Install Build Errors - 'cmake' various packages
For several weeks (months?) my installs are failing for build packages… notably krunner5 but recently when trying to install some libraries…
Seems to be related to ‘cmake’ not working? (I re-installed cmake package - to no avail)
Building libarib25...
==> Making package: libarib25 0.2.5_20190204-1 (Tue 11 Jun 2024 09:55:09 AM PDT)
==> Retrieving sources...
  -> Found v0.2.5-20190204.tar.gz
==> Validating source files with md5sums...
    v0.2.5-20190204.tar.gz ... Passed
==> Extracting sources...
  -> Extracting v0.2.5-20190204.tar.gz with bsdtar
==> Removing existing $pkgdir/ directory...
==> Starting build()...
  File "/home/admin/.local/bin/cmake", line 5, in <module>
    from cmake import cmake
ModuleNotFoundError: No module named 'cmake'
==> ERROR: A failure occurred in build().
    Aborting...
````Preparing...
Cloning krunner5 build files...
Generating krunner5 information...
Checking krunner5 dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building krunner5...
==> Making package: krunner5 5.115.0-4 (Tue 11 Jun 2024 09:59:19 AM PDT)
  -> Found krunner-5.115.0.tar.xz
==> Validating source files with b2sums...
    krunner-5.115.0.tar.xz ... Passed
  -> Extracting krunner-5.115.0.tar.xz with bsdtar
    Aborting...`
How about you remove the cmake in .local/bin and use the system one?
It may be wise to rename the whole .local/bin folder, in case there are more messed up things there.
That package is no longer in the repositories due to the upgrade to Plasma 6. You should uninstall it, as it’s not needed for anything.
libarib25 is an AUR package, and I have no idea what it is or why you would need it, but check whether you have cmake and cmake-extra-modules installed — both of those are in the Manjaro repo.
This was a good fix…
That is not wise at all. I should not have to explain why.
That is wise, indeed. However, it should be removed the same way it was installed.
What’s this? What did you do? :thinking:
How and why this is happening?
This has been reported on 2 my AUR pkgbuilds (all different people) and I’m starting to get curious
:wink:
I mean, why people end up with ~/.local/bin/cmake
Because they installed it locally for whatever reason. :man_shrugging:
I just tell anyone that complains not to mix local and system packages. Not our responsibility as AUR Package Maintainers to say anything else.
Because they installed it from Download CMake like Windows trained them to do :stuck_out_tongue:
renaming cmake in .local/bin fixed my issue
i see that cmake is an installed package, if i uninstall it then will there still be the ability to run build installs?
The stuff you have in /home/admin/.local/bin don’t come the package installed from the repository
pkgbuilds that need cmake to build will fail if cmake is missing
I think he means “if I remove ~/.local/bin/cmake. Which he should, given that it’s installed system-wide already.
