Hi,
I have inkscape crashing just after launch on an haswell laptop with manjaro KDE (X11 session). Anyone experiencing something similar? Because it’s the first time that I try inkscape in manjaro I cannot say if this is a regression.
Have you tried this?
Execute inkscape in the terminal to show which error-info.
Looks like the issue is a race, because it seems to be influenced by the current system activity and load.
The application has always been started from the terminal, I tend to prefer to work through the terminal, there is some complaint about fonts:
You have a huge number of font families and Cairo is limiting the size of widgets you can draw.
Your preview cell height is capped to 26.
This is because I use the upstream texlive and I make the otf and ttf fonts installed with texlive visible to the system.
If I see something else I’ll report it.
