Hello,
I am using Manjaro for two years now.
It is already second time that bootloader is damaged during an update. I thought to come back to Gnome (last time I thought to try Plasma) and install all the system again. I have a separated partition for home. It worked once but I forgot to mount the partition as home so I did it once more and all troubles began from there. It install all normally and at the end there is an error message.
Can you help me to understand what went wrong ?
Thank you so much !
<div><strong><class 'FileExistsError'></strong></div><div>[Errno 17] File exists: '/usr/share/themes/Firefox-Gnome-Maia/chrome/' -> '/tmp/calamares-root-u6jjhk9a/root/.mozilla/firefox/87syjf8o.default-release/chrome/firefox-gnome-theme'</div><div><br/>Traceback:</div><div><pre>File "/usr/lib/calamares/modules/postcfg/main.py", line 159, in run
return config.run()
File "/usr/lib/calamares/modules/postcfg/main.py", line 115, in run
self.copy_folder('etc/skel', 'root')
File "/usr/lib/calamares/modules/postcfg/main.py", line 71, in copy_folder
copy_tree("/" + source, join(self.root, target), preserve_symlinks=1)
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/dir_util.py", line 157, in copy_tree
copy_tree(src_name, dst_name, preserve_mode,
[Previous line repeated 1 more time]
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/dir_util.py", line 152, in copy_tree
os.symlink(link_dest, dst_name)</pre></div>
Please provide more information for us so we can find out what’s fails.
Follow instructions from tutorial: [HowTo] Provide System Information
Thank you, here are the informations :
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2137 quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: HP product: HP Laptop 14-dk0xxx v: N/A
Mobo: HP model: 85E0 v: 84.42 serial: <superuser required> UEFI: AMI
v: F.42 date: 07/03/2019
ID-1: BAT0 charge: 24.5 Wh (66.9%) condition: 36.6/36.6 Wh (100.0%)
volts: 12.7 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: charging
RAM: total: 5.71 GiB used: 2.88 GiB (50.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Athlon 300U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1371 high: 1447 min/max: 1400/2400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1371 2: 1447
3: 1430 4: 1236 bogomips: 19170
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 05c8:03d2 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0828 built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 14.0.6 DRM 3.42
5.15.60-1-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-5:4 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Local Storage: total: 935.22 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RTM2 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT 101 G2
size: 3.71 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 334 MiB fs: vfat label: BOOT
uuid: 8EBB-93E0
ID-2: /dev/sda2 maj-min: 8:2 size: 93.08 GiB fs: ext4 label: ST
uuid: 5990ea71-ccd1-4035-999d-6922da542cb1
ID-3: /dev/sda4 maj-min: 8:4 size: 483 MiB fs: ntfs label: Windows RE
tools uuid: 9A8E7C598E7C2FBD
ID-4: /dev/sda5 maj-min: 8:5 size: 133.91 GiB fs: ext4 label: N/A
uuid: 9f6aad38-ea70-44a2-8019-ef921290af52
ID-5: /dev/sda6 maj-min: 8:6 size: 6.05 GiB fs: swap label: N/A
uuid: b4b98282-a562-4781-a76d-3899660412ca
ID-6: /dev/sda7 maj-min: 8:7 size: 697.68 GiB fs: ext4 label: N/A
uuid: ccb6c1b0-a15f-454b-952e-26101c980976
ID-7: /dev/sdb1 maj-min: 8:17 size: 3.33 GiB fs: iso9660
ID-8: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: CA66-9EA7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-2:2 info: Kingston DT101 G2 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0951:1642 class-ID: 0806 serial: <filter>
Device-2: 1-4:3 info: Cheng Uei Precision Industry (Foxlink) HP TrueVision
HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05c8:03d2 class-ID: 0e02
Device-3: 1-5:4 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 239 Uptime: 17m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1278 lib: 308 flatpak: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.20
After small analysis, I’ve found out that root’s home has file that should be linked in install phase. So, file exists, but script tires to link new file and it fals. Probably you can format your system partition. Or try another iso version if you can.
Thank you erasing the system table and formating back solved the problem.
system
Closed
11 October 2022 03:13
6
