Sorting through a bunch of weirdness after the major Plasma 6 update, and trying to learn how to learn the fundamentals of how to solve these issues Im facing.
Im updating more applications with the Pamac gui. I am trying to update CPU-X and I get the following error:
File "/home/hardbrocklife/.local/bin/cmake", line 5, in <module>
from cmake import cmake
ModuleNotFoundError: No module named 'cmake'
==> ERROR: A failure occurred in build().
Aborting...
I read in another thread that /.local/bin/cmake is a “fake cmake” or something? The cmake file there is a python script that looks like this:
#!/usr/bin/python
# -*- coding: utf-8 -*-
import re
import sys
if __name__ == '__main__':
sys.argv[0] = re.sub(r'(-script\.pyw|\.exe)?$', '', sys.argv[0])
sys.exit(cmake())
What Im trying to learn is if Pamac should not be looking here for that python cmake script, or if that python cmake script is telling the build to look in the wrong place, of if my PATH variables or something are screwed up after the update.
I am also getting dependency issues with node/NPM when trying to update balena-etcher:
npm ERR! code 1
npm ERR! path /var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io
npm ERR! command failed
npm ERR! command sh -c node-gyp rebuild
npm ERR! make: Entering directory '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io/build'
npm ERR! CC(target) Release/obj.target/binding/binding.o
npm ERR! make: Leaving directory '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io/build'
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.4.1
npm ERR! gyp info using node@20.13.1 | linux | x64
npm ERR! gyp info find Python using Python version 3.12.3 found at "/usr/bin/python3"
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io/build/config.gypi',
npm ERR! gyp info spawn args '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/hardbrocklife/.cache/node-gyp/20.13.1/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/hardbrocklife/.cache/node-gyp/20.13.1',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/home/hardbrocklife/.cache/node-gyp/20.13.1/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! make: *** No rule to make target '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io/build/Release/binding.node', needed by '/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io/binding.node'. Stop.
npm ERR! make: *** Waiting for unfinished jobs....
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/node-gyp/lib/build.js:203:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:519:28)
npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
npm ERR! gyp ERR! System Linux 6.6.30-2-MANJARO
npm ERR! gyp ERR! command "/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/.nvm/versions/node/v20.13.1/bin/node" "/var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/.bin/node-gyp" "rebuild"
npm ERR! gyp ERR! cwd /var/tmp/pamac-build-hardbrocklife/balena-etcher/src/etcher/node_modules/@ronomon/direct-io
npm ERR! gyp ERR! node -v v20.13.1
npm ERR! gyp ERR! node-gyp -v v9.4.1
npm ERR! gyp ERR! not ok
I see NPM ERR and referencing python location, node versions, etc…
Im curious if these issues are being cause by a singular underlying problem that occurred after the update. Like my PATH is broken or something.
Below is the PATH section from printenv if that helps:
PATH=/home/hardbrocklife/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/opt/cuda/bin:/opt/cuda/nsight_compute:/opt/cuda/nsight_systems/bin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/usr/lib/rustup/bin:/var/lib/snapd/snap/bin:/home/hardbrocklife/.local/share/JetBrains/Toolbox/scripts
I have both cmake and node installed via pamac:
