Good I would like to install manjaro on a hard disk and have on another hard disk the user data as you can do in Windows with a system disk and other data but I do not know how I could do it if during installation or after how to redirect the root / to the other hard disk.
Hi @Nachocob ,
I’d recommend you install it on the main hard drive and when it’s done, you can split everything off as required. See
Difficulty: ★★★☆☆
Introduction
As you should all already know by now, GNU/Linux is a FLOSS variant of the UNIX operating system design, and UNIX does not know the concept of drive letters, nor does it approach storage from the vantage of having different volumes. Instead, everything is mounted into a uniform directory hierarchy, so that regardless of what physical medium any particular group of files resides on ─ even if this physical medium is actually located in another computer across the …
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows?
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux???
So, below this are the main differen…
Difficulty: ★☆☆☆☆
Disk device recognition
Manjaro uses udev (see Arch Wiki ) to load devices at boot time. The loading of devices is arbitrary and therefore you cannot predict which device will be available at a given path.
But static device names do exist and you can assign specific locations to your device and thus ensure e.g. scripts will work as expected.
What to learn
Overview of system mount units
Structure and Content of a mount unit
Mount at boot (immediate mount)
Mount on demand (m…
Difficulty: ★★☆☆☆
Example mount units for systemd
The examples here are a supplement to the guide on systemd mount units
Remember to remove the comments placed in the units - they are not writing for copy-paste but as examples. (comments is text beginning with a #)
[root tip] [How To] Use systemd to mount ANY device
Only use an automount unit if the device is not readily available at boot like removable devices and network locations.
Important rule
Hope this helps!
You can set the mount point to dedicated folder: e.g. /home or /opt or …
during installation or with an existing installation.
Hello @Mirdarthos
I thought it would be easier hahahaha
Hello @Keruskerfuerst
What you say, do I do it with the custom installation? When you choose the partitions?
Well it’s not hard, it just requires you to think ahead and plan ahead.
I’ll try first from virtualbox
Thank you!
You can set the partitions during installation, partitioning.
