Install-grub: a new way to keep your EFI/MBR in-sync with grub package
I’ve had a live-ISO lying around for years and it’s become a habit for a long time.
To my knowledge there is not any difference for btrfs. ( I do use btrfs a lot)
Except that you will not be able to boot some systems if you go to an “old” grub that does know nothing about zstd.
@philm Oh, I am the last who could enlighten you, O Lord… :pray:
I don’t need to install this in a VM first as Btrfs has been running here for a while (previously it was EndeavorOS with Btrfs). However, I don’t know much about Btrfs and I only installed it for snapshots (Calamares’ default setup). Actually more of a company that exceeds my level of knowledge. But since I’ve run into failed updates quite often in the past, I thought it made sense to try.
It looks that its working with my Laptop MBR/Bios, the logs showing no errors but im still not 100% sure which Grub version are running and loaded actually.
Is there a way to proof which Grub version i have currently in use right now?
Edit:
That tool is not working/auto triggering the reinstall grub function with Pamac GUI.
Atleast not straight after install… but i hope it will be triggered after the next stable update, without using additional input like:
$ sudo pacman -S grub
What about manjaro-grub-reinstaller?
Because we know now after Philm’s explanation that the default/old grub-update routine, only gives partial updates for grub.
grub-install -V
Just because some users neglected it, or read something where the author was confused, does not mean it was not documented or widely understood.
(ex: How to remove plymouth? - #12 by cscs)
update-grub was never ‘updating the version of grub running on every power on’ .. maybe that is a weakness of the nomenclature. But .. its nothing new.
How you determine that a user don’t know how grub was installed so that the update could be realized without user interaction?
Please, keep in mind there are not only blody newbies and senior experts using Manjaro. If it’s automatically triggered with a grub update I would want to see the outcome of the analysis and specific proposal before execution, if it’s just another tool - how to get unexperienced users to use it?
Maybe its nothing new… but only for the minority of Manjaro users. The same you could say for the pacdiff discussion (few month ago) where alot people learned to merge this pacnew files to maintain our system.
Plymouth: It’s all in the Wiki, like most everything, but few want to actually read it.
– The spoonfed copy/paste generation.
In Grub menu (that won’t show up while booting by default, you need to hit shift during boot) hit the key E and your will see the Grub version on top. I reinstalled Grub and went from v2.06rc to 2.12-3 as suggested in the Stable Update thread known issues [Stable Update] 2023-12-23 - Kernels, Grub, Mate, Deepin, Cinnamon, ICU, KDE Frameworks - #2 by philm
Yes, we could, and the same thing applies there as here - just because it is new to some does not mean its actually new … or has not been around for years.
Or with introducing pacdiff - did it stop people from arguing with me or chewing me out? No again … even if there were existent guides and I was only acquainting these users with utilities that already exist for a framework that had been in place for years.
… I dont know what the point is though. To mull over this I mean … some people read the manuals, some dont … that is also nothing new.
I just thought the name manjaro-grub-reinstaller would fits perfectly,
since the Manjaro wiki also is named with the reinstall Topic:
GRUB/Restore the GRUB Bootloader - Manjaro
So its less confusion, nothing more… nothing less :slight_smile:
Btw. This command is actually not showing me, which Grub version is currenctly loaded…
because it showed me the equal grub version, but my PC isn’t updated at this moment:
grub-install (GRUB) 2.12-3
So i try booting into the Grub Menue and Press E, what @1efaf7d71a8637c6800a suggested.
Ha! Sounds like something @Ste74 would come up with. :stuck_out_tongue_winking_eye:
Why so technical? What about
manjaro-grub-reindeer ?
:deer:
At least it is a Christmas package.
Why not something simple, like… HansGrubber…
One of the Die Hard movies was Christmassy.
Yippee ki yay…
TODO: Die Hard-athon
Well, here is a version the user has to interact and it is very verbose. The output would be like this for an EFI system:
sudo sh ./install-grub-debug
[D] GRUB 2 EFI-x64 found
[D] Found EFI-Directory: /boot/efi
[I] Found EFI Bootloader: /boot/efi/EFI/Manjaro/grubx64.efi
[I] Found EFI Fallback: /boot/efi/EFI/boot/bootx64.efi
[I] EFI Fallback file matches EFI Bootloader
[D] Install cmd will be: grub-install --no-nvram --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --recheck --force
Do you want to proceed? (yes/no) y
ok, we will proceed
Grub will be installed on: EFI
Installing for x86_64-efi platform.
Installation finished. No error reported.
Update UEFI Fallback file: /boot/efi/EFI/Manjaro/grubx64.efi
ok, we will proceed
[D] Updating Grub Menu
ok, we will proceed
Found linux image: /boot/vmlinuz-6.7-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.7-x86_64.img
Found initrd fallback image: /boot/initramfs-6.7-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.4-x86_64.img
Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.3-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.3-x86_64.img
Found initrd fallback image: /boot/initramfs-6.3-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.19-x86_64.img
Found initrd fallback image: /boot/initramfs-5.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.18-x86_64.img
Found initrd fallback image: /boot/initramfs-5.18-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
done
And like this on a BIOS installation:
sudo sh ./install-grub-debug                                                           ✔  32s 
[D] GRUB 2 MBR found
[I] Scanning for GRUB 2 installation ...
[D] JMP instructions: eb 63
[D] Initial JMP opcode: eb
[D] Initial JMP operand: 63
[I] GRUB 2 installation found on: /dev/sda
[D] Install cmd will be: grub-install --target=i386-pc --boot-directory=/boot --recheck --force /dev/sda
ok, we will proceed
Grub will be installed on: MBR
Installing for i386-pc platform.
ok, we will proceed
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
grub-pajama-packager
Now back to our regularly scheduled QA thread…
Let’s save the sillyness for the Member Hub (yes, I know I’m guilty as well)
I like this script, I think the users are used to acknowledge what is proposed but at least a more advanced user sees what’s going to happen.
