Hey y’all, I’ve gotten to the desktop with the boot drive I have but when I try to open it it’ll close soon after it loads. I read that it is sometimes caused by a lack of system RAM but I have about 8GB and have checked to see if the system recognizes it. I can’t figure out what could be causing the issue…
My Laptop is a 14-dq1039wm, and the latest version stable release of KDE is installed.
BG405
2 February 2025 04:04
2
Hello and welcome to the Manjaro Community!
It will help if you post some system details to start with (more may be asked for).
In a Terminal, please enter the following command:
inxi -zv8
Copy the entire Terminal output and paste in your post; select the pasted output and click the </> button at the top of the reply window.
This will cause it to show in a properly-formatted code block, like it’s displayed in your Terminal.
8GB of RAM is not all that much these days, with modern browsers and websites. Those inxi
results will at least show if you have the needed swap
configured.
The installer doesn’t exactly “encourage” swap
configuration as I think it ought to.
EDIT:
I assume you mean “installation” rather than “installer”?
Have you verified the .ISO you downloaded? (sha256sum) — I’ll advise if you need guidance on this.
For example, if you downloaded this .ISO and saved the sha256sum file in the same directory:
sha256sum -c manjaro-kde-24.2.1-241216-linux612.iso.sha256
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1 splash driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: HP product: HP Laptop 14-dq1xxx v: N/A
Mobo: HP model: 86C8 v: 56.33 serial: <superuser required>
part-nu: 8BD79UA#ABA uuid: <superuser required> UEFI: AMI v: F.30
date: 07/04/2023
ID-1: BAT0 charge: 31.4 Wh (100.0%) condition: 31.4/31.4 Wh (100.0%)
volts: 12.7 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: discharging
System RAM: total: 8 GiB available: 7.45 GiB used: 3.22 GiB (43.3%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
size: 8 GiB speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMA81GS6DJR8N-VK serial: <filter>
Device-2: Bottom - Slot 2 (right) type: no module installed
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB
desc: 4x512 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1220 min/max: 400/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 1220 2: 1220 3: 1220 4: 1220 5: 1220 6: 1220
7: 1220 8: 1220 bogomips: 19048
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:5365
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x733c built: 2017 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 chroma: red: x: 0.561 y: 0.337 green: x: 0.345
y: 0.576 blue: x: 0.161 y: 0.125 white: x: 0.314 y: 0.329
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1366x768
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 3.64 GiB unified: yes
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics (ICL GT1) driver: N/A device-ID: 8086:8a56
surfaces: xcb,xlib
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:b00c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 238.47 GiB state: S
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
0: nvme1n1 maj-min: 259:5 size: 13.41 GiB state: S
Local Storage: total: 266.48 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0101AH
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: HPS1 temp: 36.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0101AHO
size: 13.41 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: HPS2 temp: 46.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB Flash Drive
size: 14.59 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: MBR
Message: No partition data found.
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 4.03 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 14.56 GiB fs: exfat label: YUMI
uuid: 4E21-0000
ID-3: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 223C-F3F8
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: SanDisk USB Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5598 class-ID: 0806
serial: <filter>
Device-2: 1-3:3 info: Quanta HP TrueVision HD Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
Device-3: 1-10:4 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1248 libs: 327 tools: pamac pm: flatpak pkgs: 0
1: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
2: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
3: https://repos.silknet.com/manjaro/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
6: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.funami.tech/manjaro/stable/$repo/$arch
8: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
10: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
11: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
12: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
13: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
14: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
15: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
16: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
18: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
19: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
20: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
22: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
23: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
24: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
25: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
26: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
27: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
28: https://mirrors2.manjaro.org/stable/$repo/$arch
29: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
30: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
31: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
32: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
33: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
35: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
36: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
37: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
38: https://muug.ca/mirror/manjaro/stable/$repo/$arch
39: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
40: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
41: https://mirror.easyname.at/manjaro/stable/$repo/$arch
42: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
43: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
44: https://mirror.koddos.net/manjaro/stable/$repo/$arch
45: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
46: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
48: https://manjaro.ynh.ovh/stable/$repo/$arch
49: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
50: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
51: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
53: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
54: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
55: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
56: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
57: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
58: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
59: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
60: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
61: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
62: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
63: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
64: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
65: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
66: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
67: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
68: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
69: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
70: http://manjaro.grena.ge/stable/$repo/$arch
71: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
72: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
73: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
74: https://mirror.zetup.net/manjaro/stable/$repo/$arch
75: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
76: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
77: https://mirror.seahost.de/manjaro/stable/$repo/$arch
78: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
79: https://mirror.dc.uz/manjaro/stable/$repo/$arch
80: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
81: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
82: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
83: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
84: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
85: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
86: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
87: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
88: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
89: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
90: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
91: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
92: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
93: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://manjaro.kurdy.org/stable/$repo/$arch
95: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
96: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
97: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
98: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
99: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
100: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
101: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
102: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
103: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
104: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
105: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
106: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
107: http://manjaro.mirror.ac.za/stable/$repo/$arch
108: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
109: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
110: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
111: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
112: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
113: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
114: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
115: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
116: https://linorg.usp.br/manjaro/stable/$repo/$arch
117: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
118: https://mirror.init7.net/manjaro/stable/$repo/$arch
119: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
120: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
121: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
122: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
123: https://mirror.23m.com/manjaro/stable/$repo/$arch
124: https://mirrors.netix.net/manjaro/stable/$repo/$arch
125: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
126: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
127: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
128: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
129: http://mirror.fcix.net/manjaro/stable/$repo/$arch
130: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
131: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
132: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 258
1: cpu: 7.8% command: plasma-systemmonitor pid: 9288 mem: 213.4 MiB (2.7%)
2: cpu: 6.4% command: konsole pid: 10161 mem: 119.0 MiB (1.5%)
3: cpu: 4.0% command: zsh pid: 10180 mem: 8.39 MiB (0.1%)
4: cpu: 3.1% command: kwin_x11 pid: 1589 mem: 206.5 MiB (2.7%)
5: cpu: 2.2% command: firefox pid: 3423 mem: 418.6 MiB (5.4%)
Memory top: 5 of 258
1: mem: 418.6 MiB (5.4%) command: firefox pid: 3423 cpu: 2.2%
2: mem: 379.0 MiB (4.9%) command: plasmashell pid: 1631 cpu: 0.4%
3: mem: 213.4 MiB (2.7%) command: plasma-systemmonitor pid: 9288 cpu: 7.8%
4: mem: 207.0 MiB (2.7%) command: firefox pid: 3593 cpu: 0.3%
5: mem: 206.5 MiB (2.7%) command: kwin_x11 pid: 1589 cpu: 3.1%
Processes: 258 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.93 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
Here is the output I got.
I’m not sure how to check the ISO, I put it into the konsole and stated “No such file or directory”
And what are swap configurations?
Thank you so much for the help!
BG405
2 February 2025 04:35
4
For the swap, this thread may be useful reading; there are a couple of links there.
As for checking the .ISO, you need to cd
to the directory you downloaded the image file and the checksum file to. Or find the directory you downloaded the files to with Dolphin and right-click & select “Open Terminal Here”.
Note the checksum files are on the same page as the .ISO downloads but you have to click “More” (or something) to see the extra links.
I’ve checked what I can but I think the problem is being misunderstood. When I press “Launch Installer” It doesn’t stay open after it loads in the logo. I’m not sure how to fix this. I got the ISO From the [https://manjaro.org/ ] Website. Admittedly I can’t understand how to proceed with the other instructions given since I got the ISO burned onto a USB with YUMI. Maybe that’s the cause of the problem? I’m unsure, or if any of this information helps.
I can’t find any other versions of the distro, any I have found are dead links, I might try others but I’m unsure if that will work or help either…
BG405
2 February 2025 05:01
6
Indeed I was misinterpreting that. I’m thinking it could be a bad .ISO download, but when I saw “vtoy” as id3 in your inxi
I assumed you were using a Ventoy USB. (I’d recommend that, anyway).
Which operating system are you using to create the USB? I guess Linux but I’m unfamiliar with YUMI.
I was using Windows 10 Pro. pendrivelinux is where I got the program from, I don’t have a Linux system yet.
I’ll try Ventoy with the same ISO to see if it gives any different results!
Unfortunately results returned the same
BG405
2 February 2025 05:40
9
I’d definitely try re-downloading the .ISO (and probably trying other flavours a well e.g. the Xfce one) to see if they behave the same.
I am rather out of touch with Windows (anything past Win7 Ultimate; the last decent MS OS in my book) so unfortunately can’t offer suggestions for verifying the checksum(s) there, but an option might be the Torrent as I believe this “verifies-as-it-goes”?
GasStation_FISH:
I’ll try Ventoy
A good idea.
From skimming the thread, a fresh ISO seems warranted.
Note :- There is no suggestion of a problem with the official Manjaro ISOs – any inconsistency will have been a result of the download. If you are downloading via a browser, I might suggest Vivaldi tends to be more reliable than some;
sudo pacman -S vivaldi
If you have a bittorrent client, then torrent files are available alongside the download links ( click More ).
You will notice the checksum is also downloadable; use this to verify your new ISO has not been damaged in transit.
Manjaro ISO’s should only be downloaded from this location, unless directed otherise by Moderation staff.
Ventoy is the bootable USB solution of choice.
The following contribution from our Tutorials category will explain how to successfully create a Ventoy USB, and how to use it to boot your Manjaro ISO.
Ventoy
A New Bootable USB Solution
Boot with a Ventoy USB and ISO files are automatically listed in the Ventoy menu.
Any ISO present can then be launched and booted directly. The obvious advantage here is that instead of constantly writing a Manjaro Installer ISO to a new USB any time you might need it, every ISO you desire can be stored on the Ventoy USB and launched the same way.
A 32GB capacity USB would allow ample space to store several ISOs of your choice; an 8GB capacity USB might …
Is RAID enabled ?
Please have a look into your BIOS / UEFI
There seem to be several inconsistencies with the information you have given;
Please confirm – is KDE Plasma installed, or is it not?
If it is installed, as you state; and as your inxi
output would seem to confirm; what is your problem?
Please provide more detail, so we can better understand the issue you’re having.
This part of your inxi
output seems to incidate you have already attempted to used Ventoy; and that remnants of both Ventoy and Yumi remain on the SanDisk USB. Plus, the USB has an MBR partition table which is useless if you are trying to install a UEFI based system.
Please fully destroy all partitions on the SanDisk USB and create a Ventoy USB using the link already given.
Are using Windows to download the ISO? The following tool is as good as any; and other options are mentioned in the second link:
If indeed you do have Plasma already installed;
After downloading the ISO, open the Dolphin file manager and right-click the ISO and choose Properties – you will find a Checksums tab which you can then use to verify that the computed checksum matches that of the downloaded checksum file.
Swap is virtual memory – either a swap
partition or file . The opportunity to configure swap
is available in Calamares when installing Manjaro to disk using the Erase Disk partitioning option. It is suggested to configure swap according to your needs at that stage of installation.
You have none configured, which suggests you either missed the option; or didn’t understand it, and ignored it.
Just to recap, please create a new Ventoy USB using the instructions (previously linked) to create a UEFI booting USB.
