP protocol family
[ 0.498962] pci 0000:00:02.2: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.498965] pci 0000:00:02.2: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 0.498973] pci 0000:00:02.2: BAR 14: assigned [mem 0xc0a00000-0xc0bfffff]
[ 0.498975] pci 0000:00:02.2: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.498977] pci 0000:00:02.2: PCI bridge to [bus 01]
[ 0.498978] pci 0000:00:02.2: bridge window [io 0x2000-0x2fff]
[ 0.498981] pci 0000:00:02.2: bridge window [mem 0xc0a00000-0xc0bfffff]
[ 0.498983] pci 0000:00:02.2: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.498986] pci 0000:00:02.3: PCI bridge to [bus 02]
[ 0.498988] pci 0000:00:02.3: bridge window [mem 0xc0900000-0xc09fffff]
[ 0.498991] pci 0000:00:02.4: PCI bridge to [bus 03]
[ 0.498994] pci 0000:00:02.4: bridge window [mem 0xc0800000-0xc08fffff]
[ 0.498998] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.498999] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.499001] pci 0000:00:08.1: bridge window [mem 0xc0400000-0xc07fffff]
[ 0.499002] pci 0000:00:08.1: bridge window [mem 0xb0000000-0xc01fffff 64bit pref]
[ 0.499006] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.499007] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.499007] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.499008] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[ 0.499009] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[ 0.499009] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[ 0.499010] pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
[ 0.499011] pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
[ 0.499011] pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
[ 0.499012] pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
[ 0.499013] pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
[ 0.499013] pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
[ 0.499014] pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
[ 0.499015] pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
[ 0.499018] pci_bus 0000:00: resource 18 [mem 0xb0000000-0xf7ffffff window]
[ 0.499018] pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfeafffff window]
[ 0.499019] pci_bus 0000:00: resource 20 [mem 0xfed45000-0xfed811ff window]
[ 0.499020] pci_bus 0000:00: resource 21 [mem 0xfed81900-0xfed81fff window]
[ 0.499020] pci_bus 0000:00: resource 22 [mem 0xfedc0000-0xfedc0fff window]
[ 0.499021] pci_bus 0000:00: resource 23 [mem 0xfedc6000-0xfedc6fff window]
[ 0.499022] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.499022] pci_bus 0000:01: resource 1 [mem 0xc0a00000-0xc0bfffff]
[ 0.499023] pci_bus 0000:01: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.499024] pci_bus 0000:02: resource 1 [mem 0xc0900000-0xc09fffff]
[ 0.499025] pci_bus 0000:03: resource 1 [mem 0xc0800000-0xc08fffff]
[ 0.499025] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.499026] pci_bus 0000:04: resource 1 [mem 0xc0400000-0xc07fffff]
[ 0.499026] pci_bus 0000:04: resource 2 [mem 0xb0000000-0xc01fffff 64bit pref]
[ 0.499370] pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.499382] pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
[ 0.499406] pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
[ 5.804442] pci 0000:04:00.3: quirk_usb_early_handoff+0x0/0x750 took 5180697 usecs
[ 5.804453] pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
[ 11.144807] pci 0000:04:00.4: quirk_usb_early_handoff+0x0/0x750 took 5215188 usecs
[ 11.144815] PCI: CLS 64 bytes, default 64
[ 11.144824] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 11.144856] Trying to unpack rootfs image as initramfs...
[ 11.144869] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 11.144870] pci 0000:00:00.2: PCI INT A: not connected
[ 11.144882] pci 0000:00:01.0: Adding to iommu group 0
[ 11.144892] pci 0000:00:02.0: Adding to iommu group 1
[ 11.144898] pci 0000:00:02.2: Adding to iommu group 2
[ 11.144904] pci 0000:00:02.3: Adding to iommu group 3
[ 11.144910] pci 0000:00:02.4: Adding to iommu group 4
[ 11.144919] pci 0000:00:08.0: Adding to iommu group 5
[ 11.144924] pci 0000:00:08.1: Adding to iommu group 5
[ 11.144932] pci 0000:00:14.0: Adding to iommu group 6
[ 11.144937] pci 0000:00:14.3: Adding to iommu group 6
[ 11.144955] pci 0000:00:18.0: Adding to iommu group 7
[ 11.144961] pci 0000:00:18.1: Adding to iommu group 7
[ 11.144966] pci 0000:00:18.2: Adding to iommu group 7
[ 11.144972] pci 0000:00:18.3: Adding to iommu group 7
[ 11.144978] pci 0000:00:18.4: Adding to iommu group 7
[ 11.144983] pci 0000:00:18.5: Adding to iommu group 7
[ 11.144988] pci 0000:00:18.6: Adding to iommu group 7
[ 11.144993] pci 0000:00:18.7: Adding to iommu group 7
[ 11.145000] pci 0000:01:00.0: Adding to iommu group 8
[ 11.145006] pci 0000:02:00.0: Adding to iommu group 9
[ 11.145013] pci 0000:03:00.0: Adding to iommu group 10
[ 11.145024] pci 0000:04:00.0: Adding to iommu group 5
[ 11.145027] pci 0000:04:00.1: Adding to iommu group 5
[ 11.145030] pci 0000:04:00.2: Adding to iommu group 5
[ 11.145033] pci 0000:04:00.3: Adding to iommu group 5
[ 11.145036] pci 0000:04:00.4: Adding to iommu group 5
[ 11.145040] pci 0000:04:00.5: Adding to iommu group 5
[ 11.145043] pci 0000:04:00.6: Adding to iommu group 5
[ 11.146634] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 11.146636] AMD-Vi: Extended features (0x206d73ef22254ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 11.146643] AMD-Vi: Interrupt remapping enabled
[ 11.146644] AMD-Vi: Virtual APIC enabled
[ 11.146644] AMD-Vi: X2APIC enabled
[ 11.183298] software IO TLB: tearing down default memory pool
[ 11.183772] LVT offset 0 assigned for vector 0x400
[ 11.184033] perf: AMD IBS detected (0x000003ff)
[ 11.184037] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 11.185402] Initialise system trusted keyrings
[ 11.185410] Key type blacklist registered
[ 11.185433] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 11.185961] zbud: loaded
[ 11.188736] Key type asymmetric registered
[ 11.188737] Asymmetric key parser 'x509' registered
[ 11.188748] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 11.188775] io scheduler mq-deadline registered
[ 11.188775] io scheduler kyber registered
[ 11.188791] io scheduler bfq registered
[ 11.188994] pcieport 0000:00:02.2: PME: Signaling with IRQ 26
[ 11.189008] pcieport 0000:00:02.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 11.189110] pcieport 0000:00:02.3: PME: Signaling with IRQ 27
[ 11.189185] pcieport 0000:00:02.4: PME: Signaling with IRQ 28
[ 11.189262] pcieport 0000:00:08.1: PME: Signaling with IRQ 29
[ 11.189315] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.191752] ACPI: AC: AC Adapter [ACAD] (off-line)
[ 11.191786] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 11.191798] ACPI: button: Lid Switch [LID]
[ 11.191810] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 11.191820] ACPI: button: Sleep Button [SLPB]
[ 11.191830] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 11.191836] ACPI: button: Power Button [PWRB]
[ 11.191908] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1726
[ 11.191920] Monitor-Mwait will be used to enter C-1 state
[ 11.191923] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 11.191990] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 11.192044] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 11.192143] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 11.192261] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 11.192391] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 11.193282] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 11.193478] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 11.193748] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 11.193998] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 11.194145] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 11.194337] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 11.194483] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 11.194733] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 11.194989] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 11.195236] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 11.195665] thermal LNXTHERM:00: registered as thermal_zone0
[ 11.195668] ACPI: thermal: Thermal Zone [TZ01] (81 C)
[ 11.195872] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 11.196890] Non-volatile memory driver v1.3
[ 11.196892] Linux agpgart interface v0.103
[ 11.196954] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 11.198250] nvme 0000:03:00.0: platform quirk: setting simple suspend
[ 11.198273] nvme nvme0: pci function 0000:03:00.0
[ 11.198372] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 11.198382] ehci-pci: EHCI PCI platform driver
[ 11.198395] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 11.198396] ohci-pci: OHCI PCI platform driver
[ 11.198401] uhci_hcd: USB Universal Host Controller Interface driver
[ 11.198428] usbcore: registered new interface driver usbserial_generic
[ 11.198431] usbserial: USB Serial support registered for generic
[ 11.198715] rtc_cmos 00:01: RTC can wake from S4
[ 11.199456] rtc_cmos 00:01: registered as rtc0
[ 11.199486] rtc_cmos 00:01: setting system clock to 2021-12-29T14:07:36 UTC (1640786856)
[ 11.199498] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 11.200180] ledtrig-cpu: registered to indicate activity on CPUs
[ 11.200559] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 11.200561] vesafb: scrolling: redraw
[ 11.200562] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 11.200573] vesafb: framebuffer at 0xb0000000, mapped to 0x0000000005587b11, using 3072k, total 3072k
[ 11.200633] fbcon: Deferring console take-over
[ 11.200634] fb0: VESA VGA frame buffer device
[ 11.200649] hid: raw HID events driver (C) Jiri Kosina
[ 11.200749] ashmem: initialized
[ 11.200855] drop_monitor: Initializing network drop monitor service
[ 11.200896] Initializing XFRM netlink socket
[ 11.200961] NET: Registered PF_INET6 protocol family
[ 11.217154] nvme nvme0: missing or invalid SUBNQN field.
[ 11.217182] nvme nvme0: Shutdown timeout set to 8 seconds
[ 11.236665] nvme nvme0: 16/0/0 default/read/poll queues
[ 11.240191] nvme0n1: p1 p2 p3 p4
[ 11.457663] ACPI: battery: Slot [BAT1] (battery present)
[ 11.783701] tsc: Refined TSC clocksource calibration: 1896.436 MHz
[ 11.783710] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x36ac0addf95, max_idle_ns: 881590783532 ns
[ 11.783758] clocksource: Switched to clocksource tsc
[ 13.868584] Freeing initrd memory: 52684K
[ 13.874657] Segment Routing with IPv6
[ 13.874660] RPL Segment Routing with IPv6
[ 13.874671] In-situ OAM (IOAM) with IPv6
[ 13.874694] NET: Registered PF_PACKET protocol family
[ 13.876266] microcode: CPU0: patch_level=0x0a50000c
[ 13.876270] microcode: CPU1: patch_level=0x0a50000c
[ 13.876289] microcode: CPU2: patch_level=0x0a50000c
[ 13.876307] microcode: CPU3: patch_level=0x0a50000c
[ 13.876324] microcode: CPU4: patch_level=0x0a50000c
[ 13.876339] microcode: CPU5: patch_level=0x0a50000c
[ 13.876357] microcode: CPU6: patch_level=0x0a50000c
[ 13.876372] microcode: CPU7: patch_level=0x0a50000c
[ 13.876391] microcode: CPU8: patch_level=0x0a50000c
[ 13.876408] microcode: CPU9: patch_level=0x0a50000c
[ 13.876427] microcode: CPU10: patch_level=0x0a50000c
[ 13.876441] microcode: CPU11: patch_level=0x0a50000c
[ 13.876460] microcode: CPU12: patch_level=0x0a50000c
[ 13.876475] microcode: CPU13: patch_level=0x0a50000c
[ 13.876493] microcode: CPU14: patch_level=0x0a50000c
[ 13.876508] microcode: CPU15: patch_level=0x0a50000c
[ 13.876512] microcode: Microcode Update Driver: v2.2.
[ 13.876887] resctrl: L3 allocation detected
[ 13.876889] resctrl: MB allocation detected
[ 13.876889] resctrl: L3 monitoring detected
[ 13.876893] IPI shorthand broadcast: enabled
[ 13.876903] sched_clock: Marking stable (13876393446, 483022)->(13885834316, -8957848)
[ 13.877230] registered taskstats version 1
[ 13.877891] Loading compiled-in X.509 certificates
[ 13.879652] Loaded X.509 cert 'Build time autogenerated kernel key: <filter>'
[ 13.882487] zswap: loaded using pool zstd/z3fold
[ 13.883613] Key type ._fscrypt registered
[ 13.883615] Key type .fscrypt registered
[ 13.883616] Key type fscrypt-provisioning registered
[ 13.883649] AppArmor: AppArmor sha1 policy hashing enabled
[ 13.883866] PM: Magic number: 1:766:132
[ 13.883915] acpi PNP0C02:04: hash matches
[ 13.883932] acpi device:07: hash matches
[ 13.884102] RAS: Correctable Errors collector initialized.
[ 13.884618] Freeing unused decrypted memory: 2036K
[ 13.884963] Freeing unused kernel image (initmem) memory: 1864K
[ 13.911808] Write protecting the kernel read-only data: 28672k
[ 13.912700] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 13.913289] Freeing unused kernel image (rodata/data gap) memory: 1408K
[ 13.935500] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 13.935509] rodata_test: all tests were successful
[ 13.935517] Run /init as init process
[ 13.935519] with arguments:
[ 13.935520] /init
[ 13.935521] with environment:
[ 13.935522] HOME=/
[ 13.935522] TERM=linux
[ 13.935522] BOOT_IMAGE=/boot/vmlinuz-x86_64
[ 13.935523] lang=en_US
[ 13.935523] keytable=us
[ 13.935523] tz=UTC
[ 13.935524] misobasedir=manjaro
[ 13.935524] misolabel=MANJARO_XFCE_2120
[ 13.935524] driver=free
[ 13.945698] fbcon: Taking over console
[ 13.945806] Console: switching to colour frame buffer device 128x48
[ 13.994104] loop: module loaded
[ 13.999911] device-mapper: uevent: version 1.0.3
[ 13.999973] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 14.161561] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 14.163382] acpi device:09: registered as cooling_device16
[ 14.163447] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/LNXVIDEO:00/input/input3
[ 14.165637] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 14.165642] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 14.165962] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 14.166056] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 14.167576] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 14.167595] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
[ 14.167720] xhci_hcd 0000:04:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 14.168162] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 14.168165] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.168166] usb usb1: Product: xHCI Host Controller
[ 14.168167] usb usb1: Manufacturer: Linux 5.15.7-1-MANJARO xhci-hcd
[ 14.168168] usb usb1: SerialNumber: 0000:04:00.2
[ 14.168427] hub 1-0:1.0: USB hub found
[ 14.168441] hub 1-0:1.0: 4 ports detected
[ 14.169104] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 14.169113] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
[ 14.169118] xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 14.169144] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.169173] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 14.169175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.169177] usb usb2: Product: xHCI Host Controller
[ 14.169178] usb usb2: Manufacturer: Linux 5.15.7-1-MANJARO xhci-hcd
[ 14.169179] usb usb2: SerialNumber: 0000:04:00.3
[ 14.169418] hub 2-0:1.0: USB hub found
[ 14.169427] hub 2-0:1.0: 2 ports detected
[ 14.169886] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 14.169895] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
[ 14.170007] xhci_hcd 0000:04:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 14.170386] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 14.170388] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.170390] usb usb3: Product: xHCI Host Controller
[ 14.170392] usb usb3: Manufacturer: Linux 5.15.7-1-MANJARO xhci-hcd
[ 14.170393] usb usb3: SerialNumber: 0000:04:00.4
[ 14.173455] cryptd: max_cpu_qlen set to 1000
[ 14.183037] AVX2 version of gcm_enc/dec engaged.
[ 14.183325] AES CTR mode by8 optimization enabled
[ 14.184278] hub 3-0:1.0: USB hub found
[ 14.184289] hub 3-0:1.0: 4 ports detected
[ 14.184657] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 14.184662] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
[ 14.184668] xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 14.184686] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.184700] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 14.184702] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.184703] usb usb4: Product: xHCI Host Controller
[ 14.184704] usb usb4: Manufacturer: Linux 5.15.7-1-MANJARO xhci-hcd
[ 14.184705] usb usb4: SerialNumber: <filter>
[ 14.189410] hub 4-0:1.0: USB hub found
[ 14.189467] hub 4-0:1.0: 2 ports detected
[ 14.238521] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 14.418252] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[ 14.431579] usb 3-2: new high-speed USB device number 2 using xhci_hcd
[ 14.564356] usb 1-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 4.00
[ 14.564363] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 14.564365] usb 1-2: Product: SAMSUNG_Android
[ 14.564367] usb 1-2: Manufacturer: SAMSUNG
[ 14.564368] usb 1-2: SerialNumber: <filter>
[ 14.635574] usb 3-2: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[ 14.635584] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 14.635588] usb 3-2: Product: Flash Disk
[ 14.635591] usb 3-2: Manufacturer: USB
[ 14.635593] usb 3-2: SerialNumber: <filter>
[ 14.640097] usb-storage 3-2:1.0: USB Mass Storage device detected
[ 14.640374] usb-storage 3-2:1.0: Quirks match for vid 090c pid 1000: 400
[ 14.640476] scsi host0: usb-storage 3-2:1.0
[ 14.640590] usbcore: registered new interface driver usb-storage
[ 14.643348] usbcore: registered new interface driver uas
[ 14.758245] usb 3-4: new high-speed USB device number 3 using xhci_hcd
[ 14.774911] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[ 14.902859] usb 3-4: New USB device found, idVendor=0489, idProduct=e0cd, bcdDevice= 1.00
[ 14.902870] usb 3-4: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[ 14.902874] usb 3-4: Product: Wireless_Device
[ 14.902877] usb 3-4: Manufacturer: MediaTek Inc.
[ 14.902879] usb 3-4: SerialNumber: 000000000
[ 14.919901] usb 1-3: New USB device found, idVendor=04f2, idProduct=b6be, bcdDevice=85.18
[ 14.919911] usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 14.919915] usb 1-3: Product: Integrated Camera
[ 14.919918] usb 1-3: Manufacturer: Chicony Electronics Co.,Ltd.
[ 14.919920] usb 1-3: SerialNumber: 0001
[ 15.070754] random: fast init done
[ 15.868426] scsi 0:0:0:0: Direct-Access USB Flash Disk 1100 PQ: 0 ANSI: 4
[ 15.870526] sd 0:0:0:0: [sda] 7866368 512-byte logical blocks: (4.03 GB/3.75 GiB)
[ 15.871590] sd 0:0:0:0: [sda] Write Protect is off
[ 15.871597] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 15.873000] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 15.881766] sda: sda1 sda2
[ 15.888132] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 16.247161] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 16.249494] ISO 9660 Extensions: RRIP_1991A
[ 16.365888] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 16.367683] ISO 9660 Extensions: RRIP_1991A
[ 16.377094] loop0: detected capacity change from 0 to 267384
[ 16.547094] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 16.584733] loop1: detected capacity change from 0 to 1795120
[ 16.771784] loop2: detected capacity change from 0 to 3192352
[ 16.934075] loop3: detected capacity change from 0 to 1499920
[ 17.137276] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 18.303267] systemd[1]: systemd 249.7-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 18.318628] systemd[1]: Detected architecture x86-64.
[ 20.158645] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 20.193814] systemd[1]: Queued start job for default target Multi-User System.
[ 20.195679] systemd[1]: Created slice Slice /system/getty.
[ 20.196392] systemd[1]: Created slice Slice /system/modprobe.
[ 20.196979] systemd[1]: Created slice User and Session Slice.
[ 20.197445] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 20.198053] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 20.198740] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 20.199476] systemd[1]: Reached target Local Encrypted Volumes.
[ 20.199910] systemd[1]: Reached target Remote File Systems.
[ 20.200297] systemd[1]: Reached target Slice Units.
[ 20.200631] systemd[1]: Reached target Swaps.
[ 20.200921] systemd[1]: Reached target Local Verity Protected Volumes.
[ 20.201440] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 20.202571] systemd[1]: Listening on LVM2 poll daemon socket.
[ 20.203892] systemd[1]: Listening on Process Core Dump Socket.
[ 20.204402] systemd[1]: Listening on Journal Audit Socket.
[ 20.204841] systemd[1]: Listening on Journal Socket (/dev/log).
[ 20.205570] systemd[1]: Listening on Journal Socket.
[ 20.206606] systemd[1]: Listening on udev Control Socket.
[ 20.207157] systemd[1]: Listening on udev Kernel Socket.
[ 20.208419] systemd[1]: Mounting Huge Pages File System...
[ 20.210061] systemd[1]: Mounting POSIX Message Queue File System...
[ 20.211983] systemd[1]: Mounting Kernel Debug File System...
[ 20.213494] systemd[1]: Mounting Kernel Trace File System...
[ 20.225477] systemd[1]: Mounting Temporary Directory /tmp...
[ 20.226926] systemd[1]: Starting Load AppArmor profiles...
[ 20.228967] systemd[1]: Starting Create List of Static Device Nodes...
[ 20.230513] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 20.232298] systemd[1]: Starting Load Kernel Module configfs...
[ 20.233997] systemd[1]: Starting Load Kernel Module drm...
[ 20.234609] random: lvm: uninitialized urandom read (4 bytes read)
[ 20.235679] systemd[1]: Starting Load Kernel Module fuse...
[ 20.293739] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 20.304455] fuse: init (API version 7.34)
[ 20.336765] systemd[1]: Starting Load Kernel Modules...
[ 20.338292] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 20.394331] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 20.395714] systemd[1]: Starting Coldplug All udev Devices...
[ 20.397773] systemd[1]: Mounted Huge Pages File System.
[ 20.398432] systemd[1]: Mounted POSIX Message Queue File System.
[ 20.399042] systemd[1]: Mounted Kernel Debug File System.
[ 20.399474] systemd[1]: Mounted Kernel Trace File System.
[ 20.399894] systemd[1]: Mounted Temporary Directory /tmp.
[ 20.400504] systemd[1]: Finished Create List of Static Device Nodes.
[ 20.401324] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 20.401490] systemd[1]: Finished Load Kernel Module configfs.
[ 20.402347] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 20.402513] systemd[1]: Finished Load Kernel Module drm.
[ 20.403206] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 20.403344] systemd[1]: Finished Load Kernel Module fuse.
[ 20.404071] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 20.405788] systemd[1]: Mounting FUSE Control File System...
[ 20.418689] systemd[1]: Mounting Kernel Configuration File System...
[ 20.430944] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 20.526246] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 20.527302] systemd[1]: Starting Load/Save Random Seed...
[ 20.539834] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 20.541122] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 20.554560] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 20.568298] systemd[1]: Mounted FUSE Control File System.
[ 20.584188] systemd[1]: Mounted Kernel Configuration File System.
[ 20.618078] audit: type=1400 audit(1640786865.914:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=456 comm="apparmor_parser"
[ 20.618851] audit: type=1400 audit(1640786865.917:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=456 comm="apparmor_parser"
[ 20.628958] audit: type=1400 audit(1640786865.927:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=455 comm="apparmor_parser"
[ 20.636899] audit: type=1400 audit(1640786865.934:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=458 comm="apparmor_parser"
[ 20.669731] audit: type=1400 audit(1640786865.967:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=457 comm="apparmor_parser"
[ 20.693514] spl: loading out-of-tree module taints kernel.
[ 20.693594] spl: module verification failed: signature and/or required key missing - tainting kernel
[ 20.706439] audit: type=1400 audit(1640786866.004:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=454 comm="apparmor_parser"
[ 20.707131] audit: type=1400 audit(1640786866.004:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=454 comm="apparmor_parser"
[ 20.726845] znvpair: module license 'CDDL' taints kernel.
[ 20.726849] Disabling lock debugging due to kernel taint
[ 20.733642] systemd[1]: Finished Coldplug All udev Devices.
[ 20.796962] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 20.809347] audit: type=1400 audit(1640786866.107:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=459 comm="apparmor_parser"
[ 20.810071] audit: type=1400 audit(1640786866.107:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=459 comm="apparmor_parser"
[ 20.810608] systemd[1]: Reached target Preparation for Local File Systems.
[ 20.825168] systemd[1]: Mounting Temporary /etc/pacman.d/gnupg directory...
[ 20.843601] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 20.843671] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[ 20.846234] systemd[1]: Starting Journal Service...
[ 20.861742] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 20.876904] systemd[1]: Finished Load AppArmor profiles.
[ 20.890581] systemd[1]: Mounted Temporary /etc/pacman.d/gnupg directory.
[ 20.904304] systemd[1]: Reached target Local File Systems.
[ 20.918117] systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
[ 20.919224] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 20.969255] systemd[1]: Started Journal Service.
[ 20.983532] audit: type=1130 audit(1640786866.280:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.117123] systemd-journald[466]: Received client request to flush runtime journal.
[ 21.545719] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 21.545725] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 21.629468] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 21.848215] random: crng init done
[ 22.422929] input: MSFT0004:00 04F3:31BE Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-MSFT0004:00/0018:04F3:31BE.0001/input/input6
[ 22.423573] input: MSFT0004:00 04F3:31BE Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-MSFT0004:00/0018:04F3:31BE.0001/input/input8
[ 22.423749] hid-generic 0018:04F3:31BE.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0004:00 04F3:31BE] on i2c-MSFT0004:00
[ 22.460117] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xff00, revision 15
[ 22.460125] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 22.460212] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xff20
[ 22.496982] hid-generic 0018:048D:8353.0002: hidraw1: I2C HID v1.00 Device [ITE8353:00 048D:8353] on i2c-ITE8353:00
[ 22.694116] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 22.694215] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 22.694221] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 22.901217] ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 22.911376] ccp 0000:04:00.2: tee enabled
[ 22.911380] ccp 0000:04:00.2: psp enabled
[ 23.122354] input: MSFT0004:00 04F3:31BE Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-MSFT0004:00/0018:04F3:31BE.0001/input/input9
[ 23.122613] input: MSFT0004:00 04F3:31BE Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-MSFT0004:00/0018:04F3:31BE.0001/input/input11
[ 23.122891] hid-multitouch 0018:04F3:31BE.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0004:00 04F3:31BE] on i2c-MSFT0004:00
[ 23.497285] mousedev: PS/2 mouse device common for all mice
[ 23.503869] kvm: Nested Virtualization enabled
[ 23.503873] SVM: kvm: Nested Paging enabled
[ 23.503885] SVM: Virtual VMLOAD VMSAVE supported
[ 23.503885] SVM: Virtual GIF supported
[ 23.528519] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input12
[ 23.640006] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 23.786879] MCE: In-kernel MCE decoding enabled.
[ 23.865063] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 24.376627] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 24.598378] intel_rapl_common: Found RAPL domain package
[ 24.598384] intel_rapl_common: Found RAPL domain core
[ 24.606867] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input13
[ 24.606912] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input14
[ 24.606945] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input15
[ 24.790949] mt7921e 0000:01:00.0: disabling ASPM L1
[ 24.790999] mt7921e 0000:01:00.0: ASIC revision: 79610010
[ 25.049093] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 25.049103] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 25.049106] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 25.049109] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 25.049110] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 25.049112] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 25.094881] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20211014150838a
[ 25.097612] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input16
[ 25.097684] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input17
[ 25.396153] mt7921e 0000:01:00.0: WM Firmware Version: ____010000, Build Time: 20211014150922
[ 25.422436] mt7921e 0000:01:00.0: Firmware init done
[ 25.460799] ZFS: Loaded module v2.1.1-1, ZFS pool version 5000, ZFS filesystem version 5
[ 25.920887] kauditd_printk_skb: 12 callbacks suppressed
[ 25.920890] audit: type=1130 audit(1640786871.217:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.931679] audit: type=1130 audit(1640786871.230:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.017330] audit: type=1334 audit(1640786871.314:26): prog-id=9 op=LOAD
[ 26.017582] audit: type=1334 audit(1640786871.314:27): prog-id=10 op=LOAD
[ 26.017744] audit: type=1334 audit(1640786871.314:28): prog-id=11 op=LOAD
[ 26.035663] audit: type=1130 audit(1640786871.334:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.269366] mt7921e 0000:01:00.0 wlp1s0: renamed from wlan0
[ 27.183578] cdc_acm 1-2:1.1: ttyACM0: USB ACM device
[ 27.183706] usbcore: registered new interface driver cdc_acm
[ 27.183709] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 27.524761] mc: Linux media interface: v0.10
[ 27.783688] videodev: Linux video capture interface: v2.00
[ 28.040998] Bluetooth: Core ver 2.22
[ 28.041051] NET: Registered PF_BLUETOOTH protocol family
[ 28.041052] Bluetooth: HCI device and connection manager initialized
[ 28.041065] Bluetooth: HCI socket layer initialized
[ 28.041071] Bluetooth: L2CAP socket layer initialized
[ 28.041080] Bluetooth: SCO socket layer initialized
[ 28.330115] usbcore: registered new interface driver btusb
[ 28.406512] usb 1-3: Found UVC 1.10 device Integrated Camera (04f2:b6be)
[ 28.412982] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/input/input18
[ 28.414229] usb 1-3: Found UVC 1.50 device Integrated Camera (04f2:b6be)
[ 28.415812] input: Integrated Camera: Integrated I as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.2/input/input19
[ 28.415952] usbcore: registered new interface driver uvcvideo
[ 28.908942] audit: type=1130 audit(1640786874.207:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.924122] audit: type=1130 audit(1640786874.220:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.951689] audit: type=1130 audit(1640786874.247:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.145538] audit: type=1130 audit(1640786874.444:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.222127] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 29.222132] Bluetooth: BNEP filters: protocol multicast
[ 29.222137] Bluetooth: BNEP socket layer initialized
[ 29.530848] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 29.608931] loop4: detected capacity change from 0 to 8
[ 29.715988] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 30.782268] NET: Registered PF_QIPCRTR protocol family
[ 31.484492] kauditd_printk_skb: 19 callbacks suppressed
[ 31.484494] audit: type=1130 audit(1640786876.780:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.903231] audit: type=1116 audit(1640786877.200:50): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949297] audit: type=1114 audit(1640786877.247:51): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user id=1000 exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949302] audit: type=1114 audit(1640786877.247:52): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949313] audit: type=1114 audit(1640786877.247:53): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949344] audit: type=1114 audit(1640786877.247:54): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949349] audit: type=1114 audit(1640786877.247:55): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949351] audit: type=1114 audit(1640786877.247:56): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949381] audit: type=1114 audit(1640786877.247:57): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 31.949385] audit: type=1114 audit(1640786877.247:58): pid=1171 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 32.205602] Bluetooth: hci0: Device setup in 3784621 usecs
[ 32.309396] NET: Registered PF_ALG protocol family
[ 40.735852] kauditd_printk_skb: 13 callbacks suppressed
[ 40.735857] audit: type=1130 audit(1640786886.034:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.027686] audit: type=1131 audit(1640786886.324:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.332873] audit: type=1130 audit(1640786887.630:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.332885] audit: type=1131 audit(1640786887.630:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.361420] audit: type=1130 audit(1640786887.657:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.375289] audit: type=1130 audit(1640786887.674:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.483684] audit: type=1100 audit(1640786894.780:78): pid=1801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 49.487014] audit: type=1101 audit(1640786894.784:79): pid=1801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 49.488237] audit: type=1103 audit(1640786894.784:80): pid=1801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 49.488519] audit: type=1006 audit(1640786894.787:81): pid=1801 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
[ 49.488533] audit: type=1300 audit(1640786894.787:81): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffc4b40e860 a2=4 a3=3e8 items=0 ppid=1 pid=1801 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty1 ses=1 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
[ 49.488538] audit: type=1327 audit(1640786894.787:81): proctitle=2F62696E2F6C6F67696E002D70002D2D
[ 49.517334] audit: type=1130 audit(1640786894.814:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.524451] audit: type=1101 audit(1640786894.820:83): pid=1803 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.524458] audit: type=1103 audit(1640786894.820:84): pid=1803 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 49.524496] audit: type=1006 audit(1640786894.820:85): pid=1803 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 59.366537] kauditd_printk_skb: 13 callbacks suppressed
[ 59.366544] audit: type=1131 audit(1640786904.664:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.496258] audit: type=1334 audit(1640786904.794:96): prog-id=0 op=UNLOAD
[ 59.496269] audit: type=1334 audit(1640786904.794:97): prog-id=0 op=UNLOAD
[ 59.496273] audit: type=1334 audit(1640786904.794:98): prog-id=0 op=UNLOAD
[ 60.827953] audit: type=1131 audit(1640786906.124:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.859051] audit: type=1334 audit(1640786906.157:100): prog-id=0 op=UNLOAD
[ 60.859067] audit: type=1334 audit(1640786906.157:101): prog-id=0 op=UNLOAD
[ 60.859073] audit: type=1334 audit(1640786906.157:102): prog-id=0 op=UNLOAD
[ 65.667273] audit: type=1131 audit(1640786910.964:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'```
