after updating to Wynsdey, i can no longer start inkscape as a user but only as root, i get the following error message when starting.
I have already uninstalled and reinstalled it, but that didn’t solve the problem.
Do not post images of text! You can surely copy paste, can you?
Delete ~/.config/inkscape
folder and see if it works.
I forgot to mention that, I’ve already tried it, but unfortunately it doesn’t work either.
Sry…
<pre>
0# Inkscape::Application::crash_handler(int) in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
1# 0x00007450F5A58E20 in /usr/lib/libc.so.6
2# Gdk::Device::get_source() const in /usr/bin/../lib/inkscape/../libgdkmm-3.0.so.1
3# 0x00007450F7472906 in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
4# Inkscape::DeviceManagerImpl::DeviceManagerImpl() in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
5# Inkscape::DeviceManager::getManager() in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
6# Inkscape::Application::Application(bool) in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
7# Inkscape::Application::create(bool) in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
8# InkscapeApplication::on_startup() in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
9# Glib::SignalProxyNormal::slot0_void_callback(_GObject*, void*) in /usr/lib/libglibmm-2.4.so.1
10# g_closure_invoke in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
11# 0x00007450F5213C1B in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
12# 0x00007450F52047A2 in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
13# g_signal_emit_valist in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
14# g_signal_emit in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
15# g_application_register in /usr/bin/../lib/inkscape/../libgio-2.0.so.0
16# 0x00007450F5309AFA in /usr/bin/../lib/inkscape/../libgio-2.0.so.0
17# g_application_run in /usr/bin/../lib/inkscape/../libgio-2.0.so.0
18# main in inkscape
19# 0x00007450F5A41D4A in /usr/lib/libc.so.6
20# __libc_start_main in /usr/lib/libc.so.6
21# _start in inkscape
</pre>
<details><summary>System info</summary>
Inkscape 1.3.2 (091e20ef0f, 2023-11-25, custom)
GLib version: 2.80.0
GTK version: 3.24.41
glibmm version: 2.66.6
gtkmm version: 3.24.8
libxml2 version: 2.12.5
libxslt version: 1.1.39
Cairo version: 1.18.0
Pango version: 1.52.2
HarfBuzz version: 8.4.0
OS version: Manjaro Linux
</details>
~ inkscape Fr 17 Mai 2024 19:29:50 CEST
Emergency save activated!
Emergency save completed. Inkscape will close now.
If you can reproduce this crash, please file a bug at https://inkscape.org/report
with a detailed description of the steps leading to the crash, so we can fix it.
(org.inkscape.Inkscape:28645): Gtk-WARNING **: 19:29:54.242: Failed to set text 'Wenn dieser Absturz reproduzierbar auftritt, <a href="https://inkscape.org/report>melde bitte einen Programmfehler</a> und füge die untenstehenden technischen Informationen über den Fehler in Deine Meldung mit ein.' from markup due to error parsing markup: Fehler in Zeile 1, Zeichen 234: Dokument endete unerwartet innerhalb eines Attributwertes
(org.inkscape.Inkscape:28645): Gtk-WARNING **: 19:29:54.264: Failed to set text 'Wenn dieser Absturz reproduzierbar auftritt, <a href="https://inkscape.org/report>melde bitte einen Programmfehler</a> und füge die untenstehenden technischen Informationen über den Fehler in Deine Meldung mit ein.' from markup due to error parsing markup: Fehler in Zeile 1, Zeichen 234: Dokument endete unerwartet innerhalb eines Attributwertes
Also delete ~/.config/gtk-3.0
Great, thank you very much! That helped and solved the problem. Thank you very much!
Ok, unfortunately it doesn’t really seem to be the solution. It worked exactly once and now I have the same problem again. And the folder ~/.config/gtk-3.0 has not been created again so that I could delete it.
<pre>
1# 0x00007CB098858E20 in /usr/lib/libc.so.6
3# 0x00007CB09A072906 in /usr/bin/../lib/inkscape/libinkscape_base.so.1.3.2.0
11# 0x00007CB097F72C1B in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
12# 0x00007CB097F637A2 in /usr/bin/../lib/inkscape/../libgobject-2.0.so.0
16# 0x00007CB098068AFA in /usr/bin/../lib/inkscape/../libgio-2.0.so.0
19# 0x00007CB098841D4A in /usr/lib/libc.so.6
</pre>
</details>
<pre>
</pre>
</details>
If you use a drawing tablet, see https://gitlab.com/inkscape/inkscape/-/issues/4649
Thanks, that fixed the problem, it was actually due to the connected graphics tablet. I hope that the error will be fixed quickly. Thank you very much.
