Input lag repeating character presses
For a while this annoying behaviour is pissing me off but I cant really guess what is happening or how to get further with my investigation.
Every minute (sometimes every few seconds, sometimes its minutes) even thou my resources are barely used (ram usage 20%, cpu load 2 on 12thread cpu) but it randomly freezes and acts like if I was holding key I held when it froze …so this basically means when I press backspace it sometimes freezes and when it unfreezes after second or two it deleted everything I typed …or it results in me typing stuff like this “peeeeeeeeeeeeeeeeople”. If I wasnt pressing anything before it froze, it doesnt do anything after it unfreezes.
I always thought it must be GPU related because I use nvidia and had some issues with it, but currently I have clean install and went for opensource driver option basically rendering my nvidia gpu useless. I dont really need it, my pc is running smoothly so I just need this (what I call) “input lag” to stop.
Speculation: It started happening month ago when I clean installed because I wanted to put nvidia card to use, so I switched to proprietary drivers on clean install and it started happening, now I reversed this change with another clean install and it still happens …so I guess some package updated now?
If you can give me some guides of how would one debugg this I m ready to do anything, I am using arch/manjaro for 5 years now so I should be competent enough but I cant guess what might be the issue.
Welcome to the forum! :wave:
Please post your system info as outlined here:
inxi -Fazy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=8513fb06-c454-42cc-877d-9f4b860ba3bf ro quiet
  resume=UUID=e00b5f20-d594-4929-8703-f0bb2e45b88b udev.log_priority=3
  Desktop: bspwm 0.9.10 info: polybar dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0D0T05 v: A00 serial: <filter> UEFI: Dell v: 1.15.0
  date: 12/25/2019
  ID-1: BAT0 charge: 80.0 Wh condition: 80.0/97.0 Wh (82%) volts: 12.8/11.4
  model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
  Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: DE L2 cache: 9 MiB
  bogomips: 52815
  Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:1c8c class ID: 0302
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 1-12:6 chip ID: 0c45:671d class ID: 0e02
  Display: x11 server: X.Org 1.20.10 driver: loaded: intel,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.8x11.2")
  s-diag: 1546mm (60.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  Monitor-2: DP1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4")
  diag: 690mm (27.2")
  Monitor-3: DP3 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8")
  diag: 609mm (24")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:a348 class ID: 0403
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: 3000
  bus ID: 3b:00.0 chip ID: 168c:003e class ID: 0280
  IF: wlp59s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  bus ID: 1-4:3 chip ID: 0cf3:e300 class ID: e001
  IF-ID-1: br-520e36b891aa state: up speed: 10000 Mbps duplex: unknown
  mac: <filter>
  IF-ID-2: br-d0e47200d7b9 state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: vethcabc108 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  v: 0.8 bus ID: 1-4:3 chip ID: 0cf3:e300 class ID: e001
  Message: Required tool hciconfig not installed. Check --recommends
  Local Storage: total: 476.94 GiB used: 70.57 GiB (14.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
  size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: 80004E00 temp: 27.9 C
  scheme: GPT
  ID-1: / raw size: 459.85 GiB size: 451.63 GiB (98.21%)
  used: 35.29 GiB (7.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 55.0 C mobo: N/A gpu: nouveau temp: 37.0 C
  Fan Speeds (RPM): cpu: 2496 fan-2: 2504
  Processes: 370 Uptime: 15h 43m wakeups: 161 Memory: 15.27 GiB
  used: 5.72 GiB (37.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
  pacman: 1095 lib: 351 Shell: Zsh v: 5.8 default: Bash v: 5.1.0
  running in: alacritty inxi: 3.3.01
dmesg
[    1.940305] input: Intel HID events as /devices/platform/INT33D5:00/input/input6
[    1.940407] intel-hid INT33D5:00: platform supports 5 button array
[    1.940425] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input7
[    1.980501] hid: raw HID events driver (C) Jiri Kosina
[    1.983401] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    1.991622] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    1.991660] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.992880] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.996518] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    2.007745] tpm_tis MSFT0101:00: 2.0 TPM (device-id 0xFC, rev-id 1)
[    2.014068] usb 2-1: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[    2.014070] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.014071] usb 2-1: Product: Flash Drive
[    2.014072] usb 2-1: Manufacturer: Samsung
[    2.014072] usb 2-1: SerialNumber: 0377319120016367
[    2.017234] intel_rapl_common: Found RAPL domain package
[    2.017235] intel_rapl_common: Found RAPL domain dram
[    2.017673] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[    2.026064] random: crng init done
[    2.040299] audit: type=1130 audit(1613485834.785:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.044116] audit: type=1130 audit(1613485834.788:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.074543] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    2.074611] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    2.074719] battery: ACPI: Battery Slot [BAT0] (battery present)
[    2.123310] Adding 17610824k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:17610824k SSFS
[    2.136468] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[    2.159734] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    2.160122] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    2.165248] i801_smbus 0000:00:1f.4: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[    2.165250] i2c i2c-0: 2/2 memory slots populated (from DMI)
[    2.165788] i2c i2c-0: Successfully instantiated SPD at 0x50
[    2.175789] i2c_hid i2c-SYNA2393:00: supply vdd not found, using dummy regulator
[    2.175807] i2c_hid i2c-SYNA2393:00: supply vddl not found, using dummy regulator
[    2.177500] audit: type=1130 audit(1613485834.922:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.183245] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    2.197825] audit: type=1130 audit(1613485834.942:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-9FAA\x2dF572 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.198026] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    2.198026] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.198027] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.198027] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.198028] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    2.198028] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    2.199654] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.203336] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.244938] cryptd: max_cpu_qlen set to 1000
[    2.244991] MXM: GUID detected in BIOS
[    2.245037] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[    2.245216] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[    2.245762] checking generic (80000000 7f0000) vs hw (eb000000 1000000)
[    2.245763] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[    2.245763] fb0: switching to inteldrmfb from EFI VGA
[    2.245801] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.277759] usb 1-4: New USB device found, idVendor=0cf3, idProduct=e300, bcdDevice= 0.01
[    2.277760] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.298629] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.299970] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    2.319285] intel-spi 0000:00:1f.5: gd25q256 (32768 Kbytes)
[    2.327776] AVX2 version of gcm_enc/dec engaged.
[    2.327777] AES CTR mode by8 optimization enabled
[    2.334119] Creating 1 MTD partitions on "0000:00:1f.5":
[    2.334121] 0x000000000000-0x000002000000 : "BIOS"
[    2.363635] audit: type=1130 audit(1613485835.108:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.370560] audit: type=1127 audit(1613485835.115:10): pid=454 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    2.403149] usb 1-5: new full-speed USB device number 4 using xhci_hcd
[    2.551150] usb 1-5: not running at top speed; connect to a high speed hub
[    2.558589] usb 1-5: New USB device found, idVendor=0bda, idProduct=5400, bcdDevice= 1.04
[    2.558590] usb 1-5: New USB device strings: Mfr=17, Product=18, SerialNumber=19
[    2.558591] usb 1-5: Product: BillBoard Device
[    2.558592] usb 1-5: Manufacturer: Realtek
[    2.558593] usb 1-5: SerialNumber: 123456789ABCDEFGH
[    2.574482] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[    2.574486] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[    2.574486] nouveau: detected PR support, will not use DSM
[    2.574508] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[    2.574692] nouveau 0000:01:00.0: NVIDIA GP107 (137000a1)
[    2.682007] nouveau 0000:01:00.0: bios: version 86.07.63.00.6d
[    2.684939] nouveau 0000:01:00.0: pmu: firmware unavailable
[    2.686463] usb 1-7: new full-speed USB device number 5 using xhci_hcd
[    2.690975] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[    2.710062] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[    2.710155] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    2.713131] pci_bus 0000:04: Allocating resources
[    2.713149] pci_bus 0000:3a: Allocating resources
[    2.744124] nouveau 0000:01:00.0: fb: 4096 MiB GDDR5
[    2.760496] ath10k_pci 0000:3b:00.0: enabling device (0000 -> 0002)
[    2.765024] ath10k_pci 0000:3b:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    2.790471] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input10
[    2.831010] usb 1-7: New USB device found, idVendor=27c6, idProduct=5395, bcdDevice= 1.00
[    2.831012] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.831013] usb 1-7: Product: Goodix Fingerprint Device
[    2.831014] usb 1-7: Manufacturer: HTMicroelectronics
[    2.831015] usb 1-7: SerialNumber: HTK32
[    2.847366] intel_rapl_common: Found RAPL domain package
[    2.847368] intel_rapl_common: Found RAPL domain core
[    2.847369] intel_rapl_common: Found RAPL domain uncore
[    2.847370] intel_rapl_common: Found RAPL domain dram
[    2.847984] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[    2.883962] iTCO_vendor_support: vendor-support=0
[    2.884352] input: SYNA2393:00 06CB:7A13 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input11
[    2.884444] input: SYNA2393:00 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input12
[    2.884513] hid-generic 0018:06CB:7A13.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA2393:00 06CB:7A13] on i2c-SYNA2393:00
[    2.885557] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[    2.887832] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.887954] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    2.888158] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    2.959793] usb 1-12: new high-speed USB device number 6 using xhci_hcd
[    2.960376] input: SYNA2393:00 06CB:7A13 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input14
[    2.960427] input: SYNA2393:00 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input15
[    2.960471] hid-multitouch 0018:06CB:7A13.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA2393:00 06CB:7A13] on i2c-SYNA2393:00
[    2.992173] mousedev: PS/2 mouse device common for all mice
[    3.019304] ath10k_pci 0000:3b:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:1535
[    3.019305] ath10k_pci 0000:3b:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[    3.019635] ath10k_pci 0000:3b:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebefb
[    3.081741] [TTM] Zone  kernel: Available graphics memory: 8004922 KiB
[    3.081743] [TTM] Zone   dma32: Available graphics memory: 2097152 KiB
[    3.081744] [TTM] Initializing pool allocator
[    3.081747] [TTM] Initializing DMA pool allocator
[    3.081759] nouveau 0000:01:00.0: DRM: VRAM: 4096 MiB
[    3.081760] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[    3.081762] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[    3.081763] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[    3.081764] nouveau 0000:01:00.0: DRM: Pointer to TMDS table not found
[    3.081765] nouveau 0000:01:00.0: DRM: DCB version 4.1
[    3.082220] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[    3.082498] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[    3.082499] nouveau 0000:01:00.0: DRM: Disabling PCI power management to avoid bug
[    3.086700] ath10k_pci 0000:3b:00.0: board_file api 2 bmi_id N/A crc32 318825bf
[    3.116592] usb 1-12: New USB device found, idVendor=0c45, idProduct=671d, bcdDevice=81.31
[    3.116594] usb 1-12: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    3.116595] usb 1-12: Product: Integrated_Webcam_HD
[    3.116595] usb 1-12: Manufacturer: CN0VGCNHLOG0088OA5ALA00
[    3.180638] ath10k_pci 0000:3b:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    3.258360] ath: EEPROM regdomain: 0x6c
[    3.258361] ath: EEPROM indicates we should expect a direct regpair map
[    3.258362] ath: Country alpha2 being used: 00
[    3.258362] ath: Regpair used: 0x6c
[    3.262216] ath10k_pci 0000:3b:00.0 wlp59s0: renamed from wlan0
[    3.351616] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.351894] usb-storage 2-1:1.0: Quirks match for vid 090c pid 1000: 400
[    3.351973] scsi host3: usb-storage 2-1:1.0
[    3.352034] usbcore: registered new interface driver usb-storage
[    3.354329] usbcore: registered new interface driver uas
[    3.504351] [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
[    3.513019] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    3.518385] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input17
[    3.518503] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[    3.518546] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input18
[    3.518864] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.519007] vga_switcheroo: enabled
[    3.552166] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.595434] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3266: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    3.595436] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.595437] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    3.595437] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.595438] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.595439] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x18
[    3.595440] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
[    3.595440] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    3.600903] ------------[ cut here ]------------
[    3.600907] WARNING: CPU: 5 PID: 169 at kernel/kmod.c:136 __request_module+0x29e/0x420
[    3.600907] Modules linked in: snd_hda_codec_realtek(+) pcc_cpufreq(-) acpi_cpufreq(-) snd_hda_codec_generic br_netfilter(+) bridge stp llc uas usb_storage snd_sof_pci snd_sof_intel_byt snd_sof_intel_ipc overlay snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_xtensa_dsp snd_sof_intel_hda snd_sof joydev mousedev snd_soc_skl snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core iTCO_wdt hid_multitouch snd_soc_acpi_intel_match intel_pmc_bxt snd_soc_acpi hid_generic ee1004 iTCO_vendor_support dell_laptop mei_hdcp mei_wdt snd_soc_core intel_rapl_msr ledtrig_audio x86_pkg_temp_thermal intel_powerclamp dell_wmi coretemp snd_compress dell_smbios ac97_bus snd_pcm_dmaengine kvm_intel snd_hda_intel ath10k_pci wmi_bmof intel_wmi_thunderbolt dell_wmi_descriptor dcdbas snd_intel_dspcfg dell_smm_hwmon kvm ath10k_core snd_hda_codec irqbypass snd_hda_core ath crct10dif_pclmul ofpart nls_iso8859_1 crc32_pclmul ghash_clmulni_intel nls_cp437 cmdlinepart aesni_intel vfat crypto_simd snd_hwdep intel_spi_pci
[    3.600920]  mac80211 fat snd_pcm cryptd intel_spi glue_helper spi_nor rapl intel_cstate snd_timer i915 nouveau intel_uncore cfg80211 psmouse input_leds pcspkr snd mtd i2c_i801 soundcore i2c_smbus mxm_wmi rfkill ttm libarc4 i2c_algo_bit tpm_crb drm_kms_helper cec mei_me rc_core mei intel_gtt i2c_hid ucsi_acpi intel_lpss_pci syscopyarea intel_lpss processor_thermal_device typec_ucsi sysfillrect idma64 tpm_tis intel_rapl_common sysimgblt int3403_thermal intel_pch_thermal fb_sys_fops intel_soc_dts_iosf typec hid battery tpm_tis_core int340x_thermal_zone intel_hid tpm wmi dell_smo8800 evdev rng_core mac_hid int3400_thermal acpi_thermal_rel ac sparse_keymap drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc serio_raw mmc_core atkbd libps2 crc32c_intel xhci_pci rtsx_pci xhci_hcd i8042 serio
[    3.600936] CPU: 5 PID: 169 Comm: kworker/u24:2 Not tainted 5.9.16-1-MANJARO #1
[    3.600937] Hardware name: Dell Inc. XPS 15 9570/0D0T05, BIOS 1.15.0 12/25/2019
[    3.600938] Workqueue: events_unbound async_run_entry_fn
[    3.600940] RIP: 0010:__request_module+0x29e/0x420
[    3.600941] Code: 00 48 85 c0 75 e1 65 ff 0d 0f 04 b6 73 0f 85 b1 fe ff ff e8 43 ce f4 ff e9 a7 fe ff ff e8 7a e9 ff ff 84 c0 0f 84 1a fe ff ff <0f> 0b e9 13 fe ff ff 48 c7 c6 10 11 41 8d 48 c7 c7 e0 19 a5 8d e8
[    3.600942] RSP: 0018:ffffa2b9c056f940 EFLAGS: 00010202
[    3.600943] RAX: ffff8bf7a98d8301 RBX: 0000000000000001 RCX: 0000000000000000
[    3.600943] RDX: ffffffffc07b1e96 RSI: ffffffffc0797ec7 RDI: ffff8bf7a96abe00
[    3.600943] RBP: ffffa2b9c056fa20 R08: ffff8bf7a7280383 R09: 0000000000000000
[    3.600944] R10: ffffa2b9c056fa30 R11: ffff8bf7a7280383 R12: ffffa2b9c056f980
[    3.600944] R13: ffffffffc0797ec7 R14: ffffa2b9c056fa30 R15: ffff8bf79949b660
[    3.600945] FS:  0000000000000000(0000) GS:ffff8bf7ac540000(0000) knlGS:0000000000000000
[    3.600946] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    3.600946] CR2: 000055fb45760000 CR3: 00000001fa20e006 CR4: 00000000003706e0
[    3.600947] Call Trace:
[    3.600951]  ? kobject_set_name_vargs+0x6f/0x90
[    3.600955]  rc_map_get+0x7a/0xe0 [rc_core]
[    3.600957]  rc_register_device+0x120/0x540 [rc_core]
[    3.600960]  cec_register_adapter+0x5c/0x280 [cec]
[    3.600967]  drm_dp_cec_set_edid+0x163/0x1d9 [drm_kms_helper]
[    3.601015]  intel_dp_set_edid+0x8d/0xc0 [i915]
[    3.601053]  intel_dp_detect+0x209/0x610 [i915]
[    3.601059]  drm_helper_probe_detect+0x49/0xa0 [drm_kms_helper]
[    3.601064]  drm_helper_probe_single_connector_modes+0x649/0x840 [drm_kms_helper]
[    3.601080]  drm_client_modeset_probe+0x29d/0x13e0 [drm]
[    3.601083]  ? swake_up_locked+0x20/0x40
[    3.601083]  ? complete+0x2f/0x40
[    3.601085]  ? update_load_avg+0x7e/0x660
[    3.601086]  ? update_curr+0x108/0x1f0
[    3.601092]  __drm_fb_helper_initial_config_and_unlock+0x44/0x4b0 [drm_kms_helper]
[    3.601094]  ? _raw_spin_unlock_irq+0x1d/0x30
[    3.601095]  ? finish_task_switch+0x80/0x250
[    3.601097]  ? __switch_to_asm+0x36/0x70
[    3.601133]  intel_fbdev_initial_config+0x14/0x30 [i915]
[    3.601135]  async_run_entry_fn+0x37/0x140
[    3.601136]  process_one_work+0x1da/0x3d0
[    3.601137]  worker_thread+0x4d/0x3d0
[    3.601139]  ? rescuer_thread+0x410/0x410
[    3.601140]  kthread+0x142/0x160
[    3.601141]  ? __kthread_bind_mask+0x60/0x60
[    3.601143]  ret_from_fork+0x22/0x30
[    3.601144] ---[ end trace 8e22b584c25385a7 ]---
[    3.627649] Bridge firewalling registered
[    3.629795] Registered IR keymap rc-cec
[    3.629822] rc rc0: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0
[    3.629858] input: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0/input19
[    3.684374] Registered IR keymap rc-cec
[    3.684401] rc rc1: DP-3 as /devices/pci0000:00/0000:00:02.0/rc/rc1
[    3.684443] input: DP-3 as /devices/pci0000:00/0000:00:02.0/rc/rc1/input20
[    3.686080] fbcon: i915drmfb (fb0) is primary device
[    3.686081] fbcon: Deferring console take-over
[    3.686083] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    3.920122] Initializing XFRM netlink socket
[    4.172288] br-520e36b891aa: port 1(vethcabc108) entered blocking state
[    4.172298] br-520e36b891aa: port 1(vethcabc108) entered disabled state
[    4.172334] device vethcabc108 entered promiscuous mode
[    4.172411] br-520e36b891aa: port 1(vethcabc108) entered blocking state
[    4.172412] br-520e36b891aa: port 1(vethcabc108) entered forwarding state
[    4.172431] IPv6: ADDRCONF(NETDEV_CHANGE): br-520e36b891aa: link becomes ready
[    4.172473] br-520e36b891aa: port 1(vethcabc108) entered disabled state
[    4.201812] cdc_acm 1-7:1.0: ttyACM0: USB ACM device
[    4.201968] usbcore: registered new interface driver cdc_acm
[    4.201969] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.204120] mc: Linux media interface: v0.10
[    4.230218] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C534.0002/input/input21
[    4.233011] videodev: Linux video capture interface: v2.00
[    4.239396] Bluetooth: Core ver 2.22
[    4.239408] NET: Registered protocol family 31
[    4.239409] Bluetooth: HCI device and connection manager initialized
[    4.239416] Bluetooth: HCI socket layer initialized
[    4.239417] Bluetooth: L2CAP socket layer initialized
[    4.239419] Bluetooth: SCO socket layer initialized
[    4.266401] usbcore: registered new interface driver btusb
[    4.268641] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[    4.268642] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[    4.270165] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:671d)
[    4.275056] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input22
[    4.290599] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
[    4.290637] usbcore: registered new interface driver uvcvideo
[    4.290638] USB Video Class driver (1.1.1)
[    4.293277] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/input/input23
[    4.293455] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/input/input24
[    4.307216] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.307217] Bluetooth: BNEP filters: protocol multicast
[    4.307220] Bluetooth: BNEP socket layer initialized
[    4.326728] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[    4.327093] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[    4.351373] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/input/input25
[    4.352596] hid-generic 0003:046D:C534.0003: input,hiddev0,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
[    4.353230] usbcore: registered new interface driver usbhid
[    4.353231] usbhid: USB HID core driver
[    4.499991] eth0: renamed from veth14a458a
[    4.501396] logitech-djreceiver 0003:046D:C534.0002: hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
[    4.543585] IPv6: ADDRCONF(NETDEV_CHANGE): vethcabc108: link becomes ready
[    4.543603] br-520e36b891aa: port 1(vethcabc108) entered blocking state
[    4.543603] br-520e36b891aa: port 1(vethcabc108) entered forwarding state
[    4.601478] ucsi_acpi USBC000:00: UCSI_GET_PDOS returned 0 bytes
[    4.716768] logitech-djreceiver 0003:046D:C534.0003: hiddev0,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
[    4.774821] logitech-djreceiver 0003:046D:C534.0003: device of type eQUAD nano Lite (0x0a) connected on slot 1
[    4.775129] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input28
[    4.775291] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input29
[    4.775335] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input30
[    4.775379] hid-generic 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:14.0-2/input1:1
[    4.776853] logitech-djreceiver 0003:046D:C534.0003: device of type eQUAD nano Lite (0x0a) connected on slot 2
[    4.777011] input: Logitech Wireless Mouse PID:4058 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4058.0005/input/input35
[    4.777088] hid-generic 0003:046D:4058.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4058] on usb-0000:00:14.0-2/input1:2
[    4.844553] NET: Registered protocol family 38
[    4.960105] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input39
[    4.989316] scsi 3:0:0:0: Direct-Access     Samsung  Flash Drive      1100 PQ: 0 ANSI: 6
[    4.989848] sd 3:0:0:0: [sda] 250626566 512-byte logical blocks: (128 GB/120 GiB)
[    4.990044] sd 3:0:0:0: [sda] Write Protect is off
[    4.990046] sd 3:0:0:0: [sda] Mode Sense: 43 00 00 00
[    4.990254] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.010048] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input40
[    5.010150] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input41
[    5.034664]  sda: sda1
[    5.035767] sd 3:0:0:0: [sda] Attached SCSI removable disk
[    5.063417] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input42
[    5.166383] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input43
[    5.166434] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input44
[    5.172979] input: Logitech Wireless Keyboard PID:4023 as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input45
[    5.173096] logitech-hidpp-device 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:14.0-2/input1:1
[    5.277034] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4058.0005/input/input46
[    5.277350] logitech-hidpp-device 0003:046D:4058.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:14.0-2/input1:2
[    5.537096] kauditd_printk_skb: 103 callbacks suppressed
[    5.537097] audit: type=1701 audit(1613485838.282:114): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=508 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
[    5.547207] audit: type=1334 audit(1613485838.292:115): prog-id=11 op=LOAD
[    5.547799] audit: type=1334 audit(1613485838.292:116): prog-id=12 op=LOAD
[    5.548672] audit: type=1130 audit(1613485838.292:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1545-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.834973] audit: type=1131 audit(1613485838.578:118): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1545-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.863705] audit: type=1334 audit(1613485838.612:119): prog-id=12 op=UNLOAD
[    5.863707] audit: type=1334 audit(1613485838.612:120): prog-id=11 op=UNLOAD
[    7.554980] audit: type=1131 audit(1613485840.298:121): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[    7.830911] audit: type=1130 audit(1613485840.575:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.830921] audit: type=1131 audit(1613485840.575:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.054552] nouveau 0000:01:00.0: gr: intr 00000040
[   10.901115] logitech-hidpp-device 0003:046D:4023.0004: HID++ 2.0 device connected.
[   12.259932] kauditd_printk_skb: 12 callbacks suppressed
[   12.259937] audit: type=1100 audit(1613485845.005:136): pid=1617 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=? acct="infiniter" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[   13.026534] audit: type=1131 audit(1613485845.768:137): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.996687] audit: type=1100 audit(1613485850.742:138): pid=1694 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="infiniter" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   17.997820] audit: type=1101 audit(1613485850.742:139): pid=1694 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="infiniter" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   18.116934] audit: type=1106 audit(1613485850.862:140): pid=1572 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   18.117840] audit: type=1104 audit(1613485850.862:141): pid=1572 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   18.125966] audit: type=1103 audit(1613485850.868:142): pid=1694 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="infiniter" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   18.126082] audit: type=1006 audit(1613485850.868:143): pid=1694 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   18.175722] audit: type=1130 audit(1613485850.918:144): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.195080] audit: type=1101 audit(1613485850.938:145): pid=1700 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="infiniter" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.195206] audit: type=1103 audit(1613485850.938:146): pid=1700 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="infiniter" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   18.195415] audit: type=1006 audit(1613485850.938:147): pid=1700 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   23.488090] wlp59s0: authenticate with 1a:e8:29:fc:ed:40
[   23.531000] wlp59s0: send auth to 1a:e8:29:fc:ed:40 (try 1/3)
[   23.533277] wlp59s0: authenticated
[   23.536552] wlp59s0: associate with 1a:e8:29:fc:ed:40 (try 1/3)
[   23.541409] wlp59s0: RX AssocResp from 1a:e8:29:fc:ed:40 (capab=0x411 status=0 aid=1)
[   23.544359] wlp59s0: associated
[   23.557309] IPv6: ADDRCONF(NETDEV_CHANGE): wlp59s0: link becomes ready
[   23.587392] kauditd_printk_skb: 6 callbacks suppressed
[   23.587392] audit: type=1130 audit(1613485856.332:154): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.380923] audit: type=1131 audit(1613485861.125:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.388141] audit: type=1131 audit(1613485861.132:156): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.688127] audit: type=1334 audit(1613485866.432:157): prog-id=15 op=LOAD
[   33.688157] audit: type=1334 audit(1613485866.432:158): prog-id=16 op=LOAD
[   33.966754] audit: type=1130 audit(1613485866.712:159): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.026405] audit: type=1131 audit(1613485866.768:160): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.339399] audit: type=1131 audit(1613485867.082:161): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.594097] audit: type=1334 audit(1613485867.338:162): prog-id=10 op=UNLOAD
[   34.594099] audit: type=1334 audit(1613485867.338:163): prog-id=9 op=UNLOAD
[   36.596666] audit: type=1130 audit(1613485869.342:164): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   36.886858] Bluetooth: RFCOMM TTY layer initialized
[   36.886867] Bluetooth: RFCOMM socket layer initialized
[   36.886874] Bluetooth: RFCOMM ver 1.11
[   67.974848] logitech-hidpp-device 0003:046D:4058.0005: HID++ 4.5 device connected.
[  199.576769] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=11534 end=11535) time 296 us, min 1073, max 1079, scanline start 1069, end 1089
[  200.093478] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=11565 end=11566) time 299 us, min 1073, max 1079, scanline start 1071, end 1091
[  319.577011] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=18734 end=18735) time 288 us, min 1073, max 1079, scanline start 1064, end 1065
[  323.652885] audit: type=1130 audit(1613486156.398:165): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  334.028774] audit: type=1131 audit(1613486166.772:166): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  623.617733] audit: type=1130 audit(1613486456.362:167): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  634.028413] audit: type=1131 audit(1613486466.772:168): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  676.470199] audit: type=1100 audit(1613486509.215:169): pid=11719 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="infiniter" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[  682.997189] audit: type=1100 audit(1613486515.742:170): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="infiniter" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  683.001213] audit: type=1101 audit(1613486515.745:171): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="infiniter" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  683.001800] audit: type=1110 audit(1613486515.745:172): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  683.008023] audit: type=1105 audit(1613486515.752:173): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  683.014746] audit: type=1106 audit(1613486515.758:174): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  683.015082] audit: type=1104 audit(1613486515.758:175): pid=11922 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/12 res=success'
[  691.826842] usb 2-1: USB disconnect, device number 2
[  691.828123] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[  691.828201] sd 3:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[  900.167877] audit: type=1130 audit(1613486732.912:176): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  900.167892] audit: type=1131 audit(1613486732.912:177): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  923.601340] audit: type=1130 audit(1613486756.345:178): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  934.024358] audit: type=1131 audit(1613486766.768:179): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1223.628488] audit: type=1130 audit(1613487056.372:180): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1234.029058] audit: type=1131 audit(1613487066.772:181): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1523.622408] audit: type=1130 audit(1613487356.365:182): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1534.031025] audit: type=1131 audit(1613487366.775:183): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1823.604111] audit: type=1130 audit(1613487656.348:184): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1834.027518] audit: type=1131 audit(1613487666.771:185): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2123.620557] audit: type=1130 audit(1613487956.365:186): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2134.030361] audit: type=1131 audit(1613487966.775:187): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2423.623729] audit: type=1130 audit(1613488256.368:188): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2434.023799] audit: type=1131 audit(1613488266.768:189): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2723.622040] audit: type=1130 audit(1613488556.365:190): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2734.029323] audit: type=1131 audit(1613488566.775:191): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3023.621676] audit: type=1130 audit(1613488856.365:192): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3034.029659] audit: type=1131 audit(1613488866.775:193): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3323.598525] audit: type=1130 audit(1613489156.341:194): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3334.023849] audit: type=1131 audit(1613489166.768:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3623.622885] audit: type=1130 audit(1613489456.368:196): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3634.028680] audit: type=1131 audit(1613489466.771:197): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3923.625005] audit: type=1130 audit(1613489756.368:198): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3934.030882] audit: type=1131 audit(1613489766.775:199): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4223.622236] audit: type=1130 audit(1613490056.365:200): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4234.029903] audit: type=1131 audit(1613490066.775:201): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4523.619155] audit: type=1130 audit(1613490356.365:202): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4534.023483] audit: type=1131 audit(1613490366.768:203): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4823.623308] audit: type=1130 audit(1613490656.368:204): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4834.027938] audit: type=1131 audit(1613490666.771:205): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5123.623393] audit: type=1130 audit(1613490956.368:206): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5134.025897] audit: type=1131 audit(1613490966.771:207): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5423.595782] audit: type=1130 audit(1613491256.341:208): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5434.028732] audit: type=1131 audit(1613491266.775:209): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5723.633308] audit: type=1130 audit(1613491556.378:210): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5734.028488] audit: type=1131 audit(1613491566.771:211): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6023.635062] audit: type=1130 audit(1613491856.378:212): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6034.023505] audit: type=1131 audit(1613491866.768:213): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6323.604941] audit: type=1130 audit(1613492156.348:214): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6334.023124] audit: type=1131 audit(1613492166.768:215): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6623.631884] audit: type=1130 audit(1613492456.378:216): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6634.029906] audit: type=1131 audit(1613492466.775:217): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6923.632431] audit: type=1130 audit(1613492756.378:218): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6934.028520] audit: type=1131 audit(1613492766.775:219): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7223.631463] audit: type=1130 audit(1613493056.375:220): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7234.027732] audit: type=1131 audit(1613493066.771:221): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7523.606596] audit: type=1130 audit(1613493356.351:222): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7534.027625] audit: type=1131 audit(1613493366.771:223): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7823.606989] audit: type=1130 audit(1613493656.351:224): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7834.027354] audit: type=1131 audit(1613493666.771:225): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8123.610489] audit: type=1130 audit(1613493956.355:226): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8134.028553] audit: type=1131 audit(1613493966.775:227): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8423.635288] audit: type=1130 audit(1613494256.381:228): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8434.027274] audit: type=1131 audit(1613494266.771:229): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8723.634078] audit: type=1130 audit(1613494556.378:230): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8734.026796] audit: type=1131 audit(1613494566.771:231): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9023.631090] audit: type=1130 audit(1613494856.375:232): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9034.018097] audit: type=1131 audit(1613494866.765:233): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9323.630786] audit: type=1130 audit(1613495156.375:234): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9334.022785] audit: type=1131 audit(1613495166.768:235): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9623.637295] audit: type=1130 audit(1613495456.381:236): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9634.028358] audit: type=1131 audit(1613495466.775:237): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9923.632736] audit: type=1130 audit(1613495756.378:238): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9934.028078] audit: type=1131 audit(1613495766.775:239): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10223.635353] audit: type=1130 audit(1613496056.381:240): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10234.022519] audit: type=1131 audit(1613496066.768:241): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10523.626939] audit: type=1130 audit(1613496356.371:242): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10534.027326] audit: type=1131 audit(1613496366.771:243): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10823.607833] audit: type=1130 audit(1613496656.355:244): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10834.026635] audit: type=1131 audit(1613496666.771:245): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11123.634978] audit: type=1130 audit(1613496956.381:246): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11134.027543] audit: type=1131 audit(1613496966.771:247): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11423.637164] audit: type=1130 audit(1613497256.381:248): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11434.022213] audit: type=1131 audit(1613497266.768:249): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11723.619270] audit: type=1130 audit(1613497556.365:250): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11734.027599] audit: type=1131 audit(1613497566.775:251): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12023.636991] audit: type=1130 audit(1613497856.381:252): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12034.027864] audit: type=1131 audit(1613497866.775:253): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12323.637085] audit: type=1130 audit(1613498156.381:254): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12334.021858] audit: type=1131 audit(1613498166.768:255): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12623.641138] audit: type=1130 audit(1613498456.388:256): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12634.026453] audit: type=1131 audit(1613498466.771:257): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12923.637325] audit: type=1130 audit(1613498756.385:258): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12934.026196] audit: type=1131 audit(1613498766.771:259): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13223.641846] audit: type=1130 audit(1613499056.388:260): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13234.028331] audit: type=1131 audit(1613499066.775:261): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13523.634574] audit: type=1130 audit(1613499356.381:262): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13534.021636] audit: type=1131 audit(1613499366.768:263): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13823.636898] audit: type=1130 audit(1613499656.385:264): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13834.021642] audit: type=1131 audit(1613499666.768:265): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14123.640787] audit: type=1130 audit(1613499956.388:266): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14134.025339] audit: type=1131 audit(1613499966.771:267): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14423.609268] audit: type=1130 audit(1613500256.355:268): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14434.027323] audit: type=1131 audit(1613500266.775:269): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14723.644831] audit: type=1130 audit(1613500556.391:270): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14734.023664] audit: type=1131 audit(1613500566.771:271): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15023.632329] audit: type=1130 audit(1613500856.378:272): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15034.027049] audit: type=1131 audit(1613500866.775:273): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15323.632025] audit: type=1130 audit(1613501156.378:274): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15334.025908] audit: type=1131 audit(1613501166.771:275): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15623.606679] audit: type=1130 audit(1613501456.355:276): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15634.027385] audit: type=1131 audit(1613501466.775:277): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15923.633256] audit: type=1130 audit(1613501756.381:278): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[15934.026554] audit: type=1131 audit(1613501766.775:279): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16223.613116] audit: type=1130 audit(1613502056.361:280): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16234.021231] audit: type=1131 audit(1613502066.768:281): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16523.641960] audit: type=1130 audit(1613502356.388:282): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16534.026656] audit: type=1131 audit(1613502366.775:283): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16823.640246] audit: type=1130 audit(1613502656.388:284): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16834.025287] audit: type=1131 audit(1613502666.771:285): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17123.636553] audit: type=1130 audit(1613502956.385:286): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17134.027119] audit: type=1131 audit(1613502966.775:287): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17423.643265] audit: type=1130 audit(1613503256.391:288): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17434.021982] audit: type=1131 audit(1613503266.768:289): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17723.641976] audit: type=1130 audit(1613503556.388:290): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[17734.024803] audit: type=1131 audit(1613503566.771:291): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18023.596652] audit: type=1130 audit(1613503856.345:292): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18034.019458] audit: type=1131 audit(1613503866.768:293): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18323.637741] audit: type=1130 audit(1613504156.385:294): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18334.029387] audit: type=1131 audit(1613504166.778:295): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18623.623632] audit: type=1130 audit(1613504456.371:296): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18634.026233] audit: type=1131 audit(1613504466.775:297): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18923.643837] audit: type=1130 audit(1613504756.391:298): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18934.023085] audit: type=1131 audit(1613504766.771:299): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19223.644686] audit: type=1130 audit(1613505056.391:300): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19234.029637] audit: type=1131 audit(1613505066.778:301): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19523.630457] audit: type=1130 audit(1613505356.378:302): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19534.025195] audit: type=1131 audit(1613505366.771:303): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19823.643412] audit: type=1130 audit(1613505656.391:304): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[19834.028119] audit: type=1131 audit(1613505666.775:305): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20123.643048] audit: type=1130 audit(1613505956.391:306): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20134.028779] audit: type=1131 audit(1613505966.778:307): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20423.627093] audit: type=1130 audit(1613506256.375:308): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20434.028497] audit: type=1131 audit(1613506266.775:309): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20723.632010] audit: type=1130 audit(1613506556.381:310): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20734.029593] audit: type=1131 audit(1613506566.778:311): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21023.618380] audit: type=1130 audit(1613506856.365:312): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21034.021182] audit: type=1131 audit(1613506866.768:313): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21323.644331] audit: type=1130 audit(1613507156.391:314): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21334.029079] audit: type=1131 audit(1613507166.778:315): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21623.644001] audit: type=1130 audit(1613507456.391:316): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21634.026232] audit: type=1131 audit(1613507466.775:317): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21923.646027] audit: type=1130 audit(1613507756.395:318): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21934.027945] audit: type=1131 audit(1613507766.775:319): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22223.643097] audit: type=1130 audit(1613508056.391:320): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22234.027000] audit: type=1131 audit(1613508066.775:321): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22523.636881] audit: type=1130 audit(1613508356.385:322): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22534.025831] audit: type=1131 audit(1613508366.775:323): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22823.639659] audit: type=1130 audit(1613508656.388:324): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22834.028850] audit: type=1131 audit(1613508666.778:325): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23123.637716] audit: type=1130 audit(1613508956.385:326): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23134.023888] audit: type=1131 audit(1613508966.771:327): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23423.638372] audit: type=1130 audit(1613509256.388:328): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23434.028652] audit: type=1131 audit(1613509266.778:329): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23723.611666] audit: type=1130 audit(1613509556.361:330): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23734.028158] audit: type=1131 audit(1613509566.778:331): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24023.639541] audit: type=1130 audit(1613509856.388:332): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24034.028790] audit: type=1131 audit(1613509866.778:333): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24323.646610] audit: type=1130 audit(1613510156.395:334): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24334.027013] audit: type=1131 audit(1613510166.775:335): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24623.647537] audit: type=1130 audit(1613510456.395:336): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24634.027732] audit: type=1131 audit(1613510466.778:337): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24923.643009] audit: type=1130 audit(1613510756.391:338): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24934.027515] audit: type=1131 audit(1613510766.775:339): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25223.681035] audit: type=1130 audit(1613511056.431:340): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25234.024566] audit: type=1131 audit(1613511066.775:341): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25523.651100] audit: type=1130 audit(1613511356.401:342): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25534.028193] audit: type=1131 audit(1613511366.778:343): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25823.657810] audit: type=1130 audit(1613511656.408:344): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25834.027491] audit: type=1131 audit(1613511666.778:345): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26123.675268] audit: type=1130 audit(1613511956.425:346): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26134.027219] audit: type=1131 audit(1613511966.775:347): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26423.669381] audit: type=1130 audit(1613512256.418:348): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26434.028075] audit: type=1131 audit(1613512266.778:349): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26723.665943] audit: type=1130 audit(1613512556.415:350): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[26734.027108] audit: type=1131 audit(1613512566.775:351): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27023.621487] audit: type=1130 audit(1613512856.371:352): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27034.035112] audit: type=1131 audit(1613512866.785:353): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27323.635470] audit: type=1130 audit(1613513156.385:354): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27334.024990] audit: type=1131 audit(1613513166.775:355): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27623.632764] audit: type=1130 audit(1613513456.381:356): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27634.027294] audit: type=1131 audit(1613513466.778:357): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27923.654030] audit: type=1130 audit(1613513756.405:358): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27934.026728] audit: type=1131 audit(1613513766.775:359): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28223.645344] audit: type=1130 audit(1613514056.395:360): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28234.028423] audit: type=1131 audit(1613514066.778:361): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28523.641957] audit: type=1130 audit(1613514356.391:362): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28534.021597] audit: type=1131 audit(1613514366.771:363): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28823.644678] audit: type=1130 audit(1613514656.395:364): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28834.027458] audit: type=1131 audit(1613514666.778:365): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29123.644582] audit: type=1130 audit(1613514956.395:366): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29134.021768] audit: type=1131 audit(1613514966.771:367): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29423.642697] audit: type=1130 audit(1613515256.391:368): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29434.026033] audit: type=1131 audit(1613515266.775:369): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29723.650830] audit: type=1130 audit(1613515556.401:370): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29734.026390] audit: type=1131 audit(1613515566.775:371): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30023.625638] audit: type=1130 audit(1613515856.375:372): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30034.025179] audit: type=1131 audit(1613515866.775:373): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30323.650765] audit: type=1130 audit(1613516156.401:374): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30334.025774] audit: type=1131 audit(1613516166.775:375): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30600.104349] audit: type=1130 audit(1613516432.855:376): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30600.122285] audit: type=1131 audit(1613516432.871:377): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30600.156395] audit: type=1130 audit(1613516432.908:378): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30600.156399] audit: type=1131 audit(1613516432.908:379): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30601.447627] audit: type=1130 audit(1613516434.198:380): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30601.447636] audit: type=1131 audit(1613516434.198:381): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30614.838642] audit: type=1130 audit(1613516447.588:382): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30614.838661] audit: type=1131 audit(1613516447.588:383): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30623.624935] audit: type=1130 audit(1613516456.375:384): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30634.021070] audit: type=1131 audit(1613516466.771:385): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30923.652430] audit: type=1130 audit(1613516756.401:386): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30934.020969] audit: type=1131 audit(1613516766.771:387): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31223.653054] audit: type=1130 audit(1613517056.404:388): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31234.025751] audit: type=1131 audit(1613517066.774:389): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31523.629452] audit: type=1130 audit(1613517356.381:390): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31534.024353] audit: type=1131 audit(1613517366.774:391): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31823.654245] audit: type=1130 audit(1613517656.404:392): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31834.026766] audit: type=1131 audit(1613517666.778:393): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32123.638257] audit: type=1130 audit(1613517956.388:394): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32134.021379] audit: type=1131 audit(1613517966.771:395): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32423.653614] audit: type=1130 audit(1613518256.404:396): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32434.025756] audit: type=1131 audit(1613518266.774:397): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32723.652724] audit: type=1130 audit(1613518556.404:398): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32734.027213] audit: type=1131 audit(1613518566.778:399): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33023.651535] audit: type=1130 audit(1613518856.401:400): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33034.027130] audit: type=1131 audit(1613518866.778:401): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33323.652550] audit: type=1130 audit(1613519156.404:402): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33334.025874] audit: type=1131 audit(1613519166.778:403): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33623.657002] audit: type=1130 audit(1613519456.408:404): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33634.030932] audit: type=1131 audit(1613519466.781:405): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33923.653568] audit: type=1130 audit(1613519756.404:406): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33934.024005] audit: type=1131 audit(1613519766.774:407): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34223.655014] audit: type=1130 audit(1613520056.404:408): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34234.020727] audit: type=1131 audit(1613520066.771:409): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34523.651356] audit: type=1130 audit(1613520356.401:410): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34534.026552] audit: type=1131 audit(1613520366.778:411): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34823.652756] audit: type=1130 audit(1613520656.404:412): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34834.027863] audit: type=1131 audit(1613520666.778:413): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35123.647276] audit: type=1130 audit(1613520956.398:414): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35134.024596] audit: type=1131 audit(1613520966.774:415): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35423.648373] audit: type=1130 audit(1613521256.398:416): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35434.023281] audit: type=1131 audit(1613521266.774:417): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35723.647705] audit: type=1130 audit(1613521556.398:418): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35734.019976] audit: type=1131 audit(1613521566.771:419): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36023.649437] audit: type=1130 audit(1613521856.401:420): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36034.023783] audit: type=1131 audit(1613521866.774:421): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36323.654361] audit: type=1130 audit(1613522156.404:422): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36334.024738] audit: type=1131 audit(1613522166.774:423): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36623.656159] audit: type=1130 audit(1613522456.408:424): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36634.025088] audit: type=1131 audit(1613522466.774:425): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36923.657123] audit: type=1130 audit(1613522756.404:426): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36934.024274] audit: type=1131 audit(1613522766.771:427): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37223.656776] audit: type=1130 audit(1613523056.404:428): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37234.023989] audit: type=1131 audit(1613523066.771:429): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37523.656490] audit: type=1130 audit(1613523356.404:430): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37534.019766] audit: type=1131 audit(1613523366.768:431): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37823.657765] audit: type=1130 audit(1613523656.404:432): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37834.025876] audit: type=1131 audit(1613523666.774:433): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38123.635990] audit: type=1130 audit(1613523956.384:434): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38134.019529] audit: type=1131 audit(1613523966.768:435): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38423.657984] audit: type=1130 audit(1613524256.408:436): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38434.024699] audit: type=1131 audit(1613524266.774:437): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38723.658119] audit: type=1130 audit(1613524556.408:438): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38734.025518] audit: type=1131 audit(1613524566.774:439): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39023.658064] audit: type=1130 audit(1613524856.408:440): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39034.019227] audit: type=1131 audit(1613524866.768:441): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39323.623285] audit: type=1130 audit(1613525156.371:442): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39334.023807] audit: type=1131 audit(1613525166.771:443): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39623.624402] audit: type=1130 audit(1613525456.374:444): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39634.024756] audit: type=1131 audit(1613525466.774:445): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39923.650610] audit: type=1130 audit(1613525756.398:446): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39934.018981] audit: type=1131 audit(1613525766.768:447): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40223.651304] audit: type=1130 audit(1613526056.401:448): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40234.019051] audit: type=1131 audit(1613526066.768:449): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40523.653799] audit: type=1130 audit(1613526356.401:450): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40534.019028] audit: type=1131 audit(1613526366.768:451): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40823.652542] audit: type=1130 audit(1613526656.401:452): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40834.023921] audit: type=1131 audit(1613526666.771:453): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41123.633441] audit: type=1130 audit(1613526956.381:454): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41134.024520] audit: type=1131 audit(1613526966.774:455): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41423.652866] audit: type=1130 audit(1613527256.401:456): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41434.024235] audit: type=1131 audit(1613527266.774:457): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41723.611526] audit: type=1130 audit(1613527556.361:458): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41734.018888] audit: type=1131 audit(1613527566.768:459): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42023.663150] audit: type=1130 audit(1613527856.411:460): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42034.024176] audit: type=1131 audit(1613527866.774:461): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42323.664614] audit: type=1130 audit(1613528156.414:462): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42334.018971] audit: type=1131 audit(1613528166.768:463): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42623.661446] audit: type=1130 audit(1613528456.414:464): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42634.024658] audit: type=1131 audit(1613528466.774:465): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42923.661538] audit: type=1130 audit(1613528756.411:466): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42934.023546] audit: type=1131 audit(1613528766.774:467): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43223.634891] audit: type=1130 audit(1613529056.384:468): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43234.018692] audit: type=1131 audit(1613529066.768:469): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43523.663354] audit: type=1130 audit(1613529356.411:470): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43534.018459] audit: type=1131 audit(1613529366.768:471): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43823.661268] audit: type=1130 audit(1613529656.411:472): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43834.023193] audit: type=1131 audit(1613529666.771:473): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44123.654967] audit: type=1130 audit(1613529956.404:474): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44134.025125] audit: type=1131 audit(1613529966.774:475): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44423.612001] audit: type=1130 audit(1613530256.361:476): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44434.018160] audit: type=1131 audit(1613530266.768:477): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44723.628814] audit: type=1130 audit(1613530556.378:478): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44734.023147] audit: type=1131 audit(1613530566.771:479): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45023.611313] audit: type=1130 audit(1613530856.361:480): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45034.019785] audit: type=1131 audit(1613530866.771:481): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45323.630823] audit: type=1130 audit(1613531156.381:482): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45334.022432] audit: type=1131 audit(1613531166.771:483): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45623.656250] audit: type=1130 audit(1613531456.404:484): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45634.022209] audit: type=1131 audit(1613531466.771:485): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45923.659945] audit: type=1130 audit(1613531756.411:486): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[45934.021915] audit: type=1131 audit(1613531766.771:487): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46223.655908] audit: type=1130 audit(1613532056.404:488): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46234.018403] audit: type=1131 audit(1613532066.768:489): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46523.659762] audit: type=1130 audit(1613532356.411:490): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46534.022734] audit: type=1131 audit(1613532366.771:491): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46823.633441] audit: type=1130 audit(1613532656.384:492): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46834.022257] audit: type=1131 audit(1613532666.771:493): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47123.657026] audit: type=1130 audit(1613532956.408:494): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47134.022395] audit: type=1131 audit(1613532966.771:495): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47423.657405] audit: type=1130 audit(1613533256.408:496): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47434.024393] audit: type=1131 audit(1613533266.774:497): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47723.656796] audit: type=1130 audit(1613533556.408:498): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47734.023339] audit: type=1131 audit(1613533566.774:499): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48023.669199] audit: type=1130 audit(1613533856.421:500): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48034.017310] audit: type=1131 audit(1613533866.768:501): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48323.637711] audit: type=1130 audit(1613534156.388:502): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48334.017186] audit: type=1131 audit(1613534166.768:503): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48623.665499] audit: type=1130 audit(1613534456.414:504): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48634.021876] audit: type=1131 audit(1613534466.771:505): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48923.667115] audit: type=1130 audit(1613534756.418:506): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48934.023422] audit: type=1131 audit(1613534766.774:507): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49223.670955] audit: type=1130 audit(1613535056.421:508): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49234.021990] audit: type=1131 audit(1613535066.771:509): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49523.669362] audit: type=1130 audit(1613535356.421:510): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49534.016909] audit: type=1131 audit(1613535366.768:511): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49823.664926] audit: type=1130 audit(1613535656.414:512): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49834.017561] audit: type=1131 audit(1613535666.768:513): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50123.624791] audit: type=1130 audit(1613535956.374:514): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50134.018299] audit: type=1131 audit(1613535966.768:515): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50423.659518] audit: type=1130 audit(1613536256.411:516): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50434.021402] audit: type=1131 audit(1613536266.771:517): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50723.619187] audit: type=1130 audit(1613536556.371:518): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50734.024359] audit: type=1131 audit(1613536566.774:519): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51023.659729] audit: type=1130 audit(1613536856.411:520): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51034.016623] audit: type=1131 audit(1613536866.768:521): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51323.646223] audit: type=1130 audit(1613537156.398:522): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51334.020344] audit: type=1131 audit(1613537166.771:523): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51623.660648] audit: type=1130 audit(1613537456.411:524): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51634.024750] audit: type=1131 audit(1613537466.774:525): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51923.662591] audit: type=1130 audit(1613537756.414:526): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51934.022338] audit: type=1131 audit(1613537766.774:527): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52223.643313] audit: type=1130 audit(1613538056.394:528): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52234.023444] audit: type=1131 audit(1613538066.774:529): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52523.660982] audit: type=1130 audit(1613538356.411:530): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52534.022121] audit: type=1131 audit(1613538366.774:531): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52823.661652] audit: type=1130 audit(1613538656.414:532): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[52834.022079] audit: type=1131 audit(1613538666.774:533): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53123.662694] audit: type=1130 audit(1613538956.414:534): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53134.019810] audit: type=1131 audit(1613538966.771:535): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53423.662457] audit: type=1130 audit(1613539256.414:536): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53434.020118] audit: type=1131 audit(1613539266.771:537): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53723.661730] audit: type=1130 audit(1613539556.414:538): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53734.017696] audit: type=1131 audit(1613539566.768:539): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54023.669344] audit: type=1130 audit(1613539856.421:540): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54034.018998] audit: type=1131 audit(1613539866.771:541): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54323.670301] audit: type=1130 audit(1613540156.421:542): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54334.015944] audit: type=1131 audit(1613540166.768:543): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54623.670111] audit: type=1130 audit(1613540456.421:544): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54634.019383] audit: type=1131 audit(1613540466.771:545): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54923.672373] audit: type=1130 audit(1613540756.424:546): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[54934.015677] audit: type=1131 audit(1613540766.768:547): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55223.670236] audit: type=1130 audit(1613541056.421:548): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55234.022593] audit: type=1131 audit(1613541066.774:549): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55523.671797] audit: type=1130 audit(1613541356.424:550): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55534.019696] audit: type=1131 audit(1613541366.771:551): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55823.670746] audit: type=1130 audit(1613541656.424:552): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55834.021323] audit: type=1131 audit(1613541666.774:553): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55876.571137] audit: type=1100 audit(1613541709.324:554): pid=2532123 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="infiniter" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
[55884.435773] audit: type=1100 audit(1613541717.188:555): pid=2532506 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="infiniter" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[56123.627391] audit: type=1130 audit(1613541956.381:556): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56134.021280] audit: type=1131 audit(1613541966.774:557): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56423.665879] audit: type=1130 audit(1613542256.418:558): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56426.654164] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=29096 end=29097) time 299 us, min 1073, max 1079, scanline start 1071, end 1092
[56434.022671] audit: type=1131 audit(1613542266.774:559): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56723.669023] audit: type=1130 audit(1613542556.421:560): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56734.022760] audit: type=1131 audit(1613542566.774:561): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56741.136775] audit: type=1100 audit(1613542573.888:562): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="infiniter" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56741.140840] audit: type=1101 audit(1613542573.894:563): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="infiniter" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56741.141412] audit: type=1110 audit(1613542573.894:564): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56741.147138] audit: type=1105 audit(1613542573.901:565): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56741.207200] audit: type=1106 audit(1613542573.961:566): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56741.207307] audit: type=1104 audit(1613542573.961:567): pid=2580562 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56760.305677] audit: type=1101 audit(1613542593.058:568): pid=2581553 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="infiniter" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56760.306263] audit: type=1110 audit(1613542593.058:569): pid=2581553 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
[56760.310937] audit: type=1105 audit(1613542593.064:570): pid=2581553 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/13 res=success'
/var/log/Xorg.0.log
[     7.882]
X.Org X Server 1.20.10
[     7.882] Build Operating System: Linux Manjaro Linux
[     7.882] Current Operating System: Linux infiniter 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[     7.882] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=8513fb06-c454-42cc-877d-9f4b860ba3bf ro quiet resume=UUID=e00b5f20-d594-4929-8703-f0bb2e45b88b udev.log_priority=3
[     7.882] Build Date: 16 December 2020  10:33:32PM
[     7.882]
[     7.882] Current version of pixman: 0.40.0
[     7.882] 	Before reporting problems, check http://wiki.x.org
[     7.882] Markers: (--) probed, (**) from config file, (==) default setting,
[     7.882] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 16 15:30:40 2021
[     7.882] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     7.882] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     7.883] (==) No Layout section.  Using the first Screen section.
[     7.883] (==) No screen section available. Using defaults.
[     7.883] (**) |-->Screen "Default Screen Section" (0)
[     7.883] (**) |   |-->Monitor "<default monitor>"
[     7.883] (==) No monitor specified for screen "Default Screen Section".
[     7.883] (==) Automatically adding devices
[     7.884] (==) Automatically enabling devices
[     7.884] (==) Automatically adding GPU devices
[     7.884] (==) Automatically binding GPU devices
[     7.884] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     7.884] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     7.884] 	Entry deleted from font path.
[     7.884] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     7.884] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     7.884] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     7.884] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     7.884] (==) ModulePath set to "/usr/lib/xorg/modules"
[     7.884] (II) The server relies on udev to provide the list of input devices.
[     7.884] (II) Module ABI versions:
[     7.884] 	X.Org ANSI C Emulation: 0.4
[     7.884] 	X.Org Video Driver: 24.1
[     7.884] 	X.Org XInput driver : 24.1
[     7.884] 	X.Org Server Extension : 10.0
[     7.886] (++) using VT number 7
[     7.886] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     7.888] (II) xfree86: Adding drm device (/dev/dri/card1)
[     7.889] (II) xfree86: Adding drm device (/dev/dri/card0)
[     7.909] (--) PCI:*(0@0:2:0) 8086:3e9b:1028:087c rev 0, Mem @ 0xeb000000/16777216, 0x80000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[     7.909] (--) PCI: (1@0:0:0) 10de:1c8c:1028:087c rev 161, Mem @ 0xec000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[     7.910] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     7.910] (II) LoadModule: "glx"
[     7.910] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     7.913] (II) Module glx: vendor="X.Org Foundation"
[     7.913] 	compiled for 1.20.10, module version = 1.0.0
[     7.913] 	ABI class: X.Org Server Extension, version 10.0
[     7.913] (==) Matched intel as autoconfigured driver 0
[     7.913] (==) Matched nouveau as autoconfigured driver 1
[     7.913] (==) Matched nv as autoconfigured driver 2
[     7.913] (==) Matched modesetting as autoconfigured driver 3
[     7.913] (==) Matched fbdev as autoconfigured driver 4
[     7.913] (==) Matched vesa as autoconfigured driver 5
[     7.913] (==) Assigned the driver to the xf86ConfigLayout
[     7.914] (II) LoadModule: "intel"
[     7.914] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     7.914] (II) Module intel: vendor="X.Org Foundation"
[     7.914] 	compiled for 1.20.10, module version = 2.99.917
[     7.914] 	Module class: X.Org Video Driver
[     7.914] 	ABI class: X.Org Video Driver, version 24.1
[     7.914] (II) LoadModule: "nouveau"
[     7.915] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     7.916] (II) Module nouveau: vendor="X.Org Foundation"
[     7.916] 	compiled for 1.20.10, module version = 1.0.17
[     7.916] 	Module class: X.Org Video Driver
[     7.916] 	ABI class: X.Org Video Driver, version 24.1
[     7.916] (II) LoadModule: "nv"
[     7.917] (WW) Warning, couldn't open module nv
[     7.917] (EE) Failed to load module "nv" (module does not exist, 0)
[     7.917] (II) LoadModule: "modesetting"
[     7.917] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     7.918] (II) Module modesetting: vendor="X.Org Foundation"
[     7.918] 	compiled for 1.20.10, module version = 1.20.10
[     7.918] 	Module class: X.Org Video Driver
[     7.918] 	ABI class: X.Org Video Driver, version 24.1
[     7.918] (II) LoadModule: "fbdev"
[     7.918] (WW) Warning, couldn't open module fbdev
[     7.918] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     7.918] (II) LoadModule: "vesa"
[     7.918] (WW) Warning, couldn't open module vesa
[     7.918] (EE) Failed to load module "vesa" (module does not exist, 0)
[     7.918] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     7.919] (II) intel: Driver for Intel(R) HD Graphics
[     7.919] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     7.919] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     7.919] (II) NOUVEAU driver
[     7.919] (II) NOUVEAU driver for NVIDIA chipset families :
[     7.919] 	RIVA TNT            (NV04)
[     7.919] 	RIVA TNT2           (NV05)
[     7.920] 	GeForce 256         (NV10)
[     7.920] 	GeForce 2           (NV11, NV15)
[     7.920] 	GeForce 4MX         (NV17, NV18)
[     7.920] 	GeForce 3           (NV20)
[     7.920] 	GeForce 4Ti         (NV25, NV28)
[     7.920] 	GeForce FX          (NV3x)
[     7.920] 	GeForce 6           (NV4x)
[     7.920] 	GeForce 7           (G7x)
[     7.920] 	GeForce 8           (G8x)
[     7.920] 	GeForce 9           (G9x)
[     7.920] 	GeForce GTX 2xx/3xx (GT2xx)
[     7.920] 	GeForce GTX 4xx/5xx (GFxxx)
[     7.920] 	GeForce GTX 6xx/7xx (GKxxx)
[     7.920] 	GeForce GTX 9xx     (GMxxx)
[     7.920] 	GeForce GTX 10xx    (GPxxx)
[     7.920] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     7.921] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200715
[     7.921] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[     7.937] (WW) Falling back to old probe method for modesetting
[     7.937] (II) [drm] nouveau interface version: 1.3.1
[     7.938] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[     7.938] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 6 threads
[     7.938] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     7.938] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     7.938] (==) intel(0): RGB weight 888
[     7.938] (==) intel(0): Default visual is TrueColor
[     7.938] (II) intel(0): Output eDP1 has no monitor section
[     7.939] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[     7.939] (II) intel(0): Enabled output eDP1
[     7.939] (II) intel(0): Output DP1 has no monitor section
[     7.939] (II) intel(0): Enabled output DP1
[     7.939] (II) intel(0): Output DP2 has no monitor section
[     7.939] (II) intel(0): Enabled output DP2
[     7.939] (II) intel(0): Output DP3 has no monitor section
[     7.939] (II) intel(0): Enabled output DP3
[     7.939] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     7.939] (II) intel(0): Output VIRTUAL1 has no monitor section
[     7.939] (II) intel(0): Enabled output VIRTUAL1
[     7.940] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[     7.940] (--) intel(0): Output DP1 using initial mode 1920x1080 on pipe 1
[     7.940] (--) intel(0): Output DP3 using initial mode 1920x1080 on pipe 2
[     7.940] (==) intel(0): TearFree enabled
[     7.940] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     7.940] (==) intel(0): DPI set to (96, 96)
[     7.940] (II) Loading sub module "dri3"
[     7.940] (II) LoadModule: "dri3"
[     7.940] (II) Module "dri3" already built-in
[     7.940] (II) Loading sub module "dri2"
[     7.940] (II) LoadModule: "dri2"
[     7.940] (II) Module "dri2" already built-in
[     7.940] (II) Loading sub module "present"
[     7.940] (II) LoadModule: "present"
[     7.940] (II) Module "present" already built-in
[     7.940] (--) NOUVEAU(G0): Chipset: "NVIDIA NV137"
[     7.940] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
[     7.940] (==) NOUVEAU(G0): RGB weight 888
[     7.940] (==) NOUVEAU(G0): Default visual is TrueColor
[     7.940] (==) NOUVEAU(G0): Using HW cursor
[     7.940] (==) NOUVEAU(G0): Allowed maximum DRI level 2.
[     7.940] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[     7.940] (==) NOUVEAU(G0): Page flipping enabled
[     7.940] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[     7.940] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[     7.940] (==) NOUVEAU(G0): Using gamma correction (1.0, 1.0, 1.0)
[     7.940] (II) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[     7.940] (**) NOUVEAU(G0):  Mode "1920x1080": 173.0 MHz (scaled from 0.0 MHz), 67.2 kHz, 60.0 Hz
[     7.940] (II) NOUVEAU(G0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz)
[     7.940] (==) NOUVEAU(G0): DPI set to (96, 96)
[     7.940] (II) Loading sub module "fb"
[     7.940] (II) LoadModule: "fb"
[     7.940] (II) Loading /usr/lib/xorg/modules/libfb.so
[     7.940] (II) Module fb: vendor="X.Org Foundation"
[     7.940] 	compiled for 1.20.10, module version = 1.0.0
[     7.940] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     7.940] (II) Loading sub module "shadowfb"
[     7.940] (II) LoadModule: "shadowfb"
[     7.941] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[     7.941] (II) Module shadowfb: vendor="X.Org Foundation"
[     7.941] 	compiled for 1.20.10, module version = 1.0.0
[     7.941] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     7.941] (II) UnloadModule: "modesetting"
[     7.941] (II) Unloading modesetting
[     7.941] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[     7.941] (==) intel(0): Backing store enabled
[     7.941] (==) intel(0): Silken mouse disabled
[     7.941] (II) intel(0): HW Cursor enabled
[     7.942] (==) intel(0): DPMS enabled
[     7.942] (==) intel(0): Display hotplug detection enabled
[     7.942] (II) intel(0): [DRI2] Setup complete
[     7.942] (II) intel(0): [DRI2]   DRI driver: i965
[     7.942] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     7.942] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     7.942] (II) intel(0): hardware support for Present enabled
[     8.008] (II) NOUVEAU(G0): Channel setup complete.
[     8.008] (II) NOUVEAU(G0): [COPY] async initialised.
[     8.008] (II) NOUVEAU(G0): Hardware support for Present enabled
[     8.008] (II) NOUVEAU(G0): [DRI2] Setup complete
[     8.009] (II) NOUVEAU(G0): [DRI2]   DRI driver: nouveau
[     8.009] (II) NOUVEAU(G0): [DRI2]   VDPAU driver: nouveau
[     8.009] (II) Loading sub module "exa"
[     8.009] (II) LoadModule: "exa"
[     8.009] (II) Loading /usr/lib/xorg/modules/libexa.so
[     8.010] (II) Module exa: vendor="X.Org Foundation"
[     8.010] 	compiled for 1.20.10, module version = 2.6.0
[     8.010] 	ABI class: X.Org Video Driver, version 24.1
[     8.010] (II) EXA(256): Driver allocated offscreen pixmaps
[     8.010] (II) EXA(256): Driver registered support for the following operations:
[     8.010] (II)         Solid
[     8.010] (II)         Copy
[     8.010] (II)         Composite (RENDER acceleration)
[     8.010] (II)         UploadToScreen
[     8.010] (II)         DownloadFromScreen
[     8.010] (==) NOUVEAU(G0): Backing store enabled
[     8.010] (==) NOUVEAU(G0): Silken mouse disabled
[     8.010] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[     8.010] (II) NOUVEAU(G0): [XvMC] Extension initialized.
[     8.010] (==) NOUVEAU(G0): DPMS enabled
[     8.010] (II) Initializing extension Generic Event Extension
[     8.011] (II) Initializing extension SHAPE
[     8.011] (II) Initializing extension MIT-SHM
[     8.011] (II) Initializing extension XInputExtension
[     8.012] (II) Initializing extension XTEST
[     8.012] (II) Initializing extension BIG-REQUESTS
[     8.012] (II) Initializing extension SYNC
[     8.013] (II) Initializing extension XKEYBOARD
[     8.013] (II) Initializing extension XC-MISC
[     8.013] (II) Initializing extension SECURITY
[     8.014] (II) Initializing extension XFIXES
[     8.014] (II) Initializing extension RENDER
[     8.014] (II) Initializing extension RANDR
[     8.015] (II) Initializing extension COMPOSITE
[     8.015] (II) Initializing extension DAMAGE
[     8.016] (II) Initializing extension MIT-SCREEN-SAVER
[     8.016] (II) Initializing extension DOUBLE-BUFFER
[     8.016] (II) Initializing extension RECORD
[     8.017] (II) Initializing extension DPMS
[     8.017] (II) Initializing extension Present
[     8.017] (II) Initializing extension DRI3
[     8.017] (II) Initializing extension X-Resource
[     8.018] (II) Initializing extension XVideo
[     8.018] (II) Initializing extension XVideo-MotionCompensation
[     8.018] (II) Initializing extension GLX
[     8.040] (II) AIGLX: Loaded and initialized i965
[     8.040] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.040] (II) Initializing extension XFree86-VidModeExtension
[     8.040] (II) Initializing extension XFree86-DGA
[     8.040] (II) Initializing extension XFree86-DRI
[     8.040] (II) Initializing extension DRI2
[     8.041] (II) NOUVEAU(G0): NVEnterVT is called.
[     8.045] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     8.050] (II) intel(0): switch to mode 1920x1080@60.0 on DP1 using pipe 1, position (0, 0), rotation normal, reflection none
[     8.063] (II) intel(0): switch to mode 1920x1080@60.0 on DP3 using pipe 2, position (0, 0), rotation normal, reflection none
[     8.075] (II) intel(0): Setting screen physical size to 508 x 285
[     8.101] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     8.101] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.101] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.101] (**) Power Button: Applying InputClass "system-keyboard"
[     8.101] (II) LoadModule: "libinput"
[     8.101] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.102] (II) Module libinput: vendor="X.Org Foundation"
[     8.102] 	compiled for 1.20.8, module version = 0.30.0
[     8.102] 	Module class: X.Org XInput Driver
[     8.102] 	ABI class: X.Org XInput driver, version 24.1
[     8.102] (II) Using input driver 'libinput' for 'Power Button'
[     8.102] (**) Power Button: always reports core events
[     8.102] (**) Option "Device" "/dev/input/event3"
[     8.102] (**) Option "_source" "server/udev"
[     8.103] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     8.103] (II) event3  - Power Button: device is a keyboard
[     8.103] (II) event3  - Power Button: device removed
[     8.153] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[     8.153] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.153] (**) Option "xkb_layout" "us"
[     8.154] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     8.154] (II) event3  - Power Button: device is a keyboard
[     8.155] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[     8.155] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.155] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.155] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.155] (II) Using input driver 'libinput' for 'Video Bus'
[     8.155] (**) Video Bus: always reports core events
[     8.155] (**) Option "Device" "/dev/input/event11"
[     8.155] (**) Option "_source" "server/udev"
[     8.156] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     8.156] (II) event11 - Video Bus: device is a keyboard
[     8.156] (II) event11 - Video Bus: device removed
[     8.210] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input17/event11"
[     8.210] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     8.210] (**) Option "xkb_layout" "us"
[     8.213] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     8.213] (II) event11 - Video Bus: device is a keyboard
[     8.215] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[     8.215] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.215] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.215] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.215] (II) Using input driver 'libinput' for 'Video Bus'
[     8.215] (**) Video Bus: always reports core events
[     8.215] (**) Option "Device" "/dev/input/event12"
[     8.215] (**) Option "_source" "server/udev"
[     8.219] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[     8.220] (II) event12 - Video Bus: device is a keyboard
[     8.220] (II) event12 - Video Bus: device removed
[     8.287] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input18/event12"
[     8.287] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     8.287] (**) Option "xkb_layout" "us"
[     8.290] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[     8.291] (II) event12 - Video Bus: device is a keyboard
[     8.292] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.293] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.293] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.293] (**) Power Button: Applying InputClass "system-keyboard"
[     8.293] (II) Using input driver 'libinput' for 'Power Button'
[     8.293] (**) Power Button: always reports core events
[     8.293] (**) Option "Device" "/dev/input/event1"
[     8.293] (**) Option "_source" "server/udev"
[     8.295] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.295] (II) event1  - Power Button: device is a keyboard
[     8.295] (II) event1  - Power Button: device removed
[     8.330] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     8.330] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     8.330] (**) Option "xkb_layout" "us"
[     8.333] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.333] (II) event1  - Power Button: device is a keyboard
[     8.335] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     8.335] (II) No input driver specified, ignoring this device.
[     8.335] (II) This device may have been added with another device file.
[     8.337] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[     8.337] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     8.337] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     8.337] (**) Sleep Button: Applying InputClass "system-keyboard"
[     8.337] (II) Using input driver 'libinput' for 'Sleep Button'
[     8.337] (**) Sleep Button: always reports core events
[     8.337] (**) Option "Device" "/dev/input/event2"
[     8.337] (**) Option "_source" "server/udev"
[     8.339] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[     8.339] (II) event2  - Sleep Button: device is a keyboard
[     8.340] (II) event2  - Sleep Button: device removed
[     8.370] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[     8.370] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[     8.370] (**) Option "xkb_layout" "us"
[     8.373] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[     8.373] (II) event2  - Sleep Button: device is a keyboard
[     8.375] (II) config/udev: Adding input device DP-1 (/dev/input/event13)
[     8.375] (**) DP-1: Applying InputClass "evdev keyboard catchall"
[     8.375] (**) DP-1: Applying InputClass "libinput keyboard catchall"
[     8.375] (**) DP-1: Applying InputClass "system-keyboard"
[     8.375] (II) Using input driver 'libinput' for 'DP-1'
[     8.375] (**) DP-1: always reports core events
[     8.375] (**) Option "Device" "/dev/input/event13"
[     8.375] (**) Option "_source" "server/udev"
[     8.375] (II) event13 - DP-1: is tagged by udev as: Keyboard Pointingstick
[     8.375] (II) event13 - DP-1: device is a pointer
[     8.375] (II) event13 - DP-1: device is a keyboard
[     8.376] (II) event13 - DP-1: device removed
[     8.390] (II) libinput: DP-1: needs a virtual subdevice
[     8.390] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc0/input19/event13"
[     8.390] (II) XINPUT: Adding extended input device "DP-1" (type: MOUSE, id 11)
[     8.390] (**) Option "AccelerationScheme" "none"
[     8.390] (**) DP-1: (accel) selected scheme none/0
[     8.390] (**) DP-1: (accel) acceleration factor: 2.000
[     8.390] (**) DP-1: (accel) acceleration threshold: 4
[     8.391] (II) event13 - DP-1: is tagged by udev as: Keyboard Pointingstick
[     8.391] (II) event13 - DP-1: device is a pointer
[     8.391] (II) event13 - DP-1: device is a keyboard
[     8.391] (II) config/udev: Adding input device DP-3 (/dev/input/event14)
[     8.391] (**) DP-3: Applying InputClass "evdev keyboard catchall"
[     8.391] (**) DP-3: Applying InputClass "libinput keyboard catchall"
[     8.391] (**) DP-3: Applying InputClass "system-keyboard"
[     8.391] (II) Using input driver 'libinput' for 'DP-3'
[     8.391] (**) DP-3: always reports core events
[     8.392] (**) Option "Device" "/dev/input/event14"
[     8.392] (**) Option "_source" "server/udev"
[     8.392] (II) event14 - DP-3: is tagged by udev as: Keyboard Pointingstick
[     8.392] (II) event14 - DP-3: device is a pointer
[     8.392] (II) event14 - DP-3: device is a keyboard
[     8.393] (II) event14 - DP-3: device removed
[     8.436] (II) libinput: DP-3: needs a virtual subdevice
[     8.437] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc1/input20/event14"
[     8.437] (II) XINPUT: Adding extended input device "DP-3" (type: MOUSE, id 12)
[     8.437] (**) Option "AccelerationScheme" "none"
[     8.437] (**) DP-3: (accel) selected scheme none/0
[     8.437] (**) DP-3: (accel) acceleration factor: 2.000
[     8.437] (**) DP-3: (accel) acceleration threshold: 4
[     8.438] (II) event14 - DP-3: is tagged by udev as: Keyboard Pointingstick
[     8.438] (II) event14 - DP-3: device is a pointer
[     8.438] (II) event14 - DP-3: device is a keyboard
[     8.440] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event16)
[     8.440] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[     8.440] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[     8.440] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[     8.440] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[     8.440] (**) Integrated_Webcam_HD: Integrate: always reports core events
[     8.440] (**) Option "Device" "/dev/input/event16"
[     8.440] (**) Option "_source" "server/udev"
[     8.442] (II) event16 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[     8.442] (II) event16 - Integrated_Webcam_HD: Integrate: device is a keyboard
[     8.443] (II) event16 - Integrated_Webcam_HD: Integrate: device removed
[     8.491] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input22/event16"
[     8.491] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 13)
[     8.491] (**) Option "xkb_layout" "us"
[     8.495] (II) event16 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[     8.495] (II) event16 - Integrated_Webcam_HD: Integrate: device is a keyboard
[     8.498] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event23)
[     8.498] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     8.498] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     8.499] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     8.499] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     8.499] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     8.499] (**) Option "Device" "/dev/input/event23"
[     8.499] (**) Option "_source" "server/udev"
[     8.504] (II) event23 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     8.504] (II) event23 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     8.505] (II) event23 - Logitech Wireless Keyboard PID:4023: device removed
[     8.537] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[     8.537] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input45/event23"
[     8.537] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 14)
[     8.537] (**) Option "AccelerationScheme" "none"
[     8.537] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[     8.537] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[     8.537] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[     8.542] (II) event23 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     8.542] (II) event23 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     8.546] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event19)
[     8.546] (**) Logitech Wireless Mouse: Applying InputClass "evdev pointer catchall"
[     8.546] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[     8.546] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[     8.546] (**) Logitech Wireless Mouse: always reports core events
[     8.546] (**) Option "Device" "/dev/input/event19"
[     8.546] (**) Option "_source" "server/udev"
[     8.550] (II) event19 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     8.551] (II) event19 - Logitech Wireless Mouse: device is a pointer
[     8.551] (II) event19 - Logitech Wireless Mouse: device removed
[     8.610] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4058.0005/input/input46/event19"
[     8.610] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 15)
[     8.610] (**) Option "AccelerationScheme" "none"
[     8.610] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[     8.610] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[     8.610] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[     8.615] (II) event19 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     8.615] (II) event19 - Logitech Wireless Mouse: device is a pointer
[     8.618] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse2)
[     8.618] (II) No input driver specified, ignoring this device.
[     8.618] (II) This device may have been added with another device file.
[     8.622] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Mouse (/dev/input/event9)
[     8.622] (**) SYNA2393:00 06CB:7A13 Mouse: Applying InputClass "evdev pointer catchall"
[     8.622] (**) SYNA2393:00 06CB:7A13 Mouse: Applying InputClass "libinput pointer catchall"
[     8.622] (II) Using input driver 'libinput' for 'SYNA2393:00 06CB:7A13 Mouse'
[     8.622] (**) SYNA2393:00 06CB:7A13 Mouse: always reports core events
[     8.622] (**) Option "Device" "/dev/input/event9"
[     8.622] (**) Option "_source" "server/udev"
[     8.626] (II) event9  - SYNA2393:00 06CB:7A13 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.627] (II) event9  - SYNA2393:00 06CB:7A13 Mouse: device is a pointer
[     8.629] (II) event9  - SYNA2393:00 06CB:7A13 Mouse: device removed
[     8.703] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input14/event9"
[     8.703] (II) XINPUT: Adding extended input device "SYNA2393:00 06CB:7A13 Mouse" (type: MOUSE, id 16)
[     8.704] (**) Option "AccelerationScheme" "none"
[     8.704] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) selected scheme none/0
[     8.704] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) acceleration factor: 2.000
[     8.704] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) acceleration threshold: 4
[     8.708] (II) event9  - SYNA2393:00 06CB:7A13 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.709] (II) event9  - SYNA2393:00 06CB:7A13 Mouse: device is a pointer
[     8.713] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Mouse (/dev/input/mouse0)
[     8.713] (II) No input driver specified, ignoring this device.
[     8.713] (II) This device may have been added with another device file.
[     8.715] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Touchpad (/dev/input/event10)
[     8.715] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "evdev touchpad catchall"
[     8.715] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "libinput touchpad catchall"
[     8.715] (II) Using input driver 'libinput' for 'SYNA2393:00 06CB:7A13 Touchpad'
[     8.715] (**) SYNA2393:00 06CB:7A13 Touchpad: always reports core events
[     8.715] (**) Option "Device" "/dev/input/event10"
[     8.715] (**) Option "_source" "server/udev"
[     8.720] (II) event10 - SYNA2393:00 06CB:7A13 Touchpad: is tagged by udev as: Touchpad
[     8.724] (II) event10 - SYNA2393:00 06CB:7A13 Touchpad: device is a touchpad
[     8.724] (II) event10 - SYNA2393:00 06CB:7A13 Touchpad: device removed
[     8.784] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0001/input/input15/event10"
[     8.784] (II) XINPUT: Adding extended input device "SYNA2393:00 06CB:7A13 Touchpad" (type: TOUCHPAD, id 17)
[     8.788] (**) Option "AccelerationScheme" "none"
[     8.788] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) selected scheme none/0
[     8.788] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) acceleration factor: 2.000
[     8.788] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) acceleration threshold: 4
[     8.792] (II) event10 - SYNA2393:00 06CB:7A13 Touchpad: is tagged by udev as: Touchpad
[     8.796] (II) event10 - SYNA2393:00 06CB:7A13 Touchpad: device is a touchpad
[     8.799] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Touchpad (/dev/input/mouse1)
[     8.799] (II) No input driver specified, ignoring this device.
[     8.799] (II) This device may have been added with another device file.
[     8.800] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event15)
[     8.801] (II) No input driver specified, ignoring this device.
[     8.801] (II) This device may have been added with another device file.
[     8.802] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event20)
[     8.802] (II) No input driver specified, ignoring this device.
[     8.802] (II) This device may have been added with another device file.
[     8.804] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event17)
[     8.804] (II) No input driver specified, ignoring this device.
[     8.804] (II) This device may have been added with another device file.
[     8.805] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event18)
[     8.805] (II) No input driver specified, ignoring this device.
[     8.805] (II) This device may have been added with another device file.
[     8.806] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event21)
[     8.806] (II) No input driver specified, ignoring this device.
[     8.806] (II) This device may have been added with another device file.
[     8.807] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event22)
[     8.807] (II) No input driver specified, ignoring this device.
[     8.807] (II) This device may have been added with another device file.
[     8.807] (II) config/udev: Adding input device Intel HID events (/dev/input/event5)
[     8.807] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[     8.807] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[     8.807] (**) Intel HID events: Applying InputClass "system-keyboard"
[     8.807] (II) Using input driver 'libinput' for 'Intel HID events'
[     8.807] (**) Intel HID events: always reports core events
[     8.807] (**) Option "Device" "/dev/input/event5"
[     8.807] (**) Option "_source" "server/udev"
[     8.808] (II) event5  - Intel HID events: is tagged by udev as: Keyboard
[     8.808] (II) event5  - Intel HID events: device is a keyboard
[     8.808] (II) event5  - Intel HID events: device removed
[     8.850] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input6/event5"
[     8.850] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 18)
[     8.850] (**) Option "xkb_layout" "us"
[     8.851] (II) event5  - Intel HID events: is tagged by udev as: Keyboard
[     8.851] (II) event5  - Intel HID events: device is a keyboard
[     8.851] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event6)
[     8.851] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[     8.851] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[     8.851] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[     8.851] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[     8.851] (**) Intel HID 5 button array: always reports core events
[     8.851] (**) Option "Device" "/dev/input/event6"
[     8.851] (**) Option "_source" "server/udev"
[     8.852] (II) event6  - Intel HID 5 button array: is tagged by udev as: Keyboard
[     8.852] (II) event6  - Intel HID 5 button array: device is a keyboard
[     8.852] (II) event6  - Intel HID 5 button array: device removed
[     8.886] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input7/event6"
[     8.886] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 19)
[     8.886] (**) Option "xkb_layout" "us"
[     8.887] (II) event6  - Intel HID 5 button array: is tagged by udev as: Keyboard
[     8.887] (II) event6  - Intel HID 5 button array: device is a keyboard
[     8.888] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[     8.888] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     8.888] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     8.888] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[     8.888] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[     8.888] (**) Dell WMI hotkeys: always reports core events
[     8.888] (**) Option "Device" "/dev/input/event8"
[     8.888] (**) Option "_source" "server/udev"
[     8.889] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[     8.889] (II) event8  - Dell WMI hotkeys: device is a keyboard
[     8.890] (II) event8  - Dell WMI hotkeys: device removed
[     8.953] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input10/event8"
[     8.953] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 20)
[     8.953] (**) Option "xkb_layout" "us"
[     8.958] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[     8.958] (II) event8  - Dell WMI hotkeys: device is a keyboard
[     8.961] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[     8.961] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     8.961] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     8.961] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     8.961] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     8.961] (**) AT Translated Set 2 keyboard: always reports core events
[     8.961] (**) Option "Device" "/dev/input/event4"
[     8.961] (**) Option "_source" "server/udev"
[     8.964] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     8.964] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     8.968] (II) event4  - AT Translated Set 2 keyboard: device removed
[     9.004] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[     9.004] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 21)
[     9.004] (**) Option "xkb_layout" "us"
[     9.007] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     9.008] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     9.012] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     9.012] (II) No input driver specified, ignoring this device.
[     9.012] (II) This device may have been added with another device file.
[     9.076] (**) DP-1: Applying InputClass "evdev keyboard catchall"
[     9.076] (**) DP-1: Applying InputClass "libinput keyboard catchall"
[     9.076] (**) DP-1: Applying InputClass "system-keyboard"
[     9.076] (II) Using input driver 'libinput' for 'DP-1'
[     9.076] (**) DP-1: always reports core events
[     9.076] (**) Option "Device" "/dev/input/event13"
[     9.076] (**) Option "_source" "_driver/libinput"
[     9.076] (II) libinput: DP-1: is a virtual subdevice
[     9.076] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc0/input19/event13"
[     9.076] (II) XINPUT: Adding extended input device "DP-1" (type: KEYBOARD, id 22)
[     9.076] (**) Option "xkb_layout" "us"
[     9.076] (**) DP-3: Applying InputClass "evdev keyboard catchall"
[     9.076] (**) DP-3: Applying InputClass "libinput keyboard catchall"
[     9.076] (**) DP-3: Applying InputClass "system-keyboard"
[     9.076] (II) Using input driver 'libinput' for 'DP-3'
[     9.076] (**) DP-3: always reports core events
[     9.076] (**) Option "Device" "/dev/input/event14"
[     9.076] (II) libinput: DP-3: is a virtual subdevice
[     9.076] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc1/input20/event14"
[     9.076] (II) XINPUT: Adding extended input device "DP-3" (type: KEYBOARD, id 23)
[     9.076] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     9.076] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     9.076] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     9.076] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     9.076] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     9.076] (**) Option "Device" "/dev/input/event23"
[     9.076] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[     9.076] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0003/0003:046D:4023.0004/input/input45/event23"
[     9.076] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 24)
[     9.943] (II) intel(0): EDID vendor "SHP", prod id 5274
[     9.943] (II) intel(0): Printing DDC gathered Modelines:
[     9.943] (II) intel(0): Modeline "1920x1080"x0.0  142.52  1920 1968 2000 2080  1080 1083 1088 1142 -hsync -vsync (68.5 kHz eP)
[    18.343] (II) intel(0): resizing framebuffer to 5760x1080
[    18.395] (II) intel(0): switch to mode 1920x1080@60.0 on DP1 using pipe 1, position (1920, 0), rotation normal, reflection none
[    18.430] (II) intel(0): switch to mode 1920x1080@60.0 on DP3 using pipe 2, position (3840, 0), rotation normal, reflection none
[    24.541] (EE) event23 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 31ms, your system is too slow
[   265.613] (EE) event23 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 30ms, your system is too slow
[ 56412.556] (EE) event23 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 22ms, your system is too slow
currently trying to disable “usb autosuspend” …because my keyboard/mouse appear to have this lag both, and both of them are connected via single wireless usb. Maybe that will be the culprit but its still strange because it wasnt happening. I will report on my findings in couple days
so usb autosuspend didnt change it, because just now it happened anyway …i noticed this appearing in the Xorg log. Do you know why would that happen? It is wireless keyboard+mouse through one usb input.
[   251.115] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 12ms, your system is too slow
[   341.628] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 11ms, your system is too slow
[   570.444] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 31ms, your system is too slow
[   903.754] (EE) client bug: timer event24 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  1579.572] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 19ms, your system is too slow
[  2085.268] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 19ms, your system is too slow
[  2085.268] (EE) event16 - Logitech Wireless Keyboard PID:4023: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  4457.389] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 33ms, your system is too slow
[  6821.823] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 34ms, your system is too slow
[  7081.311] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 28ms, your system is too slow
[  7095.727] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 14ms, your system is too slow
[  7132.239] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 16ms, your system is too slow
[  7132.239] (EE) event16 - Logitech Wireless Keyboard PID:4023: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  8603.383] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 18ms, your system is too slow
[  8793.040] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 21ms, your system is too slow
[  8860.392] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 20ms, your system is too slow
[ 10022.216] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 14ms, your system is too slow
[ 10998.841] (EE) event16 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 15ms, your system is too slow
[ 10998.841] (EE) event16 - Logitech Wireless Keyboard PID:4023: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
I would install the proprietary NVIDIA driver.
Open Manjaro Settings Manager > Hardware Configuration and click the Auto Install Proprietary Driver button.
Thank you but this is not the solution, I already tried it and result was the same…What appears to be my issue is what is visible in the Xorg log.
this is constantly appearing there and it correlates with my issues. So basically I need to understand how this happens. What I felt like is most likely the issue was “usb suspend” but I did this and it didnt help either (maybe I did mistake but unlikely):
I created /etc/udev/rules.d/50-usb_power_save.rules with the following content
ACTION=="add", SUBSYSTEM=="usb", TEST=="power/control", ATTR{power/control}="on"
Try it again and…
Can you please elaborate? I am using bspwm, running commands in terminals. Only thing that matches “nvidia settings” is nvidia-settings program but it doesnt have any X Server Settings so I m kinda lost there (tried my user as well as root). I would add screenshot but for some reason I cant figure way to attach screenshot here …it has sections:
  • GPU 0
  • Application Profiles
  • nvidia-settings Configuration
Every time I enable “prime hybrid” (that manjaro-settings-manager proprietary option enables) I see it being noticeably slower on videos or even my GPU-accelerated terminal seems to be slower so I would prefer not using those drivers if possible.
I m thinking I didnt disable that usb suspend properly because this is still there (Logitech line)
❯ sudo tlp-stat --usb
[sudo] password for infiniter:
--- TLP 1.3.1 --------------------------------------------
+++ USB
Autosuspend         = enabled
Device whitelist    = (not configured)
Device blacklist    = (not configured)
Bluetooth blacklist = disabled
Phone blacklist     = disabled
WWAN blacklist      = disabled
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 005 ID 27c6:5395 control = auto, autosuspend_delay_ms = 2000 -- Shenzhen Goodix Technology Co.,Ltd. Fingerprint Reader (cdc_acm)
Bus 001 Device 004 ID 0bda:5400 control = auto, autosuspend_delay_ms = 2000 -- Realtek Semiconductor Corp. BillBoard Device (no driver)
Bus 001 Device 003 ID 0cf3:e300 control = auto, autosuspend_delay_ms = 2000 -- Qualcomm Atheros Communications QCA61x4 Bluetooth 4.0 (btusb)
Bus 001 Device 002 ID 046d:c534 control = on,   autosuspend_delay_ms = 2000 -- Logitech, Inc. Unifying Receiver (usbhid)
Bus 001 Device 006 ID 0c45:671d control = auto, autosuspend_delay_ms = 2000 -- Microdia Integrated_Webcam_HD (uvcvideo)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 2.0 root hub (hub)
EDIT: ok my assumption was wrong, disabled it but still getting that same “your system is too slow”
It might not be available when using Prime, I’m not sure.
That isn’t related to the issue so that won’t help.
Do you have some other ideas what could I try? Its so random, sometimes it happens lot sometimes not at all …but when it does, I think next time it spikes I will go for ubuntu usb that is in my drawer for some years. Would be very sad
You’ll probably encounter the same issue as it also happened to me on Pop!_OS. They added a patch to the System76 Driver to enable Force Full Composition Pipeline to fix it.
I would really love to stay with arch-based distro …but if I understood your comment, this is unsolvable now and Pop!OS should allow me to type? This makes me really sad because I m “preaching word of linux” (jk) and I m kinda unable to make it work on close to 2k euro notebook. And its not like something trivial is going wrong, but I m unable to type without looking like parkinson patient …I still hope i m just doing something wrong and someone will come to the rescue.
Maybe, maybe not. Like I said, they added it to the System76 Driver which is only for System76 hardware. All it does is enable Force Composition Pipeline.
Try running glxgears (part of the mesa-demos package) and see if it helps while it’s running. If so, this GNOME extension will probably help:
