Is there a cli version of manjaro available?
How do i install it to the emmc?
I cant seem to find much information regarding the way to do this for orangepi4lts
Thanks
Thanks
So ive managed to install the kde version and get than running on sd card.
Then ive downloaded the minimal version and used dd to copy the to emmcblk.
Then when i reboot i get the following error.
If i try to use the install from the minimal version it crashed on removing extra files
If i try to use the manjaro-arm-installer there is no version for the orangepi4 lts.
Any other way to install the minimal edition to emmc?
Did you remember to extract it, before you dd’d it?
Yes I extracted the IMG and DD the IMG file not using any extra Params, just if and of
PS. Any idea why the terminal spams out the @ symbol like that photo?
No. I haven’t tested on eMMC though.
Did you check the checksum of the image before you flashed, to see if it wasn’t corrupt?
looks like emmc is corrupted.
try a clean flash again. I have it on emmc without any issue.
Ive done 3 reinstalls now. Tried using wipefs before install also. Always get the same issue (first screenshot in the thread)!
Ive noticed there is a ‘mmcblk1boot0’ and ‘mmcblk1boot1’ is there some kind of boot loader that should be installed on there?
I can view the partitions that manjaro is creating, the boot and the root, all looks fine and dandy in there… There has to be something else causing the issue.
I think ill try run just from sd card for now. I cant get the minimal install to work either.
Is there a way to disable kde and just use the desktop version as a cli only install?
ok so i think the console spam of the ^ and @ symbols is causing my login issues! but this doesnt occur on the desktop version as its all done via the gui…
Any ideas what causes this?
EDIT: looks like console spam was due to my keyboard! Ive changed keyboard and now can use the terminal and login correctly! I’ll now try to get the thing to boot from the emmc again.
Edit2: Nope still no go, getting the GPT error when booting from EMMC. I noticed the provided image has a single partition with boot files and everything on there. Is there a way to set this up with manjaro? This is the last hurdle!
I worked around this problem by dd-ing the install image to the emmc after booting from the SD card, removing the SD, and then it will boot from the emmc and do the normal install process as if booting from SD. This results in the emmc being in MBR format instead of GPT. The best i can tell, the boot errors result when you try to boot from the GPT partition table on the emmc. Of course, manjaro-arm-installer formats the disk as GPT, so using manjaro-arm-installer to the emmc does not ever seem to work
All the images for the Orange Pi 4 LTS, uses GPT partition table.
Why would GPT work from SD, but not from eMMC?
Let me do further research this evening… I actually applied this workaround using the Armbian image, but I saw the same problem previously with the Manjaro image. I will try to use manjaro-arm-installer again and then also try dd-ing the manjaro sd boot image to the emmc and see if it fails the same way. I also see I could modify the manjaro-arm-installer here to get it to use MBR type on the emmc and see if that works the same. The net net is the only way so far I can get the emmc to boot a linux image on orange pi 4 lts is if it is of MBR type.
And that’s my point. Our images should not work from SD card either, if the issue is indeed the GPT.
Unless the bootloader works on SD and not emmc. I don’t disagree with your conclusion, I will provide more data once I collect it. When trying to boot from the emmc formatted as GPT, I get the following errors from the bootloader
*** ERROR: Can’t read GPT header ***
find_valid_gpt: *** ERROR Invalid GPT ***
find_valid_gpt: *** ERROR: Invalid Backup GPT ***
I received these same errors with both Armbian and Manjaro. When booting the Manjaro from emmc (installed via manjaro-arm-installer) it did start with a header indicating Manjaro U-Boot before spewing these GPT errors over and over.
Another potential theory… I think when booting from emmc formatted as MBR, the bootloader comes from the SPI, but when booting from emmc formatted as GPT, the bootloader comes from the emmc.
As reported above, I will do some more experiments with manjaro-arm-installer tonight and report results
Is there a bootloader on the SPI? I don’t think I have one on mine.
I erased my eMMC to even get the device able to boot from SD card, without reformatting it on first boot.
The lack of bootloader in the SPI could be the difference between yours working and mine not. In my case, if I insert an SD card while I have a working bootable emmc (in MBR mode) , the SD card overrides and the SD boots instead…
I saw this generic rk3399 boot sequence article which may not be 100% applicable to orange pi 4 lts
RK3399 boot sequence wiki. pine64 .org /wiki/RK3399_boot_sequence
forum would not let me post links…
Yes, the boot order on the rk3399 is SPI → eMMC → SD. That’s where it looks for bootloaders. The first one it finds, is what gets used.
I didn’t have time to modify the manjaro-arm-installer to try MBR boot, but here are boot logs of the same image booting from SD (works) and emmc (fails)
Boot from SD
U-Boot TPL 2022.04-1 (Jun 11 2022 - 21:32:05)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2022.04-1 (Jun 11 2022 - 21:32:05 +0000)
Trying to boot from MMC1
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
Trying to boot from MMC2
U-Boot 2022.04-1 (Jun 11 2022 - 21:32:05 +0000) Manjaro Linux ARM
SoC: Rockchip rk3399
Reset cause: RST
Model: Orange Pi 4 LTS
DRAM: 3.9 GiB
PMIC: RK808
Cannot find regulator pwm init_voltage
Core: 270 devices, 24 uclasses, devicetree: separate
MMC: mmc@fe310000: 2, mmc@fe320000: 1, mmc@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@fe300000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1: Manjaro ARM
Retrieving file: /initramfs-linux.img
Retrieving file: /Image
append: initrd=/initramfs-linux.img console=ttyS2,1500000 root=PARTUUID=6334c697-a97b-482c-acd4-f7039639c6b2 rw rootwait audit=0 splash plymouth.ignore-serial-consoles
Retrieving file: /dtbs/rockchip/rk3399-orangepi-4-lts.dtb
Moving Image from 0x2080000 to 0x2200000, end=3e10000
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to f170f000, end f1f0f8a2 ... OK
Loading Device Tree to 00000000f16f8000, end 00000000f170e734 ... OK
Starting kernel ...
unable to select a mode : -70
device_remove: Device 'mmc@fe330000.blk' failed to remove, but children are gone
:: running early hook [udev]
Starting systemd-udevd version 252.4-2-arch
:: running hook [udev]
:: Triggering uevents...
:: running hook [keymap]
:: Loading keymap...kbd_mode: KDSKBMODE: Inappropriate ioctl for device
done.
:: performing fsck on '/dev/mmcblk0p2'
ROOT_MNJRO: clean, 295718/3746240 files, 3079228/15067059 blocks
:: mounting '/dev/mmcblk0p2' on real root
:: running cleanup hook [udev]
Welcome to Manjaro ARM!
Boot from emmc
256B stride
Reset cause: POR
DRAM: 3.9 GiB
PMIC: RK808
In: serial
Out: serial
Err: serial
mmc0(part 0) is current device
*** ERROR: Can't read GPT header ***
find_valid_gpt: *** ERROR: Invalid GPT ***
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
*** ERROR: Can't read GPT Entries ***
GPT: Failed to allocate memory for PTE
find_v
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
Device 0: unknown device
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3c0000: USB EHCI 1.00
Bus usb@fe900000: Failed to get PHY1 for usb@fe900000
Port not available.
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
ethernet@fe300000 Waiting for PHY auto negotiation to complete........
This must be the issue when using bsp uboot.
If you use mainline uboot then it should work fine.
or there is some issue in the partition of the image.
I’ve done lots of experimentation but still have not figured this out. The only images I can boot successfully from the emmc are the Arbmian image dd from the install image to the emmc and the nana-sata-install of Ubuntu from Orange Pi also works. No matter what partition format or partition type I used with the Manjaro image, in uboot, if I select mmc dev 0 and run mmc part it will give partition table errors.
